Warning Report 20 Oct 2014
Mon Oct 20 20:53:15 UTC 2014
Should have provided reports as attachments.
To repeat, help finishing this off is really appreciated.
On 10/20/2014 3:42 PM, Joel Sherrill wrote:
> Hi
> I just submitted my latest round of patches. With those applied,
> things are in pretty good shape but help is needed to wrap up
> the remaining issues. The biggest things to note are that:
> + the only warnings left in libcpu code is the PowerPC cache issue.
> + Only the following BSPs have warnings left in BSP specific code:
>     2 arm-nds  (inBSP=1 inLibCPU=0)
>     5 sparc-erc32  (inBSP=1 inLibCPU=0)
>     5 sparc-sis  (inBSP=1 inLibCPU=0)
>     3 arm-raspberrypi  (inBSP=2 inLibCPU=0)
>     6 arm-rtl22xx_t  (inBSP=2 inLibCPU=0)
>     7 arm-rtl22xx  (inBSP=2 inLibCPU=0)
>     7 sparc-leon2  (inBSP=3 inLibCPU=0)
>     9 powerpc-t32mppc  (inBSP=4 inLibCPU=2)
>     21 powerpc-mbx821_001  (inBSP=18 inLibCPU=0)
>     21 powerpc-mbx821_002b  (inBSP=18 inLibCPU=0)
>     21 powerpc-mbx821_002  (inBSP=18 inLibCPU=0)
>     21 powerpc-mbx860_001b  (inBSP=18 inLibCPU=0)
>     21 powerpc-mbx860_002  (inBSP=18 inLibCPU=0)
>     21 powerpc-mbx860_1b  (inBSP=18 inLibCPU=0)
>     21 powerpc-pghplus  (inBSP=18 inLibCPU=0)
>     21 powerpc-tqm8xx_stk8xx  (inBSP=18 inLibCPU=0)
>     25 powerpc-mbx860_005b  (inBSP=22 inLibCPU=0)
> + The arm BSP warnings are all for do_data_abort() and I am
> hoping someone will step up and address that per Sebastian's
> suggestion of just fix them properly.
> + The sparc BSP warnings appear to be things that have been
> addressed in the leon3 but I don't know what was done. If
> someone would look at those, it would be appreciated.
> + Thomas/Sebastian have committed to addressing the
> mpx8xx based BSPs.
> I am stepping back from addressing code in warnings in RTEMS
> code for at least a week.  I have a patch to newlib which might
> address some of the printf() format warnings in shared and test
> code. I want to make some progress on that.
> Community help is required to wrap this up.
> Thanks.
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
URL: <http://lists.rtems.org/pipermail/devel/attachments/20141020/b88063d6/attachment-0002.html>
Unique Warnings         :  138
BSPs                    :  183
BSPs with Zero          :  0
BSPs with only in shared:  139
         Warnings by Class
      2 cpp
     20 format=
      3 int-to-pointer-cast
      2 maybe-uninitialized
     46 missing-prototypes
      1 overflow
      7 pointer-to-int-cast
      5 unused-but-set-variable
     10 unused-function
     Top Ten BSPs with Warnings
    200 c/src/../../cpukit/libmisc/shell/hexdump-conv.c:145:4: warning: format '%lc' expects argument of type 'wint_t', but argument 4 has type 'wchar_t' [-Wformat=]
    180 c/src/../../cpukit/libfs/src/rfs/rtems-rfs-rtems.c:524:21: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
     78 c/src/../../cpukit/libmisc/shell/main_lsof.c:88:5: warning: format '%x' expects argument of type 'unsigned int', but argument 8 has type 'long unsigned int' [-Wformat=]
     78 c/src/../../cpukit/libmisc/shell/main_lsof.c:67:3: warning: format '%x' expects argument of type 'unsigned int', but argument 3 has type 'long unsigned int' [-Wformat=]
     78 c/src/../../cpukit/libmisc/shell/main_lsof.c:36:3: warning: format '%x' expects argument of type 'unsigned int', but argument 6 has type 'long unsigned int' [-Wformat=]
