[PATCH] sptests/sp39: Convert to sptests/spintrcritical21
Sebastian Huber
Tue Sep 9 15:15:32 UTC 2014
Use interrupt critical section test support. Do not print end of test
message in case of failure.
testsuites/sptests/Makefile.am | 3 +-
testsuites/sptests/configure.ac | 2 +-
testsuites/sptests/sp39/Makefile.am | 22 ---
testsuites/sptests/sp39/init.c | 192 ---------------------
testsuites/sptests/sp39/sp39.doc | 22 ---
testsuites/sptests/sp39/sp39.scn | 4 -
testsuites/sptests/sp39/system.h | 38 ----
testsuites/sptests/spintrcritical21/Makefile.am | 20 +++
testsuites/sptests/spintrcritical21/init.c | 170 ++++++++++++++++++
.../sptests/spintrcritical21/spintrcritical21.doc | 22 +++
.../sptests/spintrcritical21/spintrcritical21.scn | 4 +
testsuites/sptests/spintrcritical21/system.h | 39 +++++
12 files changed, 258 insertions(+), 280 deletions(-)
delete mode 100644 testsuites/sptests/sp39/Makefile.am
delete mode 100644 testsuites/sptests/sp39/init.c
delete mode 100644 testsuites/sptests/sp39/sp39.doc
delete mode 100644 testsuites/sptests/sp39/sp39.scn
delete mode 100644 testsuites/sptests/sp39/system.h
create mode 100644 testsuites/sptests/spintrcritical21/Makefile.am
create mode 100644 testsuites/sptests/spintrcritical21/init.c
create mode 100644 testsuites/sptests/spintrcritical21/spintrcritical21.doc
create mode 100644 testsuites/sptests/spintrcritical21/spintrcritical21.scn
create mode 100644 testsuites/sptests/spintrcritical21/system.h
diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
index a0acbc3..3df4ffb 100644
--- a/testsuites/sptests/Makefile.am
+++ b/testsuites/sptests/Makefile.am
@@ -6,7 +6,7 @@ _SUBDIRS = \
sp01 sp02 sp03 sp04 sp05 sp06 sp07 sp08 \
sp10 sp11 sp12 sp13 sp14 sp15 sp16 sp17 sp18 sp19 \
sp20 sp21 sp22 sp23 sp24 sp25 sp26 sp27 sp27a \
- sp30 sp31 sp32 sp33 sp34 sp35 sp37 sp38 sp39 \
+ sp30 sp31 sp32 sp33 sp34 sp35 sp37 sp38 \
sp40 sp41 sp42 sp43 sp44 sp45 sp46 sp47 sp48 sp49 \
sp50 sp51 sp52 sp53 sp54 sp55 sp56 sp57 sp58 sp59 \
sp60 sp62 sp63 sp64 sp65 sp66 sp67 sp68 sp69 \
@@ -53,6 +53,7 @@ _SUBDIRS += sptls02
endif
_SUBDIRS += sptls01
_SUBDIRS += spintrcritical20
+_SUBDIRS += spintrcritical21
_SUBDIRS += spcontext01
_SUBDIRS += spfatal26
_SUBDIRS += speventtransient01
diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
index d376a4f..fa149ab 100644
--- a/testsuites/sptests/configure.ac
+++ b/testsuites/sptests/configure.ac
@@ -53,6 +53,7 @@ spcpucounter01/Makefile
sptls02/Makefile
sptls01/Makefile
spintrcritical20/Makefile
+spintrcritical21/Makefile
spcontext01/Makefile
spfatal26/Makefile
spinternalerror02/Makefile
@@ -98,7 +99,6 @@ sp35/Makefile
sp36/Makefile
sp37/Makefile
sp38/Makefile
-sp39/Makefile
sp40/Makefile
sp41/Makefile
sp42/Makefile
diff --git a/testsuites/sptests/sp39/Makefile.am b/testsuites/sptests/sp39/Makefile.am
deleted file mode 100644
index fc091da..0000000
--- a/testsuites/sptests/sp39/Makefile.am
+++ /dev/null
@@ -1,22 +0,0 @@
-rtems_tests_PROGRAMS = sp39
-sp39_SOURCES = init.c system.h
-dist_rtems_tests_DATA = sp39.scn
-dist_rtems_tests_DATA += sp39.doc
-include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
-include $(top_srcdir)/../automake/compile.am
-include $(top_srcdir)/../automake/leaf.am
-AM_CPPFLAGS += -I$(top_srcdir)/../support/include
-LINK_OBJS = $(sp39_OBJECTS)
-LINK_LIBS = $(sp39_LDLIBS)
-sp39$(EXEEXT): $(sp39_OBJECTS) $(sp39_DEPENDENCIES)
- @rm -f sp39$(EXEEXT)
- $(make-exe)
-include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/sptests/sp39/init.c b/testsuites/sptests/sp39/init.c
index b78cd7f..0000000
--- a/testsuites/sptests/sp39/init.c
+++ /dev/null
@@ -1,192 +0,0 @@
- * Classic API Signal to Task from ISR
- * COPYRIGHT (c) 1989-2011.
