4.11 Branching To Do
Thu Oct 30 14:59:40 UTC 2014
On Thu, Oct 30, 2014 at 6:31 AM, Sebastian Huber
> On 29/10/14 22:49, Joel Sherrill wrote:
>> Very desirable
>> + x86 context switch SMP handoff logic
> For someone with good enough x86 assembly skills, this should be fairly
> simple.  You just have to implement the sequence described here:
> http://git.rtems.org/rtems/tree/cpukit/score/cpu/no_cpu/rtems/score/cpu.h#n578
Do we have memory-barrier and test-and-set primitives for x86?
> devel mailing list
> devel at rtems.org
