[PATCH] Add GPIO, I2C and SPI support for the RPi BSP
Andre Marques andre.lousa.marques at gmail.com
Fri Oct 31 11:56:40 UTC 2014
Aditional documentation can be found in the RTEMS wiki
http://www.rtems.org/wiki/index.php/Raspberry_Pi_BSP_Peripherals
and on my GSOC development blog
http://asuolgsoc2014.wordpress.com/2014/08/18/testing-the-project/
Device drivers and test cases used to test this work were moved to a github repository
https://github.com/asuol/RTEMS_rpi_testing
 c/src/lib/libbsp/arm/raspberrypi/Makefile.am       |  11 +-
 c/src/lib/libbsp/arm/raspberrypi/configure.ac      |  12 +
 c/src/lib/libbsp/arm/raspberrypi/gpio/gpio.c       | 745 +++++++++++++++++++++
 c/src/lib/libbsp/arm/raspberrypi/i2c/i2c.c         | 427 ++++++++++++
 c/src/lib/libbsp/arm/raspberrypi/i2c/i2c_init.c    |  78 +++
 c/src/lib/libbsp/arm/raspberrypi/i2c/spi.c         | 564 ++++++++++++++++
 c/src/lib/libbsp/arm/raspberrypi/i2c/spi_init.c    |  83 +++
 c/src/lib/libbsp/arm/raspberrypi/include/gpio.h    | 198 ++++++
 c/src/lib/libbsp/arm/raspberrypi/include/i2c.h     | 166 +++++
 c/src/lib/libbsp/arm/raspberrypi/include/irq.h     |   6 +-
 .../libbsp/arm/raspberrypi/include/raspberrypi.h   |  79 ++-
 c/src/lib/libbsp/arm/raspberrypi/irq/irq.c         | 103 ++-
 c/src/lib/libbsp/arm/raspberrypi/preinstall.am     |   8 +
 .../lib/libbsp/arm/raspberrypi/startup/bspstart.c  |  17 +-
 14 files changed, 2475 insertions(+), 22 deletions(-)
 create mode 100644 c/src/lib/libbsp/arm/raspberrypi/gpio/gpio.c
 create mode 100644 c/src/lib/libbsp/arm/raspberrypi/i2c/i2c.c
 create mode 100644 c/src/lib/libbsp/arm/raspberrypi/i2c/i2c_init.c
 create mode 100644 c/src/lib/libbsp/arm/raspberrypi/i2c/spi.c
 create mode 100644 c/src/lib/libbsp/arm/raspberrypi/i2c/spi_init.c
 create mode 100644 c/src/lib/libbsp/arm/raspberrypi/include/gpio.h
 create mode 100644 c/src/lib/libbsp/arm/raspberrypi/include/i2c.h
diff --git a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
index 839c8de..81dc196 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
+++ b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
@@ -44,6 +44,8 @@ include_bsp_HEADERS += include/irq.h
 include_bsp_HEADERS += include/mmu.h
 include_bsp_HEADERS += include/usart.h
 include_bsp_HEADERS += include/raspberrypi.h
+include_bsp_HEADERS += include/gpio.h
+include_bsp_HEADERS += include/i2c.h
 include_libcpu_HEADERS = ../../../libcpu/arm/shared/include/cache_.h \
     ../../../libcpu/arm/shared/include/arm-cp15.h
@@ -79,7 +81,6 @@ libbsp_a_SOURCES += ../../shared/bspclean.c
 libbsp_a_SOURCES += ../../shared/bspgetworkarea.c
 libbsp_a_SOURCES += ../../shared/bsplibc.c
 libbsp_a_SOURCES += ../../shared/bsppost.c
-libbsp_a_SOURCES += ../../shared/bsppredriverhook.c
 libbsp_a_SOURCES += ../../shared/bsppretaskinghook.c
 libbsp_a_SOURCES += ../../shared/cpucounterread.c
 libbsp_a_SOURCES += ../../shared/cpucounterdiff.c
@@ -119,11 +120,19 @@ libbsp_a_SOURCES += clock/clockdrv.c ../../../shared/clockdrv_shell.h
 # Timer
 libbsp_a_SOURCES += misc/timer.c
+# GPIO
+libbsp_a_SOURCES += gpio/gpio.c
 # RTC
 # SSP
 # I2C
+libbsp_a_SOURCES += i2c/i2c.c
+libbsp_a_SOURCES += i2c/i2c_init.c
+libbsp_a_SOURCES += i2c/spi.c
+libbsp_a_SOURCES += i2c/spi_init.c
 # Cache
 libbsp_a_SOURCES += ../../../libcpu/shared/src/cache_manager.c
diff --git a/c/src/lib/libbsp/arm/raspberrypi/configure.ac b/c/src/lib/libbsp/arm/raspberrypi/configure.ac
index 9bd6883..ef83c9d 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/configure.ac
+++ b/c/src/lib/libbsp/arm/raspberrypi/configure.ac
@@ -24,6 +24,18 @@ AM_CONDITIONAL(HAS_NETWORKING,test "$HAS_NETWORKING" = "yes")
 RTEMS_BSPOPTS_SET([BSP_START_RESET_VECTOR],[*],[])
 RTEMS_BSPOPTS_HELP([BSP_START_RESET_VECTOR],[reset vector address for BSP start])
+RTEMS_BSPOPTS_SET([I2C_IO_MODE],[*],[1])
+RTEMS_BSPOPTS_HELP([I2C_IO_MODE],[Define to 1 to use interrupt-driven I/O with the Raspberry Pi I2C bus. If defined to other value the access will be polled-driven.])
+RTEMS_BSPOPTS_SET([SPI_IO_MODE],[*],[1])
+RTEMS_BSPOPTS_HELP([SPI_IO_MODE],[Define to 1 to use interrupt-driven I/O with the Raspberry Pi SPI bus. If defined to other value the access will be polled-driven.])
+RTEMS_BSPOPTS_SET([BSP_ENABLE_SPI],[*],[0])
+RTEMS_BSPOPTS_HELP([BSP_ENABLE_SPI],[Define to 1 to use the SPI bus. This will register the bus in /dev/spi and also any device driver mentioned in i2c/spi_init.c .])
+RTEMS_BSPOPTS_SET([BSP_ENABLE_I2C],[*],[1])
+RTEMS_BSPOPTS_HELP([BSP_ENABLE_I2C],[Define to 1 to use the I2C bus. This will register the bus in /dev/i2c and also any device driver mentioned in i2c/i2c_init.c .])
 RTEMS_BSP_CLEANUP_OPTIONS(0, 0)
 RTEMS_BSP_LINKCMDS
diff --git a/c/src/lib/libbsp/arm/raspberrypi/gpio/gpio.c b/c/src/lib/libbsp/arm/raspberrypi/gpio/gpio.c
new file mode 100644
index 0000000..d245339
--- /dev/null
+++ b/c/src/lib/libbsp/arm/raspberrypi/gpio/gpio.c
@@ -0,0 +1,745 @@
+ * @file gpio.c
+ * @ingroup raspberrypi_gpio
+ * @brief Support for the Raspberry PI GPIO.
+ *  Copyright (c) 2014 Andre Marques <andre.lousa.marques at gmail.com>
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+#include <bsp/raspberrypi.h>
+#include <bsp/irq.h>
+#include <bsp/gpio.h>
+#include <stdlib.h>
+/* Calculates a bitmask to assign an alternate function to a given pin. */
+#define SELECT_PIN_FUNCTION(fn, pn) (fn << ((pn % 10) * 3))
+static bool is_initialized = false;
+rpi_gpio_pin *gpio_pin;
+ * @brief Waits a number of CPU cycles.
+ * @param[in] cycles The number of CPU cycles to wait.
+static void arm_delay (int cycles)
+  int i;
+  for (i = 0; i < cycles; i++)
+    asm volatile ("nop");
+ * @brief Initializes the GPIO API.
+ *        Allocates space to the gpio_pin array and sets every pin as NOT_USED.
+ *        If the API has already been initialized silently exits.
+void gpio_initialize(void)
+  int i;
+  if ( is_initialized )
+    return;
+  is_initialized = true;
+  gpio_pin = (rpi_gpio_pin *) malloc(GPIO_PIN_COUNT * sizeof(rpi_gpio_pin));
+  for ( i = 0; i < GPIO_PIN_COUNT; i++ ) {
+    gpio_pin[i].pin_type = NOT_USED;
+    gpio_pin[i].enabled_interrupt = NONE;
+    gpio_pin[i].h_args.debouncing_tick_count = 0;
+ * @brief Gives an output GPIO pin the logical value of 1.
+ * @param[in] pin The Raspberry Pi GPIO pin label number (not is position
+ *            on the header).
+ * @retval 0 Pin was set successfully.
+ * @retval -1 The received pin is not configured as an digital output.
+int gpio_set(int pin)
+  if (gpio_pin[pin-1].pin_type != DIGITAL_OUTPUT)
+    return -1;
+  BCM2835_REG(BCM2835_GPIO_GPSET0) = (1 << pin);
+  return 0;
+ * @brief Gives an output GPIO pin the logical value of 0.
+ *            on the header).
+ * @retval 0 Pin was cleared successfully.
+int gpio_clear(int pin)
+    return -1;
+  BCM2835_REG(BCM2835_GPIO_GPCLR0) = (1 << pin);
+  return 0;
+ * @brief Gets the value (level) of a GPIO input pin.
+ *            on the header).
+ * @retval The function returns 0 or 1 depending on the pin current
+ *         logical value.
+int gpio_get_val(int pin)
+  return BCM2835_REG(BCM2835_GPIO_GPLEV0) &= (1 << (pin));
+ * @brief Configures a GPIO pin to perform a certain function.
+ *            on the header).
+ * @param[in] type The new function of the pin.
+ * @retval 0 Pin was configured successfully.
+ * @retval -1 The received pin is already being used, or unknown function.
