[PATCH] Adding "eth" linker script section for arm bsp.
Federico Casares
federico.casares at tallertechnologies.com
Tue Sep 9 13:29:53 UTC 2014
Hi Sebastian,
The config file for the "ETH bsp" (linkcmds.lpc1768_mbed_ahb_ram_eth)
exhibit changes in the MEMORY definition, some REGION_ALIAS, and adds the
".eth" section.
Consequently, we think this file represents an specific configuration for
that BSP, which is different from the others, and the changes involve all
parts of the config.
We think that splitting the MEMORY mapping or the REGIONS_ALIAS will make
the config file quite unclear.
So, please confirm us whether you want to do the changes anyway?
Regards.
On Mon, Sep 8, 2014 at 4:02 AM, Sebastian Huber <
> On 02/09/14 15:07, Federico Casares wrote:
>> Are you suggesting to remove the
>> "lpc176x/make/custom/lpc1768_mbed_ahb_ram_eth-testsuite.tcfg" and
>> "lpc176x/make/custom/lpc1768_mbed_ahb_ram_eth.cfg" files?
>> The tcfg includes in its list two tests that should not be compiled for
>> this
>> BSP configuration, due to BBS size required by those tests. This differs
>> from
>> the other configurations available for the LPC176x.
> Ok, I am fine with adding this BSP. I think we have to address the
> explosion of test demands separately. Maybe select only one variant for
> each BSP family. There are not only BSP variants, but we also have BSP
> options. It is not possible to test everything.
> Regarding the latest patch. Please reduce the copy and paste in the *.cfg
> files. We don't need three copies of the same file.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
[image: http://www.tallertechnologies.com]
<http://www.tallertechnologies.com>
Casares, Federico
Sr. Software Engineer
Taller Technologies Argentina
San Lorenzo 47, 3rd Floor, Office 5
Córdoba, Argentina
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140909/11dc5a47/attachment.html>
