MSc (by research) involving RTEMS | University of York
Hesham Moustafa
heshamelmatary at gmail.com
Tue Oct 28 16:18:19 UTC 2014
On Tue, Oct 28, 2014 at 6:06 AM, Gedare Bloom <gedare at gwmail.gwu.edu> wrote:
> On Mon, Oct 27, 2014 at 4:43 PM, Hesham Moustafa
> <heshamelmatary at gmail.com> wrote:
> > On Mon, Oct 27, 2014 at 2:30 PM, Joel Sherrill <
> joel.sherrill at oarcorp.com>
> > wrote:
> >> On October 27, 2014 3:04:26 AM PDT, Hesham Moustafa
> >> >Hi all,
> >> >This year, I am studying MSc (by research) degree at the University of
> >> >York. My thesis proposal title is "REAL-TIME OPERATING SYSTEMS FOR
> >> >LARGE SCALE MANY-CORE NETWORK-ON-CHIP ARCHITECTURES." Part of this
> >> >research will include some work with RTEMS.
> >> Awesome!
> >> There is an asymmetric MP patch filed with a PR in bugzilla. I don't
> >> remember the architecture but it was a proprietary CPU with virtually
> >> nothing useful publicly available. The company was Kalray and here is a
> link
> >> to one of their patches.
> >> http://lists.rtems.org/pipermail/bugs/2011-October/003376.html
> >> We merged some small stuff from them but they did not work in an open
> >> collaborative way with the community. They have a commercial product
> with a
> >> mesh of multi core instances. I suspect the key folks have published
> papers.
> >> Assuming that is vaguely related.
> >> How many is many? 16, 64, etc.. Can you point to some example
> >> architectures?
> > Given that I first met my supervisor today, I am currently on the stage
> of
> > collecting information, reading literature, and get sense of research
> work
> > that involves RTOS, so that we can choose which RTOS can fit on which
> > platform better, and of course that platform would have many cores. I
> asked
> > my supervisor this exact question, and he gave me two initial options
> (that
> > may change after readings): 1) Parallella board variants [1] that can
> > contain from 16 up to 64 cores (simple RISC processors) and 2) Bluestar
> > project that University of York research group currently works on, it
> has 64
> > cores and I may have the possibility to work on some NoC/SoC HW designs
> part
> > of my research.
> I have a 16-core parallela board. I would be willing to help you in
> porting, at least in terms of guiding if not coding, although at this
> point, you're probably getting good at porting RTEMS! I believe the
> "Epiphany" core used by Parallela is an open-core, also.
> That will be great. Actually my supervisor first suggested parallela,
and then Bluestar.
> That said, if there is enough progress on Bluestar that it won't cause
> you to have to wait to try using it, then you might consider leaning
> on the local experts there. The advantage of Parallela is that it is
> already shipping boards commercially, so the tool/community support is
> likely to be much better.
> I can work on both actually. Working on Bluestar would enable me to gain
some HW experience with NoC architectures. But I will have to wait until
I get some sense of what I wanna do and which tools/platforms are best for
for that; that should be the first few months during which I will be
reading
literature.
> >> >That said, I'd appreciate any materials (papers, publications,
> >> >references, tutorials, etc) that might be of help regarding that topic
> >> >and may or may not relate to RTEMS. I think Sebastian has contributed a
> >> >lot to this area recently.
> >> Gedare and Sebastian are more in tune with the paper side of things.
> >> My suggestion is to divide it into areas. Of the top of my head, there
> are
> >> issues with algorithm scaling as the number of cores increases, locking
> >> issues, more need for finer grain locks and lockless data structures,
> and
> >> likely on the application side means to debug and formally make
> statements
> >> about WCET, end to end scheduling correctness in a way that is known to
> be
> >> analyzable for schedulability and correctness, and cache effects.
> > Great, I'd like to get ideas of what challenges the current RTOSes like
> > RTEMS face regarding many-cores systems, and I think you are the best to
> > tell me somethings like that.
> As far as RTEMS goes, your best bet is to read
> http://www.rtems.org/wiki/index.php/SMP to get a sense of the state of
> things. SMP is not yet working with fully-function real-time, but
> there aren't any open soruce hard real-time RTOS that I know of that
> do support SMP currently. At least, not to a satisfactory degree. (I
> admit, I haven't looked hard.) Sebastian may be able to give a better
> sense of the state of things, as he has been much closer to it for
> longer. I don't know what the commercial RTOS supports.
> That's a good start. I have to do a survey about the current state of SMP
support for a few RTOSes.
> Some of the biggest challenges are these:
> 1) No one has really given a good solution for migratory scheduling.
> Global scheduling fares poorly. Most solutions explore some kind of
> partitioned/clustered scheme to reduce overhead, which trades off
> optimality for efficiency. In this area, you should read up on Bjorn
> Brandenburg's work.
> 2) Interrupt handling is a killer in SMP systems. There are more
> interrupts that happen now, to deal with cross-core communication, and
> also if there is not interrupt affinity then the hw will route the
> interrupt wherever it pleases, which is really bad for real-time
> system.
> A lot of the rest is just the challenge of retro-fitting a legacy
> code-base with the necessary synchronization and parallelism-aware
> primitives to allow SMP to work, and work well. The "Giant" lock that
> RTEMS uses is not conducive to real-time analysis, and until it goes
> away, the system is in no way that matters "SMP hard real-time".
> However, that is the direction development is going.
> Thanks for information. I will definitely make use of it during my first
review
seminar (after three months).
> >> RTEMS will face the same challenges Solaris, Linux etc faced as the
> number
> >> of cores grew beyond four. So there may be useful experience papers from
> >> those.
> >> >You may also want to suggest building some simple multi-processor
> >> >and/or many-core systems that RTEMS currently supports, and how to
> >> >simulate them.
> >> Tile may be interesting but you need to look. There should be 12-16 core
> >> qoriq ppc by now and qemu might be up to that.
> >> Maestro (I think) was a MIPS based SOC out of AFRL which might be
> >> interesting.
> >> But how many is "many" and me being at my desk will help. I just core
> >> dumped in an airport at 5am.
> >> What do you want the code to do?
> > Initially, we want the code to fit in with many-cores platforms (16-64).
> So,
> > I am trying to see how far research goes regarding this area, and the
> status
> > of some SMP libraries/APIs that current RTOSes support, and start from
> > there.
> > [1] http://www.parallella.org/board/
> >> >Thanks,
> >> >Hesham
URL: <http://lists.rtems.org/pipermail/devel/attachments/20141028/b4619d0e/attachment-0001.html>
