[PATCH] [RTEMS TESTER] Add new OpenRISC/or1ksim BSP script using qemu
Hesham ALMatary
heshamelmatary at gmail.com
Sun Sep 7 01:16:58 UTC 2014
tester/rtems/testing/bsps/or1ksim.mc | 53 ++++++++++++++++++++++++++++++++++++
1 file changed, 53 insertions(+)
create mode 100644 tester/rtems/testing/bsps/or1ksim.mc
diff --git a/tester/rtems/testing/bsps/or1ksim.mc b/tester/rtems/testing/bsps/or1ksim.mc
new file mode 100644
index 0000000..7222a7f
--- /dev/null
+++ b/tester/rtems/testing/bsps/or1ksim.mc
@@ -0,0 +1,53 @@
+# RTEMS Tools Project (http://www.rtems.org/)
+# Copyright 2010-2014 Chris Johns (chrisj at rtems.org)
+# All rights reserved.
+# This file is part of the RTEMS Tools package in 'rtems-tools'.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions are met:
+# 1. Redistributions of source code must retain the above copyright notice,
+# this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright notice,
+# this list of conditions and the following disclaimer in the documentation
+# and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
+# All paths in defaults must be Unix format. Do not store any Windows format
+# paths in the defaults.
+# Every entry must describe the type of checking a host must pass.
+# Records:
+# key: type, attribute, value
+# type : none, dir, exe, triplet
+# attribute: none, required, optional
+# value : 'single line', '''multi line'''
+# The or1ksim BSP
+[global]
+bsp: none, none, 'or1ksim'
+[or1ksim]
+or1ksim: none, none, '%{_rtscripts}/qemu.cfg'
+or1ksim_arch: none, none, 'or32'
+or1ksim_opts: none, none, '%{qemu_opts_base} %{qemu_opts_no_net} -m 32M'
1.9.3