     78 c/src/../../cpukit/libmisc/shell/main_lsof.c:36:3: warning: format '%x' expects argument of type 'unsigned int', but argument 5 has type 'long unsigned int' [-Wformat=]
     78 c/src/../../cpukit/libmisc/shell/main_lsof.c:36:3: warning: format '%x' expects argument of type 'unsigned int', but argument 4 has type 'long unsigned int' [-Wformat=]
     78 c/src/../../cpukit/libmisc/shell/main_lsof.c:36:3: warning: format '%x' expects argument of type 'unsigned int', but argument 3 has type 'long unsigned int' [-Wformat=]
     78 c/src/../../cpukit/libmisc/capture/capture-cli.c:1424:18: warning: format '%x' expects argument of type 'unsigned int', but argument 3 has type 'long unsigned int' [-Wformat=]
     78 c/src/../../cpukit/libfs/src/rfs/rtems-rfs-buffer.c:61:17: warning: format '%u' expects argument of type 'unsigned int', but argument 2 has type 'long int' [-Wformat=]
     78 c/src/../../cpukit/libfs/src/rfs/rtems-rfs-buffer.c:55:7: warning: format '%u' expects argument of type 'unsigned int', but argument 2 has type 'long int' [-Wformat=]
     78 c/src/../../cpukit/libfs/src/rfs/rtems-rfs-buffer-bdbuf.c:72:13: warning: format '%u' expects argument of type 'unsigned int', but argument 2 has type 'long int' [-Wformat=]
     56 c/src/lib/libcpu/powerpc/shared/src/cache_.h:203:2: warning: #warning Most cache functions are not implemented [-Wcpp]
      7 c/src/lib/libbsp/powerpc/mbx8xx/startup/imbx8xx.c:161:6: warning: no previous prototype for '_InitMBX8xx' [-Wmissing-prototypes]
      7 c/src/lib/libbsp/powerpc/mbx8xx/irq/irq.c:79:5: warning: no previous prototype for 'BSP_irq_disable_at_cpm' [-Wmissing-prototypes]
      7 c/src/lib/libbsp/powerpc/mbx8xx/irq/irq.c:66:5: warning: no previous prototype for 'BSP_irq_enable_at_cpm' [-Wmissing-prototypes]
      7 c/src/lib/libbsp/powerpc/mbx8xx/irq/irq.c:271:1: warning: no previous prototype for 'BSP_CPM_irq_init' [-Wmissing-prototypes]
      7 c/src/lib/libbsp/powerpc/mbx8xx/irq/irq.c:252:6: warning: no previous prototype for 'BSP_SIU_irq_init' [-Wmissing-prototypes]
      7 c/src/lib/libbsp/powerpc/mbx8xx/irq/irq.c:149:5: warning: no previous prototype for 'C_dispatch_irq_handler' [-Wmissing-prototypes]
      7 c/src/lib/libbsp/powerpc/mbx8xx/ide/pcmcia_ide.c:42:6: warning: no previous prototype for 'mbx8xx_pcmciaide_probe' [-Wmissing-prototypes]
      7 c/src/lib/libbsp/powerpc/mbx8xx/ide/pcmcia_ide.c:351:19: warning: no previous prototype for 'mbx8xx_pcmciaide_config_io_speed' [-Wmissing-prototypes]
      7 c/src/lib/libbsp/powerpc/mbx8xx/ide/pcmcia_ide.c:328:5: warning: no previous prototype for 'mbx8xx_pcmciaide_control' [-Wmissing-prototypes]
      7 c/src/lib/libbsp/powerpc/mbx8xx/ide/pcmcia_ide.c:270:6: warning: no previous prototype for 'mbx8xx_pcmciaide_write_block' [-Wmissing-prototypes]
      7 c/src/lib/libbsp/powerpc/mbx8xx/ide/pcmcia_ide.c:213:6: warning: no previous prototype for 'mbx8xx_pcmciaide_read_block' [-Wmissing-prototypes]
      7 c/src/lib/libbsp/powerpc/mbx8xx/ide/pcmcia_ide.c:175:6: warning: no previous prototype for 'mbx8xx_pcmciaide_write_reg' [-Wmissing-prototypes]
      7 c/src/lib/libbsp/powerpc/mbx8xx/ide/pcmcia_ide.c:137:6: warning: no previous prototype for 'mbx8xx_pcmciaide_read_reg' [-Wmissing-prototypes]
      7 c/src/lib/libbsp/powerpc/mbx8xx/ide/pcmcia_ide.c:111:6: warning: no previous prototype for 'mbx8xx_pcmciaide_initialize' [-Wmissing-prototypes]
