[PATCH 11/62] mvme3100/startup/bspstart.c: Remove myCpu variables and clean up
    Joel Sherrill
    joel.sherrill at oarcorp.com
    Wed Oct 15 20:00:01 UTC 2014
 .../lib/libbsp/powerpc/mvme3100/startup/bspstart.c | 493 +++++++++++----------
 1 file changed, 247 insertions(+), 246 deletions(-)
diff --git a/c/src/lib/libbsp/powerpc/mvme3100/startup/bspstart.c b/c/src/lib/libbsp/powerpc/mvme3100/startup/bspstart.c
index 3c9ee9c..5a14349 100644
--- a/c/src/lib/libbsp/powerpc/mvme3100/startup/bspstart.c
+++ b/c/src/lib/libbsp/powerpc/mvme3100/startup/bspstart.c
@@ -47,14 +47,14 @@
 #endif
 extern unsigned long __rtems_end[];
-extern void	         BSP_vme_config(void);
+extern void          BSP_vme_config(void);
 extern void          BSP_pciConfigDump_early( void );
 extern unsigned      ppc_exc_lock_std, ppc_exc_gpr3_std;
  * Copy Additional boot param passed by boot loader
-#define CMDLINE_BUF_SIZE	2048
+#define CMDLINE_BUF_SIZE  2048
 static char cmdline_buf[CMDLINE_BUF_SIZE] = {0};
 char *BSP_commandline_string         = cmdline_buf;
@@ -97,13 +97,12 @@ static void
 prether(char *b, int idx)
 int i;
-	printk("Ethernet %i                  %02X", idx, *b++);
-	for ( i=0; i<5; i++ )
-		printk(":%02X",*b++);
-	printk("\n");
+  printk("Ethernet %i                  %02X", idx, *b++);
+  for ( i=0; i<5; i++ )
+    printk(":%02X",*b++);
+  printk("\n");
 BSP_output_char_function_type     BSP_output_char = BSP_output_char_via_serial;
 BSP_polling_getchar_function_type BSP_poll_char = NULL;
@@ -124,8 +123,11 @@ char *rtems_progname;
  *  Use the shared implementations of the following routines
-char * save_boot_params(void* r3, void *r4, void* r5, char *additional_boot_options)
+char * save_boot_params(
+  void* r3,
+  void *r4,
+  void* r5,
+  char *additional_boot_options)
   strncpy(cmdline_buf, additional_boot_options, CMDLINE_BUF_SIZE);
@@ -134,76 +136,76 @@ char * save_boot_params(void* r3, void *r4, void* r5, char *additional_boot_opti
 #define CS_CONFIG_CS_EN (1<<31)
-#define CS_BNDS_SA(x)	((((uint32_t)(x))>>(31-15)) & 0xff)
-#define CS_BNDS_EA(x)	((((uint32_t)(x))>>(31-31)) & 0xff)
+#define CS_BNDS_SA(x)  ((((uint32_t)(x))>>(31-15)) & 0xff)
+#define CS_BNDS_EA(x)  ((((uint32_t)(x))>>(31-31)) & 0xff)
 static inline uint32_t
 _ccsr_rd32(uint32_t off)
-	return in_be32( (volatile unsigned *)(BSP_8540_CCSR_BASE + off) );
+  return in_be32( (volatile unsigned *)(BSP_8540_CCSR_BASE + off) );
 static inline void
 _ccsr_wr32(uint32_t off, uint32_t val)
-	out_be32( (volatile unsigned *)(BSP_8540_CCSR_BASE + off), val );
+  out_be32( (volatile unsigned *)(BSP_8540_CCSR_BASE + off), val );
 STATIC uint32_t
 BSP_get_mem_size( void )
-int i;
-uint32_t	cs_bnds, cs_config;
-uint32_t	memsz=0;
-uint32_t	v;
-	for ( cs_bnds = 0x2000, cs_config=0x2080, i=0; i<4; i++, cs_bnds+=8, cs_config+=4 ) {
-		if ( CS_CONFIG_CS_EN & _ccsr_rd32( cs_config ) ) {
-			v = _ccsr_rd32( cs_bnds );
-			memsz += CS_BNDS_EA(v) - CS_BNDS_SA(v) + 1;