+int gpio_select_pin(int pin, rpi_pin type)
+  /* Calculate the pin function select register address. */
+  volatile unsigned int *pin_addr = (unsigned int *)BCM2835_GPIO_REGS_BASE + (pin / 10);
+  /* If the pin is already being used returns with an error. */
+  if ( gpio_pin[pin-1].pin_type != NOT_USED )
+    return -1;
+  /* Sets pin function select bits as zero (DIGITAL_INPUT).*/
+  *(pin_addr) &= ~SELECT_PIN_FUNCTION(7, pin);
+  switch ( type ) {
+    case DIGITAL_INPUT:
+      /* Digital input is set by default before this switch. */
+      break;
+    case DIGITAL_OUTPUT:
+      *(pin_addr) |= SELECT_PIN_FUNCTION(1, pin);
+      break;
+    case ALT_FUNC_0:
+      *(pin_addr) |= SELECT_PIN_FUNCTION(4, pin);
+      break;
+    case ALT_FUNC_1:
+      *(pin_addr) |= SELECT_PIN_FUNCTION(5, pin);
+      break;
+    case ALT_FUNC_2:
+      *(pin_addr) |= SELECT_PIN_FUNCTION(6, pin);
+      break;
+    case ALT_FUNC_3:
+      *(pin_addr) |= SELECT_PIN_FUNCTION(7, pin);
+      break;
+    case ALT_FUNC_4:
+      *(pin_addr) |= SELECT_PIN_FUNCTION(3, pin);
+      break;
+    case ALT_FUNC_5:
+      *(pin_addr) |= SELECT_PIN_FUNCTION(2, pin);
+      break;
+    default:
+      return -1;
+  /* If the alternate function was successfuly assigned to the pin,
+   * record that information on the gpio_pin structure. */
+  gpio_pin[pin-1].pin_type = type;
+  return 0;
+ * @brief Configures the pull resistor setting of an array of GPIO pins.
+ * @param[in] pins Array of Raspberry Pi GPIO pin label numbers (not their position
+ *            on the header).
+ * @param[in] pin_count Number of pins on the @var pins array.
+ * @param[in] mode The pull resistor mode.
+ * @retval 0 Pull resistor successfully configured.
+ * @retval -1 Unknown pull resistor mode.
+static int
+set_input_mode(int *pins, int pin_count, int pin_mask, rpi_gpio_input_mode mode)
+  int i;
+  /* Set control signal. */
+  switch ( mode ) {
+    case PULL_UP:
+      BCM2835_REG(BCM2835_GPIO_GPPUD) = (1 << 1);
+      break;
+    case PULL_DOWN:
+      BCM2835_REG(BCM2835_GPIO_GPPUD) = (1 << 0);
+      break;
+    case NO_PULL_RESISTOR:
+      BCM2835_REG(BCM2835_GPIO_GPPUD) = 0;
+      break;
+    default:
+      return -1;
+  /* Wait 150 cyles, as per BCM2835 documentation. */
+  arm_delay(150);
+  /* Setup clock for the control signal. */
+  BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = pin_mask;
+  arm_delay(150);
+  /* Remove the control signal. */
+  /* Remove the clock. */
+  BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = 0;
+  /* If the operation was successful, record that information
+   * on the gpio_pin structure so it can be recalled later. */
+  for ( i = 0; i < pin_count; i++ )
+    gpio_pin[pins[i]-1].input_mode = mode;
+  return 0;
+ * @brief Configures a single GPIO pin pull resistor.
+ * @param[in] pin Raspberry Pi GPIO pin label number (not its position
+ *            on the header).
+ * @retval -1 @see set_input_mode().
+int gpio_input_mode(int pin, rpi_gpio_input_mode mode)
+  int pin_mask = (1 << pin);
+  int pins[1];
+  /* If the desired actuation mode is already set, silently exits. */
+  if ( gpio_pin[pin-1].input_mode == mode )
+    return 0;
+  pins[0] = pin;
+  return set_input_mode(pins, 1, pin_mask, mode);
+ * @brief Sets the same pull-up/down resistors actuation mode to multiple GPIO input pins.
+ *        There is a maximum number of 32 pins per call, which is enough for
+ *        Raspberry Pi models A and B (17 GPIOs on P1 GPIO header)
+ *        and also model B+ (28 GPIOs on J8 GPIO header).
+ *            on the header).
+int gpio_setup_input_mode(int *pins, int pin_count, rpi_gpio_input_mode mode)
+  uint32_t pin_mask = 0;
+  int diff_mode_counter = 0;
+  int i;
+  if ( pin_count > 32 )
+    return -1;
+  /* Cycle through the given pins to check if this operation will have an effect
+   * on the resistor actuation mode of any one of the pins.
+   * Every pin that currently uses a different pull resistor mode sets a bit
+   * in its corresponding place on a bitmask. If the mode for a pin will not change
+   * then the diff_mode_counter variable is increased. */
+  for ( i = 0; i < pin_count; i++ ) {
+    if ( gpio_pin[pins[i] - 1].input_mode != mode )
+      pin_mask |= (1 << pins[i]);
+    else
+      diff_mode_counter++;
+  /* If no pin will have its resistor mode changed silently exits, avoiding an
+   * unnecessary access to the Rasberry Pi memory registers. */
+  if ( diff_mode_counter == 0 )
+    return 0;
+  return set_input_mode(pins, pin_count, pin_mask, mode);
+ * @brief Disables a GPIO pin on the APiI, making it available to be used
+ *        by anyone on the system.
+ * @param[in] dev_pin Raspberry Pi GPIO pin label number (not its position
+ *            on the header).
+ * @retval 0 Pin successfully disabled on the API.
+ * @retval -1 Could not disable an ative interrupt on this pin.
+int gpio_disable_pin(int dev_pin)
+  rtems_status_code sc;
+  rpi_gpio_pin *pin;
+  pin = &gpio_pin[dev_pin-1];
+  pin->pin_type = NOT_USED;
+  /* If the pin has an enabled interrupt then remove the handler. */
+  if ( pin->enabled_interrupt != NONE ) {
+    sc = gpio_disable_interrupt(dev_pin);
+    if ( sc != RTEMS_SUCCESSFUL )
+      return -1;
+  return sc;
+ * @brief Setups a JTAG interface using the P1 GPIO pin header
+ *        for the models A/B and J8 header on the B+.
+ *        The following pins should be unused before calling this function:
+ *        GPIO 4, 22, 24, 25 and 27.
+ *            on the header).
+ * @retval 0 JTAG interface successfully configured.
+ * @retval -1 At least one of the required pins is currently occupied.
+int gpio_select_jtag(void)
+  /* Setup gpio 4 alt5 ARM_TDI. */
+  if ( gpio_select_pin(4, ALT_FUNC_5) < 0 )
+      return -1;
+  /* Setup gpio 22 alt4 ARM_TRST. */
+  if ( gpio_select_pin(22, ALT_FUNC_4) < 0 )
+      return -1;
+  /* Setup gpio 24 alt4 ARM_TDO. */
+  if ( gpio_select_pin(24, ALT_FUNC_4) < 0 )
+      return -1;
+  /* Setup gpio 25 alt4 ARM_TCK. */
+  if ( gpio_select_pin(25, ALT_FUNC_4) < 0 )
+      return -1;
+  /* Setup gpio 27 alt4 ARM_TMS. */
+  if ( gpio_select_pin(27, ALT_FUNC_4) < 0 )
+      return -1;
+  return 0;
+ * @brief Setups a SPI interface using the P1 GPIO pin header
+ *        GPIO 7, 8, 9, 10 and 11.
+ *            on the header).
+ * @retval 0 SPI interface successfully configured.
+int gpio_select_spi_p1(void)
+  /* SPI master 0 MISO data line. */
+  if ( gpio_select_pin(9, ALT_FUNC_0) < 0 )
+      return -1;
+  /* SPI master 0 MOSI data line. */
+  if ( gpio_select_pin(10, ALT_FUNC_0) < 0 )
+      return -1;
+  /* SPI master 0 SCLK clock line. */
+  if ( gpio_select_pin(11, ALT_FUNC_0) < 0 )
+      return -1;
+  /* SPI master 0 CE_0 chip enable line. */
+  if ( gpio_select_pin(8, ALT_FUNC_0) < 0 )
+      return -1;
+  /* SPI master 0 CE_1 chip enable line. */
+  if ( gpio_select_pin(7, ALT_FUNC_0) < 0 )
+      return -1;
+  return 0;
+ * @brief Setups a I2C interface using the P1 GPIO pin header
+ *        GPIO 2 and 3.
+ *            on the header).
+int gpio_select_i2c_p1_rev2(void)
+  int pins[] = {2,3};
+  /* I2C BSC1 SDA data line. */
+  if ( gpio_select_pin(2, ALT_FUNC_0) < 0 )
+      return -1;
+  /* I2C BSC1 SCL clock line. */
+  if ( gpio_select_pin(3, ALT_FUNC_0) < 0 )
+      return -1;
+  /* Enable pins 2 and 3 pull-up resistors. */
+  if ( gpio_setup_input_mode(pins, 2, PULL_UP) < 0 )
+    return -1;
+  return 0;
+ * @brief De-bounces a switch by requiring a certain time to pass between interrupts.
+ *        Any interrupt fired too close to the last will be ignored as it is probably
+ *        the result of a involuntary switch/button bounce after being released.
+ *            on the header).
+ * @retval 0 Interrupt is likely provoked by a user press on the switch.
+ * @retval -1 Interrupt was generated too close to the last one. Probable switch bounce.
+static int debounce_switch(int dev_pin)
+  rtems_interval time;
+  time = rtems_clock_get_ticks_since_boot();
+  if ( (time - pin->h_args.last_isr_tick) < pin->h_args.debouncing_tick_count )
+    return -1;
+  pin->h_args.last_isr_tick = time;
+  return 0;
+ * @brief Generic ISR that clears the event register on the Raspberry Pi and calls
+ *        an user defined ISR.
+ * @param[in] arg Void pointer to a handler_arguments structure.
