[PATCH] smptests/smpcache01: Disable SMP cache manager test when not applicable
Daniel Cederman cederman at gaisler.com
Mon Sep 1 11:15:19 UTC 2014
 testsuites/smptests/smpcache01/init.c | 29 ++++++++++++++++++++++++++---
 1 file changed, 26 insertions(+), 3 deletions(-)
diff --git a/testsuites/smptests/smpcache01/init.c b/testsuites/smptests/smpcache01/init.c
index dd2f9f1..48154d4 100644
--- a/testsuites/smptests/smpcache01/init.c
+++ b/testsuites/smptests/smpcache01/init.c
@@ -20,6 +20,8 @@
 const char rtems_test_name[] = "SMPCACHE 1";
+char test_is_applicable = 1;
 #define CPU_COUNT 32
 #define WORKER_PRIORITY 100
@@ -33,7 +35,19 @@ _Cache_manager_Send_smp_msg(
     Cache_manager_Function_ptr func,
     const void * addr,
     size_t size
+  ) __attribute__((weak));
+void
+_Cache_manager_Send_smp_msg(
+    const size_t setsize,
+    const cpu_set_t *set,
+    Cache_manager_Function_ptr func,
+    const void * addr,
+    size_t size
+  test_is_applicable = 0;
 typedef struct {
   SMP_barrier_Control barrier;
@@ -44,6 +58,11 @@ static test_context ctx = {
   .barrier = SMP_BARRIER_CONTROL_INITIALIZER,
+static void test_applicable( const void *d_addr, size_t n_bytes )
+  test_is_applicable = 1;
 static void test_cache_message( const void *d_addr, size_t n_bytes )
   rtems_test_assert(n_bytes == 123);
@@ -260,12 +279,16 @@ static void test_smp_cache_manager( void )
   all_tests();
 static void Init(rtems_task_argument arg)
   TEST_BEGIN();
-  test_smp_cache_manager();
+  _Cache_manager_Send_smp_msg( 0, 0, test_applicable, 0, 123 );
+  if ( test_is_applicable )
+    test_smp_cache_manager();
+  else
+    printf("Test not applicable!\n");
   TEST_END();
   rtems_test_exit(0);
2.1.0
