[PATCH] [RTEMS TESTER] Add new OpenRISC/or1ksim BSP script using qemu
Hesham Moustafa
heshamelmatary at gmail.com
Sun Sep 7 23:18:53 UTC 2014
On Sep 8, 2014 12:40 AM, "Chris Johns" <chrisj at rtems.org> wrote:
> On 7/09/2014 4:25 pm, Hesham Moustafa wrote:
>> The test results improved a little bit from yesterday. Here are the
results:
>> Passed: 365
>> Failed: 6
>> Timeouts: 130
>> Invalid: 2
>> Total: 503
>> Average test time: 0:00:22.877361
>> Testing time : 3:11:47.312905
>> The full log file is attached.
> If you run one of the timed out tests, say fsdosfsname01.exe from the
command line does it complete and if so how long ?
No it doesn't, some fs tests go to sleep and do not wake up again.
> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140908/0f5a1b86/attachment.html>
