[PATCH] [RTEMS TESTER] Add new OpenRISC/or1ksim BSP script using qemu
Hesham Moustafa
heshamelmatary at gmail.com
Sun Sep 7 01:28:04 UTC 2014
On Sep 7, 2014 3:18 AM, "Joel Sherrill" <joel.sherrill at oarcorp.com> wrote:
> Shouldn't your name be on it? :)
I did almost nothing but copying another file and changing few lines to fit
with or1k :-)
> Post the list of failures on devel@ and maybe they will be ones we
recognize as common.
Unfortunately I am running RTEMS Tester again now (after a few
modifications and new build of rtems), so the log file is overwritten. It's
4:24 AM here, so I will leave it running and post results tomorrow.
Ah, please do not miss the latest patches I submitted to the mailing list,
these results depends on it.
> On September 6, 2014 8:16:58 PM CDT, Hesham ALMatary <
heshamelmatary at gmail.com> wrote:
> >tester/rtems/testing/bsps/or1ksim.mc | 53
> > 1 file changed, 53 insertions(+)
> > create mode 100644 tester/rtems/testing/bsps/or1ksim.mc
> >diff --git a/tester/rtems/testing/bsps/or1ksim.mc
> >b/tester/rtems/testing/bsps/or1ksim.mc
> >new file mode 100644
> >index 0000000..7222a7f
> >--- /dev/null
> >+++ b/tester/rtems/testing/bsps/or1ksim.mc
> >@@ -0,0 +1,53 @@
> >+# RTEMS Tools Project (http://www.rtems.org/)
> >+# Copyright 2010-2014 Chris Johns (chrisj at rtems.org)
> >+# All rights reserved.
> >+# This file is part of the RTEMS Tools package in 'rtems-tools'.
> >+# Redistribution and use in source and binary forms, with or without
> >+# modification, are permitted provided that the following conditions
> >are met:
> >+# 1. Redistributions of source code must retain the above copyright
> >notice,
> >+# this list of conditions and the following disclaimer.
> >+# 2. Redistributions in binary form must reproduce the above copyright
> >notice,
> >+# this list of conditions and the following disclaimer in the
> >documentation
> >+# and/or other materials provided with the distribution.
> >+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> >"AS IS"
> >+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
> >TO, THE
> >+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> >PURPOSE
> >+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
> >CONTRIBUTORS BE
> >+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> >+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> >+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> >BUSINESS
> >+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
> >IN
> >+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
> >OTHERWISE)
> >+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
> >OF THE
> >+# POSSIBILITY OF SUCH DAMAGE.
> >+# All paths in defaults must be Unix format. Do not store any Windows
> >format
> >+# paths in the defaults.
> >+# Every entry must describe the type of checking a host must pass.
> >+# Records:
> >+# key: type, attribute, value
> >+# type : none, dir, exe, triplet
> >+# attribute: none, required, optional
> >+# value : 'single line', '''multi line'''
> >+# The or1ksim BSP
> >+[global]
> >+bsp: none, none, 'or1ksim'
> >+[or1ksim]
> >+or1ksim: none, none, '%{_rtscripts}/qemu.cfg'
> >+or1ksim_arch: none, none, 'or32'
> >+or1ksim_opts: none, none, '%{qemu_opts_base} %{qemu_opts_no_net}
> >-m 32M'
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140907/740e6a31/attachment-0001.html>
