[PATCH] [RTEMS TESTER] Add new OpenRISC/or1ksim BSP script using qemu
Sun Sep 7 23:35:23 UTC 2014
On September 7, 2014 6:18:53 PM CDT, Hesham Moustafa <heshamelmatary at gmail.com> wrote:
>On Sep 8, 2014 12:40 AM, "Chris Johns" <chrisj at rtems.org> wrote:
>> On 7/09/2014 4:25 pm, Hesham Moustafa wrote:
>>> The test results improved a little bit from yesterday. Here are the
>results:
>>> Passed:   365
>>> Failed:     6
>>> Timeouts: 130
>>> Invalid:    2
>>> Total:    503
>>> Average test time: 0:00:22.877361
>>> Testing time     : 3:11:47.312905
>>> The full log file is attached.
>> If you run one of the timed out tests, say fsdosfsname01.exe from the
>command line does it complete and if so how long ?
>No it doesn't, some fs tests go to sleep and do not wake up again.
Run in the debugger.. Break.. See where it is.. Continue.. Repeat a few times.
Test could be in an unreported fault or something slow or something misconfigured in hardware.
>> Chris
>> devel mailing list
>> devel at rtems.org
