STM32F4 register definitions and PLL settings patch
Chris Nott chrisn at vl.com.au
Mon Oct 20 00:24:58 UTC 2014
OK, thats good to hear. I have some extra code here I can incorporate
when I have time, like DMA driven I2S audio, SPI and UART.
On 19/10/2014 2:27 PM, Tomasz Gregorek wrote:
> Hi Chris
> Yes, there are more registers specific to specific CPU versions,
> different number of UARTs and other peripherals. As above, lets keep
> it simple for the start.
> Myself I have working UART driver with interrupt driven data receiver
> (currently it is polled UART). I should be able to push it in few
> days. I2C is half working but will take more time due to work overload.
> Cheers
> Tomasz
>>     Thanks and regards
>>     Tomasz
>>     2014-10-18 11:06 GMT+02:00 Chris Nott <chrisn at vl.com.au
>>     <mailto:chrisn at vl.com.au>>:
>>         Hi,
>>         I sent these header file changes previously, they didn't get
>>         picked up.
>>         I re-merged with the head, cleaned up formatting and fixed a
>>         bug with PLL_Q setting not generating the right auxiliary
>>         clock frequency for USB peripheral - Tomasz this was your
>>         change, could you please review my fix.
>>         Regards,
>>         Chris.
>>         _______________________________________________
>>         devel mailing list
>>         devel at rtems.org <mailto:devel at rtems.org>
>>         http://lists.rtems.org/mailman/listinfo/devel
>     devel mailing list
URL: <http://lists.rtems.org/pipermail/devel/attachments/20141019/218a6be3/attachment-0002.html>
