Question regarding ns16550
Thu Oct 23 08:47:37 UTC 2014
Hello Daniel,
I never notice a problem with this driver.  It should only write to the FIFO in
case it is completely empty.  Did you observe problems?
On 21/10/14 19:32, Daniel Gutson wrote:
> Hi,
>     in the writing interrupt mode (ns16550_write_support_int), we have
>    for (i = 0; i < out; ++i) {
>      set( port, NS16550_TRANSMIT_BUFFER, buf [i]);
> Shouldn't we check, before writing to the register for the iterations
> after the first one,
> whether the character entered in the FIFO? (otherwise I think the
> 'for' loop could iterate
> so fast that the device had no time to process the character)
> In such a case, something like
>     /* Wait for transmitter holding register to be empty */
>      do {
>        status = get( port, NS16550_LINE_STATUS);
>      } while ((status & SP_LSR_THOLD) == 0);
> would be better?
> Thanks,
>     Daniel.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
