[PATCH 1/2] capture: Split user extension methods out.
Jennifer Averett jennifer.averett at oarcorp.com
Wed Sep 3 18:03:51 UTC 2014
 cpukit/libmisc/Makefile.am                      |   3 +-
 cpukit/libmisc/capture/capture.c                | 428 +++--------------------
 cpukit/libmisc/capture/capture_user_extension.c | 435 ++++++++++++++++++++++++
 cpukit/libmisc/capture/captureimpl.h            | 195 +++++++++++
 4 files changed, 673 insertions(+), 388 deletions(-)
 create mode 100644 cpukit/libmisc/capture/capture_user_extension.c
 create mode 100644 cpukit/libmisc/capture/captureimpl.h
diff --git a/cpukit/libmisc/Makefile.am b/cpukit/libmisc/Makefile.am
index bc9edd0..ee7745d 100644
--- a/cpukit/libmisc/Makefile.am
+++ b/cpukit/libmisc/Makefile.am
@@ -18,7 +18,8 @@ EXTRA_DIST += capture/README
 noinst_LIBRARIES += libcapture.a
 libcapture_a_SOURCES = capture/capture.c capture/capture-cli.c \
-    capture/capture.h capture/capture-cli.h
+    capture/capture_user_extension.c \
+    capture/capture.h capture/captureimpl.h capture/capture-cli.h
 ## cpuuse
 EXTRA_DIST += cpuuse/README
diff --git a/cpukit/libmisc/capture/capture.c b/cpukit/libmisc/capture/capture.c
index 9ec07b8..54b2894 100644
--- a/cpukit/libmisc/capture/capture.c
+++ b/cpukit/libmisc/capture/capture.c
@@ -29,7 +29,7 @@
-#include "capture.h"
+#include "captureimpl.h"
@@ -57,46 +57,6 @@
 #define RTEMS_CAPTURE_RECORD_EVENTS  (0)
 #endif
-static bool
-rtems_capture_create_task (rtems_tcb* current_task,
-                           rtems_tcb* new_task);
-static void
-rtems_capture_start_task (rtems_tcb* current_task,
-                          rtems_tcb* started_task);
-static void
-rtems_capture_restart_task (rtems_tcb* current_task,
-                            rtems_tcb* restarted_task);
-static void
-rtems_capture_delete_task (rtems_tcb* current_task,
-                           rtems_tcb* deleted_task);
-static void
-rtems_capture_switch_task (rtems_tcb* current_task,
-                           rtems_tcb* heir_task);
-static void
-rtems_capture_begin_task (rtems_tcb* begin_task);
-static void
-rtems_capture_exitted_task (rtems_tcb* exitted_task);
-static void
-rtems_capture_terminated_task (rtems_tcb* terminated_task);
- * Global capture flags.
-#define RTEMS_CAPTURE_ON             (1U << 0)
-#define RTEMS_CAPTURE_NO_MEMORY      (1U << 1)
-#define RTEMS_CAPTURE_OVERFLOW       (1U << 2)
-#define RTEMS_CAPTURE_TRIGGERED      (1U << 3)
-#define RTEMS_CAPTURE_READER_ACTIVE  (1U << 4)
-#define RTEMS_CAPTURE_READER_WAITING (1U << 5)
-#define RTEMS_CAPTURE_GLOBAL_WATCH   (1U << 6)
-#define RTEMS_CAPTURE_ONLY_MONITOR   (1U << 7)
  * RTEMS Capture Data.
