[PATCH 28/42] gen68302/console: Fix warnings
Joel Sherrill
joel.sherrill at oarcorp.com
Fri Oct 17 15:23:44 UTC 2014
c/src/lib/libbsp/m68k/gen68302/console/console.c | 105 ++------
c/src/lib/libbsp/powerpc/shared/console/inch.c | 299 -----------------------
2 files changed, 26 insertions(+), 378 deletions(-)
delete mode 100644 c/src/lib/libbsp/powerpc/shared/console/inch.c
diff --git a/c/src/lib/libbsp/m68k/gen68302/console/console.c b/c/src/lib/libbsp/m68k/gen68302/console/console.c
index 1851e39..3d73b24 100644
--- a/c/src/lib/libbsp/m68k/gen68302/console/console.c
+++ b/c/src/lib/libbsp/m68k/gen68302/console/console.c
@@ -1,7 +1,9 @@
* Initialize the MC68302 SCC2 for console IO board support package.
- * COPYRIGHT (c) 1989-1999.
+ * COPYRIGHT (c) 1989-2014.
* On-Line Applications Research Corporation (OAR).
* The license and distribution terms for this file may be
@@ -19,14 +21,7 @@
/* console_initialize
* This routine initializes the console IO driver.
- * Input parameters: NONE
- * Output parameters: NONE
- * Return values:
rtems_device_driver console_initialize(
rtems_device_major_number major,
rtems_device_minor_number minor,
@@ -89,81 +84,37 @@ rtems_device_driver console_initialize(
-/* is_character_ready
- * Check to see if a character is available on the MC68302's SCC2. If so,
- * then return a TRUE (along with the character). Otherwise return FALSE.
- * Input parameters: pointer to location in which to return character
- * Output parameters: character (if available)
- * Return values: TRUE - character available
- * FALSE - no character available
-bool is_character_ready(
- char *ch /* -> character */
-#define RXS (m302.scc2.bd.rx[0].status)
-#define RXD (* ((volatile char *) m302.scc2.bd.rx[0].buffer))
- for (;;) {
- if (RXS & RBIT_HDLC_EMPTY_BIT)
- return false;
- *ch = RXD;
- RXS = RBIT_HDLC_EMPTY_BIT | RBIT_HDLC_WRAP_BIT;
- if ( *ch >= ' ' && *ch <= '~' )
- return true;
/* inbyte
* Receive a character from the MC68302's SCC2.
- * Return values: character read
-char inbyte( void )
+static char inbyte( void )
- char ch;
+ char ch;
- do {
- while (RXS & RBIT_HDLC_EMPTY_BIT)
- /* Wait until character received */ ;
+ do {
+ while (RXS & RBIT_HDLC_EMPTY_BIT)
+ /* Wait until character received */ ;
- ch = RXD;
+ ch = RXD;
+ RXS = RBIT_HDLC_EMPTY_BIT | RBIT_HDLC_WRAP_BIT;
- if (ch == '\r' || ch == '\n')
- break;
- } while (ch < ' ' || ch > '~');
+ if (ch == '\r' || ch == '\n')
+ break;
+ } while (ch < ' ' || ch > '~');
- return ch;
+ return ch;
/* outbyte
* Transmit a character out on the MC68302's SCC2.
* It may support XON/XOFF flow control.
- * ch - character to be transmitted
-void outbyte(
+static void outbyte(
char ch
@@ -173,32 +124,32 @@ void outbyte(
- while (TXS & RBIT_HDLC_READY_BIT)
- /* Wait until okay to transmit */ ;
+ while (TXS & RBIT_HDLC_READY_BIT)
+ /* Wait until okay to transmit */ ;
* Check for flow control requests and process.
while ( ! (RXS & RBIT_HDLC_EMPTY_BIT)) {
- if (RXD == XOFF)
- do {
- } while (RXD != XON);
+ if (RXD == XOFF) {
+ do {
+ } while (RXD != XON);
TXD = ch;
TXS = RBIT_HDLC_READY_BIT | RBIT_HDLC_WRAP_BIT;
if (ch == '\n')
- outbyte('\r');
+ outbyte('\r');
* Open entry point
rtems_device_driver console_open(
@@ -211,7 +162,6 @@ rtems_device_driver console_open(
* Close entry point
rtems_device_driver console_close(
@@ -224,7 +174,6 @@ rtems_device_driver console_close(
* read bytes from the serial port. We only have stdin.