- * On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
-#ifdef HAVE_CONFIG_H
-#include "config.h"
-#endif
-#define CONFIGURE_INIT
-#include "system.h"
-#include <rtems/rtems/eventimpl.h>
-const char rtems_test_name[] = "SP 39";
- * ERROR CHECKING NOTE:
- * We are either at dispatch disable level 1 or 2. Either way, it is
- * safer not to check the dispatch level explicitly so we are using
- * fatal_directive_check_status_only() not directive_failed().
-rtems_timer_service_routine test_event_from_isr(
- rtems_id timer,
- void *arg
-rtems_timer_service_routine test_event_with_timeout_from_isr(
- rtems_id timer,
- void *arg
-volatile bool case_hit;
-rtems_id main_task;
-rtems_id other_task;
- rtems_id timer,
- void *arg
- rtems_status_code status;
- if ( _Event_Sync_state == THREAD_BLOCKING_OPERATION_NOTHING_HAPPENED ) {
- * This event send hits the critical section but sends to
- * another task so doesn't impact this critical section.
- status = rtems_event_send( other_task, 0x02 );
- fatal_directive_check_status_only( status, RTEMS_SUCCESSFUL, "event send" );
- * This event send hits the main task but doesn't satisfy
- * it's blocking condition so it will still block
- status = rtems_event_send( main_task, 0x02 );
- case_hit = TRUE;
- status = rtems_event_send( main_task, 0x01 );
- rtems_id timer,
- void *arg
- * We want to catch the task while it is blocking. Otherwise
- * just send and make it happy.
- case_hit = TRUE;
-rtems_task Init(
- rtems_task_argument argument
- rtems_id timer;
- rtems_event_set out;
- int i;
- int max;
- uint32_t iterations = 0;
- TEST_BEGIN();
- main_task = rtems_task_self();
- * Timer used in multiple ways
- status = rtems_timer_create( 1, &timer );
- directive_failed( status, "rtems_timer_create" );
- status = rtems_task_create(
- 0xa5a5a5a5,
- 1,
- RTEMS_MINIMUM_STACK_SIZE,
- RTEMS_DEFAULT_MODES,
- RTEMS_DEFAULT_ATTRIBUTES,
- &other_task
- directive_failed( status, "rtems_task_create" );
- * Test Event send successful from ISR -- receive is forever
- case_hit = FALSE;
- iterations = 0;
- max = 1;
- while (1) {
- if ( case_hit )
- break;
- status = rtems_timer_fire_after( timer, 1, test_event_from_isr, NULL );
- directive_failed( status, "timer_fire_after failed" );
- for (i=0 ; i<max ; i++ )
- if ( _Event_Sync_state == THREAD_BLOCKING_OPERATION_SATISFIED )
- break;
- status = rtems_event_receive( 0x01, RTEMS_DEFAULT_OPTIONS, 0, &out );
- directive_failed( status, "rtems_event_receive" );
- if ( case_hit == TRUE )
- break;
- max += 2;
- /* with our clock tick, this is about 30 seconds */
- if ( ++iterations >= 4L * 1000L * 30L)
- break;
- printf(
- "Event sent from ISR hitting synchronization point has %soccurred\n",
- (( case_hit == TRUE ) ? "" : "NOT ")
- * Test Event send successful from ISR -- receive has timeout
- case_hit = FALSE;
- iterations = 0;
- max = 1;
- while (1) {
- if ( case_hit )
- break;
- timer, 1, test_event_with_timeout_from_isr, NULL );
- break;
- status = rtems_event_receive( 0x01, RTEMS_DEFAULT_OPTIONS, 10, &out );
- break;
- max += 2;
- break;
- printf(
- "Event sent from ISR (with timeout) hitting synchronization "
- "point has %soccurred\n",
- TEST_END();
- rtems_test_exit( 0 );
diff --git a/testsuites/sptests/sp39/sp39.doc b/testsuites/sptests/sp39/sp39.doc
index e5b7510..0000000
--- a/testsuites/sptests/sp39/sp39.doc
+++ /dev/null
@@ -1,22 +0,0 @@
-# COPYRIGHT (c) 1989-2009.