@@ -110,7 +70,6 @@ static uint32_t                 capture_flags;
 static rtems_capture_task_t*    capture_tasks;
 static rtems_capture_control_t* capture_controls;
 static int                      capture_extension_index;
-static rtems_id                 capture_id;
 static rtems_capture_timestamp  capture_timestamp;
 static rtems_task_priority      capture_ceiling;
 static rtems_task_priority      capture_floor;
@@ -118,18 +77,6 @@ static rtems_id                 capture_reader;
 static rtems_interrupt_lock     capture_lock =
   RTEMS_INTERRUPT_LOCK_INITIALIZER("capture");
-static const rtems_extensions_table capture_extensions = {
-  .thread_create    = rtems_capture_create_task,
-  .thread_start     = rtems_capture_start_task,
-  .thread_restart   = rtems_capture_restart_task,
-  .thread_delete    = rtems_capture_delete_task,
-  .thread_switch    = rtems_capture_switch_task,
-  .thread_begin     = rtems_capture_begin_task,
-  .thread_exitted   = rtems_capture_exitted_task,
-  .fatal            = NULL,
-  .thread_terminate = rtems_capture_terminated_task
  * RTEMS Event text.
@@ -151,11 +98,43 @@ static const char* capture_event_text[] =
   "TIMESTAMP"
+void rtems_capture_set_extension_index(int index)
+  capture_extension_index = index;
+int  rtems_capture_get_extension_index(void)
+  return capture_extension_index;
+uint32_t rtems_capture_get_flags(void)
+  return capture_flags;
+void rtems_capture_set_flags(uint32_t mask)
+  capture_flags |= mask;
+rtems_capture_task_t* rtems_capture_find_capture_task( rtems_id ct_id )
+  rtems_capture_task_t* ct;
+  for (ct = capture_tasks; ct; ct = ct->forw) {
+    if (ct->id == ct_id)
+      break;
+  return ct;
  * This function returns the current time. If a handler is provided
  * by the user get the time from that.
-static inline void
+void
 rtems_capture_get_time (rtems_capture_time_t* time)
   if (capture_timestamp)
@@ -290,7 +269,7 @@ rtems_capture_refcount_down (rtems_capture_task_t* task)
  * This function setups a stack so its usage can be monitored.
-static inline void
+void
 rtems_capture_init_stack_usage (rtems_capture_task_t* task)
   if (task->tcb)
@@ -378,7 +357,7 @@ rtems_capture_create_control (rtems_name name, rtems_id id)
  * This function create the task control.
-static inline rtems_capture_task_t*
 rtems_capture_create_capture_task (rtems_tcb* new_task)
   rtems_interrupt_lock_context lock_context;
@@ -456,7 +435,7 @@ rtems_capture_create_capture_task (rtems_tcb* new_task)
  * is 0 and the tcb has been cleared signalling the task has been
  * deleted.
-static inline void
+void
 rtems_capture_destroy_capture_task (rtems_capture_task_t* task)
   if (task)
@@ -487,7 +466,7 @@ rtems_capture_destroy_capture_task (rtems_capture_task_t* task)
  * This function records a capture record into the capture buffer.
-static inline void
+void
 rtems_capture_record (rtems_capture_task_t* task,
                       uint32_t              events)
@@ -550,7 +529,7 @@ rtems_capture_record (rtems_capture_task_t* task,
  * See if we have triggered and if not see if this event is a
  * cause of a trigger.
-static bool
+bool
 rtems_capture_trigger (rtems_capture_task_t* ft,
                        rtems_capture_task_t* tt,
                        uint32_t              events)
@@ -616,328 +595,12 @@ rtems_capture_trigger (rtems_capture_task_t* ft,
- * This function is called when a task is created.
-static bool
-  rtems_capture_task_t* ct;
-  rtems_capture_task_t* nt;
-  ct = current_task->extensions[capture_extension_index];
-   * The task pointers may not be known as the task may have
-   * been created before the capture engine was open. Add them.
-  if (ct == NULL)
-    ct = rtems_capture_create_capture_task (current_task);
-   * Create the new task's capture control block.
-  nt = rtems_capture_create_capture_task (new_task);
-  if (rtems_capture_trigger (ct, nt, RTEMS_CAPTURE_CREATE))
-    rtems_capture_record (ct, RTEMS_CAPTURE_CREATED_BY_EVENT);
-    rtems_capture_record (nt, RTEMS_CAPTURE_CREATED_EVENT);
-  return 1 == 1;
- * This function is called when a task is started.