+static void generic_handler(void* arg)
+  handler_arguments* handler_args;
+  int rv = 0;
+  int pin = 0;
+  handler_args = (handler_arguments*) arg;
+  pin = handler_args->pin_number;
+  /*  If the interrupt was generated by the pin attached to this ISR clears it. */
+  if ( BCM2835_REG(BCM2835_GPIO_GPEDS0) & (1 << pin) )
+    BCM2835_REG(BCM2835_GPIO_GPEDS0) &= (1 << pin);
+  /* If not lets the next ISR process the interrupt. */
+  else
+    return;
+  /* If this pin has the deboucing function attached, call it. */
+  if ( handler_args->debouncing_tick_count > 0 ) {
+    rv = debounce_switch(pin);
+    if ( rv < 0 )
+      return;
+  /* Call the user's ISR. */
+  (handler_args->handler) ();
+ * @brief Defines for a GPIO input pin the number of clock ticks that must pass before
+ *        an generated interrupt is garanteed to be generated by the user and not by
+ *        a bouncing switch/button.
+ *            on the header).
+ * @retval 0 De-bounce function successfully attached to the pin.
+ * @retval -1 The current pin is not configured as a digital input, hence
+ *            it can not be connected to a switch.
+int gpio_debounce_switch(int dev_pin, int ticks)
+  if ( gpio_pin[dev_pin-1].pin_type != DIGITAL_INPUT )
+    return -1;
+  gpio_pin[dev_pin-1].h_args.debouncing_tick_count = ticks;
+  return 0;
+ * @brief Enables interrupts to be generated on a given GPIO pin.
+ *        When fired that interrupt will call the given handler.
+ *            on the header).
+ * @param[in] interrupt Type of interrupt to enable for the pin.
+ * @param[in] handler Pointer to a function that will be called every time
+ *                    @var interrupt is generated. This function must have
+ *                    no receiving parameters and return void.
+ * @retval 0 Interrupt successfully enabled for this pin.
+ * @retval -1 Could not replace the currently active interrupt on this pin, or
+ *            unknown @var interrupt.
+int gpio_enable_interrupt(int dev_pin, gpio_interrupt interrupt, void (*handler)(void))
+  /* Only consider GPIO pins up to 31. */
+  if ( dev_pin > 31 )
+    return -1;
+  /* If the pin already has an enabled interrupt removes it first,
+   * as well as its handler. */
+      return -1;
+  pin->h_args.pin_number = dev_pin;
+  pin->h_args.handler = handler;
+  pin->h_args.last_isr_tick = rtems_clock_get_ticks_since_boot();
+  /* Installs the generic_handler, which will call the user handler received
+   * a parameter. */
+  sc = rtems_interrupt_handler_install(BCM2835_IRQ_ID_GPIO_0,
+                                       NULL,
+                                       RTEMS_INTERRUPT_SHARED,
+                                       (rtems_interrupt_handler) generic_handler,
+                                       &(pin->h_args));
+    return -1;
+  switch ( interrupt ) {
+    case FALLING_EDGE:
+      /* Enables asynchronous falling edge detection. */
+      BCM2835_REG(BCM2835_GPIO_GPAFEN0) |= (1 << dev_pin);
+      break;
+    case RISING_EDGE:
+      /* Enables asynchronous rising edge detection. */
+      BCM2835_REG(BCM2835_GPIO_GPAREN0) |= (1 << dev_pin);
+      break;
+    case BOTH_EDGES:
+      break;
+    case LOW_LEVEL:
+      /* Enables pin low level detection. */
+      BCM2835_REG(BCM2835_GPIO_GPLEN0) |= (1 << dev_pin);
+      break;
+    case HIGH_LEVEL:
+      /* Enables pin high level detection. */
+      BCM2835_REG(BCM2835_GPIO_GPHEN0) |= (1 << dev_pin);
+      break;
+    case BOTH_LEVELS:
+      break;
+    case NONE:
+      return 0;
+    default:
+      return -1;
+  pin->enabled_interrupt = interrupt;
+  return 0;
+ * @brief Stops interrupts from being generated from a given GPIO pin
+ *        and removes the corresponding handler.
+ *            on the header).
+ * @retval 0 Interrupt successfully disabled for this pin.
+ * @retval -1 Could not remove the current interrupt handler or could not
+ *            recognise the current active interrupt on this pin.
+int gpio_disable_interrupt(int dev_pin)
+  switch ( pin->enabled_interrupt ) {
+      /* Disables asynchronous falling edge detection. */
+      BCM2835_REG(BCM2835_GPIO_GPAFEN0) &= ~(1 << dev_pin);
+      break;
+    case RISING_EDGE:
+      /* Disables asynchronous rising edge detection. */
+      BCM2835_REG(BCM2835_GPIO_GPAREN0) &= ~(1 << dev_pin);
+      break;
+    case BOTH_EDGES:
+      break;
+    case LOW_LEVEL:
+      /* Disables pin low level detection. */
+      BCM2835_REG(BCM2835_GPIO_GPLEN0) &= ~(1 << dev_pin);
+      break;
+    case HIGH_LEVEL:
+      /* Disables pin high level detection. */
+      BCM2835_REG(BCM2835_GPIO_GPHEN0) &= ~(1 << dev_pin);
+      break;
+    case BOTH_LEVELS:
+      break;
+    case NONE:
+      return 0;
+    default:
+      return -1;
+  /* Removes the handler. */
+  sc = rtems_interrupt_handler_remove(BCM2835_IRQ_ID_GPIO_0,
+                                      &(pin->h_args));
+    return -1;
+  pin->enabled_interrupt = NONE;
+  return 0;
diff --git a/c/src/lib/libbsp/arm/raspberrypi/i2c/i2c.c b/c/src/lib/libbsp/arm/raspberrypi/i2c/i2c.c
index 0000000..838add4
--- /dev/null
+++ b/c/src/lib/libbsp/arm/raspberrypi/i2c/i2c.c
@@ -0,0 +1,427 @@
+ * @file i2c.c
+ * @ingroup raspberrypi_i2c
+ * @brief Support for the I2C bus on the Raspberry Pi GPIO P1 header (model A/B)
+ * and GPIO J8 header on model B+.
+ * TODO:
+ * - Clock stretching (currently using default values)
+ * - 10-bit addressing
+ * - Falling/Rising edge delays (currently using default values)
+#include <bsp.h>
+#include <bsp/i2c.h>
+ * @brief Calculates a clock divider to be used with the BSC core clock rate
+ *        to set a I2C clock rate the closest (<=) to a desired frequency.
+ * @param[in] clock_hz The desired clock frequency for the I2C bus operation.
+ * @param[out] clock_divider Pointer to a variable where the calculated
+ *                          clock divider will be stored.
+ * @retval RTEMS_SUCCESSFUL Successfully calculated a valid clock divider.
+ * @retval RTEMS_INVALID_NUMBER The resulting clock divider is invalid, due to
+ *                              an invalid BSC_CORE_CLOCK_HZ
+ *                              or clock_hz value.
+static rtems_status_code bcm2835_i2c_calculate_clock_divider(uint32_t clock_hz, uint16_t *clock_divider)
+  uint16_t divider;
+  uint32_t clock_rate;
+  /* Calculates an initial clock divider. */
+  divider = BSC_CORE_CLK_HZ / clock_hz;
+  if ( divider < 0 || divider > 0xFFFF )
+    return RTEMS_INVALID_NUMBER;
+  clock_rate = BSC_CORE_CLK_HZ / divider;
+  /* If the resulting clock rate is greater than desired, try the next greater divider. */
+  while ( clock_rate > clock_hz )
+    divider++;
+  *clock_divider = divider;
+  return RTEMS_SUCCESSFUL;
+ * @brief Set the I2C bus clock divider.
+ * @param[in] bushdl Pointer to the libi2c API bus driver data structure.
+ * @param[in] tfr_mode Pointer to a libi2c API transfer mode data structure.
+ * @retval RTEMS_SUCCESSFUL Successfully setup the bus transfer mode as desired.
+ * @retval RTEMS_INVALID_NUMBER @see bcm2835_i2c_calculate_clock_divider().
+static rtems_status_code bcm2835_i2c_set_tfr_mode(rtems_libi2c_bus_t *bushdl, const rtems_libi2c_tfr_mode_t *tfr_mode)
+  uint16_t clock_divider;
+  /* Calculate the most appropriate clock divider. */
+  sc = bcm2835_i2c_calculate_clock_divider(tfr_mode->baudrate, &clock_divider);
+    return sc;
+  /* Set clock divider. */
+  BCM2835_REG(BCM2835_I2C_DIV) = clock_divider;
+  return sc;
+ * @brief Reads/writes to/from the I2C bus.
+ * @param[in] rd_buf Read buffer. If not NULL the function will read from
+ *                   the bus and store the read on this buffer.
+ * @param[in] wr_buf Write buffer. If not NULL the function will write the
+ *                   contents of this buffer to the bus.
+ * @param[in] buffer_size Size of the non-NULL buffer.
+ * @retval -1 Could not send/receive data to/from the bus.
+ * @retval >=0 The number of bytes read/written.
