[PATCH 25/34] libcpu/sh/sh7045/sci/sci.c: Eliminate use of obsolete method
Mon Oct 20 20:34:27 UTC 2014
 c/src/lib/libcpu/sh/sh7045/sci/sci.c | 32 +++++++++-----------------------
 1 file changed, 9 insertions(+), 23 deletions(-)
diff --git a/c/src/lib/libcpu/sh/sh7045/sci/sci.c b/c/src/lib/libcpu/sh/sh7045/sci/sci.c
index e6c54e2..690035a 100644
--- a/c/src/lib/libcpu/sh/sh7045/sci/sci.c
+++ b/c/src/lib/libcpu/sh/sh7045/sci/sci.c
@@ -39,7 +39,7 @@
  *  by the authors or by TGA Technologies.
-#include <rtems.h>
+#include <bsp.h>
@@ -93,13 +93,6 @@ struct scidev_t {
 static sci_setup_t sio_param[2];
 #endif
-/*  imported from scitab.rel */
-extern int _sci_get_brparms(
-  tcflag_t      cflag,
-  unsigned char *smr,
-  unsigned char *brr
 /* Translate termios' tcflag_t into sci settings */
 static int _sci_set_cflags(
   struct scidev_t  *sci_dev,
@@ -291,7 +284,6 @@ rtems_device_driver sh_sci_initialize(
   rtems_device_driver status;
   rtems_device_minor_number i;
-  rtems_driver_name_t driver;
    * register all possible devices.
@@ -301,23 +293,17 @@ rtems_device_driver sh_sci_initialize(
    * initialization therefore we check it everytime
   for ( i = 0 ; i < SCI_MINOR_DEVICES ; i++ ) {
-    status = rtems_io_lookup_name(
-        sci_device[i].name,
-        &driver);
-    if ( status != RTEMS_SUCCESSFUL ) {
-        /* OK. We assume it is not registered yet. */
-        status = rtems_io_register_name(
-            major,
-            sci_device[i].minor
-        if (status != RTEMS_SUCCESSFUL)
-            rtems_fatal_error_occurred(status);
+    /* OK. We assume it is not registered yet. */
+    status = rtems_io_register_name(
+      sci_device[i].name,
+      major,
+      sci_device[i].minor
+    if (status != RTEMS_SUCCESSFUL)
+      rtems_fatal_error_occurred(status);
   /* non-default hardware setup occurs in sh_sci_open() */
   return RTEMS_SUCCESSFUL;
1.9.3
