[PATCH 1/4] Use correct prototype of benchmark_timer_read()
Thu Sep 11 13:28:14 UTC 2014
This change starts with removing the effectively empty file
timerdrv.h. The prototypes for benchmark_timer_XXX() were in
btimer.h which was not universally used. Thus every use of
timerdrv.h had to be changed to btimer.h. Then the prototypes
for benchmark_timer_read() had to be adjusted to return
benchmark_timer_t rather than int or uint32_t.
I took this opportunity to also correct the file headers to
separate the copyright from the file description comments which
is needed to ensure the copyright isn't propagated into Doxygen
output.
 c/src/lib/libbsp/arm/edb7312/timer/timer.c         |  2 +-
 c/src/lib/libbsp/arm/gba/timer/timer.c             |  2 +-
 .../arm/lpc176x/benchmark_timer/benchmark_timer.c  |  4 +--
 c/src/lib/libbsp/arm/lpc24xx/misc/timer.c          |  3 +-
 c/src/lib/libbsp/arm/lpc32xx/misc/timer.c          |  3 +-
 c/src/lib/libbsp/arm/raspberrypi/misc/timer.c      |  4 +--
 .../lib/libbsp/arm/tms570/clock/benchmark_timer.c  |  3 +-
 c/src/lib/libbsp/i386/pc386/timer/timer.c          |  6 ++--
 .../lib/libbsp/lm32/shared/milkymist_timer/timer.c |  2 +-
 c/src/lib/libbsp/lm32/shared/timer/timer.c         |  2 +-
 c/src/lib/libbsp/m32c/m32cbsp/timer/timer.c        |  2 +-
 c/src/lib/libbsp/m68k/gen68302/timer/timer.c       |  2 +-
 c/src/lib/libbsp/m68k/idp/timer/timer.c            |  2 +-
 c/src/lib/libbsp/m68k/mcf52235/timer/timer.c       |  2 +-
 c/src/lib/libbsp/m68k/mcf5225x/timer/timer.c       |  2 +-
 c/src/lib/libbsp/m68k/mcf5329/timer/timer.c        |  2 +-
 c/src/lib/libbsp/m68k/mrm332/timer/timer.c         |  2 +-
 c/src/lib/libbsp/m68k/mvme136/timer/timer.c        |  2 +-
 c/src/lib/libbsp/m68k/mvme147/timer/timer.c        |  2 +-
 c/src/lib/libbsp/m68k/mvme162/timer/timer.c        |  2 +-
 c/src/lib/libbsp/m68k/mvme167/timer/timer.c        | 34 ++++++++++++----------
 c/src/lib/libbsp/m68k/mvme167/timer/timerisr.S     | 13 ++++-----
 c/src/lib/libbsp/m68k/ods68302/timer/timer.c       |  2 +-
 c/src/lib/libbsp/mips/csb350/timer/timer.c         |  2 +-
 c/src/lib/libbsp/mips/genmongoosev/timer/timer.c   |  2 +-
 c/src/lib/libbsp/mips/jmr3904/timer/timer.c        |  2 +-
 c/src/lib/libbsp/nios2/nios2_iss/timer/timer.c     |  2 +-
 c/src/lib/libbsp/no_cpu/no_bsp/timer/timer.c       |  2 +-
 c/src/lib/libbsp/no_cpu/no_bsp/timer/timerisr.c    | 14 +++++----
 c/src/lib/libbsp/or1k/or1ksim/timer/timer.c        |  2 +-
 c/src/lib/libbsp/powerpc/score603e/timer/timer.c   |  2 +-
 c/src/lib/libbsp/powerpc/tqm8xx/timer/timer.c      |  2 +-
 c/src/lib/libbsp/shared/timerstub.c                |  2 +-
 c/src/lib/libbsp/sparc/erc32/timer/timer.c         |  2 +-
 c/src/lib/libbsp/sparc/leon2/timer/timer.c         |  2 +-
 c/src/lib/libbsp/sparc/leon3/timer/timer.c         |  2 +-
 c/src/lib/libcpu/arm/at91rm9200/timer/timer.c      | 25 +++++++---------
 c/src/lib/libcpu/arm/lpc22xx/timer/timer.c         | 34 ++++++++++------------
 c/src/lib/libcpu/arm/mc9328mxl/timer/timer.c       | 23 ++++++---------
 c/src/lib/libcpu/arm/pxa255/timer/timer.c          | 25 +++++++---------
 c/src/lib/libcpu/arm/s3c24xx/timer/timer.c         | 31 +++++++++-----------
 c/src/lib/libcpu/bfin/timer/timer.c                | 22 ++++++++------
 c/src/lib/libcpu/m68k/mcf5206/timer/timer.c        | 12 +++++---
 c/src/lib/libcpu/m68k/mcf5206/timer/timerisr.S     | 11 ++++---
 c/src/lib/libcpu/m68k/mcf5272/timer/timer.c        | 11 ++++---
 c/src/lib/libcpu/m68k/mcf5272/timer/timerisr.S     | 12 ++++----
 c/src/lib/libcpu/mips/timer/timer.c                | 30 +++++++------------
 c/src/lib/libcpu/powerpc/mpc505/timer/timer.c      | 15 ++++++----
 c/src/lib/libcpu/powerpc/mpc5xx/timer/timer.c      | 20 ++++++-------
 c/src/lib/libcpu/powerpc/mpc6xx/timer/timer.c      | 17 ++++++-----
 c/src/lib/libcpu/powerpc/mpc8260/timer/timer.c     | 19 ++++++------
 c/src/lib/libcpu/powerpc/mpc8xx/timer/timer.c      | 18 ++++++------
 c/src/lib/libcpu/powerpc/ppc403/timer/timer.c      | 16 +++++-----
 c/src/lib/libcpu/sh/sh7032/timer/timer.c           | 18 +++++-------
 c/src/lib/libcpu/sh/sh7045/timer/timer.c           | 18 +++++-------
 c/src/lib/libcpu/sh/sh7750/timer/timer.c           | 18 +++++-------
 cpukit/libcsupport/Makefile.am                     |  1 -
 cpukit/libcsupport/include/timerdrv.h              | 34 ----------------------
 cpukit/libcsupport/preinstall.am                   |  4 ---
 cpukit/sapi/include/confdefs.h                     |  2 +-
 doc/bsp_howto/timer.t                              |  2 +-
 testsuites/psxtmtests/psxtmbarrier01/init.c        |  2 +-
 testsuites/psxtmtests/psxtmbarrier02/init.c        |  2 +-
