[PATCH 53/62] powerpc/score603e: Fix warnings
Joel Sherrill
joel.sherrill at oarcorp.com
Wed Oct 15 20:00:43 UTC 2014
c/src/lib/libbsp/powerpc/score603e/PCI_bus/PCI.c | 14 +-
c/src/lib/libbsp/powerpc/score603e/PCI_bus/flash.c | 2 +
.../libbsp/powerpc/score603e/PCI_bus/universe.c | 23 +-
.../lib/libbsp/powerpc/score603e/console/console.c | 40 +-
c/src/lib/libbsp/powerpc/score603e/cscope.out | 11129 +++++++++++++++++++
c/src/lib/libbsp/powerpc/score603e/include/bsp.h | 88 +-
c/src/lib/libbsp/powerpc/score603e/irq/FPGA.c | 11 +-
7 files changed, 11197 insertions(+), 110 deletions(-)
create mode 100644 c/src/lib/libbsp/powerpc/score603e/cscope.out
diff --git a/c/src/lib/libbsp/powerpc/score603e/PCI_bus/PCI.c b/c/src/lib/libbsp/powerpc/score603e/PCI_bus/PCI.c
index 817037e..999ab93 100644
--- a/c/src/lib/libbsp/powerpc/score603e/PCI_bus/PCI.c
+++ b/c/src/lib/libbsp/powerpc/score603e/PCI_bus/PCI.c
@@ -1,6 +1,5 @@
- * COPYRIGHT (c) 1989-2009.
+ * COPYRIGHT (c) 1989-2014.
* On-Line Applications Research Corporation (OAR).
* The license and distribution terms for this file may be
@@ -25,10 +24,10 @@
* an UNIVERSE register, without sufficient delay, the second access will
* not work correctly.
-void PCI_bus_delay (void)
+static void PCI_bus_delay (void)
- __asm__ (" nop");
- __asm__ (" nop");
+ __asm__ volatile ("nop");
@@ -43,7 +42,7 @@ void PCI_bus_write(
*_addr = _data;
-uint32_t PCI_bus_read(
+uint32_t PCI_bus_read(
volatile uint32_t * _addr /* IN */
@@ -57,8 +56,7 @@ uint32_t PCI_bus_read(
* PCI Configuration Cycle Read/Write Access which is used to access all of
* devices registers on the PCI bus. i.e.: Universe, Ethernet & PMC.
-uint32_t Read_pci_device_register(
+uint32_t Read_pci_device_register(
uint32_t address
diff --git a/c/src/lib/libbsp/powerpc/score603e/PCI_bus/flash.c b/c/src/lib/libbsp/powerpc/score603e/PCI_bus/flash.c
index c50c09b..a2e084a 100644
--- a/c/src/lib/libbsp/powerpc/score603e/PCI_bus/flash.c
+++ b/c/src/lib/libbsp/powerpc/score603e/PCI_bus/flash.c
@@ -60,6 +60,7 @@ unsigned int SCORE603e_FLASH_verify_enable( void )
return RTEMS_SUCCESSFUL;
+#if 0
unsigned int SCORE603e_FLASH_pci_reset_reg(
uint8_t reg,
uint32_t cmask,
@@ -79,6 +80,7 @@ unsigned int SCORE603e_FLASH_pci_reset_reg(
+#endif
* SCORE603e_FLASH_Enable_writes
diff --git a/c/src/lib/libbsp/powerpc/score603e/PCI_bus/universe.c b/c/src/lib/libbsp/powerpc/score603e/PCI_bus/universe.c
index a1011da..c373aa6 100644
--- a/c/src/lib/libbsp/powerpc/score603e/PCI_bus/universe.c
+++ b/c/src/lib/libbsp/powerpc/score603e/PCI_bus/universe.c
@@ -16,22 +16,6 @@
#include <bsp.h>
#include "PCI.h"
- ********* Prototypes *********
typedef struct {
uint32_t PCI_ID; /* 0x80030000 */
uint32_t PCI_CSR; /* 0x80030004 */
@@ -153,7 +137,6 @@ volatile Universe_Memory *UNIVERSE =
* by the boot code. This routine should be called by user code only if
* a complete SCORE603e VME initialization is required.
void initialize_universe(void)
uint32_t jumper_selection;
@@ -227,7 +210,7 @@ void set_vme_base_address (
* Gets the VME base address
-uint32_t get_vme_base_address (void)
+static uint32_t get_vme_base_address (void)
volatile uint32_t temp;
@@ -236,7 +219,7 @@ uint32_t get_vme_base_address (void)
return (temp);
-uint32_t get_vme_slave_size(void)
+uint32_t get_vme_slave_size(void)
temp = PCI_bus_read( &UNIVERSE->VSI0_BD);
@@ -249,7 +232,7 @@ uint32_t get_vme_slave_size(void)
* Set the size of the VME slave image
* Note: The maximum size is up to 24 M bytes. (00000000 - 017FFFFF)
-void set_vme_slave_size (uint32_t size)
+void set_vme_slave_size (uint32_t size)
diff --git a/c/src/lib/libbsp/powerpc/score603e/console/console.c b/c/src/lib/libbsp/powerpc/score603e/console/console.c
index 5ae61ea..afbc5b4 100644
--- a/c/src/lib/libbsp/powerpc/score603e/console/console.c
+++ b/c/src/lib/libbsp/powerpc/score603e/console/console.c
@@ -4,8 +4,10 @@
* This driver uses the termios pseudo driver.
* Currently only polled mode is supported.
@@ -36,14 +38,12 @@ int USE_FOR_CONSOLE = USE_FOR_CONSOLE_DEF;
* Console Device Driver Entry Points
-/* PAGE
* console_inbyte_nonblocking
* Console Termios polling input entry point.
-int console_inbyte_nonblocking(
+static int console_inbyte_nonblocking(
int minor
@@ -164,8 +164,7 @@ void console_outbyte_interrupts(
#endif
-/* PAGE
* console_initialize
* Routine called to initialize the console device driver.
@@ -178,7 +177,7 @@ rtems_device_driver console_initialize(
rtems_status_code status;
rtems_device_minor_number console;
- int port, chip, p0,p1;
+ int port, p0,p1;
* initialize the termio interface.
@@ -234,7 +233,6 @@ rtems_device_driver console_initialize(
for (port=1; port<NUM_Z85C30_PORTS; port++) {
- chip = port >> 1;
initialize_85c30_port( &Ports_85C30[port] );
@@ -245,14 +243,13 @@ rtems_device_driver console_initialize(
-/* PAGE
* console_write_support
* Console Termios output entry point.
-ssize_t console_write_support(
+static ssize_t console_write_support(
int minor,
const char *buf,
size_t len)
@@ -289,12 +286,10 @@ ssize_t console_write_support(
return nwrite;
-/* PAGE
* console_open
* open a port as a termios console.
rtems_device_driver console_open(
rtems_device_major_number major,
@@ -354,19 +349,10 @@ rtems_device_driver console_open(
#if (CONSOLE_USE_INTERRUPTS)
* console_outbyte_interrupts
* This routine transmits a character out.
- * Input parameters:
- * port - port to transmit character to
- * ch - character to be transmitted
- * Output parameters: NONE
- * Return values: NONE
const Port_85C30_info *Port,
@@ -396,12 +382,10 @@ void console_outbyte_interrupts(
Ring_buffer_Add_character( &protocol->TX_Buffer, ch );
#endif
/* const char arg to be compatible with BSP_output_char decl. */
-void
-debug_putc_onlcr(const char c)
+static void debug_putc_onlcr(const char c)
int console;
volatile uint8_t *csr;
diff --git a/c/src/lib/libbsp/powerpc/score603e/cscope.out b/c/src/lib/libbsp/powerpc/score603e/cscope.out
new file mode 100644
index 0000000..80b31bd
--- /dev/null
+++ b/c/src/lib/libbsp/powerpc/score603e/cscope.out
@@ -0,0 +1,11129 @@
+cscope 15 $HOME/rtems-4.11-work/rtems/c/src/lib/libbsp/powerpc/score603e 0000068551
+ @PCI_bus/PCI.c
+10
+ ~<¹ems.h
+11
+ ~<as£¹.h
+12
+ ~<¡dio.h
+14
+ ~<b¥.h
+27
+ $PCI_bus_day
+29
+__asm__
+ volatile ("nop");
+30
+__asm__
+ volatile ("nop");
+31
+36
+ $PCI_bus_wre
+37 vÞ©
+ut32_t
+_addr
+38
+ut32_t
+_d©a
+41
+_d©a
+ `CÚvt_Endn_32
+( _data );
+42 *
+_addr
+_d©a
+43
+45
+ut32_t
+ $PCI_bus_»ad
+46 vÞ©
+ut32_t
+_addr
+49
+ut32_t
+d©a
+51
+d©a
+_addr
+52
+d©a
+ `CÚvt_Endn_32
+( data );
+53
+d©a
+54
+59
+ut32_t
+ $Rd_pci_deviû_»gi¡
+60
+ut32_t
+add»ss
+63
+ut32_t
+d©a
+68
+ `PCI_bus_wre
+Ð(vÞ©
+ut32_t
+SCORE603E_PCI_IO_CFG_ADDR
+add»ss
+73
+ `PCI_bus_day
+78
+d©a
+ `PCI_bus_»ad
+Ð(vÞ©
+ut32_t
+SCORE603E_PCI_IO_CFG_DATA
+80
+d©a
+81
+83
+ $Wre_pci_deviû_»gi¡
+84
+ut32_t
+add»ss
+85
+ut32_t
+d©a
+91
+ `PCI_bus_wre
+Ð(vÞ©
+ut32_t
+add»ss
+96
+ `PCI_bus_day
+101
+ `PCI_bus_wre
+Ð(vÞ©
+ut32_t
+d©a
+102
+ @PCI_bus/PCI.h
+17 #iâdeà
+__PCI_h
+18
+ #__PCI_h
+24
+PCI_bus_wre
+25 vÞ©
+ut32_t
+_addr
+26
+ut32_t
+_d©a
+29
+ut32_t
+PCI_bus_»ad
+30 vÞ©
+ut32_t
+_addr
+33
+ut32_t
+Rd_pci_deviû_»gi¡
+34
+ut32_t
+add»ss
+37
+Wre_pci_deviû_»gi¡
+38
+ut32_t
+add»ss
+39
+ut32_t
+d©a
+ @PCI_bus/flash.c
+10
+ ~<¹ems.h
+11
+ ~<as£¹.h
+12
+ ~<¡dio.h
+13
+ ~<y³s.h
+15
+ ~<b¥.h
+16
+ ~<b¥/q.h
+17
+ ~"PCI.h
+22
+ $SCORE603e_FLASH_Di§bË
+23
+ut32_t
+26
+ut8_t
+v®ue
+28
+v®ue
+SCORE603E_BOARD_CTRL_REG
+29
+v®ue
+ = v®u| (~
+SCORE603E_BRD_FLASH_DISABLE_MASK
+30 *
+v®ue
+32
+RTEMS_SUCCESSFUL
+33
+35
+ $SCORE603e_FLASH_vify_abË
+37 vÞ©
+ut8_t
+Cl_Stus_Regi¡
+38 (*)
+39
+ut8_t
+ù¾_v®ue
+40
+ut32_t
+pci_v®ue
+42
+ù¾_v®ue
+Cl_Stus_Regi¡
+43 iàÐ
+ù¾_v®ue
+44
+ `´tf
+ ("Flash Writes Disabled by board controlegister %x\n",
+45
+ù¾_v®ue
+46
+ `as£¹
+( 0x0 );
+49
+pci_v®ue
+ `Rd_pci_deviû_»gi¡
+( 0x800000A8 );
+50 ià(Ð
+pci_v®ue
+ & 0x00001000 ) == 0) {
+51
+ `´tf
+("Error PCI A8 \n");
+52
+ `as£¹
+( 0x0 );
+55
+pci_v®ue
+( 0x800000AC );
+56 iàÐ
+pci_v®ue
+ & 0x02000000) {
+57
+ `´tf
+("Error PCI AC \n");
+58
+ `as£¹
+( 0x0 );
+60
+RTEMS_SUCCESSFUL
+61
+64
+ $SCORE603e_FLASH_pci_»£t_»g
+65
+ut8_t
+»g
+66
+ut32_t
+cmask
+67
+ut32_t
+mask
+70
+ut32_t
+pci_v®ue
+71
+ut32_t
+v®ue
+73
+pci_v®ue
+Ð
+»g
+74
+pci_v®ue
+ &ð
+cmask
+75
+pci_v®ue
+ |ð
+mask
+76
+ `Wre_pci_deviû_»gi¡
+Ð
+»g
+pci_v®ue
+77
+v®ue
+Ð
+»g
+78 ià(
+v®ue
+ !ð
+pci_v®ue
+79
+ `´tf
+("E¼Ü PCI 0x%2"
+PRIX8
+" wrÙ0x%8"
+PRIX32
+"d %8"PRIX32"\n",
+»g
+pci_v®ue
+v®ue
+81
+RTEMS_SUCCESSFUL
+82
+88
+ $SCORE603e_FLASH_EÇbË_wres
+89
+ut32_t
+92
+ut8_t
+ù¾_v®ue
+93
+ut32_t
+pci_v®ue
+95
+ù¾_v®ue
+96
+ù¾_v®ue
+ = ctrl_value & 0xbf;
+97 *
+ù¾_v®ue
+99
+pci_v®ue
+( 0x800000A8 );
+100
+pci_v®ue
+ |= 0x00001000;
+101
+Ð0x800000A8,
+pci_v®ue
+103
+pci_v®ue
+( 0x800000AC );
+104
+pci_v®ue
+ &= (~0x02000000);
+105
