rtems-tld tracing with printk
Chris Johns
chrisj at rtems.org
Wed Sep 10 03:53:30 UTC 2014
Hi,
This is an update on the RTEMS trace linker being worked on and found in
the http://git.rtems.org/chrisj/rtl-host.git repo.
The following is a trace using the both_hello example in examples-v2
using the trace configuration file attached:
$ sparc-rtems4.11-run both_hello.exe
>> _Thread_Initialize (0x020013C0)
1] Objects_Information*(4) = 0203C70C
2] Thread_Control*(4) = 0203EB48
3] const Scheduler_Control*(4) = 02035FF8
4] void*(4) = 00000000
5] size_t(4) = 00001000
6] bool(1) = 00
7] Priority_Control(4) = 000000FF
8] bool(1) = 01
9] Thread_CPU_budget_algorithms(4) = 00000000
10] Thread_CPU_budget_algorithm_callout(4) = 00000000
11] uint32_t(4) = 00000000
12] Objects_Name(4) = 49444C45
<< _Thread_Initialize (0x020013C0)
rt] bool(1) = 01
1] Objects_Information*(4) = 0203C5EC
2] Thread_Control*(4) = 0203F0F8
6] bool(1) = 00
7] Priority_Control(4) = 00000001
8] bool(1) = 00
12] Objects_Name(4) = 55493120
rt] bool(1) = 01
1] Objects_Information*(4) = 0203C86C
2] Thread_Control*(4) = 0203F940
5] size_t(4) = 00002000
6] bool(1) = 01
7] Priority_Control(4) = 000000FD
8] bool(1) = 01
12] Objects_Name(4) = 00000000
rt] bool(1) = 01
Classic -- Hello World
POSIX -- Hello World
>> exit (0x02001324)
1] int(4) = 00000000
I also attach the waf script I used to build the example. You need to
build and install the rtl-host code to get a working rtems-tld.
The 3 threads created are the Init, POSIX_Init and IDLE No code in RTEMS
was altered to do this.
; RTEMS Trace Linker Configuration: hello
; This script configure the both hello example to perform some
; tracing via the printf trace generator.
[tracer]
; Name of the trace.
name = Hello RTEMS Tracer
; Options can be defined here or on the command line.
options = all-funcs, verbose
; Functions to trace.
traces = hello-trace
; Define the function sets. These are the function's that can be
; added to the trace lists.
functions = hello-trace
; Include RTEMS Trace support.
include = rtems.ini, rtld-base.ini
; User application trace example.
[hello-trace]
generator = printk-generator
signatures = hello-signatures
trace = exit, Init, POSIX_Init, _Thread_Initialize
header = "#include <rtems.h>"
header = "#include <rtems/score/objectimpl.h>"
header = "#include <rtems/score/scheduler.h>"
[hello-signatures]
exit=void, int
Init = void, rtems_task_argument
POSIX_Init = void*, void*
_Thread_Initialize = bool, Objects_Information*, Thread_Control*, const Scheduler_Control*, void*, size_t, bool, Priority_Control, bool, Thread_CPU_budget_algorithms, Thread_CPU_budget_algorithm_callout, uint32_t, Objects_Name
# Copyright 2013 Gedare Bloom (gedare at rtems.org)
# Copyright 2014 Chris Johns (chrisj at rtems.org)
# This file's license is 2-clause BSD as in this distribution's LICENSE.2 file.
# Waf build script for an RTEMS Hello
import rtems_waf.rtems as rtems
def build(bld):
rtems.build(bld)
if rtems.check_env(bld, 'RTEMS_TLD'):
bld(features = 'c rtrace',
target = 'both_hello.exe',
source = ['test.c'],
rtems_trace_cfg = '../../hello/both_hello/hello.ini')
else:
bld(features = 'c cprogram',
source = ['test.c'])