 testsuites/psxtmtests/psxtmbarrier03/init.c        |  2 +-
 testsuites/psxtmtests/psxtmbarrier04/init.c        |  2 +-
 testsuites/psxtmtests/psxtmcond01/init.c           |  2 +-
 testsuites/psxtmtests/psxtmcond02/init.c           |  2 +-
 testsuites/psxtmtests/psxtmcond03/init.c           |  2 +-
 testsuites/psxtmtests/psxtmcond04/init.c           |  2 +-
 testsuites/psxtmtests/psxtmcond05/init.c           |  2 +-
 testsuites/psxtmtests/psxtmcond06/init.c           |  2 +-
 testsuites/psxtmtests/psxtmcond07/init.c           |  2 +-
 testsuites/psxtmtests/psxtmcond08/init.c           |  2 +-
 testsuites/psxtmtests/psxtmkey01/init.c            |  2 +-
 testsuites/psxtmtests/psxtmkey02/init.c            |  2 +-
 testsuites/psxtmtests/psxtmmq01/init.c             |  2 +-
 testsuites/psxtmtests/psxtmmutex01/init.c          |  2 +-
 testsuites/psxtmtests/psxtmmutex02/init.c          |  2 +-
 testsuites/psxtmtests/psxtmmutex03/init.c          |  2 +-
 testsuites/psxtmtests/psxtmmutex04/init.c          |  2 +-
 testsuites/psxtmtests/psxtmmutex05/init.c          |  2 +-
 testsuites/psxtmtests/psxtmmutex06/init.c          |  2 +-
 testsuites/psxtmtests/psxtmmutex07/init.c          |  2 +-
 testsuites/psxtmtests/psxtmnanosleep01/init.c      |  2 +-
 testsuites/psxtmtests/psxtmnanosleep02/init.c      |  2 +-
 testsuites/psxtmtests/psxtmrwlock01/init.c         |  2 +-
 testsuites/psxtmtests/psxtmrwlock02/init.c         |  2 +-
 testsuites/psxtmtests/psxtmrwlock03/init.c         |  2 +-
 testsuites/psxtmtests/psxtmrwlock04/init.c         |  2 +-
 testsuites/psxtmtests/psxtmrwlock05/init.c         |  2 +-
 testsuites/psxtmtests/psxtmrwlock06/init.c         |  2 +-
 testsuites/psxtmtests/psxtmrwlock07/init.c         |  2 +-
 testsuites/psxtmtests/psxtmsem01/init.c            |  2 +-
 testsuites/psxtmtests/psxtmsem02/init.c            |  2 +-
 testsuites/psxtmtests/psxtmsem03/init.c            |  2 +-
 testsuites/psxtmtests/psxtmsem04/init.c            |  2 +-
 testsuites/psxtmtests/psxtmsem05/init.c            |  2 +-
 testsuites/psxtmtests/psxtmsleep01/init.c          |  2 +-
 testsuites/psxtmtests/psxtmsleep02/init.c          |  2 +-
 testsuites/psxtmtests/psxtmthread02/init.c         |  2 +-
 testsuites/psxtmtests/psxtmthread03/init.c         |  2 +-
 testsuites/psxtmtests/psxtmthread04/init.c         |  2 +-
 testsuites/psxtmtests/psxtmthread05/init.c         |  2 +-
 testsuites/psxtmtests/psxtmthread06/init.c         |  2 +-
 testsuites/rhealstone/rhdeadlockbrk/deadlockbrk.c  |  2 +-
 testsuites/rhealstone/rhilatency/ilatency.c        |  2 +-
 testsuites/rhealstone/rhmlatency/mlatency.c        |  2 +-
 testsuites/rhealstone/rhsemshuffle/semshuffle.c    |  2 +-
 testsuites/rhealstone/rhtaskpreempt/taskpreempt.c  |  2 +-
 testsuites/rhealstone/rhtaskswitch/taskswitch.c    |  2 +-
 testsuites/support/src/tmtests_support.c           |  4 +--
 111 files changed, 309 insertions(+), 369 deletions(-)
 delete mode 100644 cpukit/libcsupport/include/timerdrv.h
diff --git a/c/src/lib/libbsp/arm/edb7312/timer/timer.c b/c/src/lib/libbsp/arm/edb7312/timer/timer.c
index c17ee5a..b795122 100644
--- a/c/src/lib/libbsp/arm/edb7312/timer/timer.c
+++ b/c/src/lib/libbsp/arm/edb7312/timer/timer.c
@@ -46,7 +46,7 @@ void benchmark_timer_initialize( void )
                              /* This value is in microseconds. */
 #define LEAST_VALID       1  /* Don't trust a clicks value lower than this */
-uint32_t benchmark_timer_read( void )
+benchmark_timer_t benchmark_timer_read( void )
   uint16_t         t;
   uint32_t         total;
diff --git a/c/src/lib/libbsp/arm/gba/timer/timer.c b/c/src/lib/libbsp/arm/gba/timer/timer.c
index 058dfcb..9aad103 100644
--- a/c/src/lib/libbsp/arm/gba/timer/timer.c
+++ b/c/src/lib/libbsp/arm/gba/timer/timer.c
@@ -94,7 +94,7 @@ void benchmark_timer_initialize( void )
  *  @param  None
  *  @return Timer value in microseconds
   uint32_t  ticks;
   uint32_t  total;
diff --git a/c/src/lib/libbsp/arm/lpc176x/benchmark_timer/benchmark_timer.c b/c/src/lib/libbsp/arm/lpc176x/benchmark_timer/benchmark_timer.c
index a8f2855..2aa4910 100644
--- a/c/src/lib/libbsp/arm/lpc176x/benchmark_timer/benchmark_timer.c
+++ b/c/src/lib/libbsp/arm/lpc176x/benchmark_timer/benchmark_timer.c
@@ -32,7 +32,7 @@ void benchmark_timer_initialize( void )
   benchmark_timer_base = lpc176x_timer_get_timer_value( LPC176X_TIMER_1 );
   uint32_t delta = lpc176x_timer_get_timer_value( LPC176X_TIMER_1 ) -
                    benchmark_timer_base;
@@ -42,4 +42,4 @@ uint32_t benchmark_timer_read( void )
 void benchmark_timer_disable_subtracting_average_overhead( bool find_avg_ovhead )
\ No newline at end of file