-	return memsz << 24;
+  int i;
+  uint32_t  cs_bnds, cs_config;
+  uint32_t  memsz=0;
+  uint32_t  v;
+  for ( cs_bnds = 0x2000, cs_config=0x2080, i=0; i<4; i++, cs_bnds+=8, cs_config+=4 ) {
+    if ( CS_CONFIG_CS_EN & _ccsr_rd32( cs_config ) ) {
+      v = _ccsr_rd32( cs_bnds );
+      memsz += CS_BNDS_EA(v) - CS_BNDS_SA(v) + 1;
+  return memsz << 24;
 STATIC void
 BSP_calc_freqs( void )
-uint32_t	porpllsr   = _ccsr_rd32( 0xe0000 );
-unsigned	plat_ratio = (porpllsr >> (31-30)) & 0x1f;
-unsigned    e500_ratio = (porpllsr >> (31-15)) & 0x3f;
-	switch ( plat_ratio ) {
-		case  2: case  3: case  4: case  5: case  6:
-		case  8: case  9: case 10: case 12: case 16:
-		/* supported ratios */
-			BSP_bus_frequency = BSP_pci_bus_frequency * plat_ratio;
-		break;
-		default:
-			BSP_panic("Unknown PLL sys-clock ratio; something's wrong here");
-	switch ( e500_ratio ) {
-		case 4: case 5: case 6: case 7:
-			BSP_processor_frequency = (BSP_pci_bus_frequency * e500_ratio) >> 1;
-		break;
-		default:
-			BSP_panic("Unknown PLL e500-clock ratio; something's wrong here");
-	printk("Core Complex Bus (CCB) Clock Freq: %10u Hz\n", BSP_bus_frequency);
-	printk("CPU Clock Freq:                    %10u Hz\n", BSP_processor_frequency);
+  uint32_t  porpllsr   = _ccsr_rd32( 0xe0000 );
+  unsigned  plat_ratio = (porpllsr >> (31-30)) & 0x1f;
+  unsigned    e500_ratio = (porpllsr >> (31-15)) & 0x3f;
+  switch ( plat_ratio ) {
+    case  2: case  3: case  4: case  5: case  6:
+    case  8: case  9: case 10: case 12: case 16:
+    /* supported ratios */
+      BSP_bus_frequency = BSP_pci_bus_frequency * plat_ratio;
+    break;
+    default:
+      BSP_panic("Unknown PLL sys-clock ratio; something's wrong here");
+  switch ( e500_ratio ) {
+    case 4: case 5: case 6: case 7:
+      BSP_processor_frequency = (BSP_pci_bus_frequency * e500_ratio) >> 1;
+    break;
+    default:
+      BSP_panic("Unknown PLL e500-clock ratio; something's wrong here");
+  printk("Core Complex Bus (CCB) Clock Freq: %10u Hz\n", BSP_bus_frequency);
+  printk("CPU Clock Freq:                    %10u Hz\n", BSP_processor_frequency);
 void
 bsp_predriver_hook(void)
-	/* Some drivers (RTC) may need i2c */
-	BSP_i2c_initialize();
+  /* Some drivers (RTC) may need i2c */
+  BSP_i2c_initialize();
@@ -218,221 +220,220 @@ SPR_RW(HID1)
 void bsp_start( void )
-unsigned char       *stack;
-uintptr_t           intrStackStart;
-uintptr_t           intrStackSize;
-char                *chpt;
-ppc_cpu_id_t        myCpu;
-ppc_cpu_revision_t  myCpuRevision;
-int                 i;
-E500_tlb_va_cache_t *tlb;
+  unsigned char       *stack;
+  uintptr_t            intrStackStart;
+  uintptr_t            intrStackSize;
+  char                *chpt;
+  int                  i;
+  ppc_cpu_id_t         myCpu;
+  ppc_cpu_revision_t   myCpuRevision;
+  E500_tlb_va_cache_t *tlb;
 VpdBufRec          vpdData [] = {
-	{ key: ProductIdent, instance: 0, buf: BSP_productIdent, buflen: sizeof(BSP_productIdent) - 1 },
