[PATCH] Add -std=gnu++11 to CXXFLAGS if SMP is enabled
Nick Withers nick.withers at anu.edu.au
Tue Sep 9 06:59:54 UTC 2014
On Tue, 2014-09-09 at 08:52 +0200, Sebastian Huber wrote:
> On 09/09/14 04:00, Nick Withers wrote:
> > On Mon, 2014-09-08 at 11:14 +0200, Sebastian Huber wrote:
> >> >This is necessary to use the <atomic> header file used for the atomic
> >> >operations.
> > "-std=c++11" wouldn't cut it?
> I don't know, we use some GNU extensions here and there.
If they weren't enabled before...?
Or is the CXXFLAGS set with GNU extensions somewhere else, maybe
overriding what you're trying to achieve here?
Nick Withers
Embedded Systems Programmer
Department of Nuclear Physics, Research School of Physics and Engineering
The Australian National University (CRICOS: 00120C)