diff --git a/c/src/lib/libbsp/arm/lpc24xx/misc/timer.c b/c/src/lib/libbsp/arm/lpc24xx/misc/timer.c
index 8b4bc67..c700d04 100644
--- a/c/src/lib/libbsp/arm/lpc24xx/misc/timer.c
+++ b/c/src/lib/libbsp/arm/lpc24xx/misc/timer.c
@@ -22,7 +22,6 @@
 #include <bsp.h>
 #include <rtems/btimer.h>
-#include <rtems/timerdrv.h>
 #include <bsp/system-clocks.h>
@@ -35,7 +34,7 @@ void benchmark_timer_initialize(void)
   benchmark_timer_base = lpc24xx_timer();
-uint32_t benchmark_timer_read(void)
+benchmark_timer_t benchmark_timer_read(void)
   uint32_t delta = lpc24xx_timer() - benchmark_timer_base;
diff --git a/c/src/lib/libbsp/arm/lpc32xx/misc/timer.c b/c/src/lib/libbsp/arm/lpc32xx/misc/timer.c
index 3edae37..5079452 100644
--- a/c/src/lib/libbsp/arm/lpc32xx/misc/timer.c
+++ b/c/src/lib/libbsp/arm/lpc32xx/misc/timer.c
@@ -21,7 +21,6 @@
 #include <bsp.h>
@@ -32,7 +31,7 @@ void benchmark_timer_initialize(void)
   benchmark_timer_base = lpc32xx_timer();
   return lpc32xx_timer() - benchmark_timer_base;
diff --git a/c/src/lib/libbsp/arm/raspberrypi/misc/timer.c b/c/src/lib/libbsp/arm/raspberrypi/misc/timer.c
index 7e83e40..e90af08 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/misc/timer.c
+++ b/c/src/lib/libbsp/arm/raspberrypi/misc/timer.c
@@ -17,7 +17,7 @@
+#include <rtems/btimer.h>
 #include <bsp/raspberrypi.h>
 static bool benchmark_timer_find_average_overhead = false;
@@ -29,7 +29,7 @@ void benchmark_timer_initialize(void)
   benchmark_timer_base = BCM2835_REG(BCM2835_GPU_TIMER_CLO);
   uint32_t delta = BCM2835_REG(BCM2835_GPU_TIMER_CLO) - benchmark_timer_base;
diff --git a/c/src/lib/libbsp/arm/tms570/clock/benchmark_timer.c b/c/src/lib/libbsp/arm/tms570/clock/benchmark_timer.c
index b45f0f4..a2a0304 100644
--- a/c/src/lib/libbsp/arm/tms570/clock/benchmark_timer.c
+++ b/c/src/lib/libbsp/arm/tms570/clock/benchmark_timer.c
@@ -28,7 +28,6 @@
 #include <bsp.h>
@@ -39,7 +38,7 @@ void benchmark_timer_initialize(void)
   benchmark_timer_base = _CPU_Counter_read();
   uint32_t delta = _CPU_Counter_read() - benchmark_timer_base;
diff --git a/c/src/lib/libbsp/i386/pc386/timer/timer.c b/c/src/lib/libbsp/i386/pc386/timer/timer.c
index 8c3235b..953db03 100644
--- a/c/src/lib/libbsp/i386/pc386/timer/timer.c
+++ b/c/src/lib/libbsp/i386/pc386/timer/timer.c
@@ -51,9 +51,9 @@ volatile uint32_t         Ttimer_val;
 bool                      benchmark_timer_find_average_overhead = true;
 volatile unsigned int     fastLoop1ms, slowLoop1ms;
-void     (*benchmark_timer_initialize_function)(void) = 0;
-uint32_t (*benchmark_timer_read_function)(void) = 0;
-void     (*Timer_exit_function)(void) = 0;
+void              (*benchmark_timer_initialize_function)(void) = 0;
+benchmark_timer_t (*benchmark_timer_read_function)(void) = 0;
+void              (*Timer_exit_function)(void) = 0;
 /* timer (int 08h) Interrupt Service Routine (defined in 'timerisr.s') */
 extern void timerisr(void);
diff --git a/c/src/lib/libbsp/lm32/shared/milkymist_timer/timer.c b/c/src/lib/libbsp/lm32/shared/milkymist_timer/timer.c
index 5eb0215..bba2eee 100644
--- a/c/src/lib/libbsp/lm32/shared/milkymist_timer/timer.c
+++ b/c/src/lib/libbsp/lm32/shared/milkymist_timer/timer.c
@@ -47,7 +47,7 @@ void benchmark_timer_initialize(void)
 #define LEAST_VALID       4  /* Don't trust a clicks value lower than this */
   uint32_t ticks;
   uint32_t total;
diff --git a/c/src/lib/libbsp/lm32/shared/timer/timer.c b/c/src/lib/libbsp/lm32/shared/timer/timer.c
index 98eb576..aa39c1a 100644
--- a/c/src/lib/libbsp/lm32/shared/timer/timer.c
+++ b/c/src/lib/libbsp/lm32/shared/timer/timer.c
@@ -76,7 +76,7 @@ void benchmark_timer_initialize( void )
   uint32_t ticks;
   uint32_t total;
diff --git a/c/src/lib/libbsp/m32c/m32cbsp/timer/timer.c b/c/src/lib/libbsp/m32c/m32cbsp/timer/timer.c
index 5ce906c..0b5aa99 100644
--- a/c/src/lib/libbsp/m32c/m32cbsp/timer/timer.c
+++ b/c/src/lib/libbsp/m32c/m32cbsp/timer/timer.c
@@ -41,7 +41,7 @@ void benchmark_timer_initialize(void)
   TABSR = 0x55;
   uint32_t count;
diff --git a/c/src/lib/libbsp/m68k/gen68302/timer/timer.c b/c/src/lib/libbsp/m68k/gen68302/timer/timer.c
index a942fe6..6749efc 100644
--- a/c/src/lib/libbsp/m68k/gen68302/timer/timer.c
+++ b/c/src/lib/libbsp/m68k/gen68302/timer/timer.c
@@ -64,7 +64,7 @@ void benchmark_timer_initialize( void )
  * Return timer value in 1/2-microsecond units
   uint16_t         clicks;
   uint32_t         total;
diff --git a/c/src/lib/libbsp/m68k/idp/timer/timer.c b/c/src/lib/libbsp/m68k/idp/timer/timer.c
index 0788e49..23ffff7 100644
--- a/c/src/lib/libbsp/m68k/idp/timer/timer.c
+++ b/c/src/lib/libbsp/m68k/idp/timer/timer.c
@@ -49,7 +49,7 @@ void benchmark_timer_initialize(void)