+static int bcm2835_i2c_read_write(rtems_libi2c_bus_t * bushdl, unsigned char *rd_buf, const unsigned char *wr_buf, int buffer_size)
+  bcm2835_i2c_softc_t *softc_ptr = &(((bcm2835_i2c_desc_t *)(bushdl))->softc);
+  uint32_t bytes_sent = buffer_size;
+  /* Since there is a maximum of 0xFFFF packets per transfer
+   * (size of the DLEN register), count how many transfers will be
+   * needed and adjust each transfer size accordingly. */
+  int transfer_count = buffer_size / 0xFFFF;
+  uint16_t dlen_buffer_size;
+  /* If the buffer size is a multiple of the max size per transfer,
+   * round up the transfer count. */
+  if ( buffer_size % 0xFFFF != 0 )
+    transfer_count++;
+  do {
+    if (transfer_count > 1)
+      dlen_buffer_size = 0xFFFF;
+    else
+      dlen_buffer_size = (buffer_size & 0xFFFF);
+    /* Set the DLEN register, which specifies how many data packets will be transferred. */
+    BCM2835_REG(BCM2835_I2C_DLEN) = dlen_buffer_size;
+    /* Clear the acknowledgment and clock stretching error status. */
+    BCM2835_REG(BCM2835_I2C_S) |= (3 << 8);
+    /* While there is data to transfer. */
+    while ( dlen_buffer_size >= 1 ) {
+      /* If writing. */
+      if ( rd_buf == NULL ) {
+        /* If transfer is not active, send start bit. */
+        if( (BCM2835_REG(BCM2835_I2C_S) & (1 << 0)) == 0)
+          BCM2835_REG(BCM2835_I2C_C) |= (1 << 7);
+        /* If using the I2C bus in interrupt-driven mode. */
+        if ( I2C_IO_MODE == 1 ) {
+          /* Generate interrupts on the TXW bit condition. */
+          BCM2835_REG(BCM2835_I2C_C) |= (1 << 9);
+          if ( rtems_semaphore_obtain(softc_ptr->irq_sema_id, RTEMS_WAIT, 50) != RTEMS_SUCCESSFUL )
+            return -1;
+        /* If using the bus in polling mode. */
+        else
+          /* Poll TXW bit until there is space available to write. */
+          while ( (BCM2835_REG(BCM2835_I2C_S) & (1 << 2)) == 0 )
+        /* Write data to the TX FIFO. */
+        BCM2835_REG(BCM2835_I2C_FIFO) = (*(uint8_t *)wr_buf);
+        wr_buf++;
+        /* Check for acknowledgment or clock stretching errors. */
+        if ( (BCM2835_REG(BCM2835_I2C_S) & (1 << 8)) || (BCM2835_REG(BCM2835_I2C_S) & (1 << 9)) )
+          return -1;
+      /* If reading. */
+      else {
+        /* Send start bit. Before any read a libi2c_send_addr call should be made signaling a read operation. */
+        /* Check for an acknowledgment error. */
+        if ( (BCM2835_REG(BCM2835_I2C_S) & (1 << 8)) != 0)
+          return -1;
+        /* Poll RXD bit until there is data on the RX FIFO to read. */
+        while ( (BCM2835_REG(BCM2835_I2C_S) & (1 << 5)) == 0 )
+        /* Read data from the RX FIFO. */
+        (*(uint8_t *)rd_buf) = BCM2835_REG(BCM2835_I2C_FIFO) & 0xFF;
+        rd_buf++;
+          return -1;
+      dlen_buffer_size--;
+      transfer_count--;
+      buffer_size--;
+  } while ( transfer_count > 0 );
+    /* Generate interrupts on the DONE bit condition. */
+    BCM2835_REG(BCM2835_I2C_C) |= (1 << 8);
+      return -1;
+  else
+    /* Poll DONE bit until data has been sent. */
+    while ( (BCM2835_REG(BCM2835_I2C_S) & (1 << 1)) == 0 )
+  bytes_sent -= buffer_size;
+  return bytes_sent;
+ * @brief Handler function that is called on any I2C interrupt.
+ *        There are 3 situations that can generate an interrupt:
+ *        1. Transfer (read/write) complete;
+ *        2. The TX FIFO has space for more data (during a write transfer);
+ *        3. The RX FIFO is full.
+ *        Because the I2C FIFO has a 16 byte size, the 3. situation is not
+ *        as useful to many applications as knowing that at least 1 byte can
+ *        be read from the RX FIFO. For that reason this information is
+ *        got through polling the RXD bit even in interrupt-driven mode.
+ *        This leaves only 2 interrupts to be caught. At any given time
+ *        when no I2C bus transfer is taking place no I2C interrupts are
+ *        generated, and they do they are only enabled one at a time:
+ *        - When trying to write, the 2. interrupt is enabled to signal that
+ *          data can be written on the TX FIFO, avoiding data loss in case
+ *          it is full. When caught the handler disables that interrupt from
+ *          being generated and releases the irq semaphore, which will allow
+ *          the transfer process to continue (by writing to the TX FIFO);
+ *        - When the transfer is done on Raspberry side, the 1. interrupt is
+ *          enabled for the device to signal it has finished the transfer as
+ *          well. When caught the handler disables that interrupt from being
+ *          generated and releases the irq semaphore, marking the end of the
+ *          transfer.
+ * @param[in] arg Void pointer to the bus data structure.
+static void i2c_handler(void* arg)
+  bcm2835_i2c_softc_t *softc_ptr = (bcm2835_i2c_softc_t *) arg;
+  /* If the current enabled interrupt is on the TXW condition, disable it. */
+  if ( (BCM2835_REG(BCM2835_I2C_C) & (1 << 9)) )
+    BCM2835_REG(BCM2835_I2C_C) &= ~(1 << 9);
+  /* If the current enabled interrupt is on the DONE condition, disable it. */
+  else if ( (BCM2835_REG(BCM2835_I2C_C) & (1 << 8)) )
+    BCM2835_REG(BCM2835_I2C_C) &= ~(1 << 8);
+    /* Release the irq semaphore. */
+    rtems_semaphore_release(softc_ptr->irq_sema_id);
+ * @brief Low level function to initialize the I2C bus.
+ *        This function is used by the libi2c API.
+ * @retval RTEMS_SUCCESSFUL SPI bus successfully initialized.
+ * @retval Any other status code @see rtems_semaphore_create() and
+ *         @see rtems_interrupt_handler_install().
+rtems_status_code bcm2835_i2c_init(rtems_libi2c_bus_t * bushdl)
+  rtems_status_code sc = RTEMS_SUCCESSFUL;
+  if ( softc_ptr->initialized == 1 )
+    return sc;
+  softc_ptr->initialized = 1;
+  /* Enable the I2C BSC interface. */
+  BCM2835_REG(BCM2835_I2C_C) |= (1 << 15);
+  /* If the access to the bus is configured to be interrupt-driven. */
+    sc = rtems_semaphore_create(rtems_build_name('i','2','c','s'), 0, RTEMS_FIFO | RTEMS_SIMPLE_BINARY_SEMAPHORE, 0, &softc_ptr->irq_sema_id);
+    sc = rtems_interrupt_handler_install(BCM2835_IRQ_ID_I2C, NULL, RTEMS_INTERRUPT_UNIQUE, (rtems_interrupt_handler) i2c_handler, softc_ptr);
+  return sc;
+ * @brief Low level function that would send a start condition over the I2C bus.
+ *        Because of the way the BSC controller implements the I2C protocol, the
+ *        start sequence is sent whenever appropriate in bcm2835_i2c_read_write.
+ *        Instead this function clears the bus FIFOS before each new data
+ *        transfer.
+rtems_status_code bcm2835_i2c_send_start(rtems_libi2c_bus_t * bushdl)
+  /* Clear FIFOs. */
+  BCM2835_REG(BCM2835_I2C_C) |= (3 << 4);
+ * @brief Low level function that would send a stop condition over the I2C bus,
+ *        however the BSC controller send this condition automatically when the
+ *        DLEN (data length - the number of bytes to be transferred) register
+ *        value reaches 0.
+ *        For that reason, it is here just to satisfy, the libi2c API,
+ *         which requires this function.
+rtems_status_code bcm2835_i2c_stop(rtems_libi2c_bus_t * bushdl)
+ * @brief Low level function which addresses a I2C device.
+ * @param[in] addr Address of a connected I2C device
+ * @param[in] rw Defines the nature of the transfer which will take place with
+ *               the addressed device - 0 to write and 1 to read.
+ * @retval RTEMS_SUCCESSFUL The device has been successfully addressed.
+rtems_status_code bcm2835_i2c_send_addr(rtems_libi2c_bus_t * bushdl, uint32_t addr, int rw)
+  /* Address slave device. */
+  BCM2835_REG(BCM2835_I2C_A) = addr;
+  /* Set read/write bit.
+   * If writing. */
+  if ( rw == 0 )
+    BCM2835_REG(BCM2835_I2C_C) &= ~(1 << 0);
+  /* If reading. */
+  else
+    BCM2835_REG(BCM2835_I2C_C) |= (1 << 0);
+ * @brief Low level function that reads a number of bytes from the I2C bus
+ *        on to a buffer.
+ * @param[in] bytes Buffer where the data read from the bus will be stored.
+ * @param[in] nbytes Number of bytes to be read from the bus to the bytes buffer.
+ * @retval @see bcm2835_i2c_read_write().
+int bcm2835_i2c_read_bytes(rtems_libi2c_bus_t * bushdl, unsigned char *bytes, int nbytes)
+  return bcm2835_i2c_read_write(bushdl, bytes, NULL, nbytes);
+ * @brief Low level function that writes a number of bytes from a buffer
+ *        to the I2C bus.
+ * @param[in] bytes Buffer with data to send through the bus.
+ * @param[in] nbytes Number of bytes to be written from the bytes buffer
+                     to the bus.
+int bcm2835_i2c_write_bytes(rtems_libi2c_bus_t * bushdl, unsigned char *bytes, int nbytes)
+  return bcm2835_i2c_read_write(bushdl, NULL, bytes, nbytes);
+ * @brief Low level function that is used to perform ioctl
+ *        operations on the bus. Currently only setups
+ *        the bus transfer mode, namely the bus clock divider.
+ * @param[in] cmd IOCTL request command.
+ * @param[in] arg Arguments needed to fulfill the requested IOCTL command.
+ * @retval -1 Unknown request command.
+ * @retval >=0 @see bcm2835_i2c_set_tfr_mode().
+int bcm2835_i2c_ioctl(rtems_libi2c_bus_t * bushdl, int cmd, void *arg)
+  switch ( cmd ) {
+    case RTEMS_LIBI2C_IOCTL_SET_TFRMODE:
+      return bcm2835_i2c_set_tfr_mode(bushdl, (const rtems_libi2c_tfr_mode_t *)arg);
+    default:
+      return -1;
+  return 0;
diff --git a/c/src/lib/libbsp/arm/raspberrypi/i2c/i2c_init.c b/c/src/lib/libbsp/arm/raspberrypi/i2c/i2c_init.c
index 0000000..f231537
--- /dev/null
+++ b/c/src/lib/libbsp/arm/raspberrypi/i2c/i2c_init.c
@@ -0,0 +1,78 @@
+ * @file i2c_init.c
+ * @brief Raspberry Pi I2C bus initialization.
