[PATCH 32/34] shared/clockdrv_shell.h: Always include <rtems/clockdrv.h> to avoid warnings
Mon Oct 20 20:34:34 UTC 2014
 c/src/lib/libbsp/shared/clockdrv_shell.h | 16 ++--------------
 1 file changed, 2 insertions(+), 14 deletions(-)
diff --git a/c/src/lib/libbsp/shared/clockdrv_shell.h b/c/src/lib/libbsp/shared/clockdrv_shell.h
index 324e1e5..5dbea13 100644
--- a/c/src/lib/libbsp/shared/clockdrv_shell.h
+++ b/c/src/lib/libbsp/shared/clockdrv_shell.h
@@ -7,7 +7,7 @@
- *  COPYRIGHT (c) 1989-2012.
+ *  COPYRIGHT (c) 1989-2014.
  *  On-Line Applications Research Corporation (OAR).
  *  The license and distribution terms for this file may be
@@ -18,6 +18,7 @@
 #include <bsp.h>
+#include <rtems/clockdrv.h>
  * @defgroup bsp_clock Clock Support
@@ -58,10 +59,6 @@ void Clock_exit( void );
  *  This is the clock tick interrupt handler.
  *  @param vector Vector number.
- *  Output parameters:  NONE
- *  Return values:      NONE
 #if defined(BSP_FEATURE_IRQ_EXTENSION) || \
     (CPU_SIMPLE_VECTORED_INTERRUPTS != TRUE)
@@ -123,15 +120,7 @@ rtems_isr Clock_isr(
  *  This routine allows the clock driver to exit by masking the interrupt and
  *  disabling the clock's counter.
- *  Input parameters:   NONE
   Clock_driver_support_shutdown_hardware();
@@ -150,7 +139,6 @@ void Clock_exit( void )
  * @retval rtems_device_driver status code
 rtems_device_driver Clock_initialize(
   rtems_device_major_number major,
   rtems_device_minor_number minor,
1.9.3