+Ð0x000000AC,
+pci_v®ue
+107
+RTEMS_SUCCESSFUL
+108
+ @PCI_bus/universe.c
+10
+ ~<¹ems.h
+11
+ ~<as£¹.h
+12
+ ~<¡dio.h
+13
+ ~<y³s.h
+14
+ ~<¹ems/b¥Io.h
+16
+ ~<b¥.h
+17
+ ~"PCI.h
+20
+ut32_t
+ mPCI_ID
+21
+ut32_t
+ mPCI_CSR
+22
+ut32_t
+ mPCI_CLASS
+23
+ut32_t
+ mPCI_MISC0
+24
+ut32_t
+ mPCI_BS
+25
+ut32_t
+ mBuf_0x80030014
+[ 0x0A ];
+26
+ut32_t
+ mPCI_MISC1
+27
+ut32_t
+ mBuf_0x80030040
+[ 0x30 ];
+28
+ut32_t
+ mLSI0_CTL
+29
+ut32_t
+ mLSI0_BS
+30
+ut32_t
+ mLSI0_BD
+31
+ut32_t
+ mLSI0_TO
+32
+ut32_t
+ mBuf_0x80030110
+33
+ut32_t
+ mLSI1_CTL
+34
+ut32_t
+ mLSI1_BS
+35
+ut32_t
+ mLSI1_BD
+36
+ut32_t
+ mLSI1_TO
+37
+ut32_t
+ mBuf_0x80030124
+38
+ut32_t
+ mLSI2_CTL
+39
+ut32_t
+ mLSI2_BS
+40
+ut32_t
+ mLSI2_BD
+41
+ut32_t
+ mLSI2_TO
+42
+ut32_t
+ mBuf_0x80030138
+43
+ut32_t
+ mLSI3_CTL
+44
+ut32_t
+ mLSI3_BS
+45
+ut32_t
+ mLSI3_BD
+46
+ut32_t
+ mLSI3_TO
+47
+ut32_t
+ mBuf_0x8003014C
+[ 0x09 ];
+48
+ut32_t
+ mSCYC_CTL
+49
+ut32_t
+ mSCYC_ADDR
+50
+ut32_t
+ mSCYC_EN
+51
+ut32_t
+ mSCYC_CMP
+52
+ut32_t
+ mSCYC_SWP
+53
+ut32_t
+ mLMISC
+54
+ut32_t
+ mSLSI
+55
+ut32_t
+ mL_CMDERR
+56
+ut32_t
+ mLAERR
+57
+ut32_t
+ mBuf_0x80030194
+[ 0x1B ];
+58
+ut32_t
+ mDCTL
+59
+ut32_t
+ mDTBC
+60
+ut32_t
+ mDLA
+61
+ut32_t
+ mBuf_0x8003020C
+62
+ut32_t
+ mDVA
+63
+ut32_t
+ mBuf_0x80030214
+64
+ut32_t
+ mDCPP
+65
+ut32_t
+ mBuf_0x8003021C
+66
+ut32_t
+ mDGCS
+67
+ut32_t
+ mD_LLUE
+68
+ut32_t
+ mBuf_0x80030228
+[ 0x36 ];
+69
+ut32_t
+ mLINT_EN
+70
+ut32_t
+ mLINT_STAT
+71
+ut32_t
+ mLINT_MAP0
+72
+ut32_t
+ mLINT_MAP1
+73
+ut32_t
+ mVINT_EN
+74
+ut32_t
+ mVINT_STAT
+75
+ut32_t
+ mVINT_MAP0
+76
+ut32_t
+ mVINT_MAP1
+77
+ut32_t
+ mSTATID
+78
+ut32_t
+ mV1_STATID
+79
+ut32_t
+ mV2_STATID
+80
+ut32_t
+ mV3_STATID
+81
+ut32_t
+ mV4_STATID
+82
+ut32_t
+ mV5_STATID
+83
+ut32_t
+ mV6_STATID
+84
+ut32_t
+ mV7_STATID
+85
+ut32_t
+ mBuf_0x80030340
+[ 0x30 ];
+86
+ut32_t
+ mMAST_CTL
+87
+ut32_t
+ mMISC_CTL
+88
+ut32_t
+ mMISC_STAT
+89
+ut32_t
+ mUSER_AM
+90
+ut32_t
+ mBuf_0x80030410
+[ 0x2bc ];
+91
+ut32_t
+ mVSI0_CTL
+92
+ut32_t
+ mVSI0_BS
+93
+ut32_t
+ mVSI0_BD
+94
+ut32_t
+ mVSI0_TO
+95
+ut32_t
+ mBuf_0x80030f10
+96
+ut32_t
+ mVSI1_CTL
+97
+ut32_t
+ mVSI1_BS
+98
+ut32_t
+ mVSI1_BD
+99
+ut32_t
+ mVSI1_TO
+100
+ut32_t
+ mBuf_0x80030F24
+101
+ut32_t
+ mVSI2_CTL
+102
+ut32_t
+ mVSI2_BS
+103
+ut32_t
+ mVSI2_BD
+104
+ut32_t
+ mVSI2_TO
+105
+ut32_t
+ mBuf_0x80030F38
+106
+ut32_t
+ mVSI3_CTL
+107
+ut32_t
+ mVSI3_BS
+108
+ut32_t
+ mVSI3_BD
+109
+ut32_t
+ mVSI3_TO
+110
+ut32_t
+ mBuf_0x80030F4C
+[ 0x9 ];
+111
+ut32_t
+ mVRAI_CTL
+112
+ut32_t
+ mVRAI_BS
+113
+ut32_t
+ mBuf_0x80030F78
+[ 0x2 ];
+114
+ut32_t
+ mVCSR_CTL
+115
+ut32_t
+ mVCSR_TO
+116
+ut32_t
+ mV_AMERR
+117
+ut32_t
+ mVAERR
+118
+ut32_t
+ mBuf_0x80030F90
+[ 0x19 ];
+119
+ut32_t
+ mVCSR_CLR
+120
+ut32_t
+ mVCSR_SET
+121
+ut32_t
+ mVCSR_BS
+122 }
+ tUniv£_MemÜy
+124 vÞ©
+Univ£_MemÜy
+ gUNIVERSE
+125 (vÞ©
+Univ£_MemÜy
+SCORE603E_UNIVERSE_BASE
+140
+ $lize_univ£
+142
+ut32_t
+jum³r_£ËùiÚ
+143
+ut32_t
+pci_id
+148
+jum³r_£ËùiÚ
+ `PCI_bus_»ad
+149 (vÞ©
+ut32_t
+SCORE603E_VME_JUMPER_ADDR
+150
+ `´tk
+("initialize_universe: Read 0x%x = 0x%x\n",
+151
+jum³r_£ËùiÚ
+152
+jum³r_£ËùiÚ
+ = (jumper_selection >> 3) & 0x1f;
+157
+pci_id
+Ð
+SCORE603E_IO_VME_UNIVERSE_BASE
+162 ià(
+pci_id
+ !ð
+SCORE603E_UNIVERSE_CHIP_ID
+163
+ `´tk
+ ("Inv®id SCORE603E_UNIVERSE_CHIP_ID: 0x08%"
+PRId32
+ "\n",
+pci_id
+164
+ `¹ems_çl_rÜ_occu¼ed
+( 0x603e0bad );
+166
+ `´tk
+("initialize_universe: Reg 0x%xead 0x%x\n",
+167
+pci_id
+173
+180
+ $£t_vme_ba£_add»ss
+181
+ut32_t
+ba£_add»ss
+184 vÞ©
+ut32_t
+mp
+189
+mp
+ `PCI_bus_»ad
+Ð&
+UNIVERSE
+VSI0_BD
+) & 0xFFFFF000) -
+190 Ð
+ `PCI_bus_»ad
+Ð&
+UNIVERSE
+VSI0_BS
+) & 0xFFFFF000);
+196
+ `PCI_bus_wre
+Ð&
+UNIVERSE
+VSI0_BS
+ba£_add»ss
+ & 0xFFFFF000) );
+201
+ `PCI_bus_wre
+Ð&
+UNIVERSE
+VSI0_BD
+mp
+206
+mp
+ = 0xFFFFFFFF - (
+ba£_add»ss
+ & 0xFFFFF000) + 1 + 0x80000000;
+207
+ `PCI_bus_wre
+Ð&
+UNIVERSE
+VSI0_TO
+mp
+208
+213
+ut32_t
+ $g_vme_ba£_add»ss
+215 vÞ©
+ut32_t
+mp
+217
+mp
+ `PCI_bus_»ad
+Ð&
+UNIVERSE
+VSI0_BS
+218
+mp
+ &= 0xFFFFF000;
+219 (
+mp
+220
+222
+ut32_t
+ $g_vme_¦ave_size
+224 vÞ©
+ut32_t
+mp
+225
+mp
+ `PCI_bus_»ad
+Ð&
+UNIVERSE
+VSI0_BD
+226
+mp
+ &= 0xFFFFF000;
+227
+mp
+ =em°-
+ `g_vme_ba£_add»ss
+228
+mp
+229
+235
+ $£t_vme_¦ave_size
+ut32_t
+size
+237 vÞ©
+ut32_t
+mp
+239 ià(
+size
+<0)
+240
+size
+ = 0;
+242 ià(
+size
+ > 0x17FFFFF)
+243
+size
+ = 0x17FFFFF;
+248
+mp
+ `g_vme_ba£_add»ss
+253
+mp
+ =em°+ (
+size
+ & 0xFFFFF000);
+254
+ `PCI_bus_wre
+Ð&
+UNIVERSE
+VSI0_BD
+mp
+255
+ @console/85c30.c
+17
+ ~<¹ems.h
+18
+ ~<b¥.h
+19
+ ~<¹ems/libio.h
+20
+ ~<as£¹.h
+22
+ ~"85c30.h
+23
+ ~"cÚsÞeb¥.h
+25
+ #STATUS_REGISTER
+ 0x00
+26
+ #DATA_REGISTER
+ 0x08
+28
+ #Z8530_Stus_Is_RX_ch¬aù_avaabË
+Ð
+_¡©us
+29 Ð(
+_¡©us
+è& 0x01 )
+31
+ #Z8530_Stus_Is_TX_bufãr_em±y
+Ð
+_¡©us
+32 Ð(
+_¡©us
+è& 0x04 )
+34
+ #Z8530_Stus_Is_b»ak_abÜt
+Ð
+_¡©us
+35 Ð(
+_¡©us
+è& 0x80 )
+38
+ m»ad_£tup
+39
+ mwre_£tup
+40
+ mmask_v®ue
+41 }
+ tch¬_size_fo
+43 cÚ¡
+ch¬_size_fo
+ gCh¬_size_85c30
+44 {
+Z8530_READ_CHARACTER_BITS_8
+Z8530_WRITE_CHARACTER_BITS_8
+, 0xFF },
+45 {
+Z8530_READ_CHARACTER_BITS_7
+Z8530_WRITE_CHARACTER_BITS_7
+, 0x7F },
+46 {
+Z8530_READ_CHARACTER_BITS_6
+Z8530_WRITE_CHARACTER_BITS_6
+, 0x3F },
+47 {
+Z8530_READ_CHARACTER_BITS_5
+Z8530_WRITE_CHARACTER_BITS_5
+, 0x1F }
+50 cÚ¡
+ gClock_¥d_85c30
+51
+Z8530_x1_CLOCK
+Z8530_x16_CLOCK
+Z8530_x32_CLOCK
+Z8530_x64_CLOCK
+53 cÚ¡
+ gStÝ_b_85c30
+54
+Z8530_STOP_BITS_1
+Z8530_STOP_BITS_1_AND_A_HALF
+Z8530_STOP_BITS_2
+56 cÚ¡
+ gP¬y_85c30
+57
+Z8530_PARITY_NONE
+Z8530_PARITY_ODD
+Z8530_PARITY_EVEN
+65
+ $Rd_85c30_»gi¡
+66 vÞ©*
+c¤
+67
+»gi¡_numb
+70
+D©a
+72 *
+c¤
+»gi¡_numb
+74
+ `¹ems_b¥_day__bus_cyþes
+( 40 );
+76
+D©a
+c¤
+78
+( 40 );
+80
+D©a
+81
+88
+ $Wre_85c30_»gi¡
+89 vÞ©*
+c¤
+90
+»gi¡_numb
+91
+d©a
+94 *
+c¤
+»gi¡_numb
+96
+( 40 );
+97 *
+c¤
+d©a
+98
+( 40 );
+99
+108
+ $Re£t_85c30_ch
+109 vÞ©*
+ù¾_0
+110 vÞ©*
+ù¾_1
+113
+ `Wre_85c30_»gi¡
+Ð
+ù¾_0
+, 0x09, 0x80 );
+114
+ `Wre_85c30_»gi¡
+Ð
+ù¾_1
+, 0x09, 0x40 );
+115
+123
+ $lize_85c30_pÜt
+124 cÚ¡
+PÜt_85C30_fo
+PÜt
+127
+ut16_t
+v®ue
+128 vÞ©*
+ù¾
+129
+CÚsÞe_PrÙocÞ
+Sup
+130
+ut16_t
+baud_cÚ¡ªt
+132
+Sup
+PÜt
+PrÙocÞ
+133
+ù¾
+PÜt
+->ctrl;
+135
+baud_cÚ¡ªt
+ `_ScÜe603e_Z8530_Baud
+Ð
+PÜt
+Ch
+þock_äequcy
+136
+PÜt
+Ch
+þock_x
+Sup
+baud_¿
+142
+v®ue
+Clock_¥d_85c30
+PÜt
+Ch
+þock_¥d
+143
+StÝ_b_85c30
+Sup
+¡Ý_bs
+144
+P¬y_85c30
+Sup
+·ry
+145
+ `Wre_85c30_»gi¡
+Ð
+ù¾
+, 0x04,
+v®ue
+150
+ `Wre_85c30_»gi¡
+Ð
+ù¾
+, 1, 0 );
+152 #ià
+CONSOLE_USE_INTERRUPTS
+156
+ `Wre_85c30_»gi¡
+Ð
+ù¾
+, 2,
+PÜt
+Ch
+veùÜ
+162
+ `Wre_85c30_»gi¡
+Ð
+ù¾
+, 0x03, 0x00 );
+167
+ `Wre_85c30_»gi¡
+Ð
+ù¾
+, 5, 0x00 );
+176
+ `Wre_85c30_»gi¡
+Ð
+ù¾
+, 9, 0x00 );
+181
+ `Wre_85c30_»gi¡
+Ð
+ù¾
+, 0x0a, 0x00 );
+188
+ `Wre_85c30_»gi¡
+Ð
+ù¾
+, 0x0b, 0x56 );
+190
+v®ue
+baud_cÚ¡ªt
+197
+ `Wre_85c30_»gi¡
+Ð
+ù¾
+, 0x0c,
+v®ue
+ & 0xff );
+203
+ `Wre_85c30_»gi¡
+Ð
+ù¾
+, 0x0d,
+v®ue
+>>8 );
+211
+ `Wre_85c30_»gi¡
+Ð
+ù¾
+, 0x0e, 0x07 );
+223
+v®ue
+ = 0x01;
+224
+v®ue
+ = v®u|
+Ch¬_size_85c30
+Sup
+»ad_ch¬_bs
+»ad_£tup
+226
+ `Wre_85c30_»gi¡
+Ð
+ù¾
+, 0x03,
+v®ue
+238
+v®ue
+ = 0x8a;
+239
+v®ue
+ = v®u|
+Ch¬_size_85c30
+Sup
+wre_ch¬_bs
+wre_£tup
+240
+ `Wre_85c30_»gi¡
+Ð
+ù¾
+, 0x05,
+v®ue
+246
+ `Wre_85c30_»gi¡
+Ð
+ù¾
+, 0x00, 0xf0 );
+248 #ià
+252
+ `Wre_85c30_»gi¡
+Ð
+ù¾
+, 1, 0x10 );
+259
+ `Wre_85c30_»gi¡
+Ð
+ù¾
+, 15, 0x00 );
+264
+ `Wre_85c30_»gi¡
+Ð
+ù¾
+, 0x00, 0x10 );
+266 #ià
+274
+ `Wre_85c30_»gi¡
+Ð
+ù¾
+, 1, 0x16 );
+280
+ `Wre_85c30_»gi¡
+Ð
+ù¾
+, 9, 0x0A );
+287
+ `Wre_85c30_»gi¡
+Ð
+PÜt
+ù¾
+STATUS_REGISTER
+, 0x38 );
+291
+300
+ $outby_pÞËd_85c30
+301 vÞ©*
+c¤
+302
+ch
+305
+z8530_¡©us
+306
+ut32_t
+i¤Ëv
+308
+ `¹ems_¼u±_di§bË
+Ð
+i¤Ëv
+314
+z8530_¡©us
+ `Rd_85c30_»gi¡
+Ð
+c¤
+STATUS_REGISTER
+315 } !
+ `Z8530_Stus_Is_TX_bufãr_em±y
+Ð
+z8530_¡©us
+320
+ `Wre_85c30_»gi¡
+Ð
+c¤
+DATA_REGISTER
+, (è
+ch
+322
+ `¹ems_¼u±_abË
+Ð
+i¤Ëv
+323
+332
+ $by_nÚblockg_85c30
+333 cÚ¡
+PÜt_85C30_fo
+PÜt
+336 vÞ©*
+c¤
+337
+z8530_¡©us
+338
+ut8_t
+d©a
+340
+c¤
+PÜt
+ù¾
+345
+z8530_¡©us
+ `Rd_85c30_»gi¡
+Ð
+c¤
+STATUS_REGISTER
+346 iàÐ!
+ `Z8530_Stus_Is_RX_ch¬aù_avaabË
+Ð
+z8530_¡©us
+352
+d©a
+ `Rd_85c30_»gi¡
+Ð
+c¤
+DATA_REGISTER
+353
+d©a
+ &ð
+Ch¬_size_85c30
+PÜt
+PrÙocÞ
+»ad_ch¬_bs
+mask_v®ue
+355
+d©a
+356
+362 #ià
+369
+¹ems_i¤
+ $ISR_85c30_Async
+370 cÚ¡
+PÜt_85C30_fo
+PÜt
+373
+ut16_t
+¡©us
+374 vÞ©
+CÚsÞe_PrÙocÞ
+PrÙocÞ
+375
+d©a
+376
+boÞ
+did_somhg
+çl£
+378
+PrÙocÞ
+PÜt
+->Protocol;
+380
+¡©us
+ `Rd_85c30_»gi¡
+Ð
+PÜt
+ù¾
+, 0x00 );
+386 iàÐ
+Ð
+¡©us
+387
+d©a
+ `Rd_85c30_»gi¡
+Ð
+PÜt
+ù¾
+DATA_REGISTER
+388
+d©a
+ &ð
+Ch¬_size_85c30
+PÜt
+PrÙocÞ
+»ad_ch¬_bs
+mask_v®ue
+390
+ `¹ems_rmios_queue_¿w_ch¬aùs
+Ð
+PÜt
+PrÙocÞ
+cÚsÞe_rmios_d©a
+391 &
+d©a
+, 1 );
+392
+did_somhg
+ue
+399 ià(
+Ð
+¡©us
+400 iàÐ!
