[PATCH 29/34] powerpc/shared/startup/bspstart.c: Fix warning for mvme2100
    Joel Sherrill
    joel.sherrill at oarcorp.com
    Mon Oct 20 20:34:31 UTC 2014
 c/src/lib/libbsp/powerpc/shared/startup/bspstart.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/c/src/lib/libbsp/powerpc/shared/startup/bspstart.c b/c/src/lib/libbsp/powerpc/shared/startup/bspstart.c
index 1d5d5d5..08dc12b 100644
--- a/c/src/lib/libbsp/powerpc/shared/startup/bspstart.c
+++ b/c/src/lib/libbsp/powerpc/shared/startup/bspstart.c
@@ -123,7 +123,7 @@ unsigned int EUMBBAR;
  * Register (EUMBBAR) as read from the processor configuration register using
  * Processor Address Map B (CHRP).
-unsigned int get_eumbbar(void) {
+static unsigned int get_eumbbar(void) {
   out_le32( (volatile unsigned *)0xfec00000, 0x80000078 );
   return in_le32( (volatile unsigned *)0xfee00000 );
1.9.3
