[PATCH 13/34] libcpu/arm/pxa255/ffuart/ffuart.c: Fix warning
Mon Oct 20 20:34:15 UTC 2014
 c/src/lib/libcpu/arm/pxa255/ffuart/ffuart.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/c/src/lib/libcpu/arm/pxa255/ffuart/ffuart.c b/c/src/lib/libcpu/arm/pxa255/ffuart/ffuart.c
index 1604f1d..335fc6f 100644
--- a/c/src/lib/libcpu/arm/pxa255/ffuart/ffuart.c
+++ b/c/src/lib/libcpu/arm/pxa255/ffuart/ffuart.c
@@ -204,7 +204,7 @@ static int ffuart_set_attributes(int minor, const struct termios *t)
  * Read from UART. This is used in the exit code, and can't
  * rely on interrupts.
-int ffuart_poll_read(int minor)
+static int ffuart_poll_read(int minor)
     return ffuart_read(minor);
1.9.3
