[PATCH] Add -std=gnu++11 to CXXFLAGS if SMP is enabled
Sebastian Huber
Mon Sep 8 09:14:23 UTC 2014
This is necessary to use the <atomic> header file used for the atomic
operations.
c/src/aclocal/prog-cxx.m4 | 11 +++++++++--
testsuites/aclocal/prog-cxx.m4 | 7 ++++++-
2 files changed, 15 insertions(+), 3 deletions(-)
diff --git a/c/src/aclocal/prog-cxx.m4 b/c/src/aclocal/prog-cxx.m4
index ba596ba..957a595 100644
--- a/c/src/aclocal/prog-cxx.m4
+++ b/c/src/aclocal/prog-cxx.m4
@@ -6,11 +6,18 @@ AC_DEFUN([RTEMS_PROG_CXX_FOR_TARGET],
AC_BEFORE([$0], [RTEMS_CANONICALIZE_TOOLS])dnl
AC_REQUIRE([RTEMS_ENABLE_CXX])
+AC_REQUIRE([RTEMS_CHECK_SMP])
+# If CXXFLAGS is not set, default to CFLAGS
+if test x"$rtems_cv_HAS_SMP" = x"yes" ; then
+ CXXFLAGS=${CXXFLAGS-${CFLAGS} -std=gnu++11}
+else
+ CXXFLAGS=${CXXFLAGS-${CFLAGS}}
+fi
RTEMS_CHECK_TOOL(CXX,g++)
if test "$RTEMS_HAS_CPLUSPLUS" = "yes";
then
- CXXFLAGS=${CXXFLAGS-${CFLAGS}}
dnl Only accept g++
dnl NOTE: This might be too restrictive
test -z "$CXX" \
diff --git a/testsuites/aclocal/prog-cxx.m4 b/testsuites/aclocal/prog-cxx.m4
index fdbb129..c71bac9 100644
--- a/testsuites/aclocal/prog-cxx.m4
+++ b/testsuites/aclocal/prog-cxx.m4
@@ -6,9 +6,14 @@ AC_DEFUN([RTEMS_PROG_CXX_FOR_TARGET],
+RTEMS_CHECK_CPUOPTS([RTEMS_SMP])
-CXXFLAGS=${CXXFLAGS-${CFLAGS}}
+if test x"$rtems_cv_RTEMS_SMP" = x"yes" ; then
+else
+fi
1.8.4.5