 #define AVG_OVERHEAD      9  /* may not be right -- do this later */
 #define LEAST_VALID       10 /* Don't trust a value lower than this */
   uint8_t         data;
   uint8_t          msb, osb, lsb;
diff --git a/c/src/lib/libbsp/m68k/mcf52235/timer/timer.c b/c/src/lib/libbsp/m68k/mcf52235/timer/timer.c
index 9faed0d..f912254 100644
--- a/c/src/lib/libbsp/m68k/mcf52235/timer/timer.c
+++ b/c/src/lib/libbsp/m68k/mcf52235/timer/timer.c
  * Return timer value in microsecond units
   return MCF_DTIM3_DTCN;
diff --git a/c/src/lib/libbsp/m68k/mcf5225x/timer/timer.c b/c/src/lib/libbsp/m68k/mcf5225x/timer/timer.c
index 19a9513..ac0ca6d 100644
--- a/c/src/lib/libbsp/m68k/mcf5225x/timer/timer.c
+++ b/c/src/lib/libbsp/m68k/mcf5225x/timer/timer.c
diff --git a/c/src/lib/libbsp/m68k/mcf5329/timer/timer.c b/c/src/lib/libbsp/m68k/mcf5329/timer/timer.c
index 6d3dc85..0f762c0 100644
--- a/c/src/lib/libbsp/m68k/mcf5329/timer/timer.c
+++ b/c/src/lib/libbsp/m68k/mcf5329/timer/timer.c
diff --git a/c/src/lib/libbsp/m68k/mrm332/timer/timer.c b/c/src/lib/libbsp/m68k/mrm332/timer/timer.c
index 71a2e48..8c14f8f 100644
--- a/c/src/lib/libbsp/m68k/mrm332/timer/timer.c
+++ b/c/src/lib/libbsp/m68k/mrm332/timer/timer.c
@@ -38,7 +38,7 @@ void benchmark_timer_initialize( void )
   uint32_t         total;
   total = 0;
diff --git a/c/src/lib/libbsp/m68k/mvme136/timer/timer.c b/c/src/lib/libbsp/m68k/mvme136/timer/timer.c
index d767e68..a445b71 100644
--- a/c/src/lib/libbsp/m68k/mvme136/timer/timer.c
+++ b/c/src/lib/libbsp/m68k/mvme136/timer/timer.c
@@ -50,7 +50,7 @@ void benchmark_timer_initialize(void)
                              /* (6 countdowns) to start/stop the timer. */
   uint8_t          msb, lsb;
diff --git a/c/src/lib/libbsp/m68k/mvme147/timer/timer.c b/c/src/lib/libbsp/m68k/mvme147/timer/timer.c
index 98331c7..1db32c5 100644
--- a/c/src/lib/libbsp/m68k/mvme147/timer/timer.c
+++ b/c/src/lib/libbsp/m68k/mvme147/timer/timer.c
@@ -45,7 +45,7 @@ void benchmark_timer_initialize(void)
 				synchronized whith the counter updates*/
   uint32_t         total;
   uint16_t         counter_value;
diff --git a/c/src/lib/libbsp/m68k/mvme162/timer/timer.c b/c/src/lib/libbsp/m68k/mvme162/timer/timer.c
index b8bdde8..579685c 100644
--- a/c/src/lib/libbsp/m68k/mvme162/timer/timer.c
+++ b/c/src/lib/libbsp/m68k/mvme162/timer/timer.c
                                 /* (3 countdowns) to start/stop the timer. */
 #define LEAST_VALID       10U   /* Don't trust a value lower than this */
   uint32_t            total;
diff --git a/c/src/lib/libbsp/m68k/mvme167/timer/timer.c b/c/src/lib/libbsp/m68k/mvme167/timer/timer.c
index 556d7bf..3b5dad4 100644
--- a/c/src/lib/libbsp/m68k/mvme167/timer/timer.c
+++ b/c/src/lib/libbsp/m68k/mvme167/timer/timer.c
@@ -1,22 +1,26 @@
-/*  timer.c
+ * @file
- *  This file manages the benchmark timer used by the RTEMS Timing Test Suite.
- *  Each measured time period is demarcated by calls to benchmark_timer_initialize() and
- *  benchmark_timer_read().  benchmark_timer_read() usually returns the number of microseconds
- *  since benchmark_timer_initialize() exitted.
+ * This file manages the benchmark timer used by the RTEMS Timing Test Suite.
+ * Each measured time period is demarcated by calls to
+ * benchmark_timer_initialize() and benchmark_timer_read().
+ * benchmark_timer_read() usually returns the number of microseconds
+ * since benchmark_timer_initialize() exitted.
- *  These functions are prototyped in rtems/c/src/lib/include/timerdrv.h and
- *  must be implemented as part of the BSP.
+ * These functions are prototyped in rtems/btimer.h and
+ * must be implemented as part of the BSP.
- *  This port does not allow the application to select which timer on the
- *  MVME167 to use for the timer, nor does it allow the application to
- *  configure the timer. The timer uses the VMEchip2 Tick Timer #1. This timer
- *  is distinct from the clock, which uses Tick Timer #2 in the VMEchip2.
+ * This port does not allow the application to select which timer on the
+ * MVME167 to use for the timer, nor does it allow the application to
+ * configure the timer. The timer uses the VMEchip2 Tick Timer #1. This timer
+ * is distinct from the clock, which uses Tick Timer #2 in the VMEchip2.
- *  All page references are to the MVME166/MVME167/MVME187 Single Board
- *  Computer Programmer's Reference Guide (MVME187PG/D2) with the April 1993
+ * All page references are to the MVME166/MVME167/MVME187 Single Board
+ * Computer Programmer's Reference Guide (MVME187PG/D2) with the April 1993
  *  supplements/addenda (MVME187PG/D2A1).
  *  COPYRIGHT (c) 1989-1999.
  *  On-Line Applications Research Corporation (OAR).
