rtems head broken for leon3 smp
Thu Oct 30 13:56:10 UTC 2014
On 23/10/14 19:46, Jennifer Averett wrote:
> Running the leon3 with grsim fails due to the patch
> bsp/sparc: Ensure that data cache snooping is enabled
> It looks like cache snooping is disabled when it is ran for all
> the tests.  Where is this supposed to be set at with this change?
The simulator should set the right Cache Control Register settings.  If this is
not the case, then AG should fix this in their simulator.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
