[rtems commit] libmisc: Add top to cpuusage.
Thu Oct 30 17:11:11 UTC 2014
On 10/30/2014 12:06 PM, Jennifer Averett wrote:
> Addressing all the comments.  About the scoped blocks I used the style
> that existed in cpuusage already.  That section of code is modified code
> from  rtems_cpu_usage_report_with_plugin.
Just reformat it. :)
--joel
> Jennifer
>> -----Original Message-----
>> From: devel [mailto:devel-bounces at rtems.org] On Behalf Of Gedare Bloom
>> Sent: Thursday, October 30, 2014 9:54 AM
>> To: Jennifer Averett
>> Cc: rtems-devel at rtems.org
>> Subject: Re: [rtems commit] libmisc: Add top to cpuusage.
>> I missed reviewing this patch earlier, but there are some style problems with
>> it, please fix them on the head.
>> On Tue, Oct 28, 2014 at 11:17 AM, Jennifer Averett <jennifer at rtems.org>
>> wrote:
>>> Module:    rtems
>>> Branch:    master
>>> Commit:    6031da438d219c6ec5d9d48f1df2aef91710cce3
>>> Changeset:
>> http://git.rtems.org/rtems/commit/?id=6031da438d219c6ec5d9d48f1df2aef9
>>> 1710cce3
>>> Author:    Jennifer Averett <jennifer.averett at oarcorp.com>
>>> Date:      Mon Sep 29 10:20:27 2014 -0500
>>>  cpukit/libmisc/Makefile.am          |    2 +-
>>>  cpukit/libmisc/cpuuse/cpuusagetop.c |  337
>>>  cpukit/libmisc/cpuuse/cpuuse.h      |   19 ++
>>>  3 files changed, 357 insertions(+), 1 deletions(-)
>>> diff --git a/cpukit/libmisc/Makefile.am b/cpukit/libmisc/Makefile.am
>>> index 2f41ffa..d26c484 100644
>>> --- a/cpukit/libmisc/Makefile.am
>>> +++ b/cpukit/libmisc/Makefile.am
>>> @@ -27,7 +27,7 @@ EXTRA_DIST += cpuuse/README
>>>  noinst_LIBRARIES += libcpuuse.a
>>>  libcpuuse_a_SOURCES = cpuuse/cpuusagereport.c
>> cpuuse/cpuusagereset.c \
>>> -    cpuuse/cpuuse.h cpuuse/cpuusagedata.c
>>> +     cpuuse/cpuuse.h cpuuse/cpuusagedata.c cpuuse/cpuusagetop.c
>>>  ## devnull
>>>  noinst_LIBRARIES += libdevnull.a
>>> diff --git a/cpukit/libmisc/cpuuse/cpuusagetop.c
>>> b/cpukit/libmisc/cpuuse/cpuusagetop.c
>>> new file mode 100644
>>> index 0000000..7e7348a
>>> --- /dev/null
>>> +++ b/cpukit/libmisc/cpuuse/cpuusagetop.c
>>> @@ -0,0 +1,337 @@
>>> + * @file
>>> + * @brief CPU Usage Top
>>> + * @ingroup libmisc_cpuuse CPU Usage
>>> + *  COPYRIGHT (c) 2014.
>>> + *  On-Line Applications Research Corporation (OAR).
>>> + *  The license and distribution terms for this file may be
>>> + *  found in the file LICENSE in this distribution or at
>>> + *  http://www.rtems.org/license/LICENSE.
>>> +#ifdef HAVE_CONFIG_H
>>> +#include "config.h"
>>> +#endif
>>> +#include <string.h>
>>> +#include <stdlib.h>
>>> +#include <stdio.h>
>>> +#include <ctype.h>
>>> +#include <inttypes.h>
>>> +#include <rtems/cpuuse.h>
>>> +#include <rtems/score/objectimpl.h>
>>> +#include <rtems/score/threadimpl.h>
>>> +#include <rtems/score/todimpl.h>
>>> +#include <rtems/score/watchdogimpl.h>
>>> + * Common variable to sync the load monitor task.
>>> +static volatile int rtems_cpuusage_top_thread_active;
>> remove multiple blank lines
>>> +typedef struct {
>>> +  void                  *context;
>>> +  rtems_printk_plugin_t  print;
>>> +}rtems_cpu_usage_plugin_t;
>>> +#define RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS (20)
>>> + * rtems_cpuusage_top_thread
>>> + *  DESCRIPTION:
>>> + * This function displays the load of the tasks on an ANSI terminal.
>> Get rid of "DESCRIPTION", prefer to use minimalist comment style on static
>> functions.
>>> +static void
>>> +rtems_cpuusage_top_thread (rtems_task_argument arg) {
>>> +  uint32_t                  api_index;
>>> +  Thread_Control*           the_thread;
>>> +  int                       i;
>>> +  int                       j;
>>> +  int                       k;
>>> +  Objects_Information*      information;
>>> +    char                    name[13];
>>> +  int                       task_count = 0;
>>> +  uint32_t                  seconds, nanoseconds;
>>> +  rtems_cpu_usage_plugin_t* plugin = (rtems_cpu_usage_plugin_t*)arg;
>>> +  Thread_Control*
>> load_tasks[RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS + 1];
>>> +  unsigned long long
>> load[RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS + 1];
>>> +  while (true)
>> Opening brace should go on whille() line.