      7 c/src/lib/libbsp/powerpc/mbx8xx/console/console.c:714:1: warning: no previous prototype for 'serial_tstc' [-Wmissing-prototypes]
      7 c/src/lib/libbsp/powerpc/mbx8xx/console/console.c:693:1: warning: no previous prototype for 'serial_getc' [-Wmissing-prototypes]
      7 c/src/lib/libbsp/powerpc/mbx8xx/console/console.c:529:1: warning: no previous prototype for 'serial_init' [-Wmissing-prototypes]
      7 c/src/lib/libbsp/powerpc/mbx8xx/console/console.c:1102:5: warning: no previous prototype for 'mbx8xx_console_get_configuration' [-Wmissing-prototypes]
      7 c/src/../../cpukit/score/cpu/sh/context.c:171:6: warning: no previous prototype for '__CPU_Context_switch' [-Wmissing-prototypes]
      6 c/src/../../cpukit/libfs/src/dosfs/msdos_conv_utf8.c:255:31: warning: variable 'rv' set but not used [-Wunused-but-set-variable]
      6 c/src/../../cpukit/libblock/src/media-server.c:47:21: warning: variable 'sc' set but not used [-Wunused-but-set-variable]
      6 c/src/../../cpukit/libblock/src/media.c:80:21: warning: variable 'sc' set but not used [-Wunused-but-set-variable]
      5 c/src/../../cpukit/score/cpu/sparc/sparcv8-atomic.c:111:6: warning: conflicting types for built-in function '__atomic_compare_exchange_4' [enabled by default]
      4 c/src/../../cpukit/libmisc/shell/main_df.c:92:9: warning: format '%llu' expects argument of type 'long long unsigned int', but argument 6 has type 'fsblkcnt_t' [-Wformat=]
      4 c/src/../../cpukit/libmisc/shell/main_df.c:92:9: warning: format '%llu' expects argument of type 'long long unsigned int', but argument 5 has type 'long unsigned int' [-Wformat=]
      4 c/src/../../cpukit/libmisc/shell/main_df.c:92:9: warning: format '%llu' expects argument of type 'long long unsigned int', but argument 4 has type 'long unsigned int' [-Wformat=]
      4 c/src/../../cpukit/libmisc/shell/main_df.c:92:9: warning: format '%llu' expects argument of type 'long long unsigned int', but argument 3 has type 'long unsigned int' [-Wformat=]
      4 c/src/../../cpukit/libmisc/shell/main_df.c:105:9: warning: format '%llu' expects argument of type 'long long unsigned int', but argument 6 has type 'fsblkcnt_t' [-Wformat=]
      4 c/src/../../cpukit/libmisc/capture/capture-cli.c:233:3: warning: format '%lu' expects argument of type 'long unsigned int', but argument 6 has type 'uint32_t' [-Wformat=]
      4 c/src/../../cpukit/libmisc/capture/capture-cli.c:233:3: warning: format '%lu' expects argument of type 'long unsigned int', but argument 5 has type 'uint32_t' [-Wformat=]
      4 c/src/../../cpukit/libmisc/capture/capture-cli.c:233:3: warning: format '%lu' expects argument of type 'long unsigned int', but argument 4 has type 'uint32_t' [-Wformat=]
      4 c/src/../../cpukit/libmisc/capture/capture-cli.c:233:3: warning: format '%lu' expects argument of type 'long unsigned int', but argument 3 has type 'uint32_t' [-Wformat=]
      3 c/src/../../cpukit/libcsupport/src/__assert.c:52:43: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
      2 log/powerpc-virtex.log: #warning Most cache functions are not implemented
      2 log/powerpc-virtex5.log: #warning Most cache functions are not implemented
      2 log/powerpc-virtex4.log: #warning Most cache functions are not implemented
      2 log/powerpc-t32mppc.log: #warning Most cache functions are not implemented
