[PATCH 34/34] or1k/or1ksim: Fix warnings
Mon Oct 20 20:34:36 UTC 2014
 c/src/lib/libbsp/or1k/or1ksim/console/uart.c | 19 ++++++++++++-------
 1 file changed, 12 insertions(+), 7 deletions(-)
diff --git a/c/src/lib/libbsp/or1k/or1ksim/console/uart.c b/c/src/lib/libbsp/or1k/or1ksim/console/uart.c
index 31cdce6..bb86bae 100644
--- a/c/src/lib/libbsp/or1k/or1ksim/console/uart.c
+++ b/c/src/lib/libbsp/or1k/or1ksim/console/uart.c
@@ -29,15 +29,20 @@ static ssize_t uart_write(int minor, const char *buf, size_t len);
 static void uart_write_polled(int minor, char c);
 static int  uart_set_attributes(int minor, const struct termios *t);
+#if 0
+ *  These will be useful when the driver supports interrupt driven IO.
 static rtems_vector_number uart_get_irq_number(const console_tbl *ct)
-   return ct->ulIntVector;
+  return ct->ulIntVector;
 static uint32_t uart_get_baud(const console_tbl *ct)
-   return ct->ulClock;
+  return ct->ulClock;
+#endif
 static void uart_set_baud(int baud)
@@ -60,11 +65,11 @@ static void uart_initialize(int minor)
   OR1KSIM_REG(OR1KSIM_BSP_UART_REG_INT_ENABLE) = 0x00;
   /* Reset receiver and transmitter */
-   OR1KSIM_REG(OR1KSIM_BSP_UART_REG_FIFO_CTRL) =
-     OR1KSIM_BSP_UART_REG_FIFO_CTRL_ENABLE_FIFO |
-     OR1KSIM_BSP_UART_REG_FIFO_CTRL_CLEAR_RCVR  |
-     OR1KSIM_BSP_UART_REG_FIFO_CTRL_CLEAR_XMIT  |
-     OR1KSIM_BSP_UART_REG_FIFO_CTRL_TRIGGER_14;
+  OR1KSIM_REG(OR1KSIM_BSP_UART_REG_FIFO_CTRL) =
+    OR1KSIM_BSP_UART_REG_FIFO_CTRL_ENABLE_FIFO |
+    OR1KSIM_BSP_UART_REG_FIFO_CTRL_CLEAR_RCVR  |
+    OR1KSIM_BSP_UART_REG_FIFO_CTRL_CLEAR_XMIT  |
+    OR1KSIM_BSP_UART_REG_FIFO_CTRL_TRIGGER_14;
   /* Set data pattern configuration */
   OR1KSIM_REG(OR1KSIM_BSP_UART_REG_LINE_CTRL) =
1.9.3
