[PATCH 16/34] m68k/gen68360: Fix warnings
Mon Oct 20 20:34:18 UTC 2014
 c/src/lib/libbsp/m68k/gen68360/include/bsp.h       |  5 +++++
 c/src/lib/libbsp/m68k/gen68360/startup/init68360.c | 11 ++++++++---
 2 files changed, 13 insertions(+), 3 deletions(-)
diff --git a/c/src/lib/libbsp/m68k/gen68360/include/bsp.h b/c/src/lib/libbsp/m68k/gen68360/include/bsp.h
index c51a906..cb9c1a3 100644
--- a/c/src/lib/libbsp/m68k/gen68360/include/bsp.h
+++ b/c/src/lib/libbsp/m68k/gen68360/include/bsp.h
@@ -102,6 +102,11 @@ rtems_isr_entry set_vector(
 #define PGH360_PB_SPI_EEP_CE_MSK     (1<< 0)
 #endif /* defined(PGH360) */
+ * Prototypes for BSP methods which cross file boundaries
+void _Init68360(void);
 #ifdef __cplusplus
 #endif
diff --git a/c/src/lib/libbsp/m68k/gen68360/startup/init68360.c b/c/src/lib/libbsp/m68k/gen68360/startup/init68360.c
index b39a9e1..67fed27 100644
--- a/c/src/lib/libbsp/m68k/gen68360/startup/init68360.c
+++ b/c/src/lib/libbsp/m68k/gen68360/startup/init68360.c
@@ -1,6 +1,8 @@
  * MC68360 support routines
  * W. Eric Norum
  * Saskatchewan Accelerator Laboratory
  * University of Saskatchewan
@@ -8,7 +10,6 @@
  * eric at skatter.usask.ca
-#include <rtems.h>
 #include <bsp.h>
 #include <rtems/m68k/m68360.h>
@@ -45,11 +46,12 @@ void _Init68360 (void)
   int i;
   rtems_isr_entry *vbr;
   unsigned long ramSize;
+#if (defined (__mc68040__))
   volatile unsigned long *RamBase_p;
   RamBase_p = (volatile unsigned long *)&RamBase;
-#if (defined (__mc68040__))
    * Motorola 68040 and companion-mode 68360 *
@@ -645,6 +647,9 @@ void _Init68360 (void)
    m360.mcr = 0x4C7F;
 #else
+  volatile unsigned long *RamBase_p;
+  RamBase_p = (volatile unsigned long *)&RamBase;
    * Generic Standalone Motorola 68360               *
1.9.3
