[PATCH 4/8] csb337/include/bsp.h: Do not include libchip/serial to avoid conflicts when building libchip/rtc
    Joel Sherrill
    joel.sherrill at oarcorp.com
    Thu Oct  9 18:39:55 UTC 2014
 c/src/lib/libbsp/arm/csb337/include/bsp.h | 7 ++++++-
 1 file changed, 6 insertions(+), 1 deletion(-)
diff --git a/c/src/lib/libbsp/arm/csb337/include/bsp.h b/c/src/lib/libbsp/arm/csb337/include/bsp.h
index c9a6353..b752b00 100644
--- a/c/src/lib/libbsp/arm/csb337/include/bsp.h
+++ b/c/src/lib/libbsp/arm/csb337/include/bsp.h
@@ -29,7 +29,6 @@ extern "C" {
 #include <rtems/console.h>
 #include <rtems/clockdrv.h>
-#include <libchip/serial.h>
  * @defgroup arm_csb337 CSB337 Support
@@ -50,7 +49,13 @@ extern "C" {
 /* What is the last interrupt? */
 #define BSP_MAX_INT AT91RM9200_MAX_INT
+ * forward reference the type to avoid conflicts between libchip serial
+ * and libchip rtc get and set register types.
+typedef struct _console_tbl console_tbl;
 console_tbl *BSP_get_uart_from_minor(int minor);
 static inline int32_t BSP_get_baud(void) {return 38400;}
 #define ST_PIMR_PIV	33	/* 33 ticks of the 32.768Khz clock ~= 1msec */
1.9.3