+ `Rg_bufãr_Is_em±y
+Ð&
+PrÙocÞ
+TX_Bufãr
+401
+ `Rg_bufãr_Remove_ch¬aù
+Ð&
+PrÙocÞ
+TX_Bufãr
+d©a
+402
+ `Wre_85c30_»gi¡
+Ð
+PÜt
+ù¾
+DATA_REGISTER
+d©a
+405
+PrÙocÞ
+Is_TX_aùive
+çl£
+406
+ `Wre_85c30_»gi¡
+Ð
+PÜt
+ù¾
+STATUS_REGISTER
+, 0x28 );
+409
+did_somhg
+ue
+419
+ `Wre_85c30_»gi¡
+Ð
+PÜt
+ù¾
+STATUS_REGISTER
+, 0x38 );
+420
+ @console/85c30.h
+13 #iâdeà
+__85c30_H
+14
+ #__85c30_H
+20
+ #Z8530_x1_CLOCK
+ 0x00
+21
+ #Z8530_x16_CLOCK
+ 0x40
+22
+ #Z8530_x32_CLOCK
+ 0x80
+23
+ #Z8530_x64_CLOCK
+ 0xC0
+28
+ #Z8530_STOP_BITS_1
+ 0x04
+29
+ #Z8530_STOP_BITS_1_AND_A_HALF
+ 0x08
+30
+ #Z8530_STOP_BITS_2
+ 0x0C
+35
+ #Z8530_PARITY_NONE
+ 0x00
+36
+ #Z8530_PARITY_ODD
+ 0x01
+37
+ #Z8530_PARITY_EVEN
+ 0x03
+42
+ #Z8530_READ_CHARACTER_BITS_8
+ 0xC0
+43
+ #Z8530_READ_CHARACTER_BITS_7
+ 0x40
+44
+ #Z8530_READ_CHARACTER_BITS_6
+ 0x80
+45
+ #Z8530_READ_CHARACTER_BITS_5
+ 0x00
+47
+ #Z8530_WRITE_CHARACTER_BITS_8
+ 0x60
+48
+ #Z8530_WRITE_CHARACTER_BITS_7
+ 0x20
+49
+ #Z8530_WRITE_CHARACTER_BITS_6
+ 0x40
+50
+ #Z8530_WRITE_CHARACTER_BITS_5
+ 0x00
+ @console/console.c
+18
+ ~<b¥.h
+19
+ ~<¹ems/libio.h
+20
+ ~<¡dlib.h
+21
+ ~<as£¹.h
+23
+ ~"cÚsÞeb¥.h
+24
+ ~<¹ems/b¥Io.h
+33
+ #USE_FOR_CONSOLE_DEF
+ 0
+34
+ gUSE_FOR_CONSOLE
+USE_FOR_CONSOLE_DEF
+46
+ $cÚsÞe_by_nÚblockg
+47
+mÜ
+50
+pÜt
+mÜ
+55
+ `as£¹
+pÜt
+NUM_Z85C30_PORTS
+60
+ `by_nÚblockg_85c30
+Ð&
+PÜts_85C30
+pÜt
+61
+63
+¹ems_deviû_driv
+ $cÚsÞe_þo£
+64
+¹ems_deviû_majÜ_numb
+majÜ
+65
+¹ems_deviû_mÜ_numb
+mÜ
+66 *
+¬g
+69
+ `¹ems_rmios_þo£
+¬g
+70
+72
+¹ems_deviû_driv
+ $cÚsÞe_»ad
+73
+majÜ
+74
+¹ems_deviû_mÜ_numb
+mÜ
+75 *
+¬g
+78
+ `¹ems_rmios_»ad
+¬g
+79
+81
+¹ems_deviû_driv
+ $cÚsÞe_wre
+82
+majÜ
+83
+¹ems_deviû_mÜ_numb
+mÜ
+84 *
+¬g
+87
+ `¹ems_rmios_wre
+¬g
+88
+90
+¹ems_deviû_driv
+ $cÚsÞe_cÚÞ
+91
+majÜ
+92
+¹ems_deviû_mÜ_numb
+mÜ
+93 *
+¬g
+96
+ `¹ems_rmios_ioùl
+¬g
+97
+103 #ià
+105
+¹ems_i¤
+ $cÚsÞe_i¤
+106
+¹ems_veùÜ_numb
+veùÜ
+109
+i
+111
+i
+=0; i <
+NUM_Z85C30_PORTS
+; i++){
+112
+ `ISR_85c30_Async
+Ð&
+PÜts_85C30
+i
+114
+116
+ $cÚsÞe_ex
+118
+i
+119 vÞ©
+Rg_bufãr_t
+bufãr
+120
+ut32_t
+ch
+122
+i
+=0 ; i <
+NUM_Z85C30_PORTS
+ ; i++ ) {
+124
+bufãr
+ = &Ð
+PÜts_85C30
+i
+PrÙocÞ
+TX_Bufãr
+126 !
+ `Rg_bufãr_Is_em±y
+Ð
+bufãr
+127
+Ð
+bufãr
+ch
+128
+ `outby_pÞËd_85c30
+Ð
+PÜts_85C30
+i
+ù¾
+ch
+131
+133
+ $cÚsÞe_lize_¼u±s
+135 vÞ©
+Rg_bufãr_t
+bufãr
+136
+CÚsÞe_PrÙocÞ
+´ÙocÞ
+137
+i
+139
+i
+=0 ; i <
+NUM_Z85C30_PORTS
+ ; i++ ) {
+140
+´ÙocÞ
+PÜts_85C30
+i
+PrÙocÞ
+145
+bufãr
+´ÙocÞ
+TX_Bufãr
+146
+ `Rg_bufãr_Inlize
+Ð
+bufãr
+147
+´ÙocÞ
+Is_TX_aùive
+çl£
+153
+i
+=0; i <
+NUM_Z85C30_CHIPS
+; i++)
+154
+ `£t_veùÜ
+Ð
+cÚsÞe_i¤
+Chs_85C30
+i
+veùÜ
+, 1 );
+157
+ `©ex
+Ð
+cÚsÞe_ex
+159
+160
+cÚsÞe_outby_¼u±s
+161 cÚ¡
+PÜt_85C30_fo
+PÜt
+162
+ch
+172
+¹ems_deviû_driv
+ $cÚsÞe_lize
+173
+majÜ
+174
+¹ems_deviû_mÜ_numb
+mÜ
+175 *
+¬g
+178
+¹ems_¡©us_code
+¡©us
+179
+¹ems_deviû_mÜ_numb
+cÚsÞe
+180
+pÜt
+p0
+p1
+185
+ `¹ems_rmios_lize
+190
+cÚsÞe
+USE_FOR_CONSOLE
+191
+¡©us
+ `¹ems_io_»gi¡_Çme
+Ð"/dev/cÚsÞe",
+majÜ
+cÚsÞe
+192 ià(
+¡©us
+ !ð
+RTEMS_SUCCESSFUL
+193
+¡©us
+205 #iàÐ
+INITIALIZE_COM_PORTS
+211
+pÜt
+=0;
Üt<
+NUM_Z85C30_PORTS
ort++){
+212
+p0
+pÜt
+213
+pÜt
+214
+p1
+pÜt
+215
+ `Re£t_85c30_ch
+Ð
+PÜts_85C30
+p0
+ù¾
+, PÜts_85C30[
+p1
+].ctrl );
+221
+pÜt
+=2;
Üt<
+NUM_Z85C30_PORTS
ort++){
+222
+p0
+pÜt
+223
+pÜt
+224
+p1
+pÜt
+225
+ `Re£t_85c30_ch
+Ð
+PÜts_85C30
+p0
+ù¾
+, PÜts_85C30[
+p1
+].ctrl );
+235
+pÜt
+=1;
Üt<
+NUM_Z85C30_PORTS
ort++) {
+236
+ `lize_85c30_pÜt
+Ð&
+PÜts_85C30
+pÜt
+239 #ià
+240
+ `cÚsÞe_lize_¼u±s
+243
+RTEMS_SUCCESSFUL
+244
+252
+ssize_t
+ $cÚsÞe_wre_suµÜt
+253
+mÜ
+254 cÚ¡ *
+buf
+255
+size_t
+Ën
+257
+nwre
+ = 0;
+258 vÞ©
+ut8_t
+c¤
+259
+pÜt
+mÜ
+264
+ `as£¹
+pÜt
+NUM_Z85C30_PORTS
+269
+c¤
+PÜts_85C30
+pÜt
+ù¾
+274
+nwre
+Ën
+275 #ià(
+276
+ `cÚsÞe_outby_¼u±s
+Ð&
+PÜts_85C30
+pÜt
+buf
+278
+ `outby_pÞËd_85c30
+Ð
+c¤
+buf
+280
+nwre
+286
+nwre
+287
+294
+¹ems_deviû_driv
+ $cÚsÞe_Ý
+295
+majÜ
+296
+¹ems_deviû_mÜ_numb
+mÜ
+297 *
+¬g
+300
+¹ems_¡©us_code
+sc
+301
+pÜt
+mÜ
+302 #ià(
+303
+¹ems_libio_Ý_þo£_¬gs_t
+¬gs
+¬g
+304 cÚ¡
+¹ems_rmios_ÿÎbacks
+C®lbacks
+305
+NULL
+306
+NULL
+307
+NULL
+308
+cÚsÞe_wre_suµÜt
+309
+NULL
+310
+NULL
+311
+NULL
+315 cÚ¡
+¹ems_rmios_ÿÎbacks
+pÞlC®lbacks
+316
+NULL
+317
+NULL
+318
+cÚsÞe_by_nÚblockg
+319
+cÚsÞe_wre_suµÜt
+320
+NULL
+321
+NULL
+322
+NULL
+330 ià(
+mÜ
+ < 0)
+331
+RTEMS_INVALID_NUMBER
+333 iàÐ
+pÜt
+NUM_Z85C30_PORTS
+334
+340 #ià(
+341
+sc
+ `¹ems_rmios_Ý
+Ð
+majÜ
+mÜ
+¬g
+C®lbacks
+343
+PÜts_85C30
+mÜ
+PrÙocÞ
+cÚsÞe_rmios_d©a
+¬gs
+iÝ
+d©a1
+345
+sc
+ `¹ems_rmios_Ý
+Ð
+majÜ
+mÜ
+¬g
+pÞlC®lbacks
+348
+sc
+349
+351 #ià(
+357
+ $cÚsÞe_outby_¼u±s
+358 cÚ¡
+PÜt_85C30_fo
+PÜt
+359
+ch
+362
+CÚsÞe_PrÙocÞ
+´ÙocÞ
+363
+ut32_t
+i¤Ëv
+365
+´ÙocÞ
+PÜt
+PrÙocÞ
+371 iàÐ
+´ÙocÞ
+Is_TX_aùive
+ =ð
+çl£
+373
+ `¹ems_¼u±_di§bË
+Ð
+i¤Ëv
+374
+´ÙocÞ
+Is_TX_aùive
+ue
+375
+ `outby_pÞËd_85c30
+Ð
+PÜt
+ù¾
+ch
+376
+ `¹ems_¼u±_abË
+Ð
+i¤Ëv
+381
+ `Rg_bufãr_Is_fuÎ
+Ð&
+´ÙocÞ
+TX_Bufãr
+383
+ `Rg_bufãr_Add_ch¬aù
+Ð&
+´ÙocÞ
+TX_Bufãr
+ch
+384
+388
+ $debug_putc_Úlü
+(cÚ¡
+c
+390
+cÚsÞe
+391 vÞ©
+ut8_t
+c¤
+392
+ut32_t
+i¤Ëv
+394
+cÚsÞe
+USE_FOR_CONSOLE
+395
+c¤
+PÜts_85C30
+cÚsÞe
+ù¾
+397 ià('\n'==
+c
+398
+ `¹ems_¼u±_di§bË
+Ð
+i¤Ëv
+399
+ `outby_pÞËd_85c30
+Ð
+c¤
+, '\r' );
+400
+__asm__
+ volatile("isync");
+401
+ `¹ems_¼u±_abË
+Ð
+i¤Ëv
+404
+ `¹ems_¼u±_di§bË
+Ð
+i¤Ëv
+405
+ `outby_pÞËd_85c30
+Ð
+c¤
+c
+406
+__asm__
+407
+ `¹ems_¼u±_abË
+Ð
+i¤Ëv
+408
+410
+BSP_ouut_ch¬_funùiÚ_ty³
+ gBSP_ouut_ch¬
+debug_putc_Úlü
+411
+BSP_pÞlg_gch¬_funùiÚ_ty³
+ gBSP_pÞl_ch¬
+NULL
+ @console/consolebsp.h
+13 #iâdeà
+__CONSOLEBSP_H
+14
+ #__CONSOLEBSP_H
+16
+ ~<¹ems.h
+17
+ ~<¹ems/rgbuf.h
+18
+ ~<b¥.h
+20 #ifdeà
+__ýlu¥lus
+35 #ià(
+HAS_PMC_PSC8
+36
+ #NUM_Z85C30_CHIPS_ON_MEZZANINE
+ 4
+38
+ 0
+41
+ #NUM_Z85C30_CHIPS
+ (2 +
+NUM_Z85C30_CHIPS_ON_MEZZANINE
+42
+ #NUM_Z85C30_PORTS
+NUM_Z85C30_CHIPS
+ * 2)
+45
+CONSOLE_x1_CLOCK
+46
+CONSOLE_x16_CLOCK
+47
+CONSOLE_x32_CLOCK
+48
+CONSOLE_x64_CLOCK
+49 }
+ tCONSOLE_Clock_¥d
+52
+CONSOLE_STOP_BITS_1
+53
+CONSOLE_STOP_BITS_1_AND_A_HALF
+54
+CONSOLE_STOP_BITS_2
+55 }
+ tCONSOLE_StÝ_bs
+58
+CONSOLE_PARITY_NONE
+59
+CONSOLE_PARITY_ODD
+60
+CONSOLE_PARITY_EVEN
+61 }
+ tCONSOLE_P¬y
+64
+CONSOLE_CHARACTER_BITS_8
+65
+CONSOLE_CHARACTER_BITS_7
+66
+CONSOLE_CHARACTER_BITS_6
+67
+CONSOLE_CHARACTER_BITS_5
+68 }
+ tCONSOLE_Ch¬aù_bs
+71
+ut32_t
+baud_¿
+72
+CONSOLE_StÝ_bs
+¡Ý_bs
+73
+CONSOLE_P¬y
+·ry
+74
+CONSOLE_Ch¬aù_bs
+»ad_ch¬_bs
+75
+CONSOLE_Ch¬aù_bs
+wre_ch¬_bs
+77 #ià
+78 vÞ©
+Rg_bufãr_t
+TX_Bufãr
+79 vÞ©
+boÞ
+Is_TX_aùive
+80 *
+cÚsÞe_rmios_d©a
+83 }
+ tCÚsÞe_PrÙocÞ
+89
+ut32_t
+veùÜ
+90
+ut32_t
+þock_äequcy
+91
+ut16_t
+þock_x
+92
+CONSOLE_Clock_¥d
+þock_¥d
+93 }
+ tCh_85C30_fo
+100 vÞ©*
+ù¾
+101 vÞ©*
+d©a
+103
+pÜt
+105
+CÚsÞe_PrÙocÞ
+PrÙocÞ
+106
+Ch_85C30_fo
+Ch
+108 }
+ tPÜt_85C30_fo
+113
+Ch_85C30_fo
+Chs_85C30
+NUM_Z85C30_CHIPS
+114
cÚ¡
+PÜt_85C30_fo
+PÜts_85C30
+NUM_Z85C30_PORTS
+119
+lize_85c30_pÜt
+120 cÚ¡
+PÜt_85C30_fo
+PÜt
+123
+outby_pÞËd_85c30
+124 vÞ©*
+c¤
+125
+ch
+128
+by_nÚblockg_85c30
+129 cÚ¡
+PÜt_85C30_fo
+PÜt
+132
+Re£t_85c30_ch
+133 vÞ©*
+ù¾_0
+134 vÞ©*
+ù¾_1
+137 #ià
+138
+¹ems_i¤
+ISR_85c30_Async
+139 cÚ¡
+PÜt_85C30_fo
+PÜt
+142 #ifdeà
+__ýlu¥lus
+ @console/tbl85c30.c
+13
+ ~"cÚsÞeb¥.h
+14
+ ~<b¥.h
+15
+ ~<b¥/q.h
+17
+ #CONSOLE_DEFAULT_BAUD_RATE
+ 9600
+18
+ #CONSOLE_DEFAULT_BAUD_CONSTANT
+ `ScÜe603e_Z8530_Ch0_Baud
+(9600)
+20
+ #CONSOLE_DEFAULT_STOP_BITS
+21
+ #CONSOLE_DEFAULT_PARITY
+22
+ #CONSOLE_DEFAULT_READ_CHARACTER_BITS
+23
+ #CONSOLE_DEFAULT_WRITE_CHARACTER_BITS
+24
+ #CONSOLE_DEFAULT_CONSOLE_CLOCK
+CONSOLE_x16_CLOCK
+26
+ #DEFAULT_PROTOCOL
+CONSOLE_DEFAULT_BAUD_RATE
+27
+CONSOLE_DEFAULT_STOP_BITS
+28
+CONSOLE_DEFAULT_PARITY
+29
+CONSOLE_DEFAULT_READ_CHARACTER_BITS
+30
+CONSOLE_DEFAULT_WRITE_CHARACTER_BITS
+35
+CÚsÞe_PrÙocÞ
+ gPrÙocÞs_85c30
+NUM_Z85C30_PORTS
+37
+DEFAULT_PROTOCOL
+38
+DEFAULT_PROTOCOL
+39
+DEFAULT_PROTOCOL
+40
+DEFAULT_PROTOCOL
+42 #ià(
+HAS_PMC_PSC8
+43
+DEFAULT_PROTOCOL
+44
+DEFAULT_PROTOCOL
+45
+DEFAULT_PROTOCOL
+46
+DEFAULT_PROTOCOL
+47
+DEFAULT_PROTOCOL
+48
+DEFAULT_PROTOCOL
+49
+DEFAULT_PROTOCOL
+50
+DEFAULT_PROTOCOL
+58
+Ch_85C30_fo
+ gChs_85C30
+NUM_Z85C30_CHIPS
+61
+SCORE603E_85C30_0_IRQ
+62
+SCORE603E_85C30_0_CLOCK
+63
+SCORE603E_85C30_0_CLOCK_X
+64
+CONSOLE_DEFAULT_CONSOLE_CLOCK
+67
+SCORE603E_85C30_1_IRQ
+68
+SCORE603E_85C30_1_CLOCK
+69
+SCORE603E_85C30_1_CLOCK_X
+70
+73 #ià(
+HAS_PMC_PSC8
+75
+SCORE603E_85C30_2_IRQ
+76
+SCORE603E_85C30_2_CLOCK
+77
+SCORE603E_85C30_2_CLOCK_X
+78
+81
+SCORE603E_85C30_3_IRQ
+82
+SCORE603E_85C30_3_CLOCK
+83
+SCORE603E_85C30_3_CLOCK_X
+84
+87
+SCORE603E_85C30_4_IRQ
+88
+SCORE603E_85C30_4_CLOCK
+89
+SCORE603E_85C30_4_CLOCK_X
+90
+93
+SCORE603E_85C30_5_IRQ
+94
+SCORE603E_85C30_5_CLOCK
+95
+SCORE603E_85C30_5_CLOCK_X
+96
+106 cÚ¡
+PÜt_85C30_fo
+ gPÜts_85C30
+NUM_Z85C30_PORTS
+108 (vÞ©*è
+SCORE603E_85C30_CTRL_0
+109 (vÞ©*è
+SCORE603E_85C30_DATA_0
+111 &
+PrÙocÞs_85c30
+[0],
+112 &
+Chs_85C30
+[0],
+115 (vÞ©*è
+SCORE603E_85C30_CTRL_1
