PowerPC Cache Warning Help Request
Fri Oct 24 14:03:22 UTC 2014
On Fri, Oct 24, 2014 at 1:36 AM, Sebastian Huber
> On 23/10/14 19:41, Gedare Bloom wrote:
>> We might consider removing the cache manager in favor of making dcache
>> flush/invalidate and icache invalidate lines part of the score/cpu
>> port (are they the same across cpu's in the same arch family?)
> No, the caches are highly chip specific.
OK. I just grepped and I don't see any CPU_cache being used from
anywhere except bsp code. I suspect we should give this framework the
axe, or reduce it drastically and move it into the BSP layer.