-static void
-   * Get the capture task control block so we can trace this
-   * event.
-  rtems_capture_task_t* st;
-  st = started_task->extensions[capture_extension_index];
-  if (ct == NULL)
-  if (st == NULL)
-    st = rtems_capture_create_capture_task (started_task);
-  if (rtems_capture_trigger (ct, st, RTEMS_CAPTURE_START))
-    rtems_capture_record (ct, RTEMS_CAPTURE_STARTED_BY_EVENT);
-    rtems_capture_record (st, RTEMS_CAPTURE_STARTED_EVENT);
-  rtems_capture_init_stack_usage (st);
- * This function is called when a task is restarted.
-static void
-   * event.
-  rtems_capture_task_t* rt;
-  rt = restarted_task->extensions[capture_extension_index];
-  if (ct == NULL)
-  if (rt == NULL)
-    rt = rtems_capture_create_capture_task (restarted_task);
-  if (rtems_capture_trigger (ct, rt, RTEMS_CAPTURE_RESTART))
-    rtems_capture_record (ct, RTEMS_CAPTURE_RESTARTED_BY_EVENT);
-    rtems_capture_record (rt, RTEMS_CAPTURE_RESTARTED_EVENT);
-  rtems_capture_task_stack_usage (rt);
-  rtems_capture_init_stack_usage (rt);
- * This function is called when a task is deleted.
-static void
-   * event.
-  rtems_capture_task_t* dt;
-  dt = deleted_task->extensions[capture_extension_index];
-  if (ct == NULL)
-  if (dt == NULL)
-    dt = rtems_capture_create_capture_task (deleted_task);
-  if (rtems_capture_trigger (ct, dt, RTEMS_CAPTURE_DELETE))
-    rtems_capture_record (ct, RTEMS_CAPTURE_DELETED_BY_EVENT);
-    rtems_capture_record (dt, RTEMS_CAPTURE_DELETED_EVENT);
-  rtems_capture_task_stack_usage (dt);
-   * This task's tcb will be invalid. This signals the
-   * task has been deleted.
-  dt->tcb = 0;
-  rtems_capture_destroy_capture_task (dt);
- * This function is called when a task is begun.
-static void
-   * event.
-  rtems_capture_task_t* bt;
-  bt = begin_task->extensions[capture_extension_index];
-  if (bt == NULL)
-    bt = rtems_capture_create_capture_task (begin_task);
-  if (rtems_capture_trigger (NULL, bt, RTEMS_CAPTURE_BEGIN))
-    rtems_capture_record (bt, RTEMS_CAPTURE_BEGIN_EVENT);
- * This function is called when a task is exitted. That is
- * returned rather than was deleted.
-static void
-   * event.
-  rtems_capture_task_t* et;
-  et = exitted_task->extensions[capture_extension_index];
-  if (et == NULL)
-    et = rtems_capture_create_capture_task (exitted_task);
-  if (rtems_capture_trigger (NULL, et, RTEMS_CAPTURE_EXITTED))
-    rtems_capture_record (et, RTEMS_CAPTURE_EXITTED_EVENT);
-  rtems_capture_task_stack_usage (et);
- * This function is called when a termination request is identified.
-static void
-   * event.
-  rtems_capture_task_t* tt;
-  tt = terminated_task->extensions[capture_extension_index];
-  if (tt == NULL)
-    tt = rtems_capture_create_capture_task (terminated_task);
-  if (rtems_capture_trigger (NULL, tt, RTEMS_CAPTURE_TERMINATED))
-    rtems_capture_record (tt, RTEMS_CAPTURE_TERMINATED_EVENT);
-  rtems_capture_task_stack_usage (tt);
- * This function is called when a context is switched.
-static void
-   * Only perform context switch trace processing if tracing is
-   * enabled.
-  if (capture_flags & RTEMS_CAPTURE_ON)
-    rtems_capture_time_t time;
-     * Get the cpature task control block so we can update the
-     * reference and perform any watch or trigger functions.