-	{ key: SerialNumber, instance: 0, buf: BSP_serialNumber, buflen: sizeof(BSP_serialNumber) - 1 },
-	{ key: BusClockHz,   instance: 0, buf: &BSP_pci_bus_frequency, buflen: sizeof(BSP_pci_bus_frequency)  },
-	{ key: EthernetAddr, instance: 0, buf: BSP_enetAddr0, buflen: sizeof(BSP_enetAddr0) },
-	{ key: EthernetAddr, instance: 1, buf: BSP_enetAddr1, buflen: sizeof(BSP_enetAddr1) },
-	{ key: EthernetAddr, instance: 2, buf: BSP_enetAddr2, buflen: sizeof(BSP_enetAddr2) },
-	VPD_END
+ { key: ProductIdent, instance: 0, buf: BSP_productIdent, buflen: sizeof(BSP_productIdent) - 1 },
+ { key: SerialNumber, instance: 0, buf: BSP_serialNumber, buflen: sizeof(BSP_serialNumber) - 1 },
+ { key: BusClockHz,   instance: 0, buf: &BSP_pci_bus_frequency, buflen: sizeof(BSP_pci_bus_frequency)  },
+ { key: EthernetAddr, instance: 0, buf: BSP_enetAddr0, buflen: sizeof(BSP_enetAddr0) },
+ { key: EthernetAddr, instance: 1, buf: BSP_enetAddr1, buflen: sizeof(BSP_enetAddr1) },
+ { key: EthernetAddr, instance: 2, buf: BSP_enetAddr2, buflen: sizeof(BSP_enetAddr2) },
+ VPD_END
-	/* Intersperse messages with actions to help locate problems */
-	printk("-----------------------------------------\n");
+  /* Intersperse messages with actions to help locate problems */
+  printk("-----------------------------------------\n");
-	 * Get CPU identification dynamically. Note that the get_ppc_cpu_type()
-	 * function store the result in global variables so that it can be used
-	 * later...
-	myCpu 	      = get_ppc_cpu_type();
-	myCpuRevision = get_ppc_cpu_revision();
+   * Get CPU identification dynamically. Note that the get_ppc_cpu_type()
+   * function store the result in global variables so that it can be used
+   * later...
+  myCpu = get_ppc_cpu_type();
+  myCpuRevision = get_ppc_cpu_revision();
-	printk("Welcome to %s\n", _RTEMS_version);
-	printk("BSP: %s, CVS Release ($Name$)\n", "mvme3100");
+  printk("Welcome to %s\n", _RTEMS_version);
+  printk("BSP: %s, CVS Release ($Name$)\n", "mvme3100");
-	 * the initial stack  has aready been set to this value in start.S
-	 * so there is no need to set it in r1 again... It is just for info
-	 * so that It can be printed without accessing R1.
-	asm volatile("mr %0, 1":"=r"(stack));
+   * the initial stack  has aready been set to this value in start.S
+   * so there is no need to set it in r1 again... It is just for info
+   * so that It can be printed without accessing R1.
+  asm volatile("mr %0, 1":"=r"(stack));
-	/* tag the bottom */
-	*((uint32_t*)stack) = 0;
+  /* tag the bottom */
+  *((uint32_t*)stack) = 0;
-	 * Initialize the interrupt related settings.
-	intrStackStart = (uintptr_t) __rtems_end;
-	intrStackSize = rtems_configuration_get_interrupt_stack_size();
+   * Initialize the interrupt related settings.
+  intrStackStart = (uintptr_t) __rtems_end;
+  intrStackSize = rtems_configuration_get_interrupt_stack_size();
-	 * Initialize default raw exception handlers.