rtems_device_driver console_read(
@@ -256,7 +205,6 @@ rtems_device_driver console_read(
* write bytes to the serial port. Stdout and stderr are the same.
rtems_device_driver console_write(
@@ -287,7 +235,6 @@ rtems_device_driver console_write(
* IO Control entry point
rtems_device_driver console_control(
diff --git a/c/src/lib/libbsp/powerpc/shared/console/inch.c b/c/src/lib/libbsp/powerpc/shared/console/inch.c
deleted file mode 100644
index 4cbb790..0000000
--- a/c/src/lib/libbsp/powerpc/shared/console/inch.c
+++ /dev/null
@@ -1,299 +0,0 @@
- * inch.c -- keyboard minimal driver
- * Copyright (C) 1999 Eric Valette. valette at crf.canon.fr
- * This code is based on the pc386 BSP inch.c so the following
- * copyright also applies :
- * (C) Copyright 1997 -
- * - NavIST Group - Real-Time Distributed Systems and Industrial Automation
- * http://pandora.ist.utl.pt
- * Instituto Superior Tecnico * Lisboa * PORTUGAL
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
-#include <bsp.h>
-#include <bsp/bootcard.h>
-#ifdef BSP_KBD_IOBASE
-#include <bsp/irq.h>
-#include "console.inl"
-| Constants
-#define KBD_CTL 0x1 /* -------------------------------- */
-#define KBD_DATA 0x0 /* Port offsets for PC keyboard controller */
-#define KBD_STATUS 0x4 /* -------------------------------- */
-#define KBD_BUF_SIZE 256
-| Global Variables
-static char key_map[] =
- 0,033,'1','2','3','4','5','6','7','8','9','0','-','=','\b','\t',
- 'q','w','e','r','t','y','u','i','o','p','[',']',015,0x80,
- 'a','s','d','f','g','h','j','k','l',';',047,0140,0x80,
- 0134,'z','x','c','v','b','n','m',',','.','/',0x80,
- '*',0x80,' ',0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,
- 0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,
- 0x80,0x80,0x80,'0',0177
-}; /* Keyboard scancode -> character map with no modifiers. */
-static char shift_map[] =
- 0,033,'!','@','#','$','%','^','&','*','(',')','_','+','\b','\t',
- 'Q','W','E','R','T','Y','U','I','O','P','{','}',015,0x80,
- 'A','S','D','F','G','H','J','K','L',':',042,'~',0x80,
- '|','Z','X','C','V','B','N','M','<','>','?',0x80,
- 0x80,0x80,0x80,0x80,'7','8','9',0x80,'4','5','6',0x80,
- '1','2','3','0',177
-}; /* Keyboard scancode -> character map with SHIFT key modifier. */
-static char kbd_buffer[KBD_BUF_SIZE];
-static uint16_t kbd_first = 0;
-static uint16_t kbd_last = 0;
-static uint16_t kbd_end = KBD_BUF_SIZE - 1;
-| Function: _IBMPC_scankey
-| Description: This function can be called during a poll for input, or by
-| an ISR. Basically any time you want to process a keypress.
-| Global Variables: key_map, shift_map.
-| Arguments: outChar - character read in case of a valid reading,
-| otherwise unchanged.
-| Returns: true in case a valid character has been read,
-| false otherwise.