      2 log/powerpc-ss555.log: #warning Most cache functions are not implemented
      2 log/powerpc-qoriq_p1020rdb.log: #warning Most cache functions are not implemented
      2 log/powerpc-qoriq_core_1.log: #warning Most cache functions are not implemented
      2 log/powerpc-qoriq_core_0.log: #warning Most cache functions are not implemented
      2 log/powerpc-qemuprep.log: #warning Most cache functions are not implemented
      2 log/powerpc-qemuprep-altivec.log: #warning Most cache functions are not implemented
      2 log/powerpc-phycore_mpc5554.log: #warning Most cache functions are not implemented
      2 log/powerpc-mvme5500.log: #warning Most cache functions are not implemented
      2 log/powerpc-mvme3100.log: #warning Most cache functions are not implemented
      2 log/powerpc-mvme2307.log: #warning Most cache functions are not implemented
      2 log/powerpc-mpc5674f_rsm6.log: #warning Most cache functions are not implemented
      2 log/powerpc-mpc5674fevb_spe.log: #warning Most cache functions are not implemented
      2 log/powerpc-mpc5674fevb.log: #warning Most cache functions are not implemented
      2 log/powerpc-mpc5674f_ecu508_boot.log: #warning Most cache functions are not implemented
      2 log/powerpc-mpc5674f_ecu508_app.log: #warning Most cache functions are not implemented
      2 log/powerpc-mpc5668g.log: #warning Most cache functions are not implemented
      2 log/powerpc-mpc5643l_evb.log: #warning Most cache functions are not implemented
      2 log/powerpc-mpc5643l_dpu.log: #warning Most cache functions are not implemented
      2 log/powerpc-mpc5566evb_spe.log: #warning Most cache functions are not implemented
      2 log/powerpc-mpc5566evb.log: #warning Most cache functions are not implemented
      2 log/powerpc-mcp750.log: #warning Most cache functions are not implemented
      2 log/powerpc-haleakala.log: #warning Most cache functions are not implemented
      2 log/powerpc-gwlcfm.log: #warning Most cache functions are not implemented
      2 log/powerpc-beatnik.log: #warning Most cache functions are not implemented
      2 log/m32c-m32csim.log:../../cpukit/../../../m32csim/lib/include/rtems/score/tls.h:125:5: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
      2 log/m32c-m32csim.log:../../cpukit/../../../m32csim/lib/include/rtems/score/tls.h:123:51: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
      2 log/m32c-m32csim.log:../../cpukit/../../../m32csim/lib/include/rtems/score/tls.h:123:25: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
      2 log/m32c-m32csim.log:../../cpukit/../../../m32csim/lib/include/rtems/score/tls.h:120:49: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
      2 c/src/lib/libbsp/sparc/erc32/../../sparc/shared/startup/bsp_fatal_halt.c:33:6: warning: no previous prototype for '_CPU_Fatal_halt' [-Wmissing-prototypes]
      2 c/src/lib/libbsp/powerpc/tqm8xx/startup/cpuinit.c:22:6: warning: no previous prototype for '_InitTQM8xx' [-Wmissing-prototypes]
      2 c/src/lib/libbsp/powerpc/tqm8xx/startup/cpuinit.c:129:6: warning: no previous prototype for 'cpu_init' [-Wmissing-prototypes]
      2 c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c:86:13: warning: no previous prototype for 'bsp_tqm_get_cib_string' [-Wmissing-prototypes]
      2 c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c:75:25: warning: variable 'level' set but not used [-Wunused-but-set-variable]