@@ -104,7 +108,7 @@ void benchmark_timer_initialize(void)
  *  LEAST_VALID is the lowest number this routine should trust.  Numbers
  *  below this are "noise" and zero is returned.
   uint32_t            total;
diff --git a/c/src/lib/libbsp/m68k/mvme167/timer/timerisr.S b/c/src/lib/libbsp/m68k/mvme167/timer/timerisr.S
index d109c9c..d96f099 100644
--- a/c/src/lib/libbsp/m68k/mvme167/timer/timerisr.S
+++ b/c/src/lib/libbsp/m68k/mvme167/timer/timerisr.S
@@ -1,14 +1,13 @@
-/*  timer_isr()
+ *  @file
  *  This ISR is used to bump a count of interval "overflow" interrupts which
  *  have occurred since the timer was started. The number of overflows is taken
  *  into account in the benchmark_timer_read() routine.
- *  Input parameters:  NONE
- *  Output parameters:  NONE
- *  COPYRIGHT (c) 1989-1999.
+ *  COPYRIGHT (c) 1989-2014.
  *  The license and distribution terms for this file may be
diff --git a/c/src/lib/libbsp/m68k/ods68302/timer/timer.c b/c/src/lib/libbsp/m68k/ods68302/timer/timer.c
index f0afdfd..1e03015 100644
--- a/c/src/lib/libbsp/m68k/ods68302/timer/timer.c
+++ b/c/src/lib/libbsp/m68k/ods68302/timer/timer.c
@@ -67,7 +67,7 @@ void benchmark_timer_initialize( void )
   uint16_t         clicks;
   uint32_t         total;
diff --git a/c/src/lib/libbsp/mips/csb350/timer/timer.c b/c/src/lib/libbsp/mips/csb350/timer/timer.c
index 8fe45e5..30dbfe8 100644
--- a/c/src/lib/libbsp/mips/csb350/timer/timer.c
+++ b/c/src/lib/libbsp/mips/csb350/timer/timer.c
 #define LEAST_VALID       1  /* Don't trust a value lower than this */
                              /* tx39 simulator can count instructions. :) */
   uint32_t  total;
   uint32_t  cnt;
diff --git a/c/src/lib/libbsp/mips/genmongoosev/timer/timer.c b/c/src/lib/libbsp/mips/genmongoosev/timer/timer.c
index c60779f..a956c4b 100644
--- a/c/src/lib/libbsp/mips/genmongoosev/timer/timer.c
+++ b/c/src/lib/libbsp/mips/genmongoosev/timer/timer.c
@@ -55,7 +55,7 @@ void benchmark_timer_initialize(void)
                              /* mongoose-v can count cycles. :) */
 #include <rtems/bspIo.h>
   uint32_t          clicks;
   uint32_t          total;
diff --git a/c/src/lib/libbsp/mips/jmr3904/timer/timer.c b/c/src/lib/libbsp/mips/jmr3904/timer/timer.c
index bce4d9d..ca97cd3 100644
--- a/c/src/lib/libbsp/mips/jmr3904/timer/timer.c
+++ b/c/src/lib/libbsp/mips/jmr3904/timer/timer.c
@@ -44,7 +44,7 @@ void benchmark_timer_initialize(void)
   uint32_t          total;
diff --git a/c/src/lib/libbsp/nios2/nios2_iss/timer/timer.c b/c/src/lib/libbsp/nios2/nios2_iss/timer/timer.c
index 744cba5..e37c821 100644
--- a/c/src/lib/libbsp/nios2/nios2_iss/timer/timer.c
+++ b/c/src/lib/libbsp/nios2/nios2_iss/timer/timer.c
 #define LEAST_VALID AVG_OVERHEAD /* Don't trust a value lower than this */
   uint32_t timer_wraps;
   uint32_t timer_snap;
diff --git a/c/src/lib/libbsp/no_cpu/no_bsp/timer/timer.c b/c/src/lib/libbsp/no_cpu/no_bsp/timer/timer.c
index 78423b2..e9b59dc 100644
--- a/c/src/lib/libbsp/no_cpu/no_bsp/timer/timer.c
+++ b/c/src/lib/libbsp/no_cpu/no_bsp/timer/timer.c
@@ -53,7 +53,7 @@ void benchmark_timer_initialize( void )
   uint32_t         clicks;
   uint32_t         total;
diff --git a/c/src/lib/libbsp/no_cpu/no_bsp/timer/timerisr.c b/c/src/lib/libbsp/no_cpu/no_bsp/timer/timerisr.c
index 961a16b..5ca7152 100644
--- a/c/src/lib/libbsp/no_cpu/no_bsp/timer/timerisr.c
+++ b/c/src/lib/libbsp/no_cpu/no_bsp/timer/timerisr.c
@@ -1,4 +1,5 @@
-/*  timerisr.s
+ *  @file
  *  If required this ISR is used to bump a count of interval "overflow"
  *  interrupts which have occurred since the timer was started.  The
@@ -9,10 +10,12 @@
  *  handler you can write.  This should be the only interrupt which can
  *  occur during the measured time period.
- *  NOTE:  This file is USUALLY in assembly and is LEAN AND MEAN.
- *         Any code in this isr is pure overhead which can perturb
- *         the accuracy of the Timing Test Suite.
+ *  @note This file is USUALLY in assembly and is LEAN AND MEAN.
+ *        Any code in this isr is pure overhead which can perturb
+ *        the accuracy of the Timing Test Suite.