-bool
-_IBMPC_scankey(char *outChar)
- unsigned char inChar;
- static int alt_pressed = 0;
- static int ctrl_pressed = 0;
- static int shift_pressed = 0;
- static int caps_pressed = 0;
- static int extended = 0;
- *outChar = 0; /* default value if we return false */
- /* Read keyboard controller, toggle enable */
- inChar=kbd_inb(KBD_CTL);
- kbd_outb(KBD_CTL, inChar & ~0x80);
- kbd_outb(KBD_CTL, inChar | 0x80);
- /* See if it has data */
- inChar=kbd_inb(KBD_STATUS);
- if ((inChar & 0x01) == 0)
- return false;
- /* Read the data. Handle nonsense with shift, control, etc. */
- inChar=kbd_inb(KBD_DATA);
- if (extended)
- extended--;
- switch (inChar)
- case 0xe0:
- extended = 2;
- return false;
- break;
- case 0x38:
- alt_pressed = 1;
- return false;
- break;
- case 0xb8:
- alt_pressed = 0;
- return false;
- break;
- case 0x1d:
- ctrl_pressed = 1;
- return false;
- break;
- case 0x9d:
- ctrl_pressed = 0;
- return false;
- break;
- case 0x2a:
- if (extended)
- return false;
- case 0x36:
- shift_pressed = 1;
- return false;
- break;
- case 0xaa:
- if (extended)
- return false;
- case 0xb6:
- shift_pressed = 0;
- return false;
- break;
- case 0x3a:
- caps_pressed = 1;
- return false;
- break;
- case 0xba:
- caps_pressed = 0;
- return false;
- break;
- case 0x53:
- if (ctrl_pressed && alt_pressed)
- bsp_reset(); /* ctrl+alt+del -> reboot */
- break;
- * Ignore unrecognized keys--usually arrow and such
- default:
- if ((inChar & 0x80) || (inChar > 0x39))
- /* High-bit on means key is being released, not pressed */
- return false;
- break;
- } /* switch */
- /* Strip high bit, look up in our map */
- inChar &= 0x7f;
- if (ctrl_pressed)
- *outChar = key_map[inChar];
- *outChar &= 037;
- else
- *outChar = shift_pressed ? shift_map[inChar] : key_map[inChar];
- if (caps_pressed)
- if (*outChar >= 'A' && *outChar <= 'Z')
- *outChar += 'a' - 'A';
- else if (*outChar >= 'a' && *outChar <= 'z')
- *outChar -= 'a' - 'A';
- return true;
-} /* _IBMPC_scankey */
-| Function: _IBMPC_keyboard_isr
-| Description: Interrupt Service Routine for keyboard (0x01) IRQ.
-| Global Variables: kbd_buffer, kbd_first, kbd_last.
-| Arguments: vector - standard RTEMS argument - see documentation.
-| Returns: standard return value - see documentation.
-void _IBMPC_keyboard_isr(void)
- if (_IBMPC_scankey(&kbd_buffer[kbd_last]))
- /* Got one; save it if there is enough room in buffer. */
- unsigned int next = (kbd_last == kbd_end) ? 0 : kbd_last + 1;
- if (next != kbd_first)
- kbd_last = next;
-} /* _IBMPC_keyboard_isr */
-| Function: _IBMPC_chrdy
-| Description: Check keyboard ISR buffer and return character if not empty.
-| Arguments: c - character read if keyboard buffer not empty, otherwise
-| unchanged.
-| Returns: true if keyboard buffer not empty, false otherwise.
-bool
-_IBMPC_chrdy(char *c)
- /* Check buffer our ISR builds */
- if (kbd_first != kbd_last)
- *c = kbd_buffer[kbd_first];
- kbd_first = (kbd_first + 1) % KBD_BUF_SIZE;
- return true;
- else
- return false;
-} /* _IBMPC_chrdy */
-| Function: _IBMPC_inch
-| Description: Poll keyboard until a character is ready and return it.
-| Global Variables: None.
-| Arguments: None.
-| Returns: character read from keyboard.
-char
-_IBMPC_inch(void)
- char c;
- while (!_IBMPC_chrdy(&c))
- continue;
- return c;
-} /* _IBMPC_inch */
- * Routine that can be used before interrupt management is initialized.
-char
-BSP_wait_polled_input(void)
- char c;
- while (!_IBMPC_scankey(&c))
- continue;
- return c;
-| Function: _IBMPC_inch_sleep
-| Description: If charcter is ready return it, otherwise sleep until
-| it is ready
-| Arguments: None.
-char
-_IBMPC_inch_sleep(void)
- char c;
- rtems_interval ticks_per_second;
- ticks_per_second = 0;
- for(;;)
- if(_IBMPC_chrdy(&c))
- return c;
- if(ticks_per_second == 0)
- rtems_clock_get(RTEMS_CLOCK_GET_TICKS_PER_SECOND,
- &ticks_per_second);
- rtems_task_wake_after((ticks_per_second+24)/25);
- return c;
-#endif
1.9.3