-# On-Line Applications Research Corporation (OAR).
-# The license and distribution terms for this file may be
-# found in the file LICENSE in this distribution or at
-# http://www.rtems.org/license/LICENSE.
-This file describes the directives and concepts tested by this test set.
-test set name: sp39
-directives:
- rtems_event_receive
- rtems_event_send
-concepts:
-+ Ensure that the interrupt critical section for sending an event from an
- ISR while the receiving task is in the process of blocking with and withing
- timeout is handled properly.
diff --git a/testsuites/sptests/sp39/sp39.scn b/testsuites/sptests/sp39/sp39.scn
index adf690b..0000000
--- a/testsuites/sptests/sp39/sp39.scn
+++ /dev/null
@@ -1,4 +0,0 @@
-*** TEST 39 ***
-Event sent from ISR hitting synchronization point has occurred
-Event sent from ISR (with timeout) hitting synchronization point has occurred
-*** END OF TEST 39 ***
diff --git a/testsuites/sptests/sp39/system.h b/testsuites/sptests/sp39/system.h
index f5f1f25..0000000
--- a/testsuites/sptests/sp39/system.h
+++ /dev/null
@@ -1,38 +0,0 @@
-/* system.h
- * This include file contains information that is included in every
- * function in the test set.
- * COPYRIGHT (c) 1989-2007.
-#include <tmacros.h>
-/* functions */
-rtems_task Init(
-/* configuration information */
-#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
-#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
-#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
-#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
-#define CONFIGURE_MICROSECONDS_PER_TICK 1000
-#define CONFIGURE_MAXIMUM_TASKS 2
-#define CONFIGURE_MAXIMUM_TIMERS 1
-#include <rtems/confdefs.h>
-/* end of include file */
diff --git a/testsuites/sptests/spintrcritical21/Makefile.am b/testsuites/sptests/spintrcritical21/Makefile.am
new file mode 100644
index 0000000..b53d000
--- /dev/null
+++ b/testsuites/sptests/spintrcritical21/Makefile.am
@@ -0,0 +1,20 @@
+rtems_tests_PROGRAMS = spintrcritical21
+spintrcritical21_SOURCES = init.c ../spintrcritical_support/intrcritical.c
+dist_rtems_tests_DATA = spintrcritical21.scn spintrcritical21.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+AM_CPPFLAGS += -I$(top_srcdir)/spintrcritical_support
+LINK_OBJS = $(spintrcritical21_OBJECTS)
+LINK_LIBS = $(spintrcritical21_LDLIBS)
+spintrcritical21$(EXEEXT): $(spintrcritical21_OBJECTS) $(spintrcritical21_DEPENDENCIES)
+ @rm -f spintrcritical21$(EXEEXT)
+ $(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/sptests/spintrcritical21/init.c b/testsuites/sptests/spintrcritical21/init.c
index 0000000..8b1ddcf
--- /dev/null
+++ b/testsuites/sptests/spintrcritical21/init.c
@@ -0,0 +1,170 @@
+ * Classic API Signal to Task from ISR
+ * COPYRIGHT (c) 1989-2011.
+ * On-Line Applications Research Corporation (OAR).
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#define CONFIGURE_INIT
+#include "system.h"
+#include <intrcritical.h>
+#include <rtems/rtems/eventimpl.h>
+const char rtems_test_name[] = "SPINTRCRITICAL 21";
+ * ERROR CHECKING NOTE:
+ * We are either at dispatch disable level 1 or 2. Either way, it is
+ * safer not to check the dispatch level explicitly so we are using
+ * fatal_directive_check_status_only() not directive_failed().
+static volatile bool case_hit;
+static rtems_id main_task;
+static rtems_id other_task;
+static rtems_timer_service_routine test_event_from_isr(
+ rtems_id timer,
+ void *arg
+ rtems_status_code status;
+ if ( _Event_Sync_state == THREAD_BLOCKING_OPERATION_NOTHING_HAPPENED ) {
+ * This event send hits the critical section but sends to
+ * another task so doesn't impact this critical section.