+116 (vÞ©*è
+SCORE603E_85C30_DATA_1
+118 &
+PrÙocÞs_85c30
+[1],
+119 &
+Chs_85C30
+[0],
+122 (vÞ©*è
+SCORE603E_85C30_CTRL_2
+123 (vÞ©*è
+SCORE603E_85C30_DATA_2
+125 &
+PrÙocÞs_85c30
+[2],
+126 &
+Chs_85C30
+[1],
+129 (vÞ©*è
+SCORE603E_85C30_CTRL_3
+130 (vÞ©*è
+SCORE603E_85C30_DATA_3
+132 &
+PrÙocÞs_85c30
+[3],
+133 &
+Chs_85C30
+[1],
+136 #ià(
+HAS_PMC_PSC8
+138 (vÞ©*è
+SCORE603E_85C30_CTRL_4
+139 (vÞ©*è
+SCORE603E_85C30_DATA_4
+141 &
+PrÙocÞs_85c30
+[4],
+142 &
+Chs_85C30
+[2],
+145 (vÞ©*è
+SCORE603E_85C30_CTRL_5
+146 (vÞ©*è
+SCORE603E_85C30_DATA_5
+148 &
+PrÙocÞs_85c30
+[5],
+149 &
+Chs_85C30
+[2],
+152 (vÞ©*è
+SCORE603E_85C30_CTRL_6
+153 (vÞ©*è
+SCORE603E_85C30_DATA_6
+155 &
+PrÙocÞs_85c30
+[6],
+156 &
+Chs_85C30
+[3],
+159 (vÞ©*è
+SCORE603E_85C30_CTRL_7
+160 (vÞ©*è
+SCORE603E_85C30_DATA_7
+162 &
+PrÙocÞs_85c30
+[7],
+163 &
+Chs_85C30
+[3],
+166 (vÞ©*è
+SCORE603E_85C30_CTRL_8
+167 (vÞ©*è
+SCORE603E_85C30_DATA_8
+169 &
+PrÙocÞs_85c30
+[8],
+170 &
+Chs_85C30
+[4],
+173 (vÞ©*è
+SCORE603E_85C30_CTRL_9
+174 (vÞ©*è
+SCORE603E_85C30_DATA_9
+176 &
+PrÙocÞs_85c30
+[9],
+177 &
+Chs_85C30
+[4],
+180 (vÞ©*è
+SCORE603E_85C30_CTRL_10
+181 (vÞ©*è
+SCORE603E_85C30_DATA_10
+183 &
+PrÙocÞs_85c30
+[10],
+184 &
+Chs_85C30
+[5],
+187 (vÞ©*è
+SCORE603E_85C30_CTRL_11
+188 (vÞ©*è
+SCORE603E_85C30_DATA_11
+190 &
+PrÙocÞs_85c30
+[11],
+191 &
+Chs_85C30
+[5],
+ @include/bsp.h
+14 #iâdeà
+_BSP_H
+15
+ #_BSP_H
+17 #ifdeà
+__ýlu¥lus
+21
+ #BSP_ZERO_WORKSPACE_AUTOMATICALLY
+TRUE
+23
+ ~<b¥Ýts.h
+24
+ ~<b¥/deçuÉ-l-exnsiÚ.h
+25
+ ~<¹ems.h
+26
+ ~<¹ems/cÚsÞe.h
+27
+ ~<libýu/io.h
+28
+ ~<¹ems/þockdrv.h
+29
+ ~<b¥/veùÜs.h
+31 #ifdeà
+ASM
+33
+ #ALIGN_REGS
+ 0x0140
+36
+ ~<¹ems.h
+37
+ ~<¹ems/cÚsÞe.h
+38
+ ~<¹ems/þockdrv.h
+39
+ ~<¹ems/iosuµ.h
+45
+ ~<g2.h
+46
+ ~<b¥/q.h
+54
+ #_ScÜe603e_Z8530_Baud
+Ð
+_äequcy
+_þock_by
+_baud_¿
+55 Ð(
+_äequcy
+ /Ð
+_þock_by
+ * 2 *
+_baud_¿
+)è- 2)
+57
+ #ScÜe603e_Z8530_Ch1_Baud
+Ð
+_v®ue
+58
+Ð
+59
+_v®ue
+61
+ #ScÜe603e_Z8530_Ch0_Baud
+Ð
+_v®ue
+62
+Ð
+63
+_v®ue
+65
+ #Inlize_Bßrd_ù¾_»gi¡
+66 *
+ = (*SCORE603E_BOARD_CTRL_REG | \
+67
+69
+ #ProûssÜ_SynchrÚize
+70
+__asm__
+ vÞ©e("iØ")
+91
+RAM_START
+92
+RAM_END
+93
+RAM_SIZE
+95
+PROM_START
+96
+PROM_END
+97
+PROM_SIZE
+99
+CLOCK_SPEED
+100
+CPU_PPC_CLICKS_PER_MS
+102
+d
+107
+d
+108
+RAM_END
+109
+ut32_t
+BSP_mem_size
+116
+ #BSP_LIBIO_MAX_FDS
+ 20
+123
+¹ems_i¤_y
+£t_EE_veùÜ
+124
+¹ems_i¤_y
+hªdËr
+125
+¹ems_veùÜ_numb
+veùÜ
+127
+lize_exº®_exû±iÚ_veùÜ
+132
+_PCI
+133
+_RTC
+134
+¡ruùiÚ_ÿche_abË
+135
+d©a_ÿche_abË
+137
+lize_PCI_bridge
+138
+ut16_t
+»ad_ªd_þr_q
+139
+£t_q_mask
+ut16_t
+v®ue
+140
+ut16_t
+g_q_mask
+145
+lize_univ£
+146
+£t_q_mask
+ut16_t
+v®ue
+147
+ut16_t
+g_q_mask
+148
+unmask_q
+ut16_t
+q_idx
+149
+mask_q
+ut16_t
+q_idx
+150
+_q_d©a_»gi¡
+151
+ut16_t
+»ad_ªd_þr_PMC_q
+(ut16_
+q
+152
+boÞ
+Is_PMC_IRQ
+Ð
+ut32_t
+pmc_q
+ut16_t
+¡©us_wÜd
+153
+ut16_t
+»ad_ªd_þr_q
+154
+£t_vme_ba£_add»ss
+ut32_t
+ba£_add»ss
+155
+ut32_t
+g_vme_¦ave_size
+156
+£t_vme_¦ave_size
+ut32_t
+size
+161
+lize_PCI_bridge
+162
+_q_d©a_»gi¡
+163
+ut32_t
+Rd_pci_deviû_»gi¡
+(ut32_
+add»ss
+164
+Wre_pci_deviû_»gi¡
+ut32_t
+add»ss
+, ut32_
+d©a
+167
+SCORE603e_FLASH_Di§bË
+ut32_t
+unu£d
+168
+SCORE603e_FLASH_vify_abË
+169
+SCORE603e_FLASH_EÇbË_wres
+ut32_t
+174
+ut32_t
+PCI_bus_»ad
+(vÞ©ut32_*
+_addr
+175
+PCI_bus_wre
+(vÞ©
+ut32_t
+_addr
+, ut32_
+_d©a
+177
+ #BSP_FLASH_ENABLE_WRITES
+Ð
+_¬
+è
+ `SCORE603e_FLASH_EÇbË_wres
+Ð_¬ )
+178
+ #BSP_FLASH_DISABLE_WRITES
+_¬
+è
+ `SCORE603e_FLASH_Di§bË
+Ð_¬ )
+180
+ #CÚvt_Endn_32
+Ð
+_d©a
+181 Ð((
+_d©a
+&0x000000ff)<<24) | ((_data&0x0000ff00)<<8) | \
+182 ((
+_d©a
+&0x00ff0000)>>8è| ((_d©a&0xff000000)>>24è)
+184
+ #CÚvt_Endn_16
+Ð
+_d©a
+185 Ð((
+_d©a
+&0x00ff)<<8è| ((_d©a&0xff00)>>8è)
+190
+BSP_discÚÃù_þock_hªdËr
+191
+BSP_cÚÃù_þock_hªdËr
+195 #ifdeà
+__ýlu¥lus
+ @include/gen2.h
+13 #iâdeà
+__SCORE_GENERATION_2_h
+14
+ #__SCORE_GENERATION_2_h
+16 #ifdeà
+__ýlu¥lus
+20
+ ~<¹ems.h
+25
+ #SCORE603E_VME_JUMPER_ADDR
+ 0x00e20000
+26
+ #BSP_FLASH_BASE
+ 0x04000000
+27
+ #SCORE603E_ISA_PCI_IO_BASE
+ 0x80000000
+28
+ #SCORE603E_TIMER_PORT_C
+ 0xfd000000
+29
+ #SCORE603E_TIMER_INT_ACK
+ 0xfd000000
+30
+ #SCORE603E_TIMER_PORT_B
+ 0xfd000008
+31
+ #SCORE603E_TIMER_PORT_A
+ 0xfd000004
+33
+ #SCORE603E_BOARD_CTRL_REG
+ ((vÞ©
+ut8_t
+*)0xfd00002c)
+34
+ #SCORE603E_BRD_FLASH_DISABLE_MASK
+ 0x40
+36
+ #SCORE603E_85C30_CTRL_0
+ ((vÞ©
+ut8_t
+*)0xã200020)
+37
+ #SCORE603E_85C30_DATA_0
+ ((vÞ©
+ut8_t
+*)0xã200024)
+38
+ #SCORE603E_85C30_CTRL_1
+ ((vÞ©
+ut8_t
+*)0xã200028)
+39
+ #SCORE603E_85C30_DATA_1
+ ((vÞ©
+ut8_t
+*)0xã20002c)
+40
+ #SCORE603E_85C30_CTRL_2
+ ((vÞ©
+ut8_t
+*)0xã200000)
+41
+ #SCORE603E_85C30_DATA_2
+ ((vÞ©
+ut8_t
+*)0xã200004)
+42
+ #SCORE603E_85C30_CTRL_3
+ ((vÞ©
+ut8_t
+*)0xã200008)
+43
+ #SCORE603E_85C30_DATA_3
+ ((vÞ©
+ut8_t
+*)0xã20000c)
+49
+ #PCI_DRAM_OFFSET
+PREP_PCI_DRAM_OFFSET
+50
+ #BSP_PCI_CONFIGURATION_BASE
+ 0x80800000
+51
+ #BSP_PMC_BASE
+BSP_PCI_CONFIGURATION_BASE
+52
+ #PCI_MEM_BASE_ADJUSTMENT
+ 0
+53
+ #BSP_PCI_PMC_DEVICE_BASE
+ 0x80808000
+54
+ #BSP_PCI_REGISTER_BASE
+ 0xfc000000
+56
+ #BSP_PCI_DEVICE_ADDRESS
+Ð
+_off£t
+57 ((vÞ©
+ut32_t
+ *)Ð
+BSP_PCI_PMC_DEVICE_BASE
+_off£t
+60
+ #BSP_PMC_SERIAL_ADDRESS
+Ð
+_off£t
+61 ((vÞ©
+ut8_t
+BSP_PCI_REGISTER_BASE
+_off£t
+66
+ #SCORE603E_85C30_CTRL_4
+ `BSP_PMC_SERIAL_ADDRESS
+(0x00200020)
+67
+ #SCORE603E_85C30_DATA_4
+(0x00200024)
+68
+ #SCORE603E_85C30_CTRL_5
+(0x00200028)
+69
+ #SCORE603E_85C30_DATA_5
+(0x0020002c)
+70
+ #SCORE603E_85C30_CTRL_6
+(0x00200030)
+71
+ #SCORE603E_85C30_DATA_6
+(0x00200034)
+72
+ #SCORE603E_85C30_CTRL_7
+(0x00200038)
+73
+ #SCORE603E_85C30_DATA_7
+(0x0020003c)
+74
+ #SCORE603E_85C30_CTRL_8
+(0x00200000)
+75
+ #SCORE603E_85C30_DATA_8
+(0x00200004)
+76
+ #SCORE603E_85C30_CTRL_9
+(0x00200008)
+77
+ #SCORE603E_85C30_DATA_9
+(0x0020000c)
+78
+ #SCORE603E_85C30_CTRL_10
+(0x00200010)
+79
+ #SCORE603E_85C30_DATA_10
+(0x00200014)
+80
+ #SCORE603E_85C30_CTRL_11
+(0x00200018)
+81
+ #SCORE603E_85C30_DATA_11
+(0x0020001c)
+83
+ #_IO_BASE
+PREP_ISA_IO_BASE
+84
+ #SCORE603E_PCI_IO_CFG_ADDR
+ 0x80000cf8
+85
+ #SCORE603E_PCI_IO_CFG_DATA
+ 0x80000cfc
+87
+ #SCORE603E_UNIVERSE_BASE
+ 0x80030000
+88
+ #SCORE603E_IO_VME_UNIVERSE_BASE
+ 0x80007000
+89
+ #PCI_MEM_BASE
+ 0xc0000000
+90
+ #BSP_PCI_MEM_BASE
+PCI_MEM_BASE
+91
+ #BSP_NVRAM_BASE
+ 0xfd100000
+92
+ #BSP_RTC_ADDRESS
+ ((vÞ©*)0xfd180000)
+93
+ #SCORE603E_JP1_JP2_PROM_BASE
+ 0xfff00000
+94
+ #SCORE603E_NOT_JP1_2_FLASH_BASE
+ 0xff800000
+96 #ià(
+SCORE603E_USE_SDS
+è| (
+SCORE603E_USE_OPEN_FIRMWARE
+è| (
+SCORE603E_USE_NONE
+97
+ #SCORE603E_VME_A16_OFFSET
+ 0x04000000
+98 #ià(
+SCORE603E_USE_DINK
+99
+ 0x11000000
+100
+ #SCORE603E_VME_A24_OFFSET
+ 0x10000000
+101
+ #BSP_VME_A24_BASE
+BSP_PCI_MEM_BASE
+SCORE603E_VME_A24_OFFSET
+106
+ #BSP_VME_A16_BASE
+BSP_PCI_MEM_BASE
+SCORE603E_VME_A16_OFFSET
+114
+ #ICM1770_CRYSTAL_FREQ_32K
+ 0x00
+115
+ #ICM1770_CRYSTAL_FREQ_1M
+ 0x01
+116
+ #ICM1770_CRYSTAL_FREQ_2M
+ 0x02
+117
+ #ICM1770_CRYSTAL_FREQ_4M
+ 0x03
+119
+ #BSP_RTC_FREQUENCY
+ICM1770_CRYSTAL_FREQ_32K
+124
+ #SCORE603E_85C30_0_CLOCK
+ 14745600
+125
+ #SCORE603E_85C30_0_CLOCK_X
+ 16
+130
+ #SCORE603E_85C30_1_CLOCK
+ 16000000
+131
+ #SCORE603E_85C30_1_CLOCK_X
+ 16
+136
+ #SCORE603E_85C30_PMC_CLOCK
+ 16000000
+137
+ #SCORE603E_85C30_PMC_CLOCK_X
+ 16
+139
+ #SCORE603E_85C30_2_CLOCK
+SCORE603E_85C30_PMC_CLOCK
+140
+ #SCORE603E_85C30_3_CLOCK
+141
+ #SCORE603E_85C30_4_CLOCK
+142
+ #SCORE603E_85C30_5_CLOCK
+143
+ #SCORE603E_85C30_2_CLOCK_X
+SCORE603E_85C30_PMC_CLOCK_X
+144
+ #SCORE603E_85C30_3_CLOCK_X
+145
+ #SCORE603E_85C30_4_CLOCK_X
+146
+ #SCORE603E_85C30_5_CLOCK_X
+148
+ #SCORE603E_UNIVERSE_CHIP_ID
+ 0x000010E3
+153
+ #SCORE603E_FPGA_VECT_DATA
+ ((vÞ©
+ut16_t
+*)0xfd000040)
+154
+ #SCORE603E_FPGA_BIT1_15_0
+ ((vÞ©
+ut16_t
+*)0xfd000044)
+155
+ #SCORE603E_FPGA_MASK_DATA
+ ((vÞ©
+ut16_t
+*)0xfd000048)
+156
+ #SCORE603E_FPGA_IRQ_INPUT
+ ((vÞ©
+ut16_t
+*)0xfd00004c)
+161
+ #BSP_PMC_STATUS_ADDRESS
+ (0))
+162
+ #Is_PMC_85C30_4_IRQ
+Ð
+_¡©us
+ ) (_¡©u & 0x80è
+163
+ #Is_PMC_85C30_2_IRQ
+Ð
+_¡©us
+ ) (_¡©u & 0x40è
+164
+ #Is_PMC_85C30_5_IRQ
+Ð
+_¡©us
+ ) (_¡©u & 0x20è
+165
+ #Is_PMC_85C30_3_IRQ
+Ð
+_¡©us
+ ) (_¡©u & 0x08è
+167
+ #SCORE603E_PMC_CONTROL_ADDRESS
+(0x100000)
+168
+ #SCORE603E_PMC_SCC_232_LOOPBACK
+_wÜd
+è(_wÜd|0x20)
+170
+ #PMC_SET_232_LOOPBACK
+_wÜd
+è(_wÜd | 0x02)
+171
+ #PMC_CLEAR_232_LOOPBACK
+_wÜd
+è(_wÜd & 0xfd)
+172
+ #PMC_SET_422_LOOPBACK
+_wÜd
+è(_wÜd | 0x01)
+173
+ #PMC_CLEAR_422_LOOPBACK
+_wÜd
+è(_wÜd & 0xã)
+185
+ #BSP_TIMER_AVG_OVERHEAD
+ 4
+187
+ #BSP_TIMER_LEAST_VALID
+ 1
+201
+ #BSP_CÚvt_deüemr
+Ð
+_v®ue
+202 (è(((
+_v®ue
+è* 4000è/ 6667)
+204 #ifdeà
+__ýlu¥lus
+ @include/tm27.h
+16 #iâdeà
+_RTEMS_TMTEST27
+20 #iâdeà
+__tm27_h
+21
+ #__tm27_h
+23
+ ~<b¥/q.h
+29
+ #MUST_WAIT_FOR_INTERRUPT
+ 1
+31
+ $nuÎFunc
+(è{
+33
+¹ems_q_cÚÃù_d©a
+ gþockIrqD©a
+BSP_DECREMENTER
+35 (
+¹ems_q_abË
+nuÎFunc
+36 (
+¹ems_q_di§bË
+nuÎFunc
+37 (
+¹ems_q_is_abËd
+è
+nuÎFunc
+38
+In¡®l_tm27_veùÜ
+_hªdËr
+40
+þockIrqD©a
+hdl
+_hªdËr
+41 ià(!