+static rtems_libi2c_bus_ops_t bcm2835_i2c_ops = {
+  init:             bcm2835_i2c_init,
+  send_start:       bcm2835_i2c_send_start,
+  send_stop:        bcm2835_i2c_stop,
+  send_addr:        bcm2835_i2c_send_addr,
+  read_bytes:       bcm2835_i2c_read_bytes,
+  write_bytes:      bcm2835_i2c_write_bytes,
+  ioctl:            bcm2835_i2c_ioctl
+static bcm2835_i2c_desc_t bcm2835_i2c_bus_desc = {
+    ops:            &bcm2835_i2c_ops,
+    size:           sizeof(bcm2835_i2c_bus_desc)
+    initialized:    0
+/* Register drivers here for all the devices
+ * which require access to the I2C bus.
+ * The libi2c function "rtems_libi2c_register_drv" must be used to
+ * register each device driver, using the received i2c bus number.
+ * This function returns 0 on success. */
+int BSP_i2c_register_drivers(int i2c_bus_number)
+  int rv = 0;
+  return rv;
+int BSP_i2c_init(void)
+  int rv;
+  /* Initialize the libi2c API. */
+  rtems_libi2c_initialize ();
+  /* Enable the I2C interface on the Raspberry Pi P1 GPIO header. */
+  gpio_initialize ();
+  if ( gpio_select_i2c_p1_rev2() < 0 )
+    return RTEMS_RESOURCE_IN_USE;
+  /* Register the I2C bus. */
+  rv = rtems_libi2c_register_bus("/dev/i2c", &(bcm2835_i2c_bus_desc.bus_desc));
+  if ( rv < 0 )
+    return -rv;
+  /* Register SPI device drivers. */
+  rv =  BSP_i2c_register_drivers(rv);
+  return 0;
diff --git a/c/src/lib/libbsp/arm/raspberrypi/i2c/spi.c b/c/src/lib/libbsp/arm/raspberrypi/i2c/spi.c
index 0000000..c260f19
--- /dev/null
+++ b/c/src/lib/libbsp/arm/raspberrypi/i2c/spi.c
@@ -0,0 +1,564 @@
+ * @file spi.c
+ * @brief Support for the SPI bus on the Raspberry Pi GPIO P1 header (model A/B)
+ * STATUS:
+ * - Bi-directional mode untested
+ * - Write-only devices not supported
+#include <bsp.h>
+ * @brief Calculates a clock divider to be used with the GPU core clock rate
+ *        to set a SPI clock rate the closest (<=) to a desired frequency.
+ * @param[in] clock_hz The desired clock frequency for the SPI bus operation.
+ *                              an invalid GPU_CORE_CLOCK_RATE
+static rtems_status_code bcm2835_spi_calculate_clock_divider(uint32_t clock_hz, uint16_t *clock_divider)
+  uint16_t divider;
+  divider = GPU_CORE_CLOCK_RATE / clock_hz;
+  if ( divider < 0 || divider > 65536 )
+  /* Because the divider must be a power of two (as per the BCM2835 datasheet),
+   * calculate the next greater power of two. */
+  divider--;
+  divider |= (divider >> 1);
+  divider |= (divider >> 2);
+  divider |= (divider >> 4);
+  divider |= (divider >> 8);
+  divider++;
+  clock_rate = GPU_CORE_CLOCK_RATE / divider;
+  /* If the resulting clock rate is greater than the desired frequency,
+   * try the next greater power of two divider. */
+  while ( clock_rate > clock_hz ) {
+    divider = (divider << 1);
+ * @brief Set the SPI bus transfer mode.
+ * @retval RTEMS_INVALID_NUMBER This can have two meanings:
+ *                              1. The specified number of bytes per char is not
+ *                                 8, 16, 24 or 32;
+ *                              2. @see bcm2835_spi_calculate_clock_divider()
+static rtems_status_code bcm2835_spi_set_tfr_mode(rtems_libi2c_bus_t *bushdl, const rtems_libi2c_tfr_mode_t *tfr_mode)
+  bcm2835_spi_softc_t *softc_ptr = &(((bcm2835_spi_desc_t *)(bushdl))->softc);
+  /* Set the dummy character. */
+  softc_ptr->dummy_char = tfr_mode->idle_char;
+  sc = bcm2835_spi_calculate_clock_divider(tfr_mode->baudrate, &clock_divider);
+    return sc;
+  /* Set the bus clock divider. */
+  BCM2835_REG(BCM2835_SPI_CLK) = clock_divider;
+  /* Calculate how many bytes each character has.
+   * Only multiples of 8 bits are accepted for the transaction. */
+  switch ( tfr_mode->bits_per_char )
+    case 8:
+    case 16:
+    case 24:
+    case 32:
+      softc_ptr->bytes_per_char = tfr_mode->bits_per_char / 8;
+      break;
+    default:
+  /* Check the data mode (most or least significant bit first) and calculate
+   * the correcting bit shift value to apply on the data before sending. */
+  if ( tfr_mode->lsb_first )
+    softc_ptr->bit_shift = 32 - tfr_mode->bits_per_char;
+  /* If MSB first. */
+  else
+    softc_ptr->bit_shift = 0;
+  /* Set SPI clock polarity.
+   * If clock_inv is TRUE, the clock is active high.*/
+  if ( tfr_mode->clock_inv )
+    /* Rest state of clock is low. */
+    BCM2835_REG(BCM2835_SPI_CS) &= ~(1 << 3);
+  else
+    /* Rest state of clock is high. */
+    BCM2835_REG(BCM2835_SPI_CS) |= (1 << 3);
+  /* Set SPI clock phase.
+   * If clock_phs is true, clock starts toggling
+   * at the start of the data transfer. */
+  if ( tfr_mode->clock_phs )
+    /* First SCLK transition at beginning of data bit. */
+    BCM2835_REG(BCM2835_SPI_CS) |= (1 << 2);
+  else
+    /* First SCLK transition at middle of data bit. */
+    BCM2835_REG(BCM2835_SPI_CS) &= ~(1 << 2);
+  return sc;
+ * @brief Reads/writes to/from the SPI bus.
+static int bcm2835_spi_read_write(rtems_libi2c_bus_t * bushdl, unsigned char *rd_buf, const unsigned char *wr_buf, int buffer_size)
+  uint8_t bytes_per_char = softc_ptr->bytes_per_char;
+  uint8_t bit_shift =  softc_ptr->bit_shift;
+  uint32_t dummy_char = softc_ptr->dummy_char;
+  uint32_t fifo_data;
+  /* Clear SPI bus FIFOs. */
+  BCM2835_REG(BCM2835_SPI_CS) |= (3 << 4);
+  /* Set SPI transfer active. */
+  BCM2835_REG(BCM2835_SPI_CS) |= (1 << 7);
+  /* If using the SPI bus in interrupt-driven mode. */
+  if ( SPI_IO_MODE == 1 ) {
+    softc_ptr->irq_write = 1;
+    BCM2835_REG(BCM2835_SPI_CS) |= (1 << 9);
+      return -1;
+  else
+    /* Poll TXD bit until there is space to write at least one byte on the TX FIFO. */
+    while ( (BCM2835_REG(BCM2835_SPI_CS) & (1 << 18)) == 0 )
+  /* While there is data to be transferred. */
+  while ( buffer_size >= bytes_per_char ) {
+    /* If reading from the bus, send a dummy character to the device. */
+    if ( rd_buf != NULL )
+      BCM2835_REG(BCM2835_SPI_FIFO) = dummy_char;
+    /* If writing to the bus, move the buffer data to the TX FIFO. */
+    else {
+      switch ( bytes_per_char ) {
+        case 1:
+          BCM2835_REG(BCM2835_SPI_FIFO) = (((*wr_buf) & 0xFF) << bit_shift);
+          break;
+        case 2:
+          BCM2835_REG(BCM2835_SPI_FIFO) = (((*wr_buf) & 0xFFFF) << bit_shift);
+          break;
+        case 3:
+          BCM2835_REG(BCM2835_SPI_FIFO) = (((*wr_buf) & 0xFFFFFF) << bit_shift);
+          break;
+        case 4:
+          BCM2835_REG(BCM2835_SPI_FIFO) = ((*wr_buf) << bit_shift);
+          break;
+        default:
+          return -1;
+      wr_buf += bytes_per_char;
+      buffer_size -= bytes_per_char;
+    /* If using bi-directional SPI. */
+    if ( softc_ptr->bidirectional == 1 )
+      /* Change bus direction to read from the slave device. */
+      BCM2835_REG(BCM2835_SPI_CS) |= (1 << 12);
+      softc_ptr->irq_write = 0;
+        return -1;
+    else {
+      /* Poll the Done bit until the data transfer is complete. */
+      while ( (BCM2835_REG(BCM2835_SPI_CS) & (1 << 16)) == 0 )
+      /* Poll the RXD bit until there is at least one byte on the RX FIFO to be read. */
+      while ( (BCM2835_REG(BCM2835_SPI_CS) & (1 << 17)) == 0 )
+    /* If writing to the bus, read the dummy char sent by the slave device. */
+      fifo_data = BCM2835_REG(BCM2835_SPI_FIFO) & 0xFF;
+    /* If reading from the bus, retrieve data from the RX FIFO and store it on the buffer. */
+    if ( rd_buf != NULL ) {
+        case 1:
+          (*rd_buf) = (fifo_data >> bit_shift);
+          break;
+        case 2:
+          fifo_data = BCM2835_REG(BCM2835_SPI_FIFO) & 0xFFFF;
+          break;
+        case 3:
+          fifo_data = BCM2835_REG(BCM2835_SPI_FIFO) & 0xFFFFFF;
+          break;
+        case 4:
+          fifo_data = BCM2835_REG(BCM2835_SPI_FIFO);
+          break;
+        default:
+          return -1;
+      rd_buf += bytes_per_char;
+      /* Restore bus direction to write to the slave. */
+      BCM2835_REG(BCM2835_SPI_CS) &= ~(1 << 12);
+      return -1;
+  else
+ * @brief Handler function that is called on any SPI interrupt.
+ *        There are 2 situations that can generate an interrupt:
+ *        2. RX FIFO full.
+ *        Because the 2. situation is not useful to many applications,
+ *        the only interrupt that is generated and handled is the
+ *        transfer complete interrupt.
+ *        The objective of the handler is then, depending on the transfer
+ *        context (reading or writing on the bus), to check if there is enough
+ *        space available on the TX FIFO to send data over the bus (if writing)
+ *        or if the slave device has sent enough data to be fetched from the
+ *        RX FIFO (if reading).
