nios2 fails to link spcache01
Wed Sep 3 14:44:43 UTC 2014
Hi
Any suggestions on how to address this?
nios2-rtems4.11-gcc -B../../../../../nios2_iss/lib/ -specs bsp_specs
-qrtems -DHAVE_CONFIG_H -I.
-I../../../../../../../rtems/c/src/../../testsuites/sptests/spcache01
-I..
-I../../../../../../../rtems/c/src/../../testsuites/sptests/../support/include
-mno-hw-mul -mno-hw-div -O0 -g -Wall -Wmissing-prototypes
-Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT
init.o -MD -MP -MF .deps/init.Tpo -c -o init.o
../../../../../../../rtems/c/src/../../testsuites/sptests/spcache01/init.c
mv -f .deps/init.Tpo .deps/init.Po
-qrtems -mno-hw-mul -mno-hw-div -O0 -g -Wall -Wmissing-prototypes
-mno-hw-mul -mno-hw-div   -o spcache01.exe init.o
init.o: In function `test_data_flush_and_invalidate':
/users/joel/rtems-4.11-work/rtems-testing/rtems/build-nios2-nios2_iss-rtems/nios2-rtems4.11/c/nios2_iss/testsuites/sptests/spcache01/../../../../../../../rtems/c/src/../../testsuites/sptests/spcache01/init.c:46:
undefined reference to `rtems_cache_get_data_line_size'
/users/joel/rtems-4.11-work/rtems-testing/rtems/build-nios2-nios2_iss-rtems/nios2-rtems4.11/c/nios2_iss/testsuites/sptests/spcache01/../../../../../../../rtems/c/src/../../testsuites/sptests/spcache01/init.c:64:
undefined reference to `rtems_cache_flush_multiple_data_lines'
/users/joel/rtems-4.11-work/rtems-testing/rtems/build-nios2-nios2_iss-rtems/nios2-rtems4.11/c/nios2_iss/testsuites/sptests/spcache01/../../../../../../../rtems/c/src/../../testsuites/sptests/spcache01/init.c:74:
undefined reference to `rtems_cache_invalidate_multiple_data_lines'
/users/joel/rtems-4.11-work/rtems-testing/rtems/build-nios2-nios2_iss-rtems/nios2-rtems4.11/c/nios2_iss/testsuites/sptests/spcache01/../../../../../../../rtems/c/src/../../testsuites/sptests/spcache01/init.c:91:
/users/joel/rtems-4.11-work/rtems-testing/rtems/build-nios2-nios2_iss-rtems/nios2-rtems4.11/c/nios2_iss/testsuites/sptests/spcache01/../../../../../../../rtems/c/src/../../testsuites/sptests/spcache01/init.c:92:
init.o: In function `test_timing':
/users/joel/rtems-4.11-work/rtems-testing/rtems/build-nios2-nios2_iss-rtems/nios2-rtems4.11/c/nios2_iss/testsuites/sptests/spcache01/../../../../../../../rtems/c/src/../../testsuites/sptests/spcache01/init.c:179:
undefined reference to `rtems_cache_get_data_cache_size'
/users/joel/rtems-4.11-work/rtems-testing/rtems/build-nios2-nios2_iss-rtems/nios2-rtems4.11/c/nios2_iss/testsuites/sptests/spcache01/../../../../../../../rtems/c/src/../../testsuites/sptests/spcache01/init.c:187:
/users/joel/rtems-4.11-work/rtems-testing/rtems/build-nios2-nios2_iss-rtems/nios2-rtems4.11/c/nios2_iss/testsuites/sptests/spcache01/../../../../../../../rtems/c/src/../../testsuites/sptests/spcache01/init.c:195:
/users/joel/rtems-4.11-work/rtems-testing/rtems/build-nios2-nios2_iss-rtems/nios2-rtems4.11/c/nios2_iss/testsuites/sptests/spcache01/../../../../../../../rtems/c/src/../../testsuites/sptests/spcache01/init.c:202:
undefined reference to `rtems_cache_flush_entire_data'
/users/joel/rtems-4.11-work/rtems-testing/rtems/build-nios2-nios2_iss-rtems/nios2-rtems4.11/c/nios2_iss/testsuites/sptests/spcache01/../../../../../../../rtems/c/src/../../testsuites/sptests/spcache01/init.c:222:
/users/joel/rtems-4.11-work/rtems-testing/rtems/build-nios2-nios2_iss-rtems/nios2-rtems4.11/c/nios2_iss/testsuites/sptests/spcache01/../../../../../../../rtems/c/src/../../testsuites/sptests/spcache01/init.c:242:
/users/joel/rtems-4.11-work/rtems-testing/rtems/build-nios2-nios2_iss-rtems/nios2-rtems4.11/c/nios2_iss/testsuites/sptests/spcache01/../../../../../../../rtems/c/src/../../testsuites/sptests/spcache01/init.c:262:
/users/joel/rtems-4.11-work/rtems-testing/rtems/build-nios2-nios2_iss-rtems/nios2-rtems4.11/c/nios2_iss/testsuites/sptests/spcache01/../../../../../../../rtems/c/src/../../testsuites/sptests/spcache01/init.c:282:
/users/joel/rtems-4.11-work/rtems-testing/rtems/build-nios2-nios2_iss-rtems/nios2-rtems4.11/c/nios2_iss/testsuites/sptests/spcache01/../../../../../../../rtems/c/src/../../testsuites/sptests/spcache01/init.c:302:
/users/joel/rtems-4.11-work/rtems-testing/rtems/build-nios2-nios2_iss-rtems/nios2-rtems4.11/c/nios2_iss/testsuites/sptests/spcache01/../../../../../../../rtems/c/src/../../testsuites/sptests/spcache01/init.c:318:
undefined reference to `rtems_cache_get_instruction_line_size'
undefined reference to `rtems_cache_get_instruction_cache_size'
/users/joel/rtems-4.11-work/rtems-testing/rtems/build-nios2-nios2_iss-rtems/nios2-rtems4.11/c/nios2_iss/testsuites/sptests/spcache01/../../../../../../../rtems/c/src/../../testsuites/sptests/spcache01/init.c:326:
/users/joel/rtems-4.11-work/rtems-testing/rtems/build-nios2-nios2_iss-rtems/nios2-rtems4.11/c/nios2_iss/testsuites/sptests/spcache01/../../../../../../../rtems/c/src/../../testsuites/sptests/spcache01/init.c:334:
/users/joel/rtems-4.11-work/rtems-testing/rtems/build-nios2-nios2_iss-rtems/nios2-rtems4.11/c/nios2_iss/testsuites/sptests/spcache01/../../../../../../../rtems/c/src/../../testsuites/sptests/spcache01/init.c:341:
undefined reference to `rtems_cache_invalidate_entire_instruction'
/users/joel/rtems-4.11-work/rtems-testing/rtems/build-nios2-nios2_iss-rtems/nios2-rtems4.11/c/nios2_iss/testsuites/sptests/spcache01/../../../../../../../rtems/c/src/../../testsuites/sptests/spcache01/init.c:360:
undefined reference to `rtems_cache_invalidate_multiple_instruction_lines'
collect2: error: ld returned 1 exit status
gmake[6]: *** [spcache01.exe] Error 1