+ `BSP_¡®l_¹ems_q_hªdËr
+þockIrqD©a
+42
+ `´tk
+("Error installing clock interrupt handler!\n");
+43
+(1);
+45
+47
+ #Cau£_tm27_
+49
+ut32_t
+_þicks
+ = 8; \
+50
+__asm__
+ vÞ©eÐ"mtdeø%0" : "ô" ((
+_þicks
+)) : "r" ((_clicks)) ); \
+51 } 0)
+53
+ #Cˬ_tm27_
+55
+ut32_t
+_þicks
+ = 0xffffffff; \
+56
+__asm__
+_þicks
+57 } 0)
+59
+ #Low_tm27_
+61
+ut32_t
+_m¤
+ = 0; \
+62
+ `_ISR_S_Ëv
+( 0 ); \
+63
+__asm__
+ vÞ©eÐ"mfm¤ %0 ;" : "ô" (
+_m¤
+) : "r" (_msr) ); \
+64
+_m¤
+ |= 0x8002; \
+65
+__asm__
+ vÞ©eÐ"mtm¤ %0 ;" : "ô" (
+_m¤
+66 } 0)
+ @irq/FPGA.c
+14
+ ~<b¥.h
+15
+ ~<b¥/q.h
+16
+ ~<¡rg.h
+17
+ ~<fú.h
+18
+ ~<as£¹.h
+20
+ ~<¹ems/libio.h
+21
+ ~<¹ems/libcsuµÜt.h
+22
+ ~<¹ems/b¥Io.h
+27
+ $lize_PCI_bridge
+32
+34
+ $£t_q_mask
+35
+ut16_t
+v®ue
+38 vÞ©
+ut16_t
+loc
+40
+loc
+ut16_t
+SCORE603E_FPGA_MASK_DATA
+42 *
+loc
+v®ue
+43
+45
+ut16_t
+ $g_q_mask
+47 vÞ©
+ut16_t
+loc
+48
+ut16_t
+v®ue
+50
+loc
+ut16_t
+52
+v®ue
+loc
+54
+v®ue
+55
+57
+ $mask_q
+58
+ut16_t
+q_idx
+61
+ut16_t
+v®ue
+62
+ut32_t
+mask_idx
+q_idx
+64
+v®ue
+ `g_q_mask
+66 #ià(
+HAS_PMC_PSC8
+67
+q_idx
+ScÜe_IRQ_F¡
+68
+69
+70
+71
+72
+mask_idx
+SCORE603E_PCI_IRQ_0
+ScÜe_IRQ_F¡
+79
+v®ue
+ |ð(0x1 <<
+mask_idx
+80
+ `£t_q_mask
+Ð
+v®ue
+81
+83
+ $unmask_q
+84
+ut16_t
+q_idx
+87
+ut16_t
+v®ue
+88
+ut32_t
+mask_idx
+q_idx
+90
+v®ue
+ `g_q_mask
+92 #ià(
+HAS_PMC_PSC8
+93
+q_idx
+ScÜe_IRQ_F¡
+94
+95
+96
+97
+98
+mask_idx
+ScÜe_IRQ_F¡
+105
+v®ue
+ &ð(~(0x1 <<
+mask_idx
+106
+ `£t_q_mask
+Ð
+v®ue
+107
+109
+ $_q_d©a_»gi¡
+111
+ut32_t
+dex
+112
+ut32_t
+i
+114
+ `£t_q_mask
+( 0xffff );
+119
+i
+=0; i<20; i++) {
+120
+dex
+SCORE603E_FPGA_VECT_DATA
+121 iàÐ(
+dex
+&0x10) != 0x10 )
+124
+126
+ut16_t
+ $»ad_ªd_þr_PMC_q
+127
+ut16_t
+q
+130
+ut16_t
+¡©us_wÜd
+q
+132
+¡©us_wÜd
+BSP_PMC_STATUS_ADDRESS
+134
+¡©us_wÜd
+135
+137
+boÞ
+ $Is_PMC_IRQ
+138
+ut32_t
+pmc_q
+139
+ut16_t
+¡©us_wÜd
+142
+boÞ
+»suÉ
+çl£
+144
+pmc_q
+145
+146
+»suÉ
+ `Is_PMC_85C30_4_IRQ
+Ð
+¡©us_wÜd
+ue
+çl£
+148
+149
+»suÉ
+ `Is_PMC_85C30_2_IRQ
+Ð
+¡©us_wÜd
+ue
+çl£
+151
+152
+»suÉ
+ `Is_PMC_85C30_5_IRQ
+Ð
+¡©us_wÜd
+ue
+çl£
+154
+155
+»suÉ
+ `Is_PMC_85C30_3_IRQ
+Ð
+¡©us_wÜd
+ue
+çl£
+158
+ `as£¹
+( 0 );
+162
+»suÉ
+163
+165
+ut16_t
+ $»ad_ªd_þr_q
+167
+ut16_t
+q
+170
+q
+171
+ `ProûssÜ_SynchrÚize
+172 ià((
+q
+ & 0xffff0) != 0x10) {
+173
+ `´tk
+Ð"»ad_ªd_þr_q:: ERROR==>nØq d©¨0x%x\n",
+q
+174 (
+q
+ | 0x80);
+177
+q
+ &=0xf;
+178
+q
+ +ð
+ScÜe_IRQ_F¡
+179
+q
+180
+ @irq/irq.c
+11
+ ~<¡dlib.h
+13
+ ~<b¥.h
+14
+ ~<b¥/q.h
+15
+ ~<b¥/VME.h
+16
+ ~<¹ems/scÜe/xt.h
+17
+ ~<libýu/io.h
+18
+ ~<b¥/veùÜs.h
+19
+ ~<¡dlib.h
+20
+ ~<¹ems/b¥Io.h
+25
+¹ems_q_cÚÃù_d©a
+ gdeçuÉ_¹ems_y
+31
+¹ems_q_glob®_£gs
+ gº®_cÚfig
+32
+¹ems_q_cÚÃù_d©a
+ g¹ems_hdl_tbl
+37
+le
+ $is_i§_q
+(cÚ¡
+¹ems_q_numb
+qLe
+39 (((è
+qLe
+ <ð
+BSP_ISA_IRQ_MAX_OFFSET
+40 ((è
+qLe
+ >ð
+BSP_ISA_IRQ_LOWEST_OFFSET
+42
+47
+le
+ $is_pci_q
+(cÚ¡
+¹ems_q_numb
+qLe
+49 (((è
+qLe
+ <ð
+BSP_PCI_IRQ_MAX_OFFSET
+50 ((è
+qLe
+ >ð
+BSP_PCI_IRQ_LOWEST_OFFSET
+52
+57
+le
+ $is_´oûssÜ_q
+(cÚ¡
+¹ems_q_numb
+qLe
+59 (((è
+qLe
+ <ð
+BSP_PROCESSOR_IRQ_MAX_OFFSET
+60 ((è
+qLe
+ >ð
+BSP_PROCESSOR_IRQ_LOWEST_OFFSET
+62
+73
+ $isV®idIÁru±
+q
+75 iàÐ(
+q
+BSP_LOWEST_OFFSET
+è|| (q >
+BSP_MAX_OFFSET
+78
+83
+ $BSP_¡®l_¹ems_sh¬ed_q_hªdËr
+ (cÚ¡
+¹ems_q_cÚÃù_d©a
+q
+85
+¹ems_¼u±_Ëv
+Ëv
+86
+¹ems_q_cÚÃù_d©a
+vcha
+88
+ `´tk
+(" BSP_¡®l_¹ems_sh¬ed_q_hªd˸%d\n",
+q
+Çme
+90 ià(!
+ `isV®idIÁru±
+q
+Çme
+91
+ `´tk
+("Inv®id iÁru± veùÜ %d\n",
+q
+Çme
+95
+ `¹ems_¼u±_di§bË
+Ëv
+97 iàÐ()
+¹ems_hdl_tbl
+q
+Çme
+Ãxt_hªdËr
+ == -1 ) {
+98
+ `¹ems_¼u±_abË
+Ëv
+99
+ `´tk
+("IRQ veùÜ %dÌdy cÚÃùedت unsh¬ed hªdËr\n",
+q
+Çme
+103
+vcha
+¹ems_q_cÚÃù_d©a
+ `m®loc
+((rtems_irq_connect_data));
+106
+vcha
+[0]ð
+¹ems_hdl_tbl
+q
+Çme
+111
+¹ems_hdl_tbl
+q
+Çme
+] = *irq;
+114
+¹ems_hdl_tbl
+q
+Çme
+Ãxt_hªdËr
+vcha
+119 ià(
+ `is_pci_q
+q
+Çme
+122 ià(
+ `is_´oûssÜ_q
+q
+Çme
+130 ià(
+q
+Ú
+131
+q
+ `Ú
+(irq);
+133
+ `¹ems_¼u±_abË
+Ëv
+136
+141
+¹ems_¡©us_code
+ $b¥_¼u±_veùÜ_di§bË
+Ð
+¹ems_veùÜ_numb
+qLe
+145
+ `´tk
+("b¥_¼u±_veùÜ_di§bË: 0x%x\n",
+qLe
+146
+RTEMS_SUCCESSFUL
+147
+149
+¹ems_¡©us_code
+ $b¥_¼u±_veùÜ_abË
+Ð
+¹ems_veùÜ_numb
+qLe
+152
+ `´tk
+("b¥_¼u±_veùÜ_abË: 0x%x\n",
+qLe
+154
+RTEMS_SUCCESSFUL
+155
+163
+ $BSP_¡®l_¹ems_q_hªdËr
+ (cÚ¡
+¹ems_q_cÚÃù_d©a
+q
+165
+¹ems_¼u±_Ëv
+Ëv
+167
+ `´tk
+(" BSP_¡®l_¹ems_q_hªd˸%d\n",
+q
+Çme
+169 ià(!
+ `isV®idIÁru±
+q
+Çme
+170
+ `´tk
+q
+Çme
+180
+ `¹ems_¼u±_di§bË
+Ëv
+181 ià(
+¹ems_hdl_tbl
+q
+Çme
+hdl
+ !ð
+deçuÉ_¹ems_y
+.hdl) {
+182
+ `¹ems_¼u±_abË
+Ëv
+183
+ `´tk
+("IRQ veùÜ %dÌdy cÚÃùed\n",
+q
+Çme
+190
+¹ems_hdl_tbl
+q
+Çme
+] = *irq;
+191
+¹ems_hdl_tbl
+q
+Çme
+Ãxt_hªdËr
+ = (*)-1;
+194 ià(
+ `is_pci_q
+q
+Çme
+198
+ `´tk
+("is_pci_irq = TRUE - FIX THIS!\n");
+201 ià(
+ `is_´oûssÜ_q
+q
+Çme
+205
+ `´tk
+("is_processor_irq = TRUE : Fix This\n");
+211 ià(
+q
+Ú
+212
+ `´tk
+("C®È0x%x\n",
+q
+Ú
+213
+q
+ `Ú
+(irq);
+216
+ `¹ems_¼u±_abË
+Ëv
+219
+221
+ $BSP_g_cu¼t_¹ems_q_hªdËr
+¹ems_q_cÚÃù_d©a
+q
+223
+¹ems_¼u±_Ëv
+Ëv
+225
+ `´tk
+(" BSP_g_cu¼t_¹ems_q_hªd˸%d\n",
+q
+Çme
+226 ià(!
+ `isV®idIÁru±
+q
+Çme
+229
+ `¹ems_¼u±_di§bË
+Ëv
+230 *
+q
+¹ems_hdl_tbl
+[q->
+Çme
+231
+ `¹ems_¼u±_abË
+Ëv
+233
+235
+ $BSP_»move_¹ems_q_hªdËr
+ (cÚ¡
+¹ems_q_cÚÃù_d©a
+q
+237
+¹ems_q_cÚÃù_d©a
+pcha
+ð
+NULL
+vcha
+ = NULL;
+238
+¹ems_¼u±_Ëv
+Ëv
+240
+ `´tk
+(" BSP_»move_¹ems_q_hªd˸%d\n",
+q
+Çme
+241 ià(!