+ *        When any of these two conditions occur, disables further interrupts
+ *        to be generated and releases a irq semaphore which will allow the
+ *        following transfer to proceed.
+static void spi_handler(void* arg)
+  bcm2835_spi_softc_t *softc_ptr = (bcm2835_spi_softc_t *) arg;
+  /* If waiting to write to the bus, expect the TXD bit to be set, or
+   * if waiting to read from the bus, expect the RXD bit to be set
+   * before releasing the irq semaphore. */
+  if (( softc_ptr->irq_write == 1 && (BCM2835_REG(BCM2835_SPI_CS) & (1 << 18)) != 0 )
+      ( softc_ptr->irq_write == 0 && (BCM2835_REG(BCM2835_SPI_CS) & (1 << 17)) != 0 ))
+    /* Disable the SPI interrupt generation when a transfer is complete. */
+    BCM2835_REG(BCM2835_SPI_CS) &= ~(1 << 9);
+ * @brief Low level function to initialize the SPI bus.
+rtems_status_code bcm2835_spi_init(rtems_libi2c_bus_t * bushdl)
+    return sc;
+  /* FIXME: This should be set on the device driver itself and configured
+   * during the bus transfer mode setup or another ioctl request. */
+  softc_ptr->bidirectional = 0;
+    sc = rtems_semaphore_create(rtems_build_name('s','p','i','s'), 0, RTEMS_FIFO | RTEMS_SIMPLE_BINARY_SEMAPHORE, 0, &softc_ptr->irq_sema_id);
+      return sc;
+    sc = rtems_interrupt_handler_install(BCM2835_IRQ_ID_SPI, NULL, RTEMS_INTERRUPT_UNIQUE, (rtems_interrupt_handler) spi_handler, softc_ptr);
+  return sc;
+ * @brief Low level function that would send a start condition over an I2C bus.
+ *        As it is not required to access a SPI bus it is here just to satisfy
+ *        the libi2c API, which requires this function.
+rtems_status_code bcm2835_spi_send_start(rtems_libi2c_bus_t * bushdl)
+ * @brief Low level function that terminates a SPI transfer.
+ *        It stops the SPI transfer and unselects the current SPI slave device.
+ * @retval RTEMS_SUCCESSFUL The slave device has been successfully unselected.
+ * @retval RTEMS_INVALID_ADDRESS The stored slave address is neither 0 or 1.
+rtems_status_code bcm2835_spi_stop(rtems_libi2c_bus_t * bushdl)
+  uint32_t addr = softc_ptr->current_slave_addr;
+  uint32_t chip_select_bit = 21 + addr;
+  /* Set SPI transfer as not active. */
+  BCM2835_REG(BCM2835_SPI_CS) &= ~(1 << 7);
+  /* Unselect the active SPI slave. */
+  switch ( addr ) {
+    case 0:
+    case 1:
+      BCM2835_REG(BCM2835_SPI_CS) |= (1 << chip_select_bit);
+      break;
+    default:
+      return RTEMS_INVALID_ADDRESS;
+ * @brief Low level function which addresses a SPI slave device.
+ * @param[in] addr SPI slave select line address (0 for CE0 or 1 for CE1).
+ * @param[in] rw This values is unnecessary to address a SPI device and its
+ *               presence here is only to fulfill a libi2c requirement.
+ * @retval RTEMS_SUCCESSFUL The slave device has been successfully addressed.
+ * @retval RTEMS_INVALID_ADDRESS The received address is neither 0 or 1.
+rtems_status_code bcm2835_spi_send_addr(rtems_libi2c_bus_t * bushdl, uint32_t addr, int rw)
+  /* Calculates the bit corresponding to the received address
+   * on the SPI control register. */
+  /* Save which slave will be currently addressed,
+   * so it can be unselected later. */
+  softc_ptr->current_slave_addr = addr;
+  /* Select one of the two available SPI slave address lines. */
+  switch ( addr ) {
+    case 0:
+    case 1:
+      BCM2835_REG(BCM2835_SPI_CS) &= ~(1 << chip_select_bit);
+      break;
+    default:
+ * @brief Low level function that reads a number of bytes from the SPI bus
+ *        on to a buffer.
+ * @retval @see bcm2835_spi_read_write().
+int bcm2835_spi_read_bytes(rtems_libi2c_bus_t * bushdl, unsigned char *bytes, int nbytes)
+  return bcm2835_spi_read_write(bushdl, bytes, NULL, nbytes);
+ *        to the SPI bus.
+ * @param[in] bytes Buffer with data to send over the SPI bus.
+                     to the bus.
+int bcm2835_spi_write_bytes(rtems_libi2c_bus_t * bushdl, unsigned char *bytes, int nbytes)
+  return bcm2835_spi_read_write(bushdl, NULL, bytes, nbytes);
+ *        the bus transfer mode.
+ * @retval >=0 @see bcm2835_spi_set_tfr_mode().
+int bcm2835_spi_ioctl(rtems_libi2c_bus_t * bushdl, int cmd, void *arg)
+  switch ( cmd ) {
+      return bcm2835_spi_set_tfr_mode(bushdl, (const rtems_libi2c_tfr_mode_t *)arg);
+    default:
+      return -1;
+  return 0;
diff --git a/c/src/lib/libbsp/arm/raspberrypi/i2c/spi_init.c b/c/src/lib/libbsp/arm/raspberrypi/i2c/spi_init.c
index 0000000..cde59f1
--- /dev/null
+++ b/c/src/lib/libbsp/arm/raspberrypi/i2c/spi_init.c
@@ -0,0 +1,83 @@
+ * @file spi_init.c
+ * @brief Raspberry Pi SPI bus initialization.
+static rtems_libi2c_bus_ops_t bcm2835_spi_ops = {
+  init:        bcm2835_spi_init,
+  send_start:  bcm2835_spi_send_start,
+  send_stop:   bcm2835_spi_stop,
+  send_addr:   bcm2835_spi_send_addr,
+  read_bytes:  bcm2835_spi_read_bytes,
+  write_bytes: bcm2835_spi_write_bytes,
+  ioctl:       bcm2835_spi_ioctl
+static bcm2835_spi_desc_t bcm2835_spi_bus_desc = {
+    ops:  &bcm2835_spi_ops,
+    size: sizeof(bcm2835_spi_bus_desc)
+    initialized:    0
+ * which require access to the SPI bus.
+ * register each device driver, using the received spi bus number.
+int BSP_spi_register_drivers(int spi_bus_number)
+  int rv = 0;
+  return rv;
+int BSP_spi_init(void)
+  int rv;
+  /* Enable the SPI interface on the Raspberry Pi P1 GPIO header. */
+  if ( gpio_select_spi_p1() < 0 )
+  /* Clear SPI control register and clear SPI FIFOs. */
+  BCM2835_REG(BCM2835_SPI_CS) = 0x0000030;
+  /* Register the SPI bus. */
+  rv = rtems_libi2c_register_bus("/dev/spi", &(bcm2835_spi_bus_desc.bus_desc));
+  if ( rv < 0 )
+    return rv;
+  rv =  BSP_spi_register_drivers(rv);
+  return rv;
diff --git a/c/src/lib/libbsp/arm/raspberrypi/include/gpio.h b/c/src/lib/libbsp/arm/raspberrypi/include/gpio.h
index 0000000..3b4e178
--- /dev/null
+++ b/c/src/lib/libbsp/arm/raspberrypi/include/gpio.h
@@ -0,0 +1,198 @@
+ * @file gpio.h
+ * @brief Raspberry Pi specific GPIO definitions.
+#ifndef LIBBSP_ARM_RASPBERRYPI_GPIO_H
+#define LIBBSP_ARM_RASPBERRYPI_GPIO_H
+#include <rtems.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+ * @brief  Number of total GPIOS on the Raspberry Pi,
+ *         including the internal ones.
+#define GPIO_PIN_COUNT 54
+ * @brief The set of possible configurations for a GPIO pull-up resistor.
+ * Enumerated type to define the possible pull-up resistor configuratons
+ * for an input pin.
+typedef enum
+  PULL_UP,
+  PULL_DOWN,
+  NO_PULL_RESISTOR
+} rpi_gpio_input_mode;
+ * @brief The set of possible functions a pin can have.
+ * Enumerated type to define a pin function.
+typedef enum
+  DIGITAL_INPUT,
+  DIGITAL_OUTPUT,
+  ALT_FUNC_0,
+  ALT_FUNC_1,
+  ALT_FUNC_2,
+  ALT_FUNC_3,
+  ALT_FUNC_4,
+  ALT_FUNC_5,
+  NOT_USED
+} rpi_pin;
+ * @brief The set of possible interrupts an input pin can generate.
+ * Enumerated type to define an input pin interrupt.
+typedef enum
+  FALLING_EDGE,
+  RISING_EDGE,
+  BOTH_EDGES,
+  LOW_LEVEL,
+  HIGH_LEVEL,
+  BOTH_LEVELS,
+  NONE
+} gpio_interrupt;
+ * @brief Object containing relevant information to a interrupt handler.
+ * Encapsulates relevant data for a GPIO interrupt handler.
+typedef struct
+  int pin_number;
+  void (*handler) (void);
+  int debouncing_tick_count;
+  rtems_interval last_isr_tick;
+} handler_arguments;
+ * @brief Object containing information on a GPIO pin.
+ * Encapsulates relevant data about a GPIO pin.
+typedef struct
+  /* The pin type */
+  rpi_pin pin_type;
+  /* Interrupt handler arguments*/
+  handler_arguments h_args;
+  gpio_interrupt enabled_interrupt;
+  /* GPIO input pin mode. */
+  rpi_gpio_input_mode input_mode;
+} rpi_gpio_pin;
+ * @name gpio Usage
+extern void gpio_initialize(void);
+ * @brief Turns on the given pin.
+extern int gpio_set(int pin);
+ * @brief Turns off the given pin.
+extern int gpio_clear(int pin);
+ * @brief Returns the current value of a GPIO pin.
+extern int gpio_get_val(int pin);
+ * @brief Selects a GPIO pin for a specific function.