>>> +    #ifndef __RTEMS_USE_TICKS_FOR_STATISTICS__
>>> +      Timestamp_Control  uptime, total, ran, uptime_at_last_reset;
>>> +    #else
>>> +      uint32_t           total_units = 0;
>>> +    #endif
>>> +    rtems_cpuusage_top_thread_active = 1;
>>> +    memset (load_tasks, 0, sizeof (load_tasks));
>>> +    memset (load, 0, sizeof (load));
>>> +     * Iterate over the tasks and sort the highest load tasks
>>> +     * into our local arrays. We only handle a limited number of
>>> +     * tasks.
>>> +    for ( api_index = 1 ; api_index <= OBJECTS_APIS_LAST ; api_index++ ) {
>>> +      #if !defined(RTEMS_POSIX_API) || defined(RTEMS_DEBUG)
>>> +        if ( !_Objects_Information_table[ api_index ] )
>>> +          continue;
>>> +      #endif
>>> +      information = _Objects_Information_table[ api_index ][ 1 ];
>>> +      if ( information ) {
>>> +        for ( k=1 ; k <= information->maximum ; k++ ) {
>> I prefer that nested iterators should be used in increasing order, e.g. i first.
>>> +          the_thread = (Thread_Control *)information->local_table[ k ];
>>> +          if ( the_thread ) {
>> No blank space after the opening brace.
>>> +            Thread_CPU_usage_t l = the_thread->cpu_time_used;
>> Avoid using l and I as variable names.They're hard to differentiate from each
>> other and from the digit 1. This should be a more useful variable name
>> anyway. A one-letter variable should really only be used for iterators. We
>> ought to have a rule about this if we don't.
>>> +             *  When not using nanosecond CPU usage resolution, we have to
>> count
>>> +             *  the number of "ticks" we gave credit for to give the user a rough
>>> +             *  guideline as to what each number means proportionally.
>>> +            #ifdef __RTEMS_USE_TICKS_FOR_STATISTICS__
>>> +              total_units += l;
>>> +            #endif
>>> +            /* Count the number of tasks and sort this load value */
>>> +            task_count++;
>>> +            for (i = 0; i < RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS; i++) {
>>> +              if (load_tasks[i]) {
>>> +                if ((l == 0) || (l < load[i]))
>>> +                  continue;
>>> +                for (j = (RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS - 1); j >= i; j-
>>> +                  load_tasks[j + 1] = load_tasks[j];
>>> +                  load[j + 1]  = load[j];
>>> +              load_tasks[i] = the_thread;
>>> +              load[i]  = l;
>>> +              break;
>>> +      _Timestamp_Set_to_zero( &total );
>>> +      uptime_at_last_reset = CPU_usage_Uptime_at_last_reset;
>>> +    #endif
>>> +    _TOD_Get_uptime( &uptime );
>>> +    seconds = _Timestamp_Get_seconds( &uptime );
>>> +    nanoseconds = _Timestamp_Get_nanoseconds( &uptime ) /
>>> +                  TOD_NANOSECONDS_PER_MICROSECOND;
>>> +    (*plugin->print)(plugin->context, "\x1b[H\x1b[J Press ENTER to
>> exit.\n\n");
>>> +    (*plugin->print)(plugin->context, "uptime: ");
>>> +      "%7" PRIu32 ".%06" PRIu32 "\n",  seconds, nanoseconds
>>> +    (*plugin->print)(
>>> +       plugin->context,
>>> +       "-------------------------------------------------------------------------------\n"
>>> +       "                              CPU USAGE BY THREAD\n"
>> \n"
>>> +        " ID         | NAME                | RPRI | CPRI   | SECONDS       | PERCENT\n"
>>> +       #else
>>> +         " ID        | NAME                | RPRI | CPRI   | TICKS         | PERCENT\n"
>>> +       #endif
>> \n"
>> Fix style here.
>>> +      if (!load_tasks[i])
>>> +        break;
>>> +       * If this is the currently executing thread, account for time
>>> +       * since the last context switch.
>>> +      the_thread = load_tasks[i];
>>> +      rtems_object_get_name( the_thread->Object.id, sizeof(name), name
>>> +      (*plugin->print)(
>>> +        plugin->context,
>>> +        " 0x%08" PRIx32 " | %-19s |  %3" PRId32 " |  %3" PRId32 "   |",
>>> +        the_thread->Object.id,
>>> +        name,
>>> +        the_thread->real_priority,
>>> +        the_thread->current_priority
>> I don't know how to feel about artifically adding scoped blocks.
>> Anyone else weigh in?
