[PATCH 06/23] lm3s69xx/.../bspreset.c: Eliminate warning for set not used variable
Wed Sep 3 15:26:00 UTC 2014
 c/src/lib/libbsp/arm/lm3s69xx/startup/bspreset.c | 1 +
 1 file changed, 1 insertion(+)
diff --git a/c/src/lib/libbsp/arm/lm3s69xx/startup/bspreset.c b/c/src/lib/libbsp/arm/lm3s69xx/startup/bspreset.c
index 9b8764e..6509f81 100644
--- a/c/src/lib/libbsp/arm/lm3s69xx/startup/bspreset.c
+++ b/c/src/lib/libbsp/arm/lm3s69xx/startup/bspreset.c
@@ -24,6 +24,7 @@ void bsp_reset(void)
   rtems_interrupt_level level;
+  (void) level;
   rtems_interrupt_disable(level);
   _ARMV7M_SCB->aircr = ARMV7M_SCB_AIRCR_VECTKEY
1.9.3