@@ -22,6 +25,7 @@
 extern uint32_t         _Timer_interrupts;
diff --git a/c/src/lib/libbsp/or1k/or1ksim/timer/timer.c b/c/src/lib/libbsp/or1k/or1ksim/timer/timer.c
index ec3c33e..e5f3fd6 100644
--- a/c/src/lib/libbsp/or1k/or1ksim/timer/timer.c
+++ b/c/src/lib/libbsp/or1k/or1ksim/timer/timer.c
@@ -32,7 +32,7 @@ void benchmark_timer_initialize(void)
 #define AVG_OVERHEAD  0
   uint64_t         clicks;
   uint64_t         total;
diff --git a/c/src/lib/libbsp/powerpc/score603e/timer/timer.c b/c/src/lib/libbsp/powerpc/score603e/timer/timer.c
index fbe2b00..f1f1312 100644
--- a/c/src/lib/libbsp/powerpc/score603e/timer/timer.c
+++ b/c/src/lib/libbsp/powerpc/score603e/timer/timer.c
@@ -42,7 +42,7 @@ void benchmark_timer_initialize()
-uint32_t benchmark_timer_read()
+benchmark_timer_t benchmark_timer_read()
   uint64_t          clicks;
   uint64_t          total64;
diff --git a/c/src/lib/libbsp/powerpc/tqm8xx/timer/timer.c b/c/src/lib/libbsp/powerpc/tqm8xx/timer/timer.c
index 10d8568..06c43c5 100644
--- a/c/src/lib/libbsp/powerpc/tqm8xx/timer/timer.c
+++ b/c/src/lib/libbsp/powerpc/tqm8xx/timer/timer.c
@@ -85,7 +85,7 @@ benchmark_timer_initialize (void)
   uint32_t retval;
   retval = *(uint32_t*)&m8xx.tcn1;
diff --git a/c/src/lib/libbsp/shared/timerstub.c b/c/src/lib/libbsp/shared/timerstub.c
index 50e3e44..d1e3313 100644
--- a/c/src/lib/libbsp/shared/timerstub.c
+++ b/c/src/lib/libbsp/shared/timerstub.c
@@ -15,7 +15,7 @@ void benchmark_timer_initialize(void)
   if (benchmark_timer_find_average_overhead)
     return 1;
diff --git a/c/src/lib/libbsp/sparc/erc32/timer/timer.c b/c/src/lib/libbsp/sparc/erc32/timer/timer.c
index c6772e5..4cf638e 100644
--- a/c/src/lib/libbsp/sparc/erc32/timer/timer.c
+++ b/c/src/lib/libbsp/sparc/erc32/timer/timer.c
@@ -62,7 +62,7 @@ void benchmark_timer_initialize(void)
 #define LEAST_VALID      13  /* Don't trust a value lower than this */
 #endif
   uint32_t          total;
diff --git a/c/src/lib/libbsp/sparc/leon2/timer/timer.c b/c/src/lib/libbsp/sparc/leon2/timer/timer.c
index 0cbe0bf..de115c9 100644
--- a/c/src/lib/libbsp/sparc/leon2/timer/timer.c
+++ b/c/src/lib/libbsp/sparc/leon2/timer/timer.c
@@ -58,7 +58,7 @@ void benchmark_timer_initialize(void)
                              /*     to start/stop the timer. */
 #define LEAST_VALID       2  /* Don't trust a value lower than this */
   uint32_t total;
diff --git a/c/src/lib/libbsp/sparc/leon3/timer/timer.c b/c/src/lib/libbsp/sparc/leon3/timer/timer.c
index e7aa7f3..40bdeb8 100644
--- a/c/src/lib/libbsp/sparc/leon3/timer/timer.c
+++ b/c/src/lib/libbsp/sparc/leon3/timer/timer.c
@@ -57,7 +57,7 @@ void benchmark_timer_initialize(void)
   uint32_t total;
diff --git a/c/src/lib/libcpu/arm/at91rm9200/timer/timer.c b/c/src/lib/libcpu/arm/at91rm9200/timer/timer.c
index 2ae7bb6..c65dd80 100644
--- a/c/src/lib/libcpu/arm/at91rm9200/timer/timer.c
+++ b/c/src/lib/libcpu/arm/at91rm9200/timer/timer.c
@@ -1,26 +1,21 @@
- * Cogent CSB337 Timer driver
+ * @file
+ * @brief Cogent CSB337 Timer driver
  * This uses timer 0 for timing measurments.
- * Copyright (c) 2004 by Jay Monkman <jtm at lopingdog.com>
+ *  Copyright (c) 2004 by Jay Monkman <jtm at lopingdog.com>
  *  found in the file LICENSE in this distribution or at
  *  http://www.rtems.org/license/LICENSE.
- * Notes:
- *  Suite.  Each measured time period is demarcated by calls to
- *  benchmark_timer_initialize() and benchmark_timer_read().  benchmark_timer_read() usually returns
- *  the number of microseconds since benchmark_timer_initialize() exitted.
- *  It is important that the timer start/stop overhead be determined
- *  when porting or modifying this code.
-#include <rtems.h>
 #include <bsp.h>
+#include <rtems.h>
 #include <at91rm9200.h>
 #include <at91rm9200_pmc.h>
@@ -63,7 +58,7 @@ void benchmark_timer_initialize( void )
-int benchmark_timer_read( void )
   uint16_t t;
   uint32_t total;
diff --git a/c/src/lib/libcpu/arm/lpc22xx/timer/timer.c b/c/src/lib/libcpu/arm/lpc22xx/timer/timer.c
index 10449ee..ad73aed 100644
--- a/c/src/lib/libcpu/arm/lpc22xx/timer/timer.c
+++ b/c/src/lib/libcpu/arm/lpc22xx/timer/timer.c
@@ -1,28 +1,24 @@
- * RTL22xx board Timer driver
+ * @file
+ * @brief RTL22xx board Timer driver
  * This uses Timer1 for timing measurments.
+ * By Ray Xu <rayx.cn at gmail.com>, modify form Mc9328mxl RTEMS DSP
- *  By Ray xu<rayx.cn at gmail.com>, modify form Mc9328mxl	RTEMS DSP
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
- * Notes:
-#include <rtems.h>
 #include <bsp.h>
+#include <rtems.h>
 #include <lpc22xx.h>
 #include "lpc_timer.h"
 uint32_t g_start;
 uint32_t g_freq;
@@ -52,7 +48,7 @@ void benchmark_timer_initialize( void )
   return (T0TC/(LPC22xx_Fpclk/1000000));
diff --git a/c/src/lib/libcpu/arm/mc9328mxl/timer/timer.c b/c/src/lib/libcpu/arm/mc9328mxl/timer/timer.c
index 4ddd289..66ff4a0 100644
--- a/c/src/lib/libcpu/arm/mc9328mxl/timer/timer.c
+++ b/c/src/lib/libcpu/arm/mc9328mxl/timer/timer.c
@@ -1,27 +1,22 @@
- * Cogent CSB336 Timer driver
+ *  @file
+ *  @brief Cogent CSB336 Timer driver
  * This uses timer 2 for timing measurments.
