[PATCH] Adding "eth" linker script section for arm bsp.
Tue Sep 2 12:01:06 UTC 2014
Hello Federico,
since this just adds a linker command file variant, I would prefer to just add
the linker command file without the BSP name.  You can then use "-qnolinkcmds
-T linkcmds.lpc1768_mbed_ahb_ram_eth" to select this memory map.
On 01/09/14 15:21, Federico Casares wrote:
> Attached the new version of this add.
> Regards
> On Fri, Aug 29, 2014 at 2:30 PM, Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     Hello Federico,
>     you can do it like this:
>     http://git.rtems.org/rtems/__tree/c/src/lib/libbsp/arm/__altera-cyclone-v/startup/__linkcmds.altcycv_devkit
>     <http://git.rtems.org/rtems/tree/c/src/lib/libbsp/arm/altera-cyclone-v/startup/linkcmds.altcycv_devkit>
>     You can also use the INCLUDE directive to reduce the copy and paste.
>     Sebastian Huber, embedded brains GmbH
>     Address : Dornierstr. 4, D-82178 Puchheim, Germany
>     Phone   : +49 89 189 47 41-16
>     Fax     : +49 89 189 47 41-09
>     E-Mail  : sebastian.huber at embedded-__brains.de
>     PGP     : Public key available on request.
>     Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> http://www.tallertechnologies.com <http://www.tallertechnologies.com>
> Casares, Federico
> Sr. Software Engineer
> Taller Technologies Argentina
> San Lorenzo 47, 3rd Floor, Office 5
> Córdoba, Argentina