+ status = rtems_event_send( other_task, 0x02 );
+ fatal_directive_check_status_only( status, RTEMS_SUCCESSFUL, "event send" );
+ * This event send hits the main task but doesn't satisfy
+ * it's blocking condition so it will still block
+ status = rtems_event_send( main_task, 0x02 );
+ case_hit = true;
+ status = rtems_event_send( main_task, 0x01 );
+static bool test_body_event_from_isr( void *arg )
+ rtems_event_set out;
+ (void) arg;
+ status = rtems_event_receive( 0x01, RTEMS_DEFAULT_OPTIONS, 0, &out );
+ rtems_test_assert( status == RTEMS_SUCCESSFUL );
+ return case_hit;
+static rtems_timer_service_routine test_event_with_timeout_from_isr(
+ rtems_id timer,
+ void *arg
+ * We want to catch the task while it is blocking. Otherwise
+ * just send and make it happy.
+ case_hit = true;
+static bool test_body_event_with_timeout_from_isr( void *arg )
+ (void) arg;
+ status = rtems_event_receive( 0x01, RTEMS_DEFAULT_OPTIONS, 1, &out );
+ rtems_test_assert( status == RTEMS_SUCCESSFUL || status == RTEMS_TIMEOUT );
+ return case_hit;
+rtems_task Init(
+ rtems_task_argument argument
+ TEST_BEGIN();
+ main_task = rtems_task_self();
+ status = rtems_task_create(
+ 0xa5a5a5a5,
+ 1,
+ RTEMS_MINIMUM_STACK_SIZE,
+ RTEMS_DEFAULT_MODES,
+ RTEMS_DEFAULT_ATTRIBUTES,
+ &other_task
+ directive_failed( status, "rtems_task_create" );
+ * Test Event send successful from ISR -- receive is forever
+ case_hit = false;
+ interrupt_critical_section_test(
+ test_body_event_from_isr,
+ NULL,
+ test_event_from_isr
+ printf(
+ "Event sent from ISR hitting synchronization point has %soccurred\n",
+ case_hit ? "" : "NOT "
+ rtems_test_assert( case_hit );
+ * Test Event send successful from ISR -- receive has timeout
+ case_hit = false;
+ test_body_event_with_timeout_from_isr,
+ NULL,
+ test_event_with_timeout_from_isr
+ printf(
+ "Event sent from ISR (with timeout) hitting synchronization "
+ "point has %soccurred\n",
+ TEST_END();
+ rtems_test_exit( 0 );
diff --git a/testsuites/sptests/spintrcritical21/spintrcritical21.doc b/testsuites/sptests/spintrcritical21/spintrcritical21.doc
index 0000000..94423e1
--- /dev/null
+++ b/testsuites/sptests/spintrcritical21/spintrcritical21.doc
@@ -0,0 +1,22 @@
+# COPYRIGHT (c) 1989-2009.
+# On-Line Applications Research Corporation (OAR).
+# The license and distribution terms for this file may be
+# found in the file LICENSE in this distribution or at
+# http://www.rtems.org/license/LICENSE.
+This file describes the directives and concepts tested by this test set.
+test set name: spintrcritical21
+directives:
+ rtems_event_receive
+ rtems_event_send
+concepts:
++ Ensure that the interrupt critical section for sending an event from an
+ ISR while the receiving task is in the process of blocking with and withing
+ timeout is handled properly.
diff --git a/testsuites/sptests/spintrcritical21/spintrcritical21.scn b/testsuites/sptests/spintrcritical21/spintrcritical21.scn
index 0000000..d7a1998
--- /dev/null
+++ b/testsuites/sptests/spintrcritical21/spintrcritical21.scn
@@ -0,0 +1,4 @@
+*** BEGIN OF TEST SPINTRCRITICAL 21 ***
+Event sent from ISR hitting synchronization point has occurred
+Event sent from ISR (with timeout) hitting synchronization point has occurred
+*** END OF TEST SPINTRCRITICAL 21 ***
diff --git a/testsuites/sptests/spintrcritical21/system.h b/testsuites/sptests/spintrcritical21/system.h
index 0000000..f9111c0
--- /dev/null
+++ b/testsuites/sptests/spintrcritical21/system.h
@@ -0,0 +1,39 @@
+/* system.h
+ * This include file contains information that is included in every
+ * function in the test set.
+ * COPYRIGHT (c) 1989-2007.
+#include <tmacros.h>
+/* functions */
+rtems_task Init(
+/* configuration information */
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_MICROSECONDS_PER_TICK 1000
+#define CONFIGURE_MAXIMUM_TASKS 2
+#define CONFIGURE_MAXIMUM_TIMERS 1
+#define CONFIGURE_MAXIMUM_USER_EXTENSIONS 1
+#include <rtems/confdefs.h>
+/* end of include file */
1.8.4.5