  * Copyright (c) 2004 Cogent Computer Systems
  *        Written by Jay Monkman <jtm at lopingdog.com>
- * Notes:
 #include <bsp.h>
 #include <mc9328mxl.h>
 uint32_t g_start;
@@ -62,7 +57,7 @@ void benchmark_timer_initialize( void )
   uint32_t t;
   unsigned long long total;
diff --git a/c/src/lib/libcpu/arm/pxa255/timer/timer.c b/c/src/lib/libcpu/arm/pxa255/timer/timer.c
index de555b4..7eb3d5b 100644
--- a/c/src/lib/libcpu/arm/pxa255/timer/timer.c
+++ b/c/src/lib/libcpu/arm/pxa255/timer/timer.c
@@ -1,23 +1,20 @@
+ * @file
+ * @brief PXA255 timer
  * PXA255 timer by Yang Xi <hiyangxi at gmail.com>
- * Notes:
- *  Timer_initialize() and Read_timer().  Read_timer() usually returns
- *  the number of microseconds since Timer_initialize() exitted.
-#include <rtems.h>
 #include <bsp.h>
+#include <rtems.h>
 #include <pxa255.h>
 uint32_t tstart;
@@ -51,7 +48,7 @@ void benchmark_timer_initialize(void)
-int benchmark_timer_read(void)
   uint32_t total;
diff --git a/c/src/lib/libcpu/arm/s3c24xx/timer/timer.c b/c/src/lib/libcpu/arm/s3c24xx/timer/timer.c
index 6166c74..2bc599d 100644
--- a/c/src/lib/libcpu/arm/s3c24xx/timer/timer.c
+++ b/c/src/lib/libcpu/arm/s3c24xx/timer/timer.c
@@ -1,24 +1,19 @@
- * S3C2400 Timer driver
+ * @file
+ * @brief S3C2400 Timer driver
  * This uses timer 1 for timing measurments.
- * Notes:
-#include <rtems.h>
 #include <bsp.h>
+#include <rtems.h>
 #include <s3c24xx.h>
 uint32_t g_start;
@@ -69,7 +64,7 @@ void benchmark_timer_initialize( void )
     uint32_t t;
diff --git a/c/src/lib/libcpu/bfin/timer/timer.c b/c/src/lib/libcpu/bfin/timer/timer.c
index a5155f5..02540fe 100644
--- a/c/src/lib/libcpu/bfin/timer/timer.c
+++ b/c/src/lib/libcpu/bfin/timer/timer.c
@@ -1,10 +1,15 @@
-/*  Timer for Blackfin
+ *  @file
+ *  @brief Timer for Blackfin
  *  Copyright (c) 2006 by Atos Automacao Industrial Ltda.
  *             written by Alain Schaefer <alain.schaefer at easc.ch>
  *                    and Antonio Giovanini <antonio at atos.com.br>
@@ -14,13 +19,12 @@
 #include <bsp.h>
-uint32_t         Timer_interrupts;
-bool benchmark_timer_find_average_overhead;
+uint32_t  Timer_interrupts;
+bool      benchmark_timer_find_average_overhead;
@@ -56,7 +60,7 @@ void benchmark_timer_initialize( void )
   uint32_t          clicks;
   uint32_t          total;
diff --git a/c/src/lib/libcpu/m68k/mcf5206/timer/timer.c b/c/src/lib/libcpu/m68k/mcf5206/timer/timer.c
index a95521b..dbeebc8 100644
--- a/c/src/lib/libcpu/m68k/mcf5206/timer/timer.c
+++ b/c/src/lib/libcpu/m68k/mcf5206/timer/timer.c
@@ -1,8 +1,11 @@
- *  Timer Init
+ *  @file
+ *  @brief Timer Init
  *  This module initializes TIMER 2 for on the MCF5206E for benchmarks.
  *  Copyright (C) 2000 OKTET Ltd., St.-Petersburg, Russia
  *  Author: Victor V. Vengerov <vvv at oktet.ru>
@@ -21,6 +24,7 @@
 #include <bsp.h>
 #include "mcf5206/mcf5206e.h"
 #define TRR2_VAL 65530
@@ -99,7 +103,7 @@ benchmark_timer_initialize(void)
  * RETURNS:
  *     number of microseconds since timer has been started
-int
+benchmark_timer_t
     uint16_t   clicks;
diff --git a/c/src/lib/libcpu/m68k/mcf5206/timer/timerisr.S b/c/src/lib/libcpu/m68k/mcf5206/timer/timerisr.S
index 2d4c5bc..bbcf6e2 100644
--- a/c/src/lib/libcpu/m68k/mcf5206/timer/timerisr.S
+++ b/c/src/lib/libcpu/m68k/mcf5206/timer/timerisr.S
@@ -1,5 +1,6 @@
- *  Handle MCF5206 TIMER2 interrupts.
+ *  @file
+ *  @brief Handle MCF5206 TIMER2 interrupts
  * All code in this routine is pure overhead which can perturb the
  * accuracy of RTEMS' timing test suite.
@@ -11,7 +12,9 @@
  * An external counter, Timer_interrupts, is incremented.
@@ -29,7 +32,7 @@
 #include <rtems/asm.h>
-#include "bsp.h"
+#include <bsp.h>
 BEGIN_CODE
diff --git a/c/src/lib/libcpu/m68k/mcf5272/timer/timer.c b/c/src/lib/libcpu/m68k/mcf5272/timer/timer.c
index 0788456..812310f 100644
--- a/c/src/lib/libcpu/m68k/mcf5272/timer/timer.c
+++ b/c/src/lib/libcpu/m68k/mcf5272/timer/timer.c
@@ -1,8 +1,10 @@
- *  Timer Init
+ *  @file
  *  This module initializes TIMER 2 for on the MCF5272 for benchmarks.
@@ -22,6 +24,7 @@
 #include <bsp.h>
 #include <mcf5272/mcf5272.h>
@@ -102,7 +105,7 @@ benchmark_timer_initialize(void)
  * RETURNS:
-int
+benchmark_timer_t
     uint16_t clicks;
diff --git a/c/src/lib/libcpu/m68k/mcf5272/timer/timerisr.S b/c/src/lib/libcpu/m68k/mcf5272/timer/timerisr.S
index 2e36c34..b9c2892 100644
--- a/c/src/lib/libcpu/m68k/mcf5272/timer/timerisr.S
+++ b/c/src/lib/libcpu/m68k/mcf5272/timer/timerisr.S
@@ -1,5 +1,6 @@
- *  Handle MCF5272 TIMER2 interrupts.