      2 c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c:116:20: warning: no previous prototype for 'bsp_tqm_get_cib_uint32' [-Wmissing-prototypes]
      2 c/src/lib/libbsp/powerpc/tqm8xx/spi/spi.c:906:19: warning: no previous prototype for 'bsp_register_spi' [-Wmissing-prototypes]
      2 c/src/lib/libbsp/powerpc/tqm8xx/../shared/startup/bspidle.c:27:7: warning: no previous prototype for 'bsp_idle_thread' [-Wmissing-prototypes]
      2 c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c:59:19: warning: no previous prototype for 'bsp_irq_enable_at_CPM' [-Wmissing-prototypes]
      2 c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c:52:19: warning: no previous prototype for 'bsp_irq_disable_at_CPM' [-Wmissing-prototypes]
      2 c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c:45:19: warning: no previous prototype for 'bsp_irq_enable_at_SIU' [-Wmissing-prototypes]
      2 c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c:38:19: warning: no previous prototype for 'bsp_irq_disable_at_SIU' [-Wmissing-prototypes]
      2 c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c:217:5: warning: no previous prototype for 'mpc8xx_exception_handler' [-Wmissing-prototypes]
      2 c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c:207:19: warning: no previous prototype for 'mpc8xx_siu_int_initialize' [-Wmissing-prototypes]
      2 c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c:187:19: warning: no previous prototype for 'mpc8xx_cpic_initialize' [-Wmissing-prototypes]
      2 c/src/lib/libbsp/powerpc/tqm8xx/clock/p_clock.c:45:5: warning: no previous prototype for 'BSP_connect_clock_handler' [-Wmissing-prototypes]
      2 c/src/lib/libbsp/arm/rtl22xx/../shared/abort/simple_abort.c:56:6: warning: no previous prototype for '_print_full_context' [-Wmissing-prototypes]
      2 c/src/lib/libbsp/arm/rtl22xx/../shared/abort/simple_abort.c:108:6: warning: no previous prototype for 'do_data_abort' [-Wmissing-prototypes]
      2 c/src/../../cpukit/score/cpu/m68k/cpu_asm.S:75:2: warning: #warning "_CPU_Context_Restart_self restoring FPU context not implemented" [-Wcpp]
      2 c/src/../../cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c:80:16: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
      2 c/src/../../cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c:33:12: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
      1 tools/cpu/nios2/ptf.c:92:26: warning: incompatible implicit declaration of built-in function â??freeâ?? [enabled by default]
      1 tools/cpu/nios2/ptf.c:77:9: warning: incompatible implicit declaration of built-in function â??freeâ?? [enabled by default]
      1 tools/cpu/nios2/ptf.c:166:31: warning: incompatible implicit declaration of built-in function â??freeâ?? [enabled by default]
      1 tools/cpu/nios2/ptf.c:156:29: warning: incompatible implicit declaration of built-in function â??freeâ?? [enabled by default]
      1 log/sh-gensh2.log:scitab.c:48:5: warning: no previous prototype for '_sci_get_brparms' [-Wmissing-prototypes]
      1 log/sh-gensh1.log:scitab.c:48:5: warning: no previous prototype for '_sci_get_brparms' [-Wmissing-prototypes]
      1 log/or1k-or1ksim.log:/users/joel/rtems-4.11-work/tools/lib/gcc/or1k-rtems4.11/4.8.3/../../../../or1k-rtems4.11/bin/ld: warning: cannot find entry symbol _start; defaulting to 0000000000000000