+ `isV®idIÁru±
+q
+Çme
+251
+ `¹ems_¼u±_di§bË
+Ëv
+252 ià(
+¹ems_hdl_tbl
+q
+Çme
+hdl
+ != irq->hdl) {
+253
+ `¹ems_¼u±_abË
+Ëv
+257 ifÐ()
+¹ems_hdl_tbl
+q
+Çme
+Ãxt_hªdËr
+ != -1 )
+259
+found
+ = 0;
+261 (
+pcha
+ð
+NULL
+vcha
+¹ems_hdl_tbl
+q
+Çme
+262 (
+vcha
+hdl
+ !ð
+deçuÉ_¹ems_y
+.hdl);
+263 (
+pcha
+ð
+vcha
+, vcha = (
+¹ems_q_cÚÃù_d©a
+*)vcha->
+Ãxt_hªdËr
+265 ifÐ
+vcha
+hdl
+ =ð
+q
+->hdl )
+267
+found
+= -1; ;
+271 ifÐ!
+found
+273
+ `¹ems_¼u±_abË
+Ëv
+279 ià(
+¹ems_hdl_tbl
+q
+Çme
+hdl
+ != irq->hdl)
+281
+ `¹ems_¼u±_abË
+Ëv
+287 ià(
+ `is_pci_q
+q
+Çme
+292 ià(
+ `is_´oûssÜ_q
+q
+Çme
+301 ià(
+q
+off
+302
+q
+ `off
+(irq);
+307 ifÐ!
+vcha
+310
+¹ems_hdl_tbl
+q
+Çme
+deçuÉ_¹ems_y
+314 ifÐ
+pcha
+317
+pcha
+Ãxt_hªdËr
+vcha
+->next_handler;
+324
+¹ems_hdl_tbl
+q
+Çme
+]ð*
+vcha
+326
+ `ä
+vcha
+329
+ `¹ems_¼u±_abË
+Ëv
+332
+338
+ $BSP_¹ems_q_mngt_£t
+¹ems_q_glob®_£gs
+cÚfig
+340
+i
+341
+¹ems_¼u±_Ëv
+Ëv
+346
+º®_cÚfig
+cÚfig
+347
+deçuÉ_¹ems_y
+cÚfig
+deçuÉEÁry
+348
+¹ems_hdl_tbl
+cÚfig
+qHdlTbl
+350
+ `´tk
+(" BSP_rtems_irq_mngt_set\n");
+352
+ `¹ems_¼u±_di§bË
+Ëv
+360
+i
+; i < BSP_PCI_IRQ_LOWEST_OFFSET +
+BSP_PCI_IRQ_NUMBER
+ ; i++) {
+361 ià(
+¹ems_hdl_tbl
+i
+hdl
+ !ð
+deçuÉ_¹ems_y
+.hdl) {
+363
+¹ems_q_cÚÃù_d©a
+vcha
+364
+vcha
+¹ems_hdl_tbl
+i
+365 (()
+vcha
+ !ð-1 && vcha->
+hdl
+ !ð
+deçuÉ_¹ems_y
+.hdl);
+366
+vcha
+¹ems_q_cÚÃù_d©a
+*)vcha->
+Ãxt_hªdËr
+368 ià(
+vcha
+Ú
+369
+vcha
+ `Ú
+(vchain);
+377
+¹ems_q_cÚÃù_d©a
+vcha
+378
+vcha
+¹ems_hdl_tbl
+i
+379 (()
+vcha
+ !ð-1 && vcha->
+hdl
+ !ð
+deçuÉ_¹ems_y
+.hdl);
+380
+vcha
+¹ems_q_cÚÃù_d©a
+*)vcha->
+Ãxt_hªdËr
+382 ià(
+vcha
+off
+383
+vcha
+ `off
+(vchain);
+391
+i
+; i < BSP_PROCESSOR_IRQ_LOWEST_OFFSET+
+BSP_PROCESSOR_IRQ_NUMBER
+; i++){
+392 ià(
+¹ems_hdl_tbl
+i
+hdl
+ !ð
+deçuÉ_¹ems_y
+.hdl) {
+394
+¹ems_q_cÚÃù_d©a
+vcha
+395
+vcha
+¹ems_hdl_tbl
+i
+396 (()
+vcha
+ !ð-1 && vcha->
+hdl
+ !ð
+deçuÉ_¹ems_y
+.hdl);
+397
+vcha
+¹ems_q_cÚÃù_d©a
+*)vcha->
+Ãxt_hªdËr
+399 ià(
+vcha
+Ú
+400
+vcha
+ `Ú
+(vchain);
+407
+¹ems_q_cÚÃù_d©a
+vcha
+408
+vcha
+¹ems_hdl_tbl
+i
+409 (()
+vcha
+ !ð-1 && vcha->
+hdl
+ !ð
+deçuÉ_¹ems_y
+.hdl);
+410
+vcha
+¹ems_q_cÚÃù_d©a
+*)vcha->
+Ãxt_hªdËr
+412 ià(
+vcha
+off
+413
+vcha
+ `off
+(vchain);
+419
+ `¹ems_¼u±_abË
+Ëv
+421
+423
+ $BSP_¹ems_q_mngt_g
+¹ems_q_glob®_£gs
+cÚfig
+425 *
+cÚfig
+º®_cÚfig
+427
+429
+ gBSP_¥uriousIÁr
+ = 0;
+434
+ $C_di¥©ch_q_hªdËr
+CPU_IÁru±_äame
+äame
+excNum
+436
+q
+437
+m¤
+438
+Ãw_m¤
+440 ià(
+excNum
+ =ð
+ASM_DEC_VECTOR
+441
+ `_CPU_MSR_GET
+m¤
+442
+Ãw_m¤
+m¤
+MSR_EE
+443
+ `_CPU_MSR_SET
+Ãw_m¤
+445
+¹ems_hdl_tbl
+BSP_DECREMENTER
+ `hdl
+Ôms_hdl_tbl[BSP_DECREMENTER].
+hªdË
+447
+ `_CPU_MSR_SET
+m¤
+452
+q
+ `»ad_ªd_þr_q
+453
+ `_CPU_MSR_GET
+m¤
+454
+Ãw_m¤
+m¤
+MSR_EE
+455
+ `_CPU_MSR_SET
+Ãw_m¤
+459
+¹ems_q_cÚÃù_d©a
+vcha
+460
+vcha
+¹ems_hdl_tbl
+q
+461 (()
+vcha
+ !ð-1 && vcha->
+hdl
+ !ð
+deçuÉ_¹ems_y
+.hdl);
+462
+vcha
+¹ems_q_cÚÃù_d©a
+*)vcha->
+Ãxt_hªdËr
+464
+vcha
+ `hdl
+(vcha->
+hªdË
+468
+ `_CPU_MSR_SET
+m¤
+471
+473
+¹ems_¡©us_code
+ $b¥_¼u±_çcy_lize
+476 ià(
+ `µc_exc_£t_hªdËr
+Ð
+ASM_EXT_VECTOR
+C_di¥©ch_q_hªdËr
+477
+RTEMS_IO_ERROR
+479 ià(
+ `µc_exc_£t_hªdËr
+Ð
+ASM_DEC_VECTOR
+C_di¥©ch_q_hªdËr
+480
+RTEMS_IO_ERROR
+482 ià(
+ `µc_exc_£t_hªdËr
+Ð
+ASM_E300_SYSMGMT_VECTOR
+C_di¥©ch_q_hªdËr
+483
+RTEMS_IO_ERROR
+486
+RTEMS_SUCCESSFUL
+487
+489
+ $b¥_¼u±_hªdËr_deçuÉ
+Ð
+¹ems_veùÜ_numb
+veùÜ
+491 ià(
+veùÜ
+ !ð
+BSP_DECREMENTER
+492
+ `´tk
+Ð"Spuriou ¼u±: 0x%08x\n",
+veùÜ
+494
+ @irq/irq.h
+20 #iâdeà
+BSP_POWERPC_IRQ_H
+21
+ #BSP_POWERPC_IRQ_H
+23
+ #BSP_SHARED_HANDLER_SUPPORT
+ 1
+24
+ ~<¹ems/q.h
+26 #iâdeà
+ASM
+28 #ifdeà
+__ýlu¥lus
+40
+ #BSP_ISA_IRQ_NUMBER
+ (16)
+41
+ #BSP_ISA_IRQ_LOWEST_OFFSET
+ (0)
+42
+ #BSP_ISA_IRQ_MAX_OFFSET
+BSP_ISA_IRQ_NUMBER
+ - 1)
+47
+ #BSP_PCI_IRQ_NUMBER
+ (16)
+48
+ #BSP_PCI_IRQ_LOWEST_OFFSET
+BSP_ISA_IRQ_NUMBER
+49
+ #BSP_PCI_IRQ_MAX_OFFSET
+BSP_PCI_IRQ_NUMBER
+ - 1)
+54
+ #BSP_PMC_IRQ_NUMBER
+ (4)
+55
+ #BSP_PMC_IRQ_LOWEST_OFFSET
+ + 1)
+56
+ #BSP_PMC_IRQ_MAX_OFFSET
+BSP_PMC_IRQ_LOWEST_OFFSET
+BSP_PMC_IRQ_NUMBER
+ - 1)
+63
+ #BSP_PROCESSOR_IRQ_NUMBER
+ (1)
+64
+ #BSP_PROCESSOR_IRQ_LOWEST_OFFSET
+BSP_PMC_IRQ_MAX_OFFSET
+ + 1)
+65
+ #BSP_PROCESSOR_IRQ_MAX_OFFSET
+ - 1)
+69
+ #BSP_MISC_IRQ_NUMBER
+ (8)
+70
+ #BSP_MISC_IRQ_LOWEST_OFFSET
+ + 1)
+71
+ #BSP_MISC_IRQ_MAX_OFFSET
+BSP_MISC_IRQ_LOWEST_OFFSET
+BSP_MISC_IRQ_NUMBER
+ - 1)
+75
+ #BSP_IRQ_NUMBER
+BSP_MISC_IRQ_MAX_OFFSET
+ + 1)
+76
+ #BSP_LOWEST_OFFSET
+77
+ #BSP_MAX_OFFSET
+82
+ #BSP_DECREMENTER
+87
+ #ScÜe_IRQ_F¡
+92
+ #SCORE603E_IRQ00
+ScÜe_IRQ_F¡
+ + 0 )
+93
+ #SCORE603E_IRQ01
+ScÜe_IRQ_F¡
+ + 1 )
+94
+ #SCORE603E_IRQ02
+ScÜe_IRQ_F¡
+ + 2 )
+95
+ #SCORE603E_IRQ03
+ScÜe_IRQ_F¡
+ + 3 )
+96
+ #SCORE603E_IRQ04
+ScÜe_IRQ_F¡
+ + 4 )
+97
+ #SCORE603E_IRQ05
+ScÜe_IRQ_F¡
+ + 5 )
+98
+ #SCORE603E_IRQ06
+ScÜe_IRQ_F¡
+ + 6 )
+99
+ #SCORE603E_IRQ07
+ScÜe_IRQ_F¡
+ + 7 )
+100
+ #SCORE603E_IRQ08
+ScÜe_IRQ_F¡
+ + 8 )
+101
+ #SCORE603E_IRQ09
+ScÜe_IRQ_F¡
+ + 9 )
+102
+ #SCORE603E_IRQ10
+ScÜe_IRQ_F¡
+ + 10 )
+103
+ #SCORE603E_IRQ11
+ScÜe_IRQ_F¡
+ + 11 )
+104
+ #SCORE603E_IRQ12
+ScÜe_IRQ_F¡
+ + 12 )
+105
+ #SCORE603E_IRQ13
+ScÜe_IRQ_F¡
+ + 13 )
+106
+ #SCORE603E_IRQ14
+ScÜe_IRQ_F¡
+ + 14 )
+107
+ #SCORE603E_IRQ15
+ScÜe_IRQ_F¡
+ + 15 )
+109
+ #SCORE603E_TIMER1_IRQ
+SCORE603E_IRQ00
+110
+ #SCORE603E_TIMER2_IRQ
+SCORE603E_IRQ01
+111
+ #SCORE603E_TIMER3_IRQ
+SCORE603E_IRQ02
+112
+ #SCORE603E_85C30_1_IRQ
+SCORE603E_IRQ03
+113
+ #SCORE603E_85C30_0_IRQ
+SCORE603E_IRQ04
+114
+ #SCORE603E_RTC_IRQ
+SCORE603E_IRQ05
+115
+ #SCORE603E_PCI_IRQ_0
+SCORE603E_IRQ06
+116
+ #SCORE603E_PCI_IRQ_1
+SCORE603E_IRQ07
+117
+ #SCORE603E_PCI_IRQ_2
+SCORE603E_IRQ08
+118
+ #SCORE603E_PCI_IRQ_3
+SCORE603E_IRQ09
+119
+ #SCORE603E_UNIVERSE_IRQ
+SCORE603E_IRQ10
+120
+ #SCORE603E_1553_IRQ
+SCORE603E_IRQ11
+121
+ #SCORE603E_MAIL_BOX_IRQ_0
+SCORE603E_IRQ12
+122
+ #SCORE603E_MAIL_BOX_IRQ_1
+SCORE603E_IRQ13
+123
+ #SCORE603E_MAIL_BOX_IRQ_2
+SCORE603E_IRQ14
+124
+ #SCORE603E_MAIL_BOX_IRQ_3
+SCORE603E_IRQ15
+131
+ #SCORE603E_IRQ16
+ScÜe_IRQ_F¡
+ + 16 )
+132
+ #SCORE603E_IRQ17
+ScÜe_IRQ_F¡
+ + 17 )
+133
+ #SCORE603E_IRQ18
+ScÜe_IRQ_F¡
+ + 18 )
+134
+ #SCORE603E_IRQ19
+ScÜe_IRQ_F¡
+ + 19 )
+139
+ #SCORE603E_85C30_4_IRQ
+SCORE603E_IRQ16
+140
+ #SCORE603E_85C30_2_IRQ
+SCORE603E_IRQ17
+141
+ #SCORE603E_85C30_5_IRQ
+SCORE603E_IRQ18
+142
+ #SCORE603E_85C30_3_IRQ
+SCORE603E_IRQ19
+144
+ #MAX_BOARD_IRQS
+SCORE603E_IRQ19
+146
+BSP_¹ems_q_mng_
+ýuId
+148 #ifdeà
+__ýlu¥lus
+ @irq/irq_init.c
+19
+ ~<libýu/io.h
+20
+ ~<libýu/¥r.h
+21
+ ~<b¥/pci.h
+22
+ ~<b¥/»sidu®.h
+23
+ ~<b¥/q.h
+24
+ ~<b¥.h
+25
+ ~<b¥/veùÜs.h
+26
+ ~<¹ems/b¥Io.h
+28
+ #SHOW_ISA_PCI_BRIDGE_SETTINGS
+ 1
+29
+ #SCAN_PCI_PRINT
+ 1
+30
+ #TRACE_IRQ_INIT
+ 0
+33
+ mbus
+34
+ mdeviû
+35
+ mfunùiÚ
+36 }
+ tpci_i§_bridge_deviû
+38
+pci_i§_bridge_deviû
+ gv_82c586
+ = 0;
+40
+exº®_exû±iÚ_veùÜ_´Þog_code_size
+41
+42
+deüemr_exû±iÚ_veùÜ_´Þog_code_size
+43
+45
+ $IRQ_DeçuÉ_¹ems_q_hdl
+46
+¹ems_q_hdl_·¿m
+±r
+49
+51
+ $IRQ_DeçuÉ_¹ems_q_abË
+52 cÚ¡
+__¹ems_q_cÚÃù_d©a__
+±r
+55
+57
+ $IRQ_DeçuÉ_¹ems_q_di§bË
+58 cÚ¡
+±r
+61
+63
+ $IRQ_DeçuÉ_¹ems_q_is_abËd
+64 cÚ¡
+±r
+67
+69
+¹ems_q_cÚÃù_d©a
+ g¹emsIrq
+BSP_IRQ_NUMBER
+70
+¹ems_q_glob®_£gs
+ gl_cÚfig
+72
+¹ems_q_cÚÃù_d©a
+ gdeçuÉIrq
+73 .
+Çme
+ = 0,
+74 .
+ ghdl
+IRQ_DeçuÉ_¹ems_q_hdl
+75 .
+ ghªdË
+NULL
+76 .
+ gÚ
+IRQ_DeçuÉ_¹ems_q_abË
+77 .
+ gÚ
+IRQ_DeçuÉ_¹ems_q_di§bË
+78 .