-    rtems_capture_task_t* ht;
-    if (_States_Is_dormant (current_task->current_state))
-      rtems_id ct_id = current_task->Object.id;
-      for (ct = capture_tasks; ct; ct = ct->forw)
-        if (ct->id == ct_id)
-          break;
-    else
-      if (ct == NULL)
-    ht = heir_task->extensions[capture_extension_index];
-    if (ht == NULL)
-      ht = rtems_capture_create_capture_task (heir_task);
-     * Update the execution time. Assume the time will not overflow
-     * for now. This may need to change.
-    rtems_capture_get_time (&time);
-     * We could end up with null pointers for both the current task
-     * and the heir task.
-    if (ht)
-      ht->in++;
-      ht->time_in = time;
-    if (ct)
-      ct->out++;
-      if (ct->time_in)
-        ct->time += time - ct->time_in;
-    if (rtems_capture_trigger (ct, ht, RTEMS_CAPTURE_SWITCH))
-      rtems_capture_record (ct, RTEMS_CAPTURE_SWITCHED_OUT_EVENT);
-      rtems_capture_record (ht, RTEMS_CAPTURE_SWITCHED_IN_EVENT);
  * This function initialises the realtime capture engine allocating the trace
  * buffer. It is assumed we have a working heap at stage of initialisation.
 rtems_status_code
 rtems_capture_open (uint32_t   size, rtems_capture_timestamp timestamp __attribute__((unused)))
-  rtems_name             name;
   rtems_status_code      sc;
@@ -961,22 +624,13 @@ rtems_capture_open (uint32_t   size, rtems_capture_timestamp timestamp __attribu
   capture_ceiling = 0;
   capture_floor   = 255;
-   * Register the user extension handlers for the CAPture Engine.
-  name = rtems_build_name ('C', 'A', 'P', 'E');
-  sc   = rtems_extension_create (name, &capture_extensions, &capture_id);
+  sc = rtems_capture_user_extension_open();
   if (sc != RTEMS_SUCCESSFUL)
-    capture_id = 0;
     free (capture_records);
     capture_records = NULL;
-  else
-    capture_extension_index = rtems_object_id_get_index (capture_id);
    * Iterate over the list of existing tasks.
@@ -1016,7 +670,7 @@ rtems_capture_close (void)
    * release the resources we have without them being used.
-  sc = rtems_extension_delete (capture_id);
+  sc = rtems_capture_user_extension_close();
     return sc;
diff --git a/cpukit/libmisc/capture/capture_user_extension.c b/cpukit/libmisc/capture/capture_user_extension.c
new file mode 100644
index 0000000..f3bebc8
--- /dev/null
+++ b/cpukit/libmisc/capture/capture_user_extension.c
@@ -0,0 +1,435 @@
+  Copyright Objective Design Systems Pty Ltd, 2002
+  All rights reserved Objective Design Systems Pty Ltd, 2002
+  Chris Johns (ccj at acm.org)
+  COPYRIGHT (c) 1989-2009.
+  On-Line Applications Research Corporation (OAR).
+  The license and distribution terms for this file may be
+  found in the file LICENSE in this distribution.
+  This software with is provided ``as is'' and with NO WARRANTY.
+  RTEMS Performance Monitoring and Measurement Framework.
+  This is the Capture Engine component.
+rtems_status_code rtems_capture_user_extension_open(void);
+rtems_status_code rtems_capture_user_extension_close(void);
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <stdlib.h>
+#include <string.h>
+#include <rtems/rtems/tasksimpl.h>
+#include <rtems/score/statesimpl.h>
+#include <rtems/score/todimpl.h>
+ * RTEMS Capture User Extension Data.
