[PATCH 01/23] raspberrypi: Use shared bspreset.c
Thu Sep 4 16:16:01 UTC 2014
On Wed, Sep 3, 2014 at 11:25 AM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
>  c/src/lib/libbsp/arm/csb337/startup/bspreset.c     |  1 +
>  c/src/lib/libbsp/arm/raspberrypi/Makefile.am       |  2 +-
>  .../lib/libbsp/arm/raspberrypi/startup/bspreset.c  | 35 ------------
>  testsuites/sptests/spintr_err01/init.c             | 65 +++++++++++-----------
>  4 files changed, 34 insertions(+), 69 deletions(-)
>  delete mode 100644 c/src/lib/libbsp/arm/raspberrypi/startup/bspreset.c
> diff --git a/c/src/lib/libbsp/arm/csb337/startup/bspreset.c b/c/src/lib/libbsp/arm/csb337/startup/bspreset.c
> index 1167d92..940ff7f 100644
> --- a/c/src/lib/libbsp/arm/csb337/startup/bspreset.c
> +++ b/c/src/lib/libbsp/arm/csb337/startup/bspreset.c
> @@ -17,6 +17,7 @@ void bsp_reset(void)
>    rtems_interrupt_level level;
> +  (void) level;
>    rtems_interrupt_disable(level);
Is it ok to put (void) level; and then use level?
>    /* Enable the watchdog timer, then wait for the world to end. */
> diff --git a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
> index a8d98b4..cda8510 100644
> --- a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
> +++ b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
> @@ -92,7 +92,7 @@ libbsp_a_SOURCES += ../shared/startup/bsp-start-memcpy.S
>  libbsp_a_SOURCES += ../shared/arm-cp15-set-ttb-entries.c
>  # Startup
> -libbsp_a_SOURCES += startup/bspreset.c
> +libbsp_a_SOURCES += ../../shared/bspreset_loop.c
>  libbsp_a_SOURCES += startup/bspstart.c
>  # IRQ
> diff --git a/c/src/lib/libbsp/arm/raspberrypi/startup/bspreset.c b/c/src/lib/libbsp/arm/raspberrypi/startup/bspreset.c
> deleted file mode 100644
> index 4b3c732..0000000
> --- a/c/src/lib/libbsp/arm/raspberrypi/startup/bspreset.c
> +++ /dev/null
> @@ -1,35 +0,0 @@
> - * @file
> - * @ingroup arm_start
> - * @brief Raspberry Pi reset code.
> - * Copyright (c) 2013 by Alan Cudmore
> - * Based on work by:
> - * Copyright (c) 2009
> - * embedded brains GmbH
> - * Obere Lagerstr. 30
> - * D-82178 Puchheim
> - * Germany
> - * <rtems at embedded-brains.de>
> - *  The license and distribution terms for this file may be
> - *  found in the file LICENSE in this distribution or at
> - *  http://www.rtems.org/license/LICENSE
> -#include <rtems.h>
> -#include <bsp/bootcard.h>
> -void bsp_reset( void)
> -  while (true) {
> -    /* Do nothing */
> diff --git a/testsuites/sptests/spintr_err01/init.c b/testsuites/sptests/spintr_err01/init.c
> index 84ebfdb..490a0e6 100644
> --- a/testsuites/sptests/spintr_err01/init.c
> +++ b/testsuites/sptests/spintr_err01/init.c
> @@ -20,11 +20,8 @@ rtems_task Init(
>    rtems_task_argument argument
> -  rtems_status_code status;
>    TEST_BEGIN();
> -  #if ((CPU_SIMPLE_VECTORED_INTERRUPTS == FALSE) || \
> -       defined(_C3x) || defined(_C4x))
> +  #if (CPU_SIMPLE_VECTORED_INTERRUPTS == FALSE)
>      puts(
>        "TA1 - rtems_interrupt_catch - "
>        "bad handler RTEMS_INVALID_ADDRESS -- SKIPPED"
> @@ -32,36 +29,38 @@ rtems_task Init(
>      puts(
>        "old isr RTEMS_INVALID_ADDRESS - SKIPPED" );
> -#else
> -  rtems_isr_entry   old_service_routine;
> -    status = rtems_interrupt_catch(
> -      Service_routine,
> -      CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER + 1,
> -      &old_service_routine
> -    fatal_directive_status(
> -      status,
> -      RTEMS_INVALID_NUMBER,
> -      "rtems_interrupt_catch with invalid vector"
> -    puts( "TA1 - rtems_interrupt_catch - RTEMS_INVALID_NUMBER" );
> +  #else
> +    rtems_status_code status;
> -    status = rtems_interrupt_catch( NULL, 3, &old_service_routine );
> -      status,
> -      RTEMS_INVALID_ADDRESS,
> -      "rtems_interrupt_catch with invalid handler"
> -    puts( "TA1 - rtems_interrupt_catch - bad handler RTEMS_INVALID_ADDRESS" );
> +    rtems_isr_entry   old_service_routine;
> +      status = rtems_interrupt_catch(
> +        Service_routine,
> +        CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER + 1,
> +        &old_service_routine
> +      fatal_directive_status(
> +        status,
> +        RTEMS_INVALID_NUMBER,
> +        "rtems_interrupt_catch with invalid vector"
> +      puts( "TA1 - rtems_interrupt_catch - RTEMS_INVALID_NUMBER" );
> +      status = rtems_interrupt_catch( NULL, 3, &old_service_routine );
> +        status,
> +        RTEMS_INVALID_ADDRESS,
> +        "rtems_interrupt_catch with invalid handler"
> +      puts( "TA1 - rtems_interrupt_catch - bad handler RTEMS_INVALID_ADDRESS" );
> +      status = rtems_interrupt_catch( Service_routine, 3, NULL );
> +        status,
> +        "rtems_interrupt_catch with invalid old isr pointer"
> +      puts( "TA1 - rtems_interrupt_catch - old isr RTEMS_INVALID_ADDRESS" );
> +  #endif
> -    status = rtems_interrupt_catch( Service_routine, 3, NULL );
> -      status,
> -      "rtems_interrupt_catch with invalid old isr pointer"
> -    puts( "TA1 - rtems_interrupt_catch - old isr RTEMS_INVALID_ADDRESS" );
> -#endif
>    TEST_END();
> 1.9.3
> devel mailing list
> devel at rtems.org