+extern int gpio_select_pin(int pin, rpi_pin type);
+ * @brief Setups a JTAG pin configuration.
+extern int gpio_select_jtag(void);
+ * @brief Setups the SPI interface on the RPI P1 GPIO header.
+extern int gpio_select_spi_p1(void);
+ * @brief Setups the I2C interface on the main (P1) GPIO pin header (rev2).
+extern int gpio_select_i2c_p1_rev2(void);
+ * @brief Configures a input GPIO pin pull-up resistor.
+extern int gpio_input_mode(int pin, rpi_gpio_input_mode mode);
+ * @brief Configures several input GPIO pins to the same pull-up resistor setup.
+extern int gpio_setup_input_mode(int *pin, int pin_count, rpi_gpio_input_mode mode);
+ * @brief Discards any configuration made on this pin.
+extern int gpio_disable_pin(int dev_pin);
+ * @brief Debouces a switch by requiring a number of clock ticks to pass between interruts.
+extern int gpio_debounce_switch(int pin, int ticks);
+ * @brief Enables interrupts on the given GPIO pin.
+extern int gpio_enable_interrupt(int dev_pin, gpio_interrupt interrupt, void (*handler) (void));
+ * @brief Disables any interrupt enabled on the given GPIO pin.
+extern int gpio_disable_interrupt(int dev_pin);
+#ifdef __cplusplus
+#endif /* LIBBSP_ARM_RASPBERRYPI_GPIO_H */
diff --git a/c/src/lib/libbsp/arm/raspberrypi/include/i2c.h b/c/src/lib/libbsp/arm/raspberrypi/include/i2c.h
index 0000000..bdc53ef
--- /dev/null
+++ b/c/src/lib/libbsp/arm/raspberrypi/include/i2c.h
@@ -0,0 +1,166 @@
+ * @file i2c.h
+ * @brief Raspberry Pi specific I2C and SPI definitions.
+#ifndef LIBBSP_ARM_RASPBERRYPI_I2C_H
+#define LIBBSP_ARM_RASPBERRYPI_I2C_H
+#include <rtems/libi2c.h>
+ * @name SPI constants.
+ * @brief  GPU processor core clock rate in Hz.
+ * Unless configured otherwise on a "config.txt" file present on the SD card
+ * the GPU defaults to 250 MHz. Currently only 250 MHz is supported.
+/* TODO: It would be nice if this value could be probed at startup, probably
+ *       using the Mailbox interface since the usual way of setting this on
+ *       the hardware is through a "config.txt" text file on the SD card.
+ *       Having this setup on the configure.ac script would require changing
+ *       the same setting on two different places. */
+#define GPU_CORE_CLOCK_RATE 250000000
+ * @name  SPI data structures.
+ * @brief Object containing the SPI bus configuration settings.
+ * Encapsulates the current SPI bus configuration.
+typedef struct {
+  int                 initialized;
+  uint8_t             bytes_per_char;
+  /* Shift to be applied on data transfers with
+   * least significative bit first (LSB) devices. */
+  uint8_t             bit_shift;
+  uint32_t            dummy_char;
+  /* If set to 0 uses 3-wire SPI, with 2 separate data lines (MOSI and MISO),
+   * if set to 1 uses 2-wire SPI, where the MOSI data line doubles as the
+   * slave out (SO) and slave in (SI) data lines. */
+  int                 bidirectional;
+  uint32_t            current_slave_addr;
+  rtems_id            irq_sema_id;
+  int                 irq_write;
+} bcm2835_spi_softc_t;
+typedef struct {
+  rtems_libi2c_bus_t  bus_desc;
+  bcm2835_spi_softc_t softc;
+} bcm2835_spi_desc_t;
+ * @name  SPI directives.
+rtems_status_code bcm2835_spi_init(rtems_libi2c_bus_t * bushdl);
+rtems_status_code bcm2835_spi_send_start(rtems_libi2c_bus_t * bushdl);
+rtems_status_code bcm2835_spi_stop(rtems_libi2c_bus_t * bushdl);
+rtems_status_code bcm2835_spi_send_addr(rtems_libi2c_bus_t * bushdl, uint32_t addr, int rw);
+int bcm2835_spi_read_bytes(rtems_libi2c_bus_t * bushdl, unsigned char *bytes, int nbytes);
+int bcm2835_spi_write_bytes(rtems_libi2c_bus_t * bushdl, unsigned char *bytes, int nbytes);
+int bcm2835_spi_ioctl(rtems_libi2c_bus_t * bushdl, int cmd, void *arg);
+int BSP_spi_register_drivers(int spi_bus_number);
+int BSP_spi_init(void);
+ * @name  I2C constants.
+ * @brief  BSC controller core clock rate in Hz.
+ * This is set to 150 MHz as per the BCM2835 datasheet.
+#define BSC_CORE_CLK_HZ 150000000
+ * @name  I2C data structures.
+typedef struct {
+  int                 initialized;
+} bcm2835_i2c_softc_t;
+typedef struct {
+  bcm2835_i2c_softc_t softc;
+} bcm2835_i2c_desc_t;
+ * @name  I2C directives.
+rtems_status_code bcm2835_i2c_init(rtems_libi2c_bus_t * bushdl);
+rtems_status_code bcm2835_i2c_send_start(rtems_libi2c_bus_t * bushdl);
+rtems_status_code bcm2835_i2c_stop(rtems_libi2c_bus_t * bushdl);
+rtems_status_code bcm2835_i2c_send_addr(rtems_libi2c_bus_t * bushdl, uint32_t addr, int rw);
+int bcm2835_i2c_read_bytes(rtems_libi2c_bus_t * bushdl, unsigned char *bytes, int nbytes);
+int bcm2835_i2c_write_bytes(rtems_libi2c_bus_t * bushdl, unsigned char *bytes, int nbytes);
+int bcm2835_i2c_ioctl(rtems_libi2c_bus_t * bushdl, int cmd, void *arg);
+int BSP_i2c_register_drivers(int i2c_bus_number);
+int BSP_i2c_init(void);
+#endif /* LIBBSP_ARM_RASPBERRYPI_I2C_H */
diff --git a/c/src/lib/libbsp/arm/raspberrypi/include/irq.h b/c/src/lib/libbsp/arm/raspberrypi/include/irq.h
index 8436c2d..fb5f90e 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/include/irq.h
+++ b/c/src/lib/libbsp/arm/raspberrypi/include/irq.h
@@ -1,5 +1,5 @@
- * @file
+ * @file irq.h
  * @ingroup raspberrypi_interrupt
@@ -7,7 +7,8 @@
- * Copyright (c) 2013 Alan Cudmore
+ *  Copyright (c) 2013 Alan Cudmore
@@ -62,6 +63,7 @@
 #define BSP_IRQ_COUNT               (BCM2835_INTC_TOTAL_IRQ)
+rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector);
 void raspberrypi_set_exception_handler(Arm_symbolic_exception_name exception,
                                          void (*handler)(void));
diff --git a/c/src/lib/libbsp/arm/raspberrypi/include/raspberrypi.h b/c/src/lib/libbsp/arm/raspberrypi/include/raspberrypi.h
index 4cc7eec..2e902c6 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/include/raspberrypi.h
+++ b/c/src/lib/libbsp/arm/raspberrypi/include/raspberrypi.h
@@ -1,6 +1,5 @@
- * @file
+ * @file raspberrypi.h
  * @ingroup raspberrypi_reg
@@ -8,7 +7,8 @@
- * Copyright (c) 2013 Alan Cudmore.
+ *  Copyright (c) 2013 Alan Cudmore.