-	ppc_exc_initialize(intrStackStart, intrStackSize);
+   * Initialize default raw exception handlers.
+  ppc_exc_initialize(intrStackStart, intrStackSize);
-	printk("CPU 0x%x - rev 0x%x\n", myCpu, myCpuRevision);
+  printk("CPU 0x%x - rev 0x%x\n", myCpu, myCpuRevision);
 #ifdef SHOW_MORE_INIT_SETTINGS
-	printk("Additionnal boot options are %s\n", BSP_commandline_string);
-	printk("Initial system stack at %x\n",      stack);
-	printk("Software IRQ stack starts at %x with size %u\n", intrStackStart, intrStackSize);
+  printk("Additionnal boot options are %s\n", BSP_commandline_string);
+  printk("Initial system stack at %x\n",      stack);
+  printk("Software IRQ stack starts at %x with size %u\n", intrStackStart, intrStackSize);
 #endif
-	printk("Going to start PCI buses scanning and initialization\n");
+  printk("Going to start PCI buses scanning and initialization\n");
 #endif
-	BSP_mem_size            = BSP_get_mem_size();
-		/* memory-select errors were disabled in 'start.S';
-		 * motload has all TLBs mapping a possible larger area as
-		 * memory (not-guarded, caching-enabled) than actual physical
-		 * memory is available.
-		 * In case of speculative loads this may cause 'memory-select' errors
-		 * which seem to raise 'core_fault_in' (found no description in
-		 * the manual but I experienced this problem).
-		 * Such errors (if HID1[RFXE] is clear) may *stall* execution
-		 * leading to mysterious 'hangs'.
-		 * Here we remove all mappings, re-enable memory-select
-		 * errors and make sure we enable HID1[RFXE] to avoid
-		 * stalls (since we don't implement handling individual
-		 * error-handling interrupts).
-		/* enable machine check for bad bus errors */
-		_write_HID1( _read_HID1() | 0x20000 );
-		rtems_e500_initlb();
-		for ( i=0, tlb=rtems_e500_tlb_va_cache; i<NumberOf(rtems_e500_tlb_va_cache); i++, tlb++ ) {
-			/* disable TLBs for caching-enabled, non-guarded areas
-			 * beyond physical memory
-			if (    tlb->att.v
-			    &&  0xa != (tlb->att.wimge & 0xa)
-				&&  (tlb->va.va_epn<<12) >= BSP_mem_size ) {
-				rtems_e500_clrtlb( E500_SELTLB_1 | i );
-		/* clear all pending memory errors */
-		_ccsr_wr32(0x2e40, 0xffffffff);
-		/* enable checking for memory-select errors */
-		_ccsr_wr32(0x2e44, _ccsr_rd32(0x2e44) & ~1 );
-	BSP_vpdRetrieveFields( vpdData );
-	printk("Board Type: %s (S/N %s)\n",
-			BSP_productIdent[0] ? BSP_productIdent : "n/a",
-			BSP_serialNumber[0] ? BSP_serialNumber : "n/a");
-	printk("External (=PCI Bus) Clock Freq   ");
-	if ( 0xdeadbeef == BSP_pci_bus_frequency ) {
-		BSP_pci_bus_frequency	= 66666666;
-		printk(" NOT FOUND in VPD; using %10u Hz\n",
-				BSP_pci_bus_frequency);
-	} else {
-		printk(": %10u Hz\n",
-	/* Calculate CPU and CCB bus freqs */
-	BSP_calc_freqs();
-	pci_initialize();
-	prether(BSP_enetAddr0, 0);
-	prether(BSP_enetAddr1, 1);
-	prether(BSP_enetAddr2, 2);
-	/* need to tweak the motload setup */
-	BSP_motload_pci_fixup();
+  BSP_mem_size            = BSP_get_mem_size();
+    /* memory-select errors were disabled in 'start.S';
+     * motload has all TLBs mapping a possible larger area as
+     * memory (not-guarded, caching-enabled) than actual physical
+     * memory is available.