+static rtems_id                 capture_id;
+static bool
+rtems_capture_create_task (rtems_tcb* current_task,
+                           rtems_tcb* new_task);
+static void
+rtems_capture_start_task (rtems_tcb* current_task,
+                          rtems_tcb* started_task);
+static void
+rtems_capture_restart_task (rtems_tcb* current_task,
+                            rtems_tcb* restarted_task);
+static void
+rtems_capture_delete_task (rtems_tcb* current_task,
+                           rtems_tcb* deleted_task);
+static void
+rtems_capture_switch_task (rtems_tcb* current_task,
+                           rtems_tcb* heir_task);
+static void
+rtems_capture_begin_task (rtems_tcb* begin_task);
+static void
+rtems_capture_exitted_task (rtems_tcb* exitted_task);
+static void
+rtems_capture_terminated_task (rtems_tcb* terminated_task);
+static const rtems_extensions_table capture_extensions = {
+  .thread_create    = rtems_capture_create_task,
+  .thread_start     = rtems_capture_start_task,
+  .thread_restart   = rtems_capture_restart_task,
+  .thread_delete    = rtems_capture_delete_task,
+  .thread_switch    = rtems_capture_switch_task,
+  .thread_begin     = rtems_capture_begin_task,
+  .thread_exitted   = rtems_capture_exitted_task,
+  .fatal            = NULL,
+  .thread_terminate = rtems_capture_terminated_task
+  rtems_status_code sc;
+  rtems_name        name;
+  int               index;
+   * Register the user extension handlers for the CAPture Engine.
+  name = rtems_build_name ('C', 'A', 'P', 'E');
+  sc   = rtems_extension_create (name, &capture_extensions, &capture_id);
+  if (sc != RTEMS_SUCCESSFUL)
+    capture_id = 0;
+  else {
+    index = rtems_object_id_get_index (capture_id);
+    rtems_capture_set_extension_index( index );
+  return sc;
+  sc = rtems_extension_delete (capture_id);
+  return sc;
+ * This function is called when a task is created.
+static bool
+  rtems_capture_task_t* nt;
+  int                   index = rtems_capture_get_extension_index();
+  ct = current_task->extensions[index];
+   * The task pointers may not be known as the task may have
+   * been created before the capture engine was open. Add them.
+  if (ct == NULL)
+    ct = rtems_capture_create_capture_task (current_task);
+   * Create the new task's capture control block.
+  nt = rtems_capture_create_capture_task (new_task);
+  if (rtems_capture_trigger (ct, nt, RTEMS_CAPTURE_CREATE))
+    rtems_capture_record (ct, RTEMS_CAPTURE_CREATED_BY_EVENT);
+    rtems_capture_record (nt, RTEMS_CAPTURE_CREATED_EVENT);
+  return 1 == 1;
+ * This function is called when a task is started.
+static void
+   * Get the capture task control block so we can trace this
+   * event.
+  rtems_capture_task_t* st;
+  st = started_task->extensions[index];
+  if (ct == NULL)
+  if (st == NULL)
+    st = rtems_capture_create_capture_task (started_task);
+  if (rtems_capture_trigger (ct, st, RTEMS_CAPTURE_START))
+    rtems_capture_record (ct, RTEMS_CAPTURE_STARTED_BY_EVENT);
+    rtems_capture_record (st, RTEMS_CAPTURE_STARTED_EVENT);
+  rtems_capture_init_stack_usage (st);
+ * This function is called when a task is restarted.
+static void
+   * event.
+  rtems_capture_task_t* rt;
+  rt = restarted_task->extensions[index];
+  if (ct == NULL)
+  if (rt == NULL)
+    rt = rtems_capture_create_capture_task (restarted_task);
+  if (rtems_capture_trigger (ct, rt, RTEMS_CAPTURE_RESTART))
+    rtems_capture_record (ct, RTEMS_CAPTURE_RESTARTED_BY_EVENT);
+    rtems_capture_record (rt, RTEMS_CAPTURE_RESTARTED_EVENT);
+  rtems_capture_task_stack_usage (rt);
+  rtems_capture_init_stack_usage (rt);
+ * This function is called when a task is deleted.
+static void
+   * event.
