[PATCH 10/34] arm/edb7312: Fix warnings
Mon Oct 20 20:34:12 UTC 2014
 c/src/lib/libbsp/arm/edb7312/include/bsp.h     | 9 +++++++++
 c/src/lib/libbsp/arm/edb7312/irq/bsp_irq_asm.S | 6 +++++-
 c/src/lib/libbsp/arm/edb7312/irq/irq.c         | 4 +++-
 3 files changed, 17 insertions(+), 2 deletions(-)
diff --git a/c/src/lib/libbsp/arm/edb7312/include/bsp.h b/c/src/lib/libbsp/arm/edb7312/include/bsp.h
index 60793c2..00e8d40 100644
--- a/c/src/lib/libbsp/arm/edb7312/include/bsp.h
+++ b/c/src/lib/libbsp/arm/edb7312/include/bsp.h
@@ -16,6 +16,8 @@
 #ifndef _BSP_H
 #define _BSP_H
+#ifndef ASM
 #ifdef __cplusplus
 extern "C" {
 #endif
@@ -57,10 +59,17 @@ int cs8900_driver_attach (struct rtems_bsdnet_ifconfig *config,
+ * Prototypes for methods called from .S but implemented in C
+void edb7312_interrupt_dispatch(rtems_vector_number vector);
 #ifdef __cplusplus
 #endif
+#endif /* !ASM */
 #endif /* _BSP_H */
diff --git a/c/src/lib/libbsp/arm/edb7312/irq/bsp_irq_asm.S b/c/src/lib/libbsp/arm/edb7312/irq/bsp_irq_asm.S
index 2cc3b38..cabd419 100644
--- a/c/src/lib/libbsp/arm/edb7312/irq/bsp_irq_asm.S
+++ b/c/src/lib/libbsp/arm/edb7312/irq/bsp_irq_asm.S
@@ -1,6 +1,8 @@
  * Cirrus EP7312 Intererrupt handler
  * Copyright (c) 2002 by Jay Monkman <jtm at smoothsmoothie.com>
  * Copyright (c) 2002 by Charlie Steader <charlies at poliac.com>
@@ -9,7 +11,9 @@
  *  found in the file LICENSE in this distribution or at
  *  http://www.rtems.org/license/LICENSE.
 #define __asm__
+#include <bsp.h>
 #include "irq.h"
 	.extern edb7312_interrupt_dispatch
diff --git a/c/src/lib/libbsp/arm/edb7312/irq/irq.c b/c/src/lib/libbsp/arm/edb7312/irq/irq.c
index 327edce..8c18ea7 100644
--- a/c/src/lib/libbsp/arm/edb7312/irq/irq.c
+++ b/c/src/lib/libbsp/arm/edb7312/irq/irq.c
@@ -1,6 +1,8 @@
  * Copyright (c) 2010 embedded brains GmbH.
1.9.3