      1 log/or1k-or1ksim.log:../../cpukit/../../../or1ksim/lib/include/rtems/confdefs.h:2687:5: warning: (near initialization for 'Configuration.idle_task') [enabled by default]
      1 log/or1k-or1ksim.log:../../cpukit/../../../or1ksim/lib/include/rtems/confdefs.h:2687:5: warning: initialization from incompatible pointer type [enabled by default]
      1 log/m68k-m5484FireEngine.log: #warning "_CPU_Context_Restart_self restoring FPU context not implemented"
      1 log/m68k-COBRA5475.log: #warning "_CPU_Context_Restart_self restoring FPU context not implemented"
      1 c/src/../../testsuites/samples/fileio/init.c:420:7: warning: large integer implicitly truncated to unsigned type [-Woverflow]
      1 c/src/../../testsuites/samples/fileio/init.c:354:9: warning: left shift count >= width of type [enabled by default]
      1 c/src/lib/libbsp/sparc/leon2/../../sparc/shared/startup/bsp_fatal_halt.c:33:6: warning: no previous prototype for '_CPU_Fatal_halt' [-Wmissing-prototypes]
      1 c/src/lib/libbsp/sparc/leon2/../../sparc/shared/can/grcan_rasta.c:42:28: warning: no previous prototype for 'grcan_rasta_register' [-Wmissing-prototypes]
      1 c/src/lib/libbsp/sparc/leon2/../../sparc/shared/can/grcan_rasta.c:42:28: warning: no previous prototype for 'grcan_rasta_register_abs' [-Wmissing-prototypes]
      1 c/src/lib/libbsp/powerpc/tqm8xx/spi/spi.c:848:26: warning: 'bsp_dummy_spi_init' defined but not used [-Wunused-function]
      1 c/src/lib/libbsp/powerpc/tqm8xx/spi/spi.c:773:26: warning: 'bsp_pghplus_spi_init' defined but not used [-Wunused-function]
      1 c/src/lib/libbsp/powerpc/tqm8xx/spi/spi.c:743:26: warning: 'bsp_pghplus_spi_send_stop' defined but not used [-Wunused-function]
      1 c/src/lib/libbsp/powerpc/tqm8xx/spi/spi.c:694:26: warning: 'bsp_pghplus_spi_sel_addr' defined but not used [-Wunused-function]
      1 c/src/lib/libbsp/powerpc/tqm8xx/spi/spi.c:673:26: warning: 'bsp_dummy_spi_send_stop' defined but not used [-Wunused-function]
      1 c/src/lib/libbsp/powerpc/tqm8xx/spi/spi.c:629:26: warning: 'bsp_dummy_spi_sel_addr' defined but not used [-Wunused-function]
      1 c/src/lib/libbsp/powerpc/t32mppc/startup/bspstart.c:52:25: warning: variable 'level' set but not used [-Wunused-but-set-variable]
      1 c/src/lib/libbsp/powerpc/t32mppc/../../shared/console_write.c:36:21: warning: no previous prototype for 'console_write' [-Wmissing-prototypes]
      1 c/src/lib/libbsp/powerpc/t32mppc/../../shared/console_read.c:36:21: warning: no previous prototype for 'console_read' [-Wmissing-prototypes]
      1 c/src/lib/libbsp/powerpc/t32mppc/../../shared/console_control.c:37:21: warning: no previous prototype for 'console_control' [-Wmissing-prototypes]
      1 c/src/lib/libbsp/powerpc/mbx8xx/console/console.c:411:26: warning: 'do_poll_write' defined but not used [-Wunused-function]
      1 c/src/lib/libbsp/powerpc/mbx8xx/console/console.c:347:26: warning: 'do_poll_read' defined but not used [-Wunused-function]
      1 c/src/lib/libbsp/powerpc/mbx8xx/console/console.c:219:16: warning: '_EPPCBug_pollWrite' defined but not used [-Wunused-function]
      1 c/src/lib/libbsp/powerpc/mbx8xx/console/console.c:114:12: warning: '_EPPCBug_pollRead' defined but not used [-Wunused-function]
      1 c/src/lib/libbsp/arm/raspberrypi/../shared/abort/simple_abort.c:56:6: warning: no previous prototype for '_print_full_context' [-Wmissing-prototypes]