+     * In case of speculative loads this may cause 'memory-select' errors
+     * which seem to raise 'core_fault_in' (found no description in
+     * the manual but I experienced this problem).
+     * Such errors (if HID1[RFXE] is clear) may *stall* execution
+     * leading to mysterious 'hangs'.
+     * Here we remove all mappings, re-enable memory-select
+     * errors and make sure we enable HID1[RFXE] to avoid
+     * stalls (since we don't implement handling individual
+     * error-handling interrupts).
+    /* enable machine check for bad bus errors */
+    _write_HID1( _read_HID1() | 0x20000 );
+    rtems_e500_initlb();
+    for ( i=0, tlb=rtems_e500_tlb_va_cache; i<NumberOf(rtems_e500_tlb_va_cache); i++, tlb++ ) {
+      /* disable TLBs for caching-enabled, non-guarded areas
+       * beyond physical memory
+      if (    tlb->att.v
+          &&  0xa != (tlb->att.wimge & 0xa)
+        &&  (tlb->va.va_epn<<12) >= BSP_mem_size ) {
+        rtems_e500_clrtlb( E500_SELTLB_1 | i );
+    /* clear all pending memory errors */
+    _ccsr_wr32(0x2e40, 0xffffffff);
+    /* enable checking for memory-select errors */
+    _ccsr_wr32(0x2e44, _ccsr_rd32(0x2e44) & ~1 );
+  BSP_vpdRetrieveFields( vpdData );
+  printk("Board Type: %s (S/N %s)\n",
+      BSP_productIdent[0] ? BSP_productIdent : "n/a",
+      BSP_serialNumber[0] ? BSP_serialNumber : "n/a");
+  printk("External (=PCI Bus) Clock Freq   ");
+  if ( 0xdeadbeef == BSP_pci_bus_frequency ) {
+    BSP_pci_bus_frequency  = 66666666;
+    printk(" NOT FOUND in VPD; using %10u Hz\n",
+        BSP_pci_bus_frequency);
+  } else {
+    printk(": %10u Hz\n",
+  /* Calculate CPU and CCB bus freqs */
+  BSP_calc_freqs();
+  pci_initialize();
+  prether(BSP_enetAddr0, 0);
+  prether(BSP_enetAddr1, 1);
+  prether(BSP_enetAddr2, 2);
+  /* need to tweak the motload setup */
+  BSP_motload_pci_fixup();
-	printk("Number of PCI buses found is : %d\n", pci_bus_count());
-		BSP_pciConfigDump_early();
+  printk("Number of PCI buses found is : %d\n", pci_bus_count());
+    BSP_pciConfigDump_early();
 #endif
-	if ( (chpt = strstr(BSP_commandline_string,"MEMSZ=")) ) {
-		char		*endp;
-		uint32_t 	sz;
-		chpt+=6 /* strlen("MEMSZ=") */;
-		sz = strtoul(chpt, &endp, 0);
-		if ( endp != chpt )
-			BSP_mem_size = sz;
-	printk("Memory:                            %10u bytes\n", BSP_mem_size);
-	BSP_bus_frequency       = 333333333;
-	BSP_processor_frequency = 833333333;
-	BSP_time_base_divisor   = 8000; /* if external RTC clock unused (HID0) */
-	/* clear hostbridge errors but leave MCP disabled -
-	 * PCI config space scanning code will trip otherwise :-(
-	_BSP_clear_hostbridge_errors(0 /* enableMCP */, 0/*quiet*/);
-	bsp_clicks_per_usec = BSP_bus_frequency/(BSP_time_base_divisor * 1000);
-	rtems_counter_initialize_converter(
-		BSP_bus_frequency / (BSP_time_base_divisor / 1000)
-	 * Initalize RTEMS IRQ system
