[PATCH] [RTEMS TESTER] Add new OpenRISC/or1ksim BSP script using qemu
Hesham Moustafa
heshamelmatary at gmail.com
Sun Sep 7 06:25:38 UTC 2014
Hi,
The test results improved a little bit from yesterday. Here are the results:
Passed: 365
Failed: 6
Timeouts: 130
Invalid: 2
Total: 503
Average test time: 0:00:22.877361
Testing time : 3:11:47.312905
The full log file is attached.
On Sun, Sep 7, 2014 at 3:28 AM, Hesham Moustafa
<heshamelmatary at gmail.com> wrote:
> On Sep 7, 2014 3:18 AM, "Joel Sherrill" <joel.sherrill at oarcorp.com> wrote:
>> Shouldn't your name be on it? :)
> I did almost nothing but copying another file and changing few lines to fit
> with or1k :-)
>> Post the list of failures on devel@ and maybe they will be ones we
>> recognize as common.
> Unfortunately I am running RTEMS Tester again now (after a few modifications
> and new build of rtems), so the log file is overwritten. It's 4:24 AM here,
> so I will leave it running and post results tomorrow.
> Ah, please do not miss the latest patches I submitted to the mailing list,
> these results depends on it.
>> On September 6, 2014 8:16:58 PM CDT, Hesham ALMatary
>> >tester/rtems/testing/bsps/or1ksim.mc | 53
>> > 1 file changed, 53 insertions(+)
>> > create mode 100644 tester/rtems/testing/bsps/or1ksim.mc
>> >diff --git a/tester/rtems/testing/bsps/or1ksim.mc
>> >b/tester/rtems/testing/bsps/or1ksim.mc
>> >new file mode 100644
>> >index 0000000..7222a7f
>> >--- /dev/null
>> >+++ b/tester/rtems/testing/bsps/or1ksim.mc
>> >@@ -0,0 +1,53 @@
>> >+# RTEMS Tools Project (http://www.rtems.org/)
>> >+# Copyright 2010-2014 Chris Johns (chrisj at rtems.org)
>> >+# All rights reserved.
>> >+# This file is part of the RTEMS Tools package in 'rtems-tools'.
>> >+# Redistribution and use in source and binary forms, with or without
>> >+# modification, are permitted provided that the following conditions
>> >are met:
>> >+# 1. Redistributions of source code must retain the above copyright
>> >notice,
>> >+# this list of conditions and the following disclaimer.
>> >+# 2. Redistributions in binary form must reproduce the above copyright
>> >notice,
>> >+# this list of conditions and the following disclaimer in the
>> >documentation
>> >+# and/or other materials provided with the distribution.
>> >+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
>> >"AS IS"
>> >+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
>> >TO, THE
>> >+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
>> >PURPOSE
>> >+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
>> >CONTRIBUTORS BE
>> >+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>> >+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>> >+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>> >BUSINESS
>> >+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
>> >IN
>> >+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>> >OTHERWISE)
>> >+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
>> >OF THE
>> >+# POSSIBILITY OF SUCH DAMAGE.
>> >+# All paths in defaults must be Unix format. Do not store any Windows
>> >format
>> >+# paths in the defaults.
>> >+# Every entry must describe the type of checking a host must pass.
>> >+# Records:
>> >+# key: type, attribute, value
>> >+# type : none, dir, exe, triplet
>> >+# attribute: none, required, optional
>> >+# value : 'single line', '''multi line'''
>> >+# The or1ksim BSP
>> >+[global]
>> >+bsp: none, none, 'or1ksim'
>> >+[or1ksim]
>> >+or1ksim: none, none, '%{_rtscripts}/qemu.cfg'
>> >+or1ksim_arch: none, none, 'or32'
>> >+or1ksim_opts: none, none, '%{qemu_opts_base} %{qemu_opts_no_net}
>> >-m 32M'
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140907/722a5524/attachment-0001.obj>
