PowerPC Cache Warning Help Request
Mon Oct 20 17:34:07 UTC 2014
On 10/20/2014 12:29 PM, Gedare Bloom wrote:
> If you do the legwork now, they could make reasonable GCI tasks if we
> decide to participate and are accepted.
And in this case, by the time I did the legwork, I could fix them.
The legwork is 97.5% of this. :)
Find the manual for the CPU, look up HID0.
If the cache bits match, it is in block 1.
Check caching against the other block. If a match,  it is in block 2.
If not a match, then it either doesn't have cache methods or you
have to write code.
And the last one is likely beyond GCI. :(
--joel
> -Gedare
> On Mon, Oct 20, 2014 at 1:20 PM, Joel Sherrill
> <joel.sherrill at oarcorp.com> wrote:
>> On 10/20/2014 12:09 PM, Gedare Bloom wrote:
>>> Cache manager implementations are a perennial open project.
>> +1
>> In this case,we only have ten RTEMS_CPU_MODELs which are not
>> addressed.  There are currently two blocks of code in the file. One
>> is protected by this:
>> #if defined(ppc603) || defined(ppc603e) || defined(mpc8260)
>> And the other by this:
>> #elif ( defined(mpx8xx) || defined(mpc860) || defined(mpc821) )
>> My guess with no research is that the first block of code is also
>> appropriate for these RTEMS_CPU_MODELs:
>> e500
>> mpc604
>> mpc7400 mpc7455 mpc750
>> qoriq
>> mpc55xx
>> A quick google makes me pretty confident that the mpc690 and mpc7* models
>> belong in the ppc603 HID0 block.
>> I do not have a guess about these
>> ppc405 ppc440 mpc555
>> If we have to implement code to support something new, then I don't want
>> to do it. If we have the code and just need to check to see if more needs to
>> be added to the conditional, then we should.
>> --joel
>>> On Mon, Oct 20, 2014 at 11:19 AM, Joel Sherrill
>>>> On 10/20/2014 10:08 AM, Sebastian Huber wrote:
>>>>> On 20/10/14 16:58, Joel Sherrill wrote:
>>>>>> On October 20, 2014 9:41:57 AM CDT, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
>>>>>>> Since nobody missed the unimplemented cache manager functions in
>>>>>>> several years
>>>>>>> it should be safe so simply remove this #warning.
>>>>>> You didn't notice it for qoriq or e500 so years is an exaggeration for some models.
>>>>> The QorIQ BSP is from 2011.
>>>>>> Take a look at the BSPs impacted. I don't care particularly about older CPU models but some are recent and should be addressed.
>>>>>> After that dropping the warning is OK by me.
>>>>> The useful functions are implemented and in case someone really needs the
>>>>> exotic ones he should notice it if the function is a simple "blr".
>>>> OK. I will just remove the warning.
>>>> Do we want to add a PR or Open Project idea for this?
>>>> Joel Sherrill, Ph.D.             Director of Research & Development
>>>> joel.sherrill at OARcorp.com        On-Line Applications Research
>>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>>> Support Available                (256) 722-9985
>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