+  rtems_capture_task_t* dt;
+  dt = deleted_task->extensions[index];
+  if (ct == NULL)
+  if (dt == NULL)
+    dt = rtems_capture_create_capture_task (deleted_task);
+  if (rtems_capture_trigger (ct, dt, RTEMS_CAPTURE_DELETE))
+    rtems_capture_record (ct, RTEMS_CAPTURE_DELETED_BY_EVENT);
+    rtems_capture_record (dt, RTEMS_CAPTURE_DELETED_EVENT);
+  rtems_capture_task_stack_usage (dt);
+   * This task's tcb will be invalid. This signals the
+   * task has been deleted.
+  dt->tcb = 0;
+  rtems_capture_destroy_capture_task (dt);
+ * This function is called when a task is begun.
+static void
+   * event.
+  rtems_capture_task_t* bt;
+  bt = begin_task->extensions[index];
+  if (bt == NULL)
+    bt = rtems_capture_create_capture_task (begin_task);
+  if (rtems_capture_trigger (NULL, bt, RTEMS_CAPTURE_BEGIN))
+    rtems_capture_record (bt, RTEMS_CAPTURE_BEGIN_EVENT);
+ * This function is called when a task is exitted. That is
+ * returned rather than was deleted.
+static void
+   * event.
+  rtems_capture_task_t* et;
+  et = exitted_task->extensions[index];
+  if (et == NULL)
+    et = rtems_capture_create_capture_task (exitted_task);
+  if (rtems_capture_trigger (NULL, et, RTEMS_CAPTURE_EXITTED))
+    rtems_capture_record (et, RTEMS_CAPTURE_EXITTED_EVENT);
+  rtems_capture_task_stack_usage (et);
+ * This function is called when a termination request is identified.
+static void
+   * event.
+  rtems_capture_task_t* tt;
+  tt = terminated_task->extensions[index];
+  if (tt == NULL)
+    tt = rtems_capture_create_capture_task (terminated_task);
+  if (rtems_capture_trigger (NULL, tt, RTEMS_CAPTURE_TERMINATED))
+    rtems_capture_record (tt, RTEMS_CAPTURE_TERMINATED_EVENT);
+  rtems_capture_task_stack_usage (tt);
+ * This function is called when a context is switched.
+static void
+  uint32_t flags = rtems_capture_get_flags();
+   * Only perform context switch trace processing if tracing is
+   * enabled.
+  if (flags & RTEMS_CAPTURE_ON)
+    rtems_capture_time_t time;
+     * Get the cpature task control block so we can update the
+     * reference and perform any watch or trigger functions.
+    rtems_capture_task_t* ht;
+    if (_States_Is_dormant (current_task->current_state))
+      rtems_id ct_id = current_task->Object.id;
+      ct = rtems_capture_find_capture_task( ct_id );
+    else
+      if (ct == NULL)
+    ht = heir_task->extensions[index];
+    if (ht == NULL)
+      ht = rtems_capture_create_capture_task (heir_task);
+     * Update the execution time. Assume the time will not overflow
+     * for now. This may need to change.
+    rtems_capture_get_time (&time);
+     * We could end up with null pointers for both the current task
+     * and the heir task.
+    if (ht)
+      ht->in++;
+      ht->time_in = time;
+    if (ct)
+      ct->out++;
+      if (ct->time_in)
+        ct->time += time - ct->time_in;
+    if (rtems_capture_trigger (ct, ht, RTEMS_CAPTURE_SWITCH))
+      rtems_capture_record (ct, RTEMS_CAPTURE_SWITCHED_OUT_EVENT);
+      rtems_capture_record (ht, RTEMS_CAPTURE_SWITCHED_IN_EVENT);
diff --git a/cpukit/libmisc/capture/captureimpl.h b/cpukit/libmisc/capture/captureimpl.h
index 0000000..ee18d82
--- /dev/null
+++ b/cpukit/libmisc/capture/captureimpl.h
@@ -0,0 +1,195 @@
+ * @file rtems/captureimpl.h
+ * @brief Capture Implementation file
+ * This file contains an interface between the capture engine and
+ * capture user extension methods.
+  COPYRIGHT (c) 1989-2014.
