[PATCH 09/23] rtl22xx/.../bspreset.c: Eliminate warning for set not used variable
Wed Sep 3 15:26:03 UTC 2014
 c/src/lib/libbsp/arm/rtl22xx/startup/bspreset.c | 5 +++--
 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/c/src/lib/libbsp/arm/rtl22xx/startup/bspreset.c b/c/src/lib/libbsp/arm/rtl22xx/startup/bspreset.c
index d3ee06b..deb58ac 100644
--- a/c/src/lib/libbsp/arm/rtl22xx/startup/bspreset.c
+++ b/c/src/lib/libbsp/arm/rtl22xx/startup/bspreset.c
@@ -16,9 +16,10 @@ void bsp_reset(void)
   SKYEYE_MAGIC_ADDRESS = 0xff;
 #else
-    rtems_interrupt_level level;
+  rtems_interrupt_level level;
-    rtems_interrupt_disable(level);
+  (void) level;
+  rtems_interrupt_disable(level);
   #ifdef __thumb__
     int tmp;
1.9.3