-	BSP_rtems_irq_mng_init(0);
-	if (1) {
-		int i;
-		unsigned msr,tcr;
-		asm volatile("mfmsr %0":"=r"(msr));
-		asm volatile("mftcr %0":"=r"(tcr));
-		printk("MSR is 0x%08x, TCR 0x%08x\n",msr,tcr);
-		asm volatile("mttcr %0"::"r"(0));
-		if (0) {
-			asm volatile("mtmsr %0"::"r"(msr|0x8000));
-			for (i=0; i<12; i++)
-				BSP_enable_irq_at_pic(i);
-			printk("IRQS enabled\n");
-	if (0) {
-		unsigned x;
-		asm volatile("mfivpr %0":"=r"(x));
-		printk("IVPR: 0x%08x\n",x);
-		asm volatile("mfivor8 %0":"=r"(x));
-		printk("IVOR8: 0x%08x\n",x);
-		printk("0x%08x\n",*(unsigned *)0xc00);
-		printk("0x%08x\n",*(unsigned *)0xc04);
-		printk("0x%08x\n",*(unsigned *)0xc08);
-		printk("0x%08x\n\n\n",*(unsigned *)0xc0c);
-		if (0) {
-			*(unsigned *)0xc08 = 0x4c000064;
-			asm volatile("dcbf 0, %0; icbi 0, %0; sync; isync"::"r"(0xc00));
-		printk("0x%08x\n", ppc_exc_lock_std);
-		printk("0x%08x\n", ppc_exc_gpr3_std);
-		asm volatile("sc");
+  if ( (chpt = strstr(BSP_commandline_string,"MEMSZ=")) ) {
+    char    *endp;
+    uint32_t   sz;
+    chpt+=6 /* strlen("MEMSZ=") */;
+    sz = strtoul(chpt, &endp, 0);
+    if ( endp != chpt )
+      BSP_mem_size = sz;
+  printk("Memory:                            %10u bytes\n", BSP_mem_size);
+  BSP_bus_frequency       = 333333333;
+  BSP_processor_frequency = 833333333;
+  BSP_time_base_divisor   = 8000; /* if external RTC clock unused (HID0) */
+  /* clear hostbridge errors but leave MCP disabled -
+   * PCI config space scanning code will trip otherwise :-(
+  _BSP_clear_hostbridge_errors(0 /* enableMCP */, 0/*quiet*/);
+  bsp_clicks_per_usec = BSP_bus_frequency/(BSP_time_base_divisor * 1000);
+  rtems_counter_initialize_converter(
+    BSP_bus_frequency / (BSP_time_base_divisor / 1000)
+   * Initalize RTEMS IRQ system
+  BSP_rtems_irq_mng_init(0);
+  if (1) {
+    int i;
+    unsigned msr,tcr;
+    asm volatile("mfmsr %0":"=r"(msr));
+    asm volatile("mftcr %0":"=r"(tcr));
+    printk("MSR is 0x%08x, TCR 0x%08x\n",msr,tcr);
+    asm volatile("mttcr %0"::"r"(0));
+    if (0) {
+      asm volatile("mtmsr %0"::"r"(msr|0x8000));
+      for (i=0; i<12; i++)
+        BSP_enable_irq_at_pic(i);
+      printk("IRQS enabled\n");
+  if (0) {
+    unsigned x;
+    asm volatile("mfivpr %0":"=r"(x));
+    printk("IVPR: 0x%08x\n",x);
+    asm volatile("mfivor8 %0":"=r"(x));
+    printk("IVOR8: 0x%08x\n",x);
+    printk("0x%08x\n",*(unsigned *)0xc00);
+    printk("0x%08x\n",*(unsigned *)0xc04);
+    printk("0x%08x\n",*(unsigned *)0xc08);
+    printk("0x%08x\n\n\n",*(unsigned *)0xc0c);
+    if (0) {
+      *(unsigned *)0xc08 = 0x4c000064;
+      asm volatile("dcbf 0, %0; icbi 0, %0; sync; isync"::"r"(0xc00));
+    printk("0x%08x\n", ppc_exc_lock_std);
+    printk("0x%08x\n", ppc_exc_gpr3_std);
+    asm volatile("sc");
-	printk("Exit from bspstart\n");
+  printk("Exit from bspstart\n");
 #endif
1.9.3
