Decreasing BSS size for STM32F4
Thu Oct 30 09:38:19 UTC 2014
On 29/10/14 17:49, Chris Nott wrote:
> Hi,
> I have a BSP almost identical to STM32F4 except I want a slight change to the
> linker settings (I want to offset the start location because there is a
> bootloader at location 0).
> Two questions:
> - Is there any way to do this other than to
>   a) duplicate the BSP and change just the linker files
You can use your own linker command file with the "-qnolinkcmds -T
yourlinkcmds" option.
>   b) use the STM32F4 BSP as-is but copy the linker files into the application
> project and modify (this is the solution I am using now)
> - As a matter of policy, how different should a platform be before we fork a BSP?
This is hard to say.  In case the number of #ifdefs exceed a certain limit,
then it may make sense to use different BSPs.  The amount of copy and paste
must should be next to zero though.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