      1 c/src/lib/libbsp/arm/raspberrypi/../shared/abort/simple_abort.c:108:6: warning: no previous prototype for 'do_data_abort' [-Wmissing-prototypes]
      1 c/src/lib/libbsp/arm/nds/libnds/source/arm9/image.c:124:20: warning: assignment from incompatible pointer type [enabled by default]
      1 c/src/../../cpukit/score/src/threadstartmultitasking.c:82:1: warning: 'noreturn' function does return [enabled by default]
      1 c/src/../../cpukit/score/src/objectextendinformation.c:159:13: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
      1 c/src/../../cpukit/score/src/objectextendinformation.c:154:9: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
      1 c/src/../../cpukit/libmisc/utf8proc/utf8proc.c:148:5: warning: left shift count >= width of type [enabled by default]
      1 c/src/../../cpukit/libfs/src/dosfs/msdos_conv.c:452:48: warning: 'c' may be used uninitialized in this function [-Wmaybe-uninitialized]
      1 c/src/../../cpukit/libcsupport/src/vprintk.c:199:41: warning: 'num' may be used uninitialized in this function [-Wmaybe-uninitialized]
1 arm-altcycv_devkit  (only shared)
1 arm-altcycv_devkit_smp  (only shared)
1 arm-arm1136jfs  (only shared)
1 arm-arm1136js  (only shared)
1 arm-arm7tdmi  (only shared)
1 arm-arm920  (only shared)
1 arm-armcortexa9  (only shared)
1 arm-csb336  (only shared)
1 arm-csb337  (only shared)
1 arm-csb637  (only shared)
1 arm-edb7312  (only shared)
1 arm-gba  (only shared)
1 arm-gp32  (only shared)
1 arm-gumstix  (only shared)
1 arm-kit637_v6  (only shared)
1 arm-lm3s3749  (only shared)
1 arm-lm3s6965  (only shared)
1 arm-lm3s6965_qemu  (only shared)
1 arm-lm4f120  (only shared)
1 arm-lpc17xx_ea_ram  (only shared)
1 arm-lpc17xx_ea_rom_int  (only shared)
1 arm-lpc17xx_plx800_ram  (only shared)
1 arm-lpc17xx_plx800_rom_int  (only shared)
1 arm-lpc2362  (only shared)
1 arm-lpc23xx_tli800  (only shared)
1 arm-lpc24xx_ea  (only shared)
1 arm-lpc24xx_ncs_ram  (only shared)
1 arm-lpc24xx_ncs_rom_ext  (only shared)
1 arm-lpc24xx_ncs_rom_int  (only shared)
1 arm-lpc24xx_plx800_ram  (only shared)
1 arm-lpc24xx_plx800_rom_int  (only shared)
1 arm-lpc32xx_mzx  (only shared)
1 arm-lpc32xx_mzx_stage_1  (only shared)
1 arm-lpc32xx_mzx_stage_2  (only shared)
1 arm-lpc32xx_phycore  (only shared)
1 arm-lpc40xx_ea_ram  (only shared)
1 arm-lpc40xx_ea_rom_int  (only shared)
1 arm-realview_pbx_a9_qemu  (only shared)
1 arm-realview_pbx_a9_qemu_smp  (only shared)
1 arm-smdk2410  (only shared)
1 arm-stm32f105rc  (only shared)
1 arm-stm32f4  (only shared)
1 arm-tms570ls3137_hdk_intram  (only shared)
1 arm-tms570ls3137_hdk  (only shared)
1 arm-tms570ls3137_hdk_sdram  (only shared)
1 arm-xilinx_zynq_a9_qemu  (only shared)
1 arm-xilinx_zynq_zc702  (only shared)
1 arm-xilinx_zynq_zc706  (only shared)
1 arm-xilinx_zynq_zedboard  (only shared)
1 lm32-lm32_evr  (only shared)
1 lm32-milkymist  (only shared)
1 mips-csb350  (only shared)
1 mips-genmongoosev  (only shared)
1 mips-hurricane  (only shared)
1 mips-jmr3904  (only shared)
1 mips-malta  (only shared)
1 mips-rbtx4925  (only shared)
1 mips-rbtx4938  (only shared)
2 h8300-h8sxsim  (only shared)
3 avr-avrtest  (only shared)
3 powerpc-brs5l  (only shared)
3 powerpc-brs6l  (only shared)
3 powerpc-br_uid  (only shared)
3 powerpc-dp2  (only shared)
3 powerpc-ep1a  (only shared)
3 powerpc-hsc_cm01  (only shared)
3 powerpc-icecube  (only shared)
3 powerpc-mpc8260ads  (only shared)
3 powerpc-mpc8309som  (only shared)
