[PATCH 2/2] libbsp/or1ksim: Fix warnings.
Mon Oct 13 18:36:22 UTC 2014
OK. When my build finishes, I will commit this unless someone
beats me to it.
--joel
On 10/13/2014 1:30 PM, Hesham Moustafa wrote:
> On Mon, Oct 13, 2014 at 8:24 PM, Joel Sherrill
> <joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>> wrote:
>     On 10/13/2014 1:06 PM, Hesham Moustafa wrote:
>>     Please have a look at this patch.
>>     On Fri, Oct 10, 2014 at 6:45 PM, Hesham ALMatary
>>     <heshamelmatary at gmail.com <mailto:heshamelmatary at gmail.com>> wrote:
>>          c/src/lib/libbsp/or1k/or1ksim/clock/clockdrv.c |  2 +-
>>          c/src/lib/libbsp/or1k/or1ksim/console/uart.c   | 15
>>          2 files changed, 12 insertions(+), 5 deletions(-)
>>         diff --git a/c/src/lib/libbsp/or1k/or1ksim/clock/clockdrv.c
>>         b/c/src/lib/libbsp/or1k/or1ksim/clock/clockdrv.c
>>         index ad49d07..4169a11 100644
>>         --- a/c/src/lib/libbsp/or1k/or1ksim/clock/clockdrv.c
>>         +++ b/c/src/lib/libbsp/or1k/or1ksim/clock/clockdrv.c
>>         @@ -137,8 +137,8 @@ CPU_Counter_ticks _CPU_Counter_difference(
>>          #define Clock_driver_support_install_isr(isr, old_isr) \
>>            do {                                                 \
>>         -    or1ksim_clock_handler_install(isr, old_isr);               \
>>              old_isr = NULL;                                    \
>>         +    or1ksim_clock_handler_install(isr, old_isr);       \
>>            } while (0)
>     Is old_isr an ISR or a pointer to an ISR method? I was wondering
>     if that should be *old_isr and be set in or1k_clock_handler_install.
> It's a pointer to the ISR method, and initially 0 (Null) within the
> ISR vector table. Since Clock_driver_support_install_isr is first
> called when installing the clock driver, old_isr would be always Null.
> Other BSPs do the same thing.
>>          #define Clock_driver_support_shutdown_hardware()
>>         or1ksim_clock_cleanup()
>>         diff --git a/c/src/lib/libbsp/or1k/or1ksim/console/uart.c
>>         b/c/src/lib/libbsp/or1k/or1ksim/console/uart.c
>>         index 7ceca81..31cdce6 100644
>>         --- a/c/src/lib/libbsp/or1k/or1ksim/console/uart.c
>>         +++ b/c/src/lib/libbsp/or1k/or1ksim/console/uart.c
>     This all looks right. I did this same thing to a LOT of BSPs. :(
>>         @@ -21,6 +21,14 @@
>>          #include <bsp/uart.h>
>>          #include <rtems/score/isr.h>
>>         +static void uart_initialize(int minor);
>>         +static int  uart_first_open(int major, int minor, void *arg);
>>         +static int  uart_last_close(int major, int minor, void *arg);
>>         +static int  uart_read_polled(int minor);
>>         +static ssize_t uart_write(int minor, const char *buf, size_t
>>         len);
>>         +static void uart_write_polled(int minor, char c);
>>         +static int  uart_set_attributes(int minor, const struct
>>         termios *t);
>>          static rtems_vector_number uart_get_irq_number(const
>>         console_tbl *ct)
>>             return ct->ulIntVector;
>>         @@ -86,10 +94,9 @@ static int uart_last_close(int major, int
>>         minor, void *arg)
>>            return 0;
>>         -static char uart_read_polled(int minor)
>>            unsigned char lsr;
>>         -  char c;
>>           /* Get a character when avaiable */
>>            do {
>>         @@ -120,7 +127,7 @@ static void uart_write_polled(int minor,
>>         char c)
>>            } while ( (lsr & transmit_finished) != transmit_finished );
>>         -static ssize_t uart_write_support_polled(
>>            int minor,
>>            const char *s,
>>            size_t n
>>         @@ -145,7 +152,7 @@ const console_fns or1ksim_uart_fns = {
>>            .deviceFirstOpen = uart_first_open,
>>            .deviceLastClose = uart_last_close,
>>            .deviceRead = uart_read_polled,
>>         -  .deviceWrite = uart_write_support_polled,
>>         +  .deviceWrite = uart_write,
>>            .deviceInitialize = uart_initialize,
>>            .deviceWritePolled = uart_write_polled,
>>            .deviceSetAttributes = uart_set_attributes,
>>         1.9.3
>     Joel Sherrill, Ph.D.             Director of Research & Development
>     joel.sherrill at OARcorp.com <mailto:joel.sherrill at OARcorp.com>        On-Line Applications Research
>     Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>     Support Available                (256) 722-9985
URL: <http://lists.rtems.org/pipermail/devel/attachments/20141013/5d99af72/attachment-0002.html>