+ gisOn
+IRQ_DeçuÉ_¹ems_q_is_abËd
+81
+¹ems_q_´io
+ gqPrioTabË
+BSP_IRQ_NUMBER
+89
+ $BSP_¹ems_q_mng_
+ýuId
+91
+i
+103
+i
+ = 0; i <
+BSP_IRQ_NUMBER
+; i++) {
+104
+qPrioTabË
+i
+] = 8;
+105
+¹emsIrq
+i
+deçuÉIrq
+106
+¹emsIrq
+i
+Çme
+ = i;
+107 #ifdeà
+BSP_SHARED_HANDLER_SUPPORT
+108
+¹emsIrq
+i
+Ãxt_hªdËr
+NULL
+115
+l_cÚfig
+qNb
+BSP_IRQ_NUMBER
+116
+l_cÚfig
+deçuÉEÁry
+deçuÉIrq
+117
+l_cÚfig
+qHdlTbl
+¹emsIrq
+118
+l_cÚfig
+qBa£
+BSP_LOWEST_OFFSET
+119
+l_cÚfig
+qPrioTbl
+qPrioTabË
+121 ià(!
+ `BSP_¹ems_q_mngt_£t
+l_cÚfig
+125
+ `BSP_·nic
+("Unableo initialize RTEMS interrupt Management!!! Systemocked\n");
+128 #ifdeà
+TRACE_IRQ_INIT
+129
+ `´tk
+("RTEMS IRQ management isow operational\n");
+131
+ @irq/no_pic.c
+13
+ ~<¹ems.h
+14
+ ~<b¥.h
+15
+ ~<b¥/q.h
+16
+ ~<b¥/q_suµ.h
+17
+ ~<b¥/veùÜs.h
+19
+¹ems_q_cÚÃù_d©a
+ g¹ems_hdl_tbl
+20
+¹ems_q_cÚÃù_d©a
+ gdæt_y
+25
+ $C_di¥©ch_q_hªdËr
+26
+BSP_Exû±iÚ_äame
+äame
+27
+excNum
+30
+q
+31 #ià(
+HAS_PMC_PSC8
+32
+ut16_t
+check_q
+33
+ut16_t
+¡©us_wÜd
+36 ià(
+excNum
+ =ð
+ASM_DEC_VECTOR
+37
+ `b¥_q_di¥©ch_li¡
+¹ems_hdl_tbl
+BSP_DECREMENTER
+dæt_y
+hdl
+41
+q
+ `»ad_ªd_þr_q
+43 #ià(
+HAS_PMC_PSC8
+44 ià(
+q
+ =ð
+45
+¡©us_wÜd
+ `»ad_ªd_þr_PMC_q
+Ð
+q
+46
+check_q
+SCORE603E_IRQ16
+; check_q<=
+SCORE603E_IRQ19
+; check_irq++) {
+47 iàÐ
+ `Is_PMC_IRQ
+Ð
+check_q
+¡©us_wÜd
+48
+ `b¥_q_di¥©ch_li¡_ba£
+¹ems_hdl_tbl
+check_q
+dæt_y
+hdl
+54
+¹ems_hdl_tbl
+q
+dæt_y
+hdl
+58
+61
+ $BSP_abË_q_©_pic
+(cÚ¡
+¹ems_q_numb
+q
+63
+ut16_t
+vec_idx
+q
+ScÜe_IRQ_F¡
+64
+ `unmask_q
+Ð
+vec_idx
+65
+68
+ $BSP_di§bË_q_©_pic
+(cÚ¡
+¹ems_q_numb
+q
+70
+ut16_t
+vec_idx
+q
+ScÜe_IRQ_F¡
+71
+ `unmask_q
+Ð
+vec_idx
+73
+76
+ $BSP_£tup_the_pic
+¹ems_q_glob®_£gs
+cÚfig
+78
+dæt_y
+cÚfig
+deçuÉEÁry
+79
+¹ems_hdl_tbl
+cÚfig
+qHdlTbl
+80
+ `_q_d©a_»gi¡
+82
+ @startup/Hwr_init.c
+11
+ ~<b¥.h
+13
+ #PPC603e_SPR_HID0
+ 1008
+14
+ #PPC603e_SPR_HID1
+ 1009
+15
+ #PPC603e_SPR_IBAT0U
+ 528
+16
+ #PPC603e_SPR_IBAT0L
+ 529
+17
+ #PPC603e_SPR_DBAT0U
+ 536
+18
+ #PPC603e_SPR_DBAT0L
+ 537
+19
+ #PPC603e_SPR_IBAT1U
+ 530
+20
+ #PPC603e_SPR_IBAT1L
+ 531
+21
+ #PPC603e_SPR_DBAT1U
+ 538
+22
+ #PPC603e_SPR_DBAT1L
+ 539
+23
+ #PPC603e_SPR_IBAT2U
+ 532
+24
+ #PPC603e_SPR_IBAT2L
+ 533
+25
+ #PPC603e_SPR_DBAT2U
+ 540
+26
+ #PPC603e_SPR_DBAT2L
+ 541
+27
+ #PPC603e_SPR_IBAT3U
+ 534
+28
+ #PPC603e_SPR_IBAT3L
+ 535
+29
+ #PPC603e_SPR_DBAT3U
+ 542
+30
+ #PPC603e_SPR_DBAT3L
+ 543
+31
+ #PPC603e_SPR_DMISS
+ 976
+32
+ #PPC603e_SPR_DCMP
+ 977
+33
+ #PPC603e_SPR_HASH1
+ 978
+34
+ #PPC603e_SPR_HASH2
+ 979
+35
+ #PPC603e_SPR_IMISS
+ 980
+36
+ #PPC603e_SPR_ICMP
+ 981
+37
+ #PPC603e_SPR_RPA
+ 982
+38
+ #PPC603e_SPR_SDR1
+ 25
+39
+ #PPC603e_SPR_PVR
+ 287
+40
+ #PPC603e_SPR_DAR
+ 19
+41
+ #PPC603e_SPR_SPRG0
+ 272
+42
+ #PPC603e_SPR_SPRG1
+ 273
+43
+ #PPC603e_SPR_SPRG2
+ 274
+44
+ #PPC603e_SPR_SPRG3
+ 275
+45
+ #PPC603e_SPR_DSISR
+ 18
+46
+ #PPC603e_SPR_SRR0
+ 26
+47
+ #PPC603e_SPR_SRR1
+ 27
+48
+ #PPC603e_SPR_TBL_WRITE
+ 284
+49
+ #PPC603e_SPR_TBU_WRITE
+ 285
+50
+ #PPC603e_SPR_DEC
+ 22
+51
+ #PPC603e_SPR_IABR
+ 1010
+52
+ #PPC603e_SPR_EAR
+ 282
+54
+ #PCI_MEM_CMD
+SCORE603E_PCI_MEM_BASE
+ >> 16)
+57
+ut32_t
+ mcouÁ_1_100
+58
+ut32_t
+ mcouÁ_hours
+59
+ut32_t
+ mcouÁ_m
+60
+ut32_t
+ mcouÁ_£c
+61
+ut32_t
+ mcouÁ_mÚth
+62
+ut32_t
+ mcouÁ_d©e
+63
+ut32_t
+ mcouÁ_yr
+64
+ut32_t
+ mcouÁ_day_of_wk
+66
+ut32_t
+ mRAM_1_100
+67
+ut32_t
+ mRAM_hours
+68
+ut32_t
+ mRAM_mÚth
+69
+ut32_t
+ mRAM_d©e
+70
+ut32_t
+ mRAM_yr
+71
+ut32_t
+ mRAM_day_of_wk
+73
+ut32_t
+ mru±_¡©us_mask
+74
+ut32_t
+ mcommªd_»gi¡
+75 }
+ tH¬ris_RTC
+77
+ $_RTC
+79 vÞ©
+H¬ris_RTC
+the_RTC
+81
+the_RTC
+ = (vÞ©
+H¬ris_RTC
+BSP_RTC_ADDRESS
+83
+the_RTC
+commªd_»gi¡
+ = 0x0;
+84
+86
+ $_PCI
+90
+92
+ #PPC_G_HID0
+Ð
+_v®ue
+94
+_v®ue
+ = 0; \
+95
+__asm__
+ volatile( \
+98 : "ô" (
+_v®ue
+99 : "0" (
+_v®ue
+101 } 0)
+103
+ #PPC_S_HID0
+Ð
+_v®ue
+105
+__asm__
+ volatile( \
+109 : "ô" (
+_v®ue
+110 : "0" (
+_v®ue
+112 } 0)
+114
+ $¡ruùiÚ_ÿche_abË
+116
+ut32_t
+v®ue
+122
+ `PPC_G_HID0
+Ð
+v®ue
+124
+v®ue
+ |= 0x00008000;
+126
+ `PPC_S_HID0
+Ð
+v®ue
+127
+129
+ $d©a_ÿche_abË
+131
+ut32_t
+v®ue
+137
+ `PPC_G_HID0
+Ð
+v®ue
+139
+v®ue
+ |= 0x00004000;
+141
+ `PPC_S_HID0
+Ð
+v®ue
+142
+ @startup/bspstart.c
+14
+ ~<¡rg.h
+16
+ ~<b¥.h
+17
+ ~<b¥/boÙÿrd.h
+18
+ ~<¹ems/libio.h
+19
+20
+ ~<¹ems/b¥Io.h
+21
+ ~<¹ems/couÁ.h
+22
+ ~<libýu/ýuIdt.h
+23
+ ~<b¥/q.h
+25
+ #DEBUG
+ 0
+30
+ gBSP_hp_¡¬t
+35
+ gBSP_bus_äequcy
+40
+ gBSP_´oûssÜ_äequcy
+47
+ gBSP_time_ba£_divisÜ
+ = 3960;
+52
+ut32_t
+ gb¥_þicks_³r_u£c
+57
+RamSize
+58
+ut32_t
+ gBSP_mem_size
+60
+__¹ems_d
+62
+ $BSP_·nic
+s
+64
+ `´tk
+("% PANIC %s\n",
+_RTEMS_vsiÚ
+s
+65
+__asm__
+ `__vÞ©e
+ ("sc");
+66
+68
+ $_BSP_F©®_rÜ
+v
+70
+ `´tk
+("% PANIC ERROR %x\n",
+_RTEMS_vsiÚ
+v
+71
+__asm__
+ `__vÞ©e
+ ("sc");
+72
+79
+_RTC
+80
+lize_PMC
+82
+ $b¥_´edriv_hook
+84
+ `_PCI
+85
+ `lize_univ£
+87 #ià
+DEBUG
+88
+ `´tk
+("bsp_predriver_hook: initialize_PCI_bridge\n");
+90
+ `lize_PCI_bridge
+92 #ià(
+HAS_PMC_PSC8
+93 #ià
+DEBUG
+94
+ `´tk
+("bsp_predriver_hook: initialize_PMC\n");
+96
+ `lize_PMC
+99 #ià
+DEBUG
+100
+ `´tk
+("bsp_predriver_hook: End ofoutine\n");
+103
+110
+ $lize_PMC
+111 vÞ©
+ut32_t
+PMC_addr
+112
+ut32_t
+d©a
+117
+PMC_addr
+ `BSP_PCI_DEVICE_ADDRESS
+( 0x4 );
+118 *
+PMC_addr
+ = 0x020080cc;
+119 #ià
+DEBUG
+120
+ `´tk
+("lize_PMC: 0x%x = 0x%x\n",
+PMC_addr
+, 0x020080cc);
+126
+PMC_addr
+( 0x14 );
+127 *
+PMC_addr
+ >> 24) & 0x3f;
+128 #ià
+DEBUG
+129
+ `´tk
+PMC_addr
+ >> 24) & 0x3f));
+132
+PMC_addr
+ = (vÞ©
+ut32_t
+133
+( 0x100000 );
+134
+d©a
+PMC_addr
+135 #ià
+DEBUG
+136
+ `´tk
+("lize_PMC: Rd 0x%x (0x%x)\n",
+PMC_addr
+d©a
+137
+ `´tk
+PMC_addr
+d©a
+ & 0xfc );
+139 *
+PMC_addr
+d©a
+ & 0xfc;
+140
+149
+ $b¥_¡¬t
+151
+m¤_v®ue
+ = 0x0000;
+152
+u_t
+SckS¹
+153
+u_t
+SckSize
+154
+µc_ýu_id_t
+myCpu
+155
+µc_ýu_»visiÚ_t
+myCpuRevisiÚ
+157
+ `¹ems_b¥_day
+( 1000 );
+162 #ià
+DEBUG
+163
+ `´tk
+("bsp_start: Zero outots of memory\n");
+166
+BSP_´oûssÜ_äequcy
+ = 266000000;
+167
+BSP_bus_äequcy
+ = 66000000;
+174
+myCpu
+ `g_µc_ýu_ty³
+175
+myCpuRevisiÚ
+ `g_µc_ýu_»visiÚ
+176
+ `´tk
+("Cpu: 0x%x RevisiÚ: %d\n",
+myCpu
+myCpuRevisiÚ
+177
+ `´tk
+("Cpu %s\n",
+ `g_µc_ýu_ty³_Çme
+myCpu
+182
+SckS¹
+u_t
+è
+__¹ems_d
+183
+SckSize
+ `¹ems_cÚfigu¿tiÚ_g_¼u±_¡ack_size
+184
+ `´tk
+("Interrupt Stack Start: 0x%x Size: 0x%x Heap Start: 0x%x\n",
+185
+SckS¹
+SckSize
+BSP_hp_¡¬t
+188
+BSP_mem_size
+ut32_t
+è
+RamSize
+189
+ `´tk
+("BSP_mem_size: %p\n",
+RamSize
+194
+ `µc_exc_lize
+SckS¹
+SckSize
+196
+m¤_v®ue
+ = 0x2030;
+197
+ `_CPU_MSR_SET
+Ð
+m¤_v®ue
+198
+__asm__
+ volatile("sync; isync");
+203 #ià
+DEBUG
+204
+ `´tk
+("bsp_start: set clicks
oer usec\n");
+206
+b¥_þicks_³r_u£c
+ = 66 / 4;
+207
+ `¹ems_couÁ_lize_cÚvr
+b¥_þicks_³r_u£c
+ * 1000000);
+209 #ià
+BSP_DATA_CACHE_ENABLED
+210 #ià
+DEBUG
+211
+ `´tk
+("bsp_start: cache_enable\n");
+213
+ `¡ruùiÚ_ÿche_abË
+214
+ `d©a_ÿche_abË
+215 #ià
+DEBUG
+216
+ `´tk
+("bsp_start: END BSP_DATA_CACHE_ENABLED\n");
+223 #ià
+DEBUG
+224
+ `´tk
+("bspstart: Call BSP_rtems_irq_mng_init\n");
+226
+ `BSP_¹ems_q_mng_
+(0);
+228 #ià
+DEBUG
+229
+ `´tk
+("bsp_start:nd BSPSTART\n");
+230
+ `ShowBATS
+232
+ @startup/genpvec.c
+13
+ ~<b¥.h
+14
+ ~<¹ems/cha.h
+15
+ ~<¹ems/b¥Io.h
+16
+ ~<as£¹.h
+18
+ ~<¡dio.h
+24
+¹ems_i¤
+exº®_exû±iÚ_ISR
+25
+¹ems_veùÜ_numb
+veùÜ
+28
+ #NUM_LIRQ_HANDLERS
+ 20
+29
+ #NUM_LIRQ
+MAX_BOARD_IRQS
+PPC_IRQ_LAST
+37
+¹ems_cha_node
+ mNode
+38
+¹ems_i¤_y
+ mhªdËr
+39
+¹ems_veùÜ_numb
+ mveùÜ
+40 }
+ tEE_ISR_Ty³
+45
+EE_ISR_Ty³
+ gISR_Nodes
+NUM_LIRQ_HANDLERS
+46
+ut16_t
+ gNodes_U£d
+47
+¹ems_cha_cÚÞ
+ gISR_A¼ay
+NUM_LIRQ
+50
+_q_d©a_»gi¡
+52
+ $In_EE_mask_
+54
+60
+¹ems_i¤_y
+ $£t_EE_veùÜ
+61
+¹ems_i¤_y
+hªdËr
+62
+¹ems_veùÜ_numb
+veùÜ
+65
+ut16_t
+vec_idx
+veùÜ
+ScÜe_IRQ_F¡
+66
+ut32_t
+dex
+68
+ `as£¹
+Nodes_U£d
+NUM_LIRQ_HANDLERS
+75
+dex
+=0 ; index <ð
+Nodes_U£d
+ ; index++ ) {
+76 iàÐ
+ISR_Nodes
+dex
+veùÜ
+ == vector &&
+77
+ISR_Nodes
+dex
+hªdËr
+ == handler )
+78
+NULL
+85
+Nodes_U£d
+87
+dex
+Nodes_U£d
+ - 1;
+89
+ISR_Nodes
+dex
+hªdËr
+ = handler;
+90
+ISR_Nodes
+dex
+veùÜ
+ = vector;
+95
+ `¹ems_cha_³nd
+Ð&
+ISR_A¼ay
+vec_idx
+ISR_Nodes
+dex
+Node
+100
+ `unmask_q
+Ð
+vec_idx
+102
+NULL
+103
+108
+¹ems_i¤
+ $exº®_exû±iÚ_ISR
+109
+¹ems_veùÜ_numb
+veùÜ
+112
+ut16_t
+dex
+113
+EE_ISR_Ty³
+node
+114
+ut16_t
+v®ue
+115 #ià(
+HAS_PMC_PSC8
+116
+ut16_t
+PMC_q
+117
+ut16_t
+check_q
+118
+ut16_t
+¡©us_wÜd
+121
+dex
+ `»ad_ªd_þr_q
+122 iàÐ
+dex
+ >ð
+NUM_LIRQ
+123
+ `´tk
+Ð"ERROR:: Inv®id iÁru±umb (%02x)\n",
+dex
+127 #ià(
+HAS_PMC_PSC8
+128
+PMC_q
+SCORE603E_IRQ00
+130 ià(
+dex
+ =ð
+PMC_q
+131
+¡©us_wÜd
+ `»ad_ªd_þr_PMC_q
+Ð
+dex
+133
+check_q
+SCORE603E_IRQ16
+; check_q<=
+SCORE603E_IRQ19
+; check_irq++) {
+134 iàÐ
+ `Is_PMC_IRQ
+Ð
+check_q
+¡©us_wÜd
+135
+dex
+check_q
+SCORE603E_IRQ00
+136
+node
+EE_ISR_Ty³
+ISR_A¼ay
+dex
+f¡
+138 iàÐ
+ `¹ems_cha_is_
+Ð&
+ISR_A¼ay
+dex
+node
+139
+ `´tk
+ ("ERROR:: check %d iÁru± %02d ha nØi¤\n",
+check_q
+dex
+140
+v®ue
+ `g_q_mask
+141
+ `´tk
+(" Mask = %02x\n",
+v®ue
+143 !