+#ifndef __CAPTUREIMPL_H_
+#define __CAPTUREIMPL_H_
+#ifdef __cplusplus
+extern "C" {
+#endif
+#include "capture.h"
+ * Global capture flags.
+#define RTEMS_CAPTURE_ON             (1U << 0)
+#define RTEMS_CAPTURE_NO_MEMORY      (1U << 1)
+#define RTEMS_CAPTURE_OVERFLOW       (1U << 2)
+#define RTEMS_CAPTURE_TRIGGERED      (1U << 3)
+#define RTEMS_CAPTURE_READER_ACTIVE  (1U << 4)
+#define RTEMS_CAPTURE_READER_WAITING (1U << 5)
+#define RTEMS_CAPTURE_GLOBAL_WATCH   (1U << 6)
+#define RTEMS_CAPTURE_ONLY_MONITOR   (1U << 7)
+ * @brief Capture set extension index.
+ * This function is used to set the extension index
+ * for the capture engine.
+ * @param[in] index specifies the extension index to be
+ * used for capture engine data.
+void rtems_capture_set_extension_index(int index);
+ * @brief Capture get extension index.
+ * This function rturns the extension index for the
+ * capture engine.
+ * @retval This method returns the extension index.
+int  rtems_capture_get_extension_index(void);
+ * @brief Capture get flags.
+ * This function gets the current flag settings
+ * @retval This method returns the global capture
+ * flags.
+uint32_t rtems_capture_get_flags(void);
+ * @brief Capture set flags.
+ * This function sets a flag in the capture engine
+ * @param[in] mask specifies the flag to set
+void rtems_capture_set_flags(uint32_t mask);
+ * @brief Capture user extension open.
+ * This function creates the capture user extensions.
+ * @retval This method returns RTEMS_SUCCESSFUL upon successful
+ * creation of the user extensions.
+ * @brief Capture user extension close.
+ * This function closes the capture user extensions.
+ * @retval This method returns RTEMS_SUCCESSFUL upon a successful
+ * delete of the user extensions.
+ * @brief Capture find capture task.
+ * This function finds the capture task control block
+ * @param[in] ct_id specifies the task_id
+ * @retval This method returns the capture task control block associated
+ * with the given task id.
+rtems_capture_task_t* rtems_capture_find_capture_task( rtems_id ct_id );
+ * @brief Capture create capture task control block.
+ * This function create the capture task control block
+ * @param[in] new_task specifies the rtems thread control block
+ * @retval This method returns a capture task control block.
+rtems_capture_task_t* rtems_capture_create_capture_task (rtems_tcb* new_task);
+ * @brief Capture trigger.
+ * This function checks if we have triggered or if this event is a
+ * cause of a trigger.
+ * @param[in] ft specifies specifices the capture from task
+ * @param[in] tt specifies specifices the capture to task
+ * @param[in] events specifies the events
+ * @retval This method returns true if we have triggered or
+ * if the event is a cause of a trigger.
+bool rtems_capture_trigger (rtems_capture_task_t* ft,
+                       rtems_capture_task_t* tt,
+                       uint32_t              events);
+ * @brief Capture initialize stack usage
+ * This function setups a stack so its usage can be monitored.
+ * @param[in] task specifies the capture task block
+void rtems_capture_init_stack_usage (rtems_capture_task_t* task);
+ * @brief Capture destroy task.
+ * This function destroy the task structure if the reference count
+ * is 0 and the tcb has been cleared signalling the task has been
+ * deleted.
+void rtems_capture_destroy_capture_task (rtems_capture_task_t* task);
+ * @brief .
+ * This function returns the current time. If a handler is provided
+ * by the user the time is gotten from that.
+ * @param[in] time specifies the capture time
+ * @retval This method returns a nano-second time if no user handler
+ * is provided.  Otherwise, it returns a resolution defined by the handler.
+void rtems_capture_get_time (rtems_capture_time_t* time);
+#ifdef __cplusplus
+#endif
+#endif
1.8.1.4