>>> +        Timestamp_Control last;
>>> +        uint32_t          ival, fval;
>>> +        ran = load[i];
>>> +        if ( _Thread_Get_time_of_last_context_switch( the_thread, &last ) )
>>> +          Timestamp_Control used;
>>> +          _Timestamp_Subtract( &last, &uptime, &used );
>>> +          _Timestamp_Add_to( &ran, &used );
>>> +        } else {
>>> +        _Timestamp_Subtract( &uptime_at_last_reset, &uptime, &total );
>>> +        _Timestamp_Divide( &ran, &total, &ival, &fval );
>>> +         * Print the information
>>> +        seconds = _Timestamp_Get_seconds( &ran );
>>> +        nanoseconds = _Timestamp_Get_nanoseconds( &ran ) /
>>> +       (*plugin->print)( plugin->context,
>>> +          "%7" PRIu32 ".%06" PRIu32 " |%4" PRIu32 ".%03" PRIu32 "\n",
>>> +          seconds, nanoseconds,
>>> +            ival, fval
>>> +      #else
>>> +        if (total_units) {
>>> +          uint64_t ival_64;
>>> +          ival_64 = load[i];
>>> +          ival_64 *= 100000;
>>> +          ival = ival_64 / total_units;
>>> +        } else {
>>> +          ival = 0;
>>> +        fval = ival % 1000;
>>> +        ival /= 1000;
>>> +          "%14" PRIu32 " |%4" PRIu32 ".%03" PRIu32 "\n",
>>> +          load[i],
>>> +          ival,
>>> +          fval
>>> +      #endif
>>> +    if (task_count < RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS)
>>> +      j = RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS - task_count;
>>> +      while (j > 0)
>>> +       (*plugin->print)( plugin->context, "\x1b[K\n");
>>> +        j--;
>>> +    rtems_cpuusage_top_thread_active = 0;
>>> +    rtems_task_wake_after (RTEMS_MICROSECONDS_TO_TICKS
>> (5000000));
>>> +void rtems_cpu_usage_top_with_plugin(
>>> +  void                  *context,
>>> +  rtems_status_code   sc;
>>> +  rtems_task_priority priority;
>>> +  rtems_name          name;
>>> +  rtems_id            id;
>>> +  rtems_cpu_usage_plugin_t  plugin;
>>> +  if ( !print )
>>> +    return;
>>> +  plugin.context = context;
>>> +  plugin.print   = print;
>>> +  sc = rtems_task_set_priority (RTEMS_SELF, RTEMS_CURRENT_PRIORITY,
>>> + &priority);
>>> +  if (sc != RTEMS_SUCCESSFUL)
>>> +    (*print)(
>>> +       context,
>>> +       "error: cannot obtain the current priority: %s\n",
>>> +       rtems_status_text (sc)
>>> +    return;
>>> +  name = rtems_build_name('C', 'P', 'l', 't');
>>> +  sc = rtems_task_create (name, priority, 4 * 1024,
>>> +                          RTEMS_NO_FLOATING_POINT | RTEMS_LOCAL,
>>> +                          RTEMS_PREEMPT | RTEMS_TIMESLICE | RTEMS_NO_ASR,
>>> +                          &id);
>>> +    (*print)(
>>> +       context,
>>> +       "error: cannot create helper thread: %s\n",
>>> +    return;
>>> +  sc = rtems_task_start (
>>> +    id, rtems_cpuusage_top_thread, (rtems_task_argument)&plugin  );
>>> + if (sc != RTEMS_SUCCESSFUL)  {
>>> +    (*print)(
>>> +       context,
>>> +       "error: cannot start helper thread: %s\n",
>>> +    rtems_task_delete (id);
>>> +    return;
>>> +  for (;;)
>>> +    int c = getchar ();
>>> +    if ((c == '\r') || (c == '\n'))
>>> +      int loops = 20;
>>> +      while (loops && rtems_cpuusage_top_thread_active)
>> (100000));
>>> +      (*print)(context, "load monitoring stopped.\n");
>>> +      return;
>>> +void rtems_cpu_usage_top( void )
>>> +  rtems_cpu_usage_top_with_plugin( NULL, printk_plugin ); }
>>> diff --git a/cpukit/libmisc/cpuuse/cpuuse.h
>>> b/cpukit/libmisc/cpuuse/cpuuse.h index 1aee275..662d905 100644
>>> --- a/cpukit/libmisc/cpuuse/cpuuse.h
>>> +++ b/cpukit/libmisc/cpuuse/cpuuse.h
>>> @@ -63,6 +63,25 @@ void rtems_cpu_usage_report_with_plugin(
>>>  void rtems_cpu_usage_report( void );
>>> + *   @brief CPU usage Top plugin
>>> + *   Report CPU Usage in top format to
>>> + *   to a print plugin.
>>> +  void                  *context,
>>> + *  @brief CPU usage top.
>>> + *  CPU Usage top
>>> +void rtems_cpu_usage_top( void );
>>>   *  @brief Reset CPU usage.
>>>   *  CPU Usage Reporter
>>> vc mailing list
>>> vc at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/vc
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
