Automate RTEMS test results?
Hesham Moustafa heshamelmatary at gmail.com
Sat Sep 6 19:58:58 UTC 2014
On Sat, Sep 6, 2014 at 9:35 PM, Gedare Bloom <gedare at rtems.org> wrote:
> See tester in rtems-tools.git it is designed for exactly what you ask. You
> probably need to modify an existing script to run or1ksim.
Thanks I did, and now I am running the new script added for or1ksim BSP.
> On Sep 6, 2014 2:58 PM, "Hesham Moustafa" <heshamelmatary at gmail.com> wrote:
>> Hi,
>> Given that I am able to run qemu-or1k from sim-scripts (I will push
>> the script soon)
>> Is there a way to run all tests with one command and get results of
>> how many passed/failed tests? (i.e, 5/10 passed tests)
>> Thanks,
>> Hesham
>> devel mailing list
>> devel at rtems.org
