libdl: rtems.git dependence on rtems-tools.git
Thu Oct 30 19:40:43 UTC 2014
On Thu, Oct 30, 2014 at 3:32 PM, Chris Johns <chrisj at rtems.org> wrote:
> Hi,
> Libdl tests in the testsuite depend on tools in rtems-tools.git/linkers.
> Should I raise a configure error if the tools are not found or not build the
> tests ?
> Raising an error is my preferred option because libdl for the supported
> archs is tested however it creates a dependency between rtems-tools.git and
> RTEMS. I can help with this by adding building of rtems-tools.git to the
> RSB's build of RTEMS tools.
> Comments ?
Only make it an error if building the rtems-tools/linker is part of
the "standard" toolset builds, thus decreasing the burden on users who
don't care to use libdl.
> Chris
> devel mailing list
> devel at rtems.org