3 powerpc-mpc8313erdb  (only shared)
3 powerpc-mpc8349eamds  (only shared)
3 powerpc-mtx603e  (only shared)
3 powerpc-mvme2100  (only shared)
3 powerpc-pm520_cr825  (only shared)
3 powerpc-pm520_ze30  (only shared)
3 powerpc-psim  (only shared)
3 powerpc-qemuppc  (only shared)
3 powerpc-score603e  (only shared)
3 v850-v850e1sim  (only shared)
3 v850-v850e2sim  (only shared)
3 v850-v850e2v3sim  (only shared)
3 v850-v850esim  (only shared)
3 v850-v850essim  (only shared)
3 v850-v850sim  (only shared)
4 arm-lpc1768_mbed_ahb_ram_eth  (only shared)
4 arm-lpc1768_mbed_ahb_ram  (only shared)
4 arm-lpc1768_mbed  (only shared)
4 sh-gensh4  (only shared)
4 sh-simsh1  (only shared)
4 sh-simsh2e  (only shared)
4 sh-simsh2  (only shared)
4 sh-simsh4  (only shared)
4 sparc-leon3  (only shared)
4 sparc-ngmp  (only shared)
5 nios2-nios2_iss  (only shared)
5 powerpc-beatnik  (inBSP=0 inLibCPU=2)
5 powerpc-gwlcfm  (inBSP=0 inLibCPU=2)
5 powerpc-mcp750  (inBSP=0 inLibCPU=2)
5 powerpc-mpc5566evb  (inBSP=0 inLibCPU=2)
5 powerpc-mpc5566evb_spe  (inBSP=0 inLibCPU=2)
5 powerpc-mpc5643l_dpu  (inBSP=0 inLibCPU=2)
5 powerpc-mpc5643l_evb  (inBSP=0 inLibCPU=2)
5 powerpc-mpc5668g  (inBSP=0 inLibCPU=2)
5 powerpc-mpc5674f_ecu508_app  (inBSP=0 inLibCPU=2)
5 powerpc-mpc5674f_ecu508_boot  (inBSP=0 inLibCPU=2)
5 powerpc-mpc5674fevb  (inBSP=0 inLibCPU=2)
5 powerpc-mpc5674fevb_spe  (inBSP=0 inLibCPU=2)
5 powerpc-mpc5674f_rsm6  (inBSP=0 inLibCPU=2)
5 powerpc-mvme2307  (inBSP=0 inLibCPU=2)
5 powerpc-mvme3100  (inBSP=0 inLibCPU=2)
5 powerpc-mvme5500  (inBSP=0 inLibCPU=2)
5 powerpc-phycore_mpc5554  (inBSP=0 inLibCPU=2)
5 powerpc-qemuprep-altivec  (inBSP=0 inLibCPU=2)
5 powerpc-qemuprep  (inBSP=0 inLibCPU=2)
5 powerpc-qoriq_core_0  (inBSP=0 inLibCPU=2)
5 powerpc-qoriq_core_1  (inBSP=0 inLibCPU=2)
5 powerpc-qoriq_p1020rdb  (inBSP=0 inLibCPU=2)
5 powerpc-ss555  (inBSP=0 inLibCPU=2)
5 powerpc-virtex4  (inBSP=0 inLibCPU=2)
5 powerpc-virtex5  (inBSP=0 inLibCPU=2)
5 powerpc-virtex  (inBSP=0 inLibCPU=2)
5 sh-gensh1  (only shared)
5 sh-gensh2  (only shared)
6 powerpc-haleakala  (inBSP=0 inLibCPU=2)
13 m32c-m32csim  (only shared)
21 bfin-bf537Stamp  (only shared)
21 bfin-eZKit533  (only shared)
21 bfin-TLL6527M  (only shared)
21 h8300-h8sim  (only shared)
21 i386-pc386  (only shared)
21 i386-pc486  (only shared)
21 i386-pc586  (only shared)
21 i386-pc586-sse  (only shared)
21 i386-pc686  (only shared)
21 i386-pcp4  (only shared)
21 m32r-m32rsim  (only shared)
21 moxie-moxiesim  (only shared)
21 sparc64-niagara  (only shared)
21 sparc64-usiii  (only shared)
23 m68k-av5282  (only shared)
23 m68k-csb360  (only shared)
23 m68k-gen68302  (only shared)
23 m68k-gen68340  (only shared)
23 m68k-gen68360_040  (only shared)
23 m68k-gen68360  (only shared)
23 m68k-idp  (only shared)
23 m68k-mcf5206elite  (only shared)
23 m68k-mcf52235  (only shared)
23 m68k-mcf5225x  (only shared)
23 m68k-mcf5235  (only shared)
23 m68k-mcf5329  (only shared)
23 m68k-mrm332  (only shared)
23 m68k-mvme147  (only shared)
23 m68k-mvme147s  (only shared)
23 m68k-mvme162lx  (only shared)
23 m68k-mvme162  (only shared)
23 m68k-mvme167  (only shared)
23 m68k-ods68302  (only shared)
23 m68k-pgh360  (only shared)
23 m68k-sim68000  (only shared)
23 m68k-simcpu32  (only shared)
23 m68k-uC5282  (only shared)
24 m68k-COBRA5475  (only shared)
24 m68k-m5484FireEngine  (only shared)
25 or1k-or1ksim  (only shared)
26 m68k-mvme136  (only shared)
