[PATCH 33/54] no_cpu/no_bsp/clock/ckinit.c: Remove clock major/minor and clean up
    Joel Sherrill
    joel.sherrill at oarcorp.com
    Mon Oct 13 15:37:17 UTC 2014
 c/src/lib/libbsp/no_cpu/no_bsp/clock/ckinit.c | 49 +++++++++------------------
 1 file changed, 16 insertions(+), 33 deletions(-)
diff --git a/c/src/lib/libbsp/no_cpu/no_bsp/clock/ckinit.c b/c/src/lib/libbsp/no_cpu/no_bsp/clock/ckinit.c
index 5badbe1..fbfe541 100644
--- a/c/src/lib/libbsp/no_cpu/no_bsp/clock/ckinit.c
+++ b/c/src/lib/libbsp/no_cpu/no_bsp/clock/ckinit.c
@@ -1,8 +1,12 @@
-/*  ckinit.c
  *  This file provides a template for the clock device driver initialization.
- *  COPYRIGHT (c) 1989-1999.
+ *  If possible, please use the clockdrv_shell.h method for instantiating
+ *  a clock driver.
+ *  COPYRIGHT (c) 1989-2014.
  *  On-Line Applications Research Corporation (OAR).
  *  The license and distribution terms for this file may be
@@ -22,14 +26,12 @@ rtems_isr Clock_isr( rtems_vector_number vector );
  *  The interrupt vector number associated with the clock tick device
  *  driver.
 #define CLOCK_VECTOR    4
  *  Clock_driver_ticks is a monotonically increasing counter of the
  *  number of clock ticks since the driver was initialized.
 volatile uint32_t         Clock_driver_ticks;
@@ -39,20 +41,11 @@ volatile uint32_t         Clock_driver_ticks;
  *  length of time between the user configured microseconds per tick
  *  has passed.
 uint32_t         Clock_isrs;              /* ISRs until next tick */
- * These are set by clock driver during its init
-rtems_device_major_number rtems_clock_major = ~0;
-rtems_device_minor_number rtems_clock_minor;
  *  The previous ISR on this clock tick interrupt vector.
 rtems_isr_entry  Old_ticker;
 void Clock_exit( void );
@@ -60,19 +53,18 @@ void Clock_exit( void );
  *  Isr Handler
-rtems_isr Clock_isr(
+static rtems_isr Clock_isr(
- * bump the number of clock driver ticks since initialization
- * determine if it is time to announce the passing of tick as configured
- * to RTEMS through the rtems_clock_tick directive
- * perform any timer dependent tasks
+   * bump the number of clock driver ticks since initialization
+   * determine if it is time to announce the passing of tick as configured
+   * to RTEMS through the rtems_clock_tick directive
+   * perform any timer dependent tasks
@@ -81,7 +73,6 @@ rtems_isr Clock_isr(
  *  Install a clock tick handler and reprograms the chip.  This
  *  is used to initially establish the clock tick.
 void Install_clock(
   rtems_isr_entry clock_isr
@@ -123,7 +114,6 @@ void Clock_exit( void )
  *  Device driver entry point for clock tick driver initialization.
 rtems_device_driver Clock_initialize(
   rtems_device_major_number major,
   rtems_device_minor_number minor,
@@ -132,13 +122,6 @@ rtems_device_driver Clock_initialize(
   Install_clock( Clock_isr );
-   * make major/minor avail to others such as shared memory driver
-  rtems_clock_major = major;
-  rtems_clock_minor = minor;
   return RTEMS_SUCCESSFUL;
1.9.3
