[PATCH] [RTEMS TESTER] Add new OpenRISC/or1ksim BSP script using qemu
Sun Sep 7 01:18:36 UTC 2014
Shouldn't your name be on it? :)
Post the list of failures on devel@ and maybe they will be ones we recognize as common.
On September 6, 2014 8:16:58 PM CDT, Hesham ALMatary <heshamelmatary at gmail.com> wrote:
>tester/rtems/testing/bsps/or1ksim.mc | 53
> 1 file changed, 53 insertions(+)
> create mode 100644 tester/rtems/testing/bsps/or1ksim.mc
>diff --git a/tester/rtems/testing/bsps/or1ksim.mc
>b/tester/rtems/testing/bsps/or1ksim.mc
>new file mode 100644
>index 0000000..7222a7f
>--- /dev/null
>+++ b/tester/rtems/testing/bsps/or1ksim.mc
>@@ -0,0 +1,53 @@
>+# RTEMS Tools Project (http://www.rtems.org/)
>+# Copyright 2010-2014 Chris Johns (chrisj at rtems.org)
>+# All rights reserved.
>+# This file is part of the RTEMS Tools package in 'rtems-tools'.
>+# Redistribution and use in source and binary forms, with or without
>+# modification, are permitted provided that the following conditions
>are met:
>+# 1. Redistributions of source code must retain the above copyright
>notice,
>+# this list of conditions and the following disclaimer.
>+# 2. Redistributions in binary form must reproduce the above copyright
>notice,
>+# this list of conditions and the following disclaimer in the
>documentation
>+# and/or other materials provided with the distribution.
>+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
>"AS IS"
>+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
>TO, THE
>+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
>PURPOSE
>+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
>CONTRIBUTORS BE
>+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>BUSINESS
>+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
>IN
>+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>OTHERWISE)
>+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
>OF THE
>+# POSSIBILITY OF SUCH DAMAGE.
>+# All paths in defaults must be Unix format. Do not store any Windows
>format
>+# paths in the defaults.
>+# Every entry must describe the type of checking a host must pass.
>+# Records:
>+#  key: type, attribute, value
>+#   type     : none, dir, exe, triplet
>+#   attribute: none, required, optional
>+#   value    : 'single line', '''multi line'''
>+# The or1ksim BSP
>+[global]
>+bsp:                      none,    none,     'or1ksim'
>+[or1ksim]
>+or1ksim:      none,    none,  '%{_rtscripts}/qemu.cfg'
>+or1ksim_arch: none,    none,  'or32'
>+or1ksim_opts: none,    none,  '%{qemu_opts_base} %{qemu_opts_no_net}
>-m 32M'