+ `¹ems_cha_is_
+Ð&
+ISR_A¼ay
+dex
+node
+144 (*
+node
+hªdËr
+)Ðnode->
+veùÜ
+145
+node
+EE_ISR_Ty³
+ *ènode->
+Node
+Ãxt
+153
+node
+EE_ISR_Ty³
+ISR_A¼ay
+dex
+f¡
+154 iàÐ
+ `¹ems_cha_is_
+Ð&
+ISR_A¼ay
+dex
+node
+155
+ `´tk
+Ð"ERROR:: iÁru± %02x ha nØi¤\n",
+dex
+156
+v®ue
+ `g_q_mask
+157
+ `´tk
+(" Mask = %02x\n",
+v®ue
+160 !
+ `¹ems_cha_is_
+Ð&
+ISR_A¼ay
+dex
+node
+161 (*
+node
+hªdËr
+)Ðnode->
+veùÜ
+162
+node
+EE_ISR_Ty³
+ *ènode->
+Node
+Ãxt
+166
+ @startup/vmeintr.c
+14
+ ~<¹ems.h
+15
+ ~<b¥.h
+16
+ ~<¹ems/vme.h
+21
+ $VME_¼u±_Di§bË
+22
+VME_¼u±_Mask
+mask
+25 vÞ©
+ut8_t
+VME_¼u±_abË
+26
+ut8_t
+v®ue
+28
+VME_¼u±_abË
+ = 0;
+29
+v®ue
+VME_¼u±_abË
+30
+v®ue
+ &ð~
+mask
+31 *
+VME_¼u±_abË
+v®ue
+32
+37
+ $VME_¼u±_EÇbË
+38
+VME_¼u±_Mask
+mask
+41 vÞ©
+ut8_t
+VME_¼u±_abË
+42
+ut8_t
+v®ue
+44
+VME_¼u±_abË
+ = 0;
+45
+v®ue
+VME_¼u±_abË
+46
+v®ue
+ |ð
+mask
+47 *
+VME_¼u±_abË
+v®ue
+48
+ @timer/timer.c
+18
+ ~<as£¹.h
+20
+ ~<b¥.h
+21
+ ~<¹ems/btim.h
+23
+ut64_t
+ gTim_driv_S¹_time
+25
+boÞ
+ gbchm¬k_tim_fd_avage_ovhd
+31
+ $bchm¬k_tim_lize
+38
+Tim_driv_S¹_time
+ `PPC_G_timeba£_»gi¡
+39
+45
+bchm¬k_tim_t
+ $bchm¬k_tim_»ad
+47
+ut64_t
+þicks
+48
+ut64_t
+tÙ®64
+49
+ut32_t
+tÙ®
+53
+þicks
+55
+ `as£¹
+Ð
+þicks
+Tim_driv_S¹_time
+57
+tÙ®64
+þicks
+Tim_driv_S¹_time
+59
+ `as£¹
+Ð
+tÙ®64
+ <= 0xffffffff );
+61
+tÙ®
+ut32_t
+è
+tÙ®64
+63 iàÐ
+bchm¬k_tim_fd_avage_ovhd
+ =ð
+ue
+64
+tÙ®
+66 iàÐ
+tÙ®
+BSP_TIMER_LEAST_VALID
+69
+ `BSP_CÚvt_deüemr
+tÙ®
+BSP_TIMER_AVG_OVERHEAD
+70
+72
+ $bchm¬k_tim_di§bË_subaùg_avage_ovhd
+73
+boÞ
+fd_æag
+76
+fd_æag
+77
+ @tod/tod.c
+14
+ ~<¹ems.h
+15
+ ~<tod.h
+16
+ ~<b¥.h
+22
+ 0x00
+23
+ 0x01
+24
+ 0x02
+25
+ 0x03
+27
+ICM7170_GTOD
+28 vÞ©*
+imc1770_»gs
+29
+ut8_t
+icm1770_äeq
+30
+¹ems_time_of_day
+¹c_tod
+32
+ICM7170_STOD
+33 vÞ©*
+imc1770_»gs
+34
+ut8_t
+icm1770_äeq
+35
+¹ems_time_of_day
+¹c_tod
+43
+ $£tRlTimeToRTEMS
+45
+¹ems_time_of_day
+¹c_tod
+47
+ `ICM7170_GTOD
+Ð
+BSP_RTC_ADDRESS
+BSP_RTC_FREQUENCY
+¹c_tod
+48
+ `¹ems_þock_£t
+Ð&
+¹c_tod
+49
+51
+ $£tRlTimeFromRTEMS
+53
+¹ems_time_of_day
+¹ems_tod
+55
+ `¹ems_þock_g
+Ð
+RTEMS_CLOCK_GET_TOD
+¹ems_tod
+56
+ `ICM7170_STOD
+Ð
+BSP_RTC_ADDRESS
+BSP_RTC_FREQUENCY
+¹ems_tod
+57
+59
+ $checkRlTime
+61
+¹ems_time_of_day
+¹ems_tod
+62
+¹ems_time_of_day
+¹c_tod
+64
+ `ICM7170_GTOD
+Ð
+BSP_RTC_ADDRESS
+BSP_RTC_FREQUENCY
+¹c_tod
+65
+ `¹ems_þock_g
+Ð
+¹ems_tod
+67 ifÐ
+¹ems_tod
+yr
+ =ð
+¹c_tod
+.year &&
+68
+¹ems_tod
+mÚth
+ =ð
+¹c_tod
+.month &&
+69
+¹ems_tod
+day
+ =ð
+¹c_tod
+.day ) {
+70 ((
+¹ems_tod
+hour
+¹c_tod
+.hour) * 3600) +
+71 ((
+¹ems_tod
+mu
+¹c_tod
+.minute) * 60) +
+72 (
+¹ems_tod
+£cÚd
+¹c_tod
+.second);
+75
+82
+ $ICM7170_GFld
+83 vÞ©*
+imc1770_»gs
+84
+»g
+87
+x
+89
+x
+imc1770_»gs
+»g
+*4];
+91
+x
+92
+94
+ $ICM7170_SFld
+95 vÞ©*
+imc1770_»gs
+96
+»g
+97
+d
+100
+imc1770_»gs
+»g
+*4] =
+d
+101
+103
+ $ICM7170_GTOD
+104 vÞ©*
+imc1770_»gs
+105
+ut8_t
+icm1770_äeq
+106
+¹ems_time_of_day
+¹c_tod
+109
+yr
+110
+u£c
+111
+boÞ
+ue
+114 ià(
+115
+ `ICM7170_SFld
+Ð
+imc1770_»gs
+, 0x11, (0x0ø|
+icm1770_äeq
+116
+çl£
+122
+u£c
+ `ICM7170_GFld
+Ð
+imc1770_»gs
+, 0x00 );
+124
+yr
+ `ICM7170_GFld
+Ð
+imc1770_»gs
+, 0x06 );
+125 iàÐ
+yr
+ >= 88 )
+126
+yr
+ += 1900;
+128
+yr
+ += 2000;
+130
+¹c_tod
+yr
+ = year;
+131
+¹c_tod
+mÚth
+ `ICM7170_GFld
+Ð
+imc1770_»gs
+, 0x04 );
+132
+¹c_tod
+day
+ `ICM7170_GFld
+Ð
+imc1770_»gs
+, 0x05 );
+133
+¹c_tod
+hour
+ `ICM7170_GFld
+Ð
+imc1770_»gs
+, 0x01 );
+134
+¹c_tod
+mu
+ `ICM7170_GFld
+Ð
+imc1770_»gs
+, 0x02 );
+135
+¹c_tod
+£cÚd
+ `ICM7170_GFld
+Ð
+imc1770_»gs
+, 0x03 );
+136
+¹c_tod
+ticks
+ `ICM7170_GFld
+Ð
+imc1770_»gs
+, 0x00 );
+137
+139
+ $ICM7170_STOD
+140 vÞ©*
+imc1770_»gs
+141
+ut8_t
+icm1770_äeq
+142
+¹ems_time_of_day
+¹c_tod
+145
+yr
+147
+yr
+¹c_tod
+->year;
+148 iàÐ
+yr
+ >= 2088 )
+149
+( 0xBAD0BAD0 );
+151 iàÐ
+yr
+ >= 2000 )
+152
+yr
+ -= 2000;
+154
+yr
+ -= 1900;
+156
+ `ICM7170_SFld
+Ð
+imc1770_»gs
+, 0x11, (0x04 |
+icm1770_äeq
+158
+ `ICM7170_SFld
+Ð
+imc1770_»gs
+, 0x06,
+yr
+159
+ `ICM7170_SFld
+Ð
+imc1770_»gs
+, 0x04,
+¹c_tod
+mÚth
+160
+ `ICM7170_SFld
+Ð
+imc1770_»gs
+, 0x05,
+¹c_tod
+day
+161
+ `ICM7170_SFld
+Ð
+imc1770_»gs
+, 0x01,
+¹c_tod
+hour
+162
+ `ICM7170_SFld
+Ð
+imc1770_»gs
+, 0x02,
+¹c_tod
+mu
+163
+ `ICM7170_SFld
+Ð
+imc1770_»gs
+, 0x03,
+¹c_tod
+£cÚd
+169
+ `ICM7170_SFld
+Ð
+imc1770_»gs
+, 0x07, 1 );
+171
+ `ICM7170_SFld
+Ð
+imc1770_»gs
+, 0x11, (0x0ø|
+icm1770_äeq
+172
+ @vme/VMEConfig.h
+1 #iâdeà
+RTEMS_BSP_VME_CONFIG_H
+2
+ #RTEMS_BSP_VME_CONFIG_H
+63 #undeà
+BSP_VME_BAT_IDX
+65
+ #_VME_A32_WIN0_ON_PCI
+ 0x10000000
+66
+ #_VME_A24_ON_PCI
+ 0x1f000000
+67
+ #_VME_A16_ON_PCI
+ 0x1fff0000
+72
+ #_VME_A32_WIN0_ON_VME
+ 0x20000000
+78 #undeà
+_VME_DRAM_OFFSET
+85 #undeà
+_VME_CSR_ON_PCI
+87 #undeà
+BSP_PCI_VME_DRIVER_DOES_EOI
+89
+BSP_VMEIn
+90
+BSP_VMEIrqMgrIn¡®l
+92
+ #BSP_VME_UNIVERSE_INSTALL_IRQ_MGR
+r
+94
+r
+ `vmeUniv£In¡®lIrqMgr
+(0,5,1,6); \
+95 } 0)
+1
+0
+24
+370
+PCI_bus/PCI.c
+PCI_bus/PCI.h
+PCI_bus/flash.c
+PCI_bus/universe.c
+console/85c30.c
+console/85c30.h
+console/console.c
+console/consolebsp.h
+console/tbl85c30.c
+include/bsp.h
+include/gen2.h
+include/tm27.h
+irq/FPGA.c
+irq/irq.c
+irq/irq.h
+irq/irq_init.c
+irq/no_pic.c
+startup/Hwr_init.c
+startup/bspstart.c
+startup/genpvec.c
+startup/vmeintr.c
+timer/timer.c
+tod/tod.c
+vme/VMEConfig.h
diff --git a/c/src/lib/libbsp/powerpc/score603e/include/bsp.h b/c/src/lib/libbsp/powerpc/score603e/include/bsp.h
index f6e3c5a..dc78498 100644
--- a/c/src/lib/libbsp/powerpc/score603e/include/bsp.h
+++ b/c/src/lib/libbsp/powerpc/score603e/include/bsp.h
@@ -1,8 +1,9 @@
-/* bsp.h
* This include file contains all board IO definitions.
- * COPYRIGHT (c) 1989-2009.
+ * COPYRIGHT (c) 1989-2014.
* On-Line Applications Research Corporation (OAR).
* The license and distribution terms for this file may be
@@ -123,68 +124,55 @@ rtems_isr_entry set_EE_vector(
rtems_isr_entry handler, /* isr routine */
rtems_vector_number vector /* vector number */
-void initialize_external_exception_vector ();
+void initialize_external_exception_vector(void);
* Hwr_init.c
-void init_PCI();
-void instruction_cache_enable ();
-void data_cache_enable ();
+void init_PCI(void);
+void init_RTC(void);
+void instruction_cache_enable(void);
+void data_cache_enable(void);
-void initialize_PCI_bridge ();
-uint16_t read_and_clear_irq ();
-void set_irq_mask(
- uint16_t value
-uint16_t get_irq_mask();
+void initialize_PCI_bridge(void);
+uint16_t read_and_clear_irq(void);
+void set_irq_mask(uint16_t value);
+uint16_t get_irq_mask(void);
* universe.c
-void initialize_universe();
-void set_irq_mask(
- uint16_t value
-void unmask_irq(
- uint16_t irq_idx
-void mask_irq(
- uint16_t irq_idx
-void init_irq_data_register();
-uint16_t read_and_clear_PMC_irq(
- uint16_t irq
-bool Is_PMC_IRQ(
- uint32_t pmc_irq,
- uint16_t status_word
-uint16_t read_and_clear_irq();
+void initialize_universe(void);
+void unmask_irq(uint16_t irq_idx);
+void mask_irq(uint16_t irq_idx);
+void init_irq_data_register(void);
+uint16_t read_and_clear_PMC_irq(uint16_t irq);
+bool Is_PMC_IRQ( uint32_t pmc_irq, uint16_t status_word);
+void set_vme_base_address(uint32_t base_address);
+uint32_t get_vme_slave_size(void);
+void set_vme_slave_size (uint32_t size);
* FPGA.c
+uint32_t Read_pci_device_register(uint32_t address);
+void Write_pci_device_register(uint32_t address, uint32_t data);
/* flash.c */
+unsigned int SCORE603e_FLASH_Disable(uint32_t unused);
+unsigned int SCORE603e_FLASH_verify_enable(void);
+unsigned int SCORE603e_FLASH_Enable_writes(uint32_t area);
-unsigned int SCORE603e_FLASH_Disable(
- uint32_t unused
-unsigned int SCORE603e_FLASH_verify_enable();
-unsigned int SCORE603e_FLASH_Enable_writes(
- uint32_t area /* Unused */
+ * PCI.c
+uint32_t PCI_bus_read(volatile uint32_t *_addr);
+void PCI_bus_write(volatile uint32_t *_addr, uint32_t _data);
#define BSP_FLASH_ENABLE_WRITES( _area) SCORE603e_FLASH_Enable_writes( _area )
#define BSP_FLASH_DISABLE_WRITES(_area) SCORE603e_FLASH_Disable( _area )
diff --git a/c/src/lib/libbsp/powerpc/score603e/irq/FPGA.c b/c/src/lib/libbsp/powerpc/score603e/irq/FPGA.c
index 33e22de..9c08d1d 100644
--- a/c/src/lib/libbsp/powerpc/score603e/irq/FPGA.c
+++ b/c/src/lib/libbsp/powerpc/score603e/irq/FPGA.c
@@ -1,6 +1,9 @@
-/* FPGA.c -- Bridge for second and subsequent generations
+ * FPGA.c -- Bridge for second and subsequent generations
@@ -120,7 +123,7 @@ void init_irq_data_register(void)
uint16_t irq
1.9.3