@@ -79,8 +79,16 @@
 #define BCM2835_GPIO_GPFSEL1     (BCM2835_GPIO_REGS_BASE+0x04)
 #define BCM2835_GPIO_GPSET0      (BCM2835_GPIO_REGS_BASE+0x1C)
 #define BCM2835_GPIO_GPCLR0      (BCM2835_GPIO_REGS_BASE+0x28)
+#define BCM2835_GPIO_GPLEV0      (BCM2835_GPIO_REGS_BASE+0x34)
+#define BCM2835_GPIO_GPEDS0      (BCM2835_GPIO_REGS_BASE+0x40)
+#define BCM2835_GPIO_GPREN0      (BCM2835_GPIO_REGS_BASE+0x4C)
+#define BCM2835_GPIO_GPFEN0      (BCM2835_GPIO_REGS_BASE+0x58)
+#define BCM2835_GPIO_GPHEN0      (BCM2835_GPIO_REGS_BASE+0x64)
+#define BCM2835_GPIO_GPLEN0      (BCM2835_GPIO_REGS_BASE+0x70)
+#define BCM2835_GPIO_GPAREN0     (BCM2835_GPIO_REGS_BASE+0x7C)
+#define BCM2835_GPIO_GPAFEN0     (BCM2835_GPIO_REGS_BASE+0x88)
 #define BCM2835_GPIO_GPPUD       (BCM2835_GPIO_REGS_BASE+0x94)
-#define BCM2835_GPIO_GPPUDCLK0   (BCM2835_GPIO_REGS_BASE+0x98)
+#define BCM2835_GPIO_GPPUDCLK0   (BCM2835_GPIO_REGS_BASE+0x98)
@@ -107,14 +115,12 @@
  * @name UART 0 (PL011) Registers
 #define BCM2835_UART0_BASE       (0x20201000)
 #define BCM2835_UART0_DR         (BCM2835_UART0_BASE+0x00)
@@ -145,9 +151,68 @@
 #define BCM2835_UART0_ICR_RX    0x10
 #define BCM2835_UART0_ICR_TX    0x20
+ * @name I2C (BSC) Registers
+#define BCM2835_I2C_BASE           (0x20804000)
+#define BCM2835_I2C_C              (BCM2835_I2C_BASE+0x00)
+#define BCM2835_I2C_S              (BCM2835_I2C_BASE+0x04)
+#define BCM2835_I2C_DLEN           (BCM2835_I2C_BASE+0x08)
+#define BCM2835_I2C_A              (BCM2835_I2C_BASE+0x0C)
+#define BCM2835_I2C_FIFO           (BCM2835_I2C_BASE+0x10)
+#define BCM2835_I2C_DIV            (BCM2835_I2C_BASE+0x14)
+#define BCM2835_I2C_DEL            (BCM2835_I2C_BASE+0x18)
+#define BCM2835_I2C_CLKT           (BCM2835_I2C_BASE+0x1C)
+ * @name SPI Registers
+#define BCM2835_SPI_BASE           (0x20204000)
+#define BCM2835_SPI_CS             (BCM2835_SPI_BASE+0x00)
+#define BCM2835_SPI_FIFO           (BCM2835_SPI_BASE+0x04)
+#define BCM2835_SPI_CLK            (BCM2835_SPI_BASE+0x08)
+#define BCM2835_SPI_DLEN           (BCM2835_SPI_BASE+0x0C)
+#define BCM2835_SPI_LTOH           (BCM2835_SPI_BASE+0x10)
+#define BCM2835_SPI_DC             (BCM2835_SPI_BASE+0x14)
+ * @name I2C/SPI slave BSC Registers
+#define BCM2835_I2C_SPI_BASE       (0x20214000)
+#define BCM2835_I2C_SPI_DR         (BCM2835_I2C_SPI_BASE+0x00)
+#define BCM2835_I2C_SPI_RSR        (BCM2835_I2C_SPI_BASE+0x04)
+#define BCM2835_I2C_SPI_SLV        (BCM2835_I2C_SPI_BASE+0x08)
+#define BCM2835_I2C_SPI_CR         (BCM2835_I2C_SPI_BASE+0x0C)
+#define BCM2835_I2C_SPI_FR         (BCM2835_I2C_SPI_BASE+0x10)
+#define BCM2835_I2C_SPI_IFLS       (BCM2835_I2C_SPI_BASE+0x14)
+#define BCM2835_I2C_SPI_IMSC       (BCM2835_I2C_SPI_BASE+0x18)
+#define BCM2835_I2C_SPI_RIS        (BCM2835_I2C_SPI_BASE+0x1C)
+#define BCM2835_I2C_SPI_MIS        (BCM2835_I2C_SPI_BASE+0x20)
+#define BCM2835_I2C_SPI_ICR        (BCM2835_I2C_SPI_BASE+0x24)
+#define BCM2835_I2C_SPI_DMACR      (BCM2835_I2C_SPI_BASE+0x28)
+#define BCM2835_I2C_SPI_TDR        (BCM2835_I2C_SPI_BASE+0x2C)
+#define BCM2835_I2C_SPI_GPUSTAT    (BCM2835_I2C_SPI_BASE+0x30)
+#define BCM2835_I2C_SPI_HCTRL      (BCM2835_I2C_SPI_BASE+0x34)
  * @name IRQ Registers
@@ -170,7 +235,6 @@
  * @name GPU Timer Registers
@@ -194,7 +258,6 @@
 #endif /* LIBBSP_ARM_RASPBERRYPI_RASPBERRYPI_H */
diff --git a/c/src/lib/libbsp/arm/raspberrypi/irq/irq.c b/c/src/lib/libbsp/arm/raspberrypi/irq/irq.c
index 4132ef9..c2c7d89 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/irq/irq.c
+++ b/c/src/lib/libbsp/arm/raspberrypi/irq/irq.c
@@ -1,5 +1,5 @@
- * @file
+ * @file irq.c
@@ -7,6 +7,8 @@
  * Copyright (c) 2009
  * embedded brains GmbH
  * Obere Lagerstr. 30
@@ -52,22 +54,47 @@ void bsp_interrupt_dispatch(void)
   rtems_vector_number vector = 255;
   /* ARM timer */
-  if (BCM2835_REG(BCM2835_IRQ_BASIC) && 0x1)
+  if ( BCM2835_REG(BCM2835_IRQ_BASIC) & 0x1 )
       vector = BCM2835_IRQ_ID_TIMER_0;
   /* UART 0 */
-  else if ( BCM2835_REG(BCM2835_IRQ_BASIC) && BCM2835_BIT(19))
+  else if ( BCM2835_REG(BCM2835_IRQ_BASIC) & BCM2835_BIT(19) )
       vector = BCM2835_IRQ_ID_UART;
+  /* GPIO 0*/
+  else if ( BCM2835_REG(BCM2835_IRQ_PENDING2) & BCM2835_BIT(17) )
+      vector = BCM2835_IRQ_ID_GPIO_0;
+  else if ( BCM2835_REG(BCM2835_IRQ_PENDING2) & BCM2835_BIT(18) )
+      vector = BCM2835_IRQ_ID_GPIO_1;
+  else if ( BCM2835_REG(BCM2835_IRQ_PENDING2) & BCM2835_BIT(19) )
+      vector = BCM2835_IRQ_ID_GPIO_2;
+  else if ( BCM2835_REG(BCM2835_IRQ_PENDING2) & BCM2835_BIT(20) )
+      vector = BCM2835_IRQ_ID_GPIO_3;
+  /* I2C */
+  else if ( BCM2835_REG(BCM2835_IRQ_PENDING2) & BCM2835_BIT(21) )
+      vector = BCM2835_IRQ_ID_I2C;
+  /* SPI */
+  else if ( BCM2835_REG(BCM2835_IRQ_PENDING2) & BCM2835_BIT(22) )
+      vector = BCM2835_IRQ_ID_SPI;
   if ( vector < 255 )
       bsp_interrupt_handler_dispatch(vector);
@@ -76,7 +103,7 @@ rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector)
   rtems_interrupt_disable(level);
-   /* ARM Timer */
+  /* ARM Timer */
   if ( vector == BCM2835_IRQ_ID_TIMER_0 )
       BCM2835_REG(BCM2835_IRQ_ENABLE_BASIC) = 0x1;
@@ -85,8 +112,38 @@ rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector)
   else if ( vector == BCM2835_IRQ_ID_UART )
       BCM2835_REG(BCM2835_IRQ_ENABLE2) =  BCM2835_BIT(25);
+  /* GPIO 0 */
+  else if ( vector == BCM2835_IRQ_ID_GPIO_0 )
+      BCM2835_REG(BCM2835_IRQ_ENABLE2) = BCM2835_BIT(17);
+  /* GPIO 1 */
+  else if ( vector == BCM2835_IRQ_ID_GPIO_1 )
+      BCM2835_REG(BCM2835_IRQ_ENABLE2) = BCM2835_BIT(18);
+  /* GPIO 2 */
+  else if ( vector == BCM2835_IRQ_ID_GPIO_2 )
+      BCM2835_REG(BCM2835_IRQ_ENABLE2) = BCM2835_BIT(19);
+  /* GPIO 3 */
+  else if ( vector == BCM2835_IRQ_ID_GPIO_3 )
+      BCM2835_REG(BCM2835_IRQ_ENABLE2) = BCM2835_BIT(20);
+  /* I2C */
+  else if ( vector == BCM2835_IRQ_ID_I2C )
+      BCM2835_REG(BCM2835_IRQ_ENABLE2) = BCM2835_BIT(21);
+  /* SPI */
+  else if ( vector == BCM2835_IRQ_ID_SPI )
+      BCM2835_REG(BCM2835_IRQ_ENABLE2) = BCM2835_BIT(22);
   rtems_interrupt_enable(level);
@@ -106,12 +163,42 @@ rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
       BCM2835_REG(BCM2835_IRQ_DISABLE2) = BCM2835_BIT(25);
+  /* GPIO 0 */
+      BCM2835_REG(BCM2835_IRQ_DISABLE2) = BCM2835_BIT(17);
+  /* GPIO 1 */
+      BCM2835_REG(BCM2835_IRQ_DISABLE2) = BCM2835_BIT(18);
+  /* GPIO 2 */
+      BCM2835_REG(BCM2835_IRQ_DISABLE2) = BCM2835_BIT(19);
+  /* GPIO 3 */
+      BCM2835_REG(BCM2835_IRQ_DISABLE2) = BCM2835_BIT(20);
+  /* I2C */
+      BCM2835_REG(BCM2835_IRQ_DISABLE2) = BCM2835_BIT(21);
+  /* SPI */
+      BCM2835_REG(BCM2835_IRQ_DISABLE2) = BCM2835_BIT(22);
 void bsp_interrupt_handler_default(rtems_vector_number vector)
     printk("spurious interrupt: %u\n", vector);
diff --git a/c/src/lib/libbsp/arm/raspberrypi/preinstall.am b/c/src/lib/libbsp/arm/raspberrypi/preinstall.am
index 70259e2..f9a87e0 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/preinstall.am
+++ b/c/src/lib/libbsp/arm/raspberrypi/preinstall.am
@@ -130,6 +130,14 @@ $(PROJECT_INCLUDE)/bsp/raspberrypi.h: include/raspberrypi.h $(PROJECT_INCLUDE)/b
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/raspberrypi.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/raspberrypi.h
+$(PROJECT_INCLUDE)/bsp/gpio.h: include/gpio.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/gpio.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/gpio.h
+$(PROJECT_INCLUDE)/bsp/i2c.h: include/i2c.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/i2c.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/i2c.h
 $(PROJECT_INCLUDE)/libcpu/cache_.h: ../../../libcpu/arm/shared/include/cache_.h $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/cache_.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/cache_.h
diff --git a/c/src/lib/libbsp/arm/raspberrypi/startup/bspstart.c b/c/src/lib/libbsp/arm/raspberrypi/startup/bspstart.c
index c5786bf..5ca6612 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/startup/bspstart.c
+++ b/c/src/lib/libbsp/arm/raspberrypi/startup/bspstart.c
@@ -1,5 +1,5 @@
- * @file
+ * @file bspstart.c
  * @ingroup arm_start
@@ -7,7 +7,8 @@
- * Copyright (c) 2013 by Alan Cudmore
+ *  Copyright (c) 2013 by Alan Cudmore
@@ -22,8 +23,18 @@
 #include <bsp/linker-symbols.h>
 #include <bsp/stackalloc.h>
+void bsp_predriver_hook(void)
+  if ( BSP_ENABLE_SPI == 1 )
+    BSP_spi_init();
+  if ( BSP_ENABLE_I2C == 1 )
+    BSP_i2c_init();
 void bsp_start(void)
-    bsp_interrupt_initialize();
+  bsp_interrupt_initialize();
1.8.5.5