+ * @file
+ * @brief Handle MCF5272 TIMER2 interrupts.
@@ -11,7 +12,9 @@
@@ -30,9 +33,6 @@
 #include <bsp.h>
-#include "mcf5272/mcf5272.h"
 BEGIN_CODE
 	PUBLIC(timerisr)
diff --git a/c/src/lib/libcpu/mips/timer/timer.c b/c/src/lib/libcpu/mips/timer/timer.c
index 4cb66e3..da5291a 100644
--- a/c/src/lib/libcpu/mips/timer/timer.c
+++ b/c/src/lib/libcpu/mips/timer/timer.c
@@ -1,7 +1,12 @@
-/*  timer.c
- *  This file contains the initialization code for the IDT 4650 timer driver.
+ *  @file
+ *  @brief IDT 4650 Timer Driver.
+ *  Suite.
  *  Author:     Craig Lebakken <craigl at transition.com>
  *  COPYRIGHT (c) 1996 by Transition Networks Inc.
@@ -19,14 +24,6 @@
  *  derived from src/lib/libbsp/no_cpu/no_bsp/timer/timer.c
- *  NOTE: It is important that the timer start/stop overhead be
- *        determined when porting or modifying this code.
@@ -35,15 +32,8 @@
- *  Rather than deleting this, it is commented out to (hopefully) help
- *  the submitter send updates.
- *  static char _sccsid[] = "@(#)timer.c 08/20/96     1.5\n";
 #define CLOCKS_PER_MICROSECOND ( CPU_CLOCK_RATE_MHZ )
 #define TIMER_MAX_VALUE 0xffffffff
@@ -78,7 +68,7 @@ void benchmark_timer_initialize( void )
                              /* This value is in cycles. */
   uint64_t   clicks;
   uint32_t   total;
diff --git a/c/src/lib/libcpu/powerpc/mpc505/timer/timer.c b/c/src/lib/libcpu/powerpc/mpc505/timer/timer.c
index b353be4..17bc2af 100644
--- a/c/src/lib/libcpu/powerpc/mpc505/timer/timer.c
+++ b/c/src/lib/libcpu/powerpc/mpc505/timer/timer.c
@@ -1,18 +1,23 @@
-/*  timer.c
+ *  @file
  *  COPYRIGHT (c) 1989, 1990, 1991, 1992, 1993, 1994.
@@ -38,7 +43,7 @@ void benchmark_timer_initialize( void )
   uint32_t   value;
   __asm__ volatile ( " mftb %0": "=r" (value) );
diff --git a/c/src/lib/libcpu/powerpc/mpc5xx/timer/timer.c b/c/src/lib/libcpu/powerpc/mpc5xx/timer/timer.c
index 699c849..65deae9 100644
--- a/c/src/lib/libcpu/powerpc/mpc5xx/timer/timer.c
+++ b/c/src/lib/libcpu/powerpc/mpc5xx/timer/timer.c
@@ -1,16 +1,13 @@
-/*  timer.c
+ *  @file
+ *  @brief Timer Driver for the PowerPC MPC5xx.
  *  This file manages the interval timer on the PowerPC MPC5xx.
- *  NOTE: This is not the PIT, but rather the RTEMS interval
- *        timer
+ *  @noe This is not the PIT, but rather the RTEMS interval timer.
  *  We shall use the bottom 32 bits of the timebase register,
- *  The following was in the 403 version of this file. I don't
- *  know what it means. JTM 5/19/98
  *  MPC5xx port sponsored by Defence Research and Development Canada - Suffield
  *  Copyright (C) 2004, Real-Time Systems Inc. (querbach at realtime.bc.ca)
@@ -47,6 +44,7 @@
 #include <mpc5xx.h>
 static volatile uint32_t Timer_starting;
@@ -80,7 +78,7 @@ void benchmark_timer_initialize(void)
   Timer_starting = get_itimer();
   uint32_t clicks;
   uint32_t total;
diff --git a/c/src/lib/libcpu/powerpc/mpc6xx/timer/timer.c b/c/src/lib/libcpu/powerpc/mpc6xx/timer/timer.c
index fcd179a..ee6e9a9 100644
--- a/c/src/lib/libcpu/powerpc/mpc6xx/timer/timer.c
+++ b/c/src/lib/libcpu/powerpc/mpc6xx/timer/timer.c
@@ -1,9 +1,11 @@
-/*  timer.c
+ *  @file
+ *  @brief
  *  This file implements a benchmark timer using the PPC Timebase
- *  Notes: NONE
  *  COPYRIGHT (c) 1989-2000.
@@ -12,10 +14,11 @@
+#include <bsp.h>
+#include <rtems.h>
 #include <assert.h>
-#include <rtems.h>
-#include <bsp.h>
 #include <libcpu/powerpc-utility.h>
@@ -58,7 +61,7 @@ void benchmark_timer_initialize(void)
   uint64_t    total64;
   uint32_t    total;
diff --git a/c/src/lib/libcpu/powerpc/mpc8260/timer/timer.c b/c/src/lib/libcpu/powerpc/mpc8260/timer/timer.c
index 85b3630..c20fdc5 100644
--- a/c/src/lib/libcpu/powerpc/mpc8260/timer/timer.c
+++ b/c/src/lib/libcpu/powerpc/mpc8260/timer/timer.c
@@ -1,15 +1,13 @@
-/*  timer.c
+ *  @file
+ *  @brief Timer for the PowerPC MPC860
- *  This file manages the interval timer on the PowerPC MPC860.
- *        timer
+ *  @note This is not the PIT, but rather the RTEMS interval timer.
  *  Author: Andy Dachs <a.dachs at sstl.co.uk>
  *  Surrey Satellite Technlogy Limited
  *   Modified for MPC8260
@@ -46,6 +44,7 @@
 #include <mpc8260.h>
@@ -78,7 +77,7 @@ void benchmark_timer_initialize(void)
 extern uint32_t bsp_timer_least_valid;
 extern uint32_t bsp_timer_average_overhead;
   uint32_t   clicks;
   uint32_t   total;
diff --git a/c/src/lib/libcpu/powerpc/mpc8xx/timer/timer.c b/c/src/lib/libcpu/powerpc/mpc8xx/timer/timer.c
index 7d4ed1d..b82d764 100644
--- a/c/src/lib/libcpu/powerpc/mpc8xx/timer/timer.c
+++ b/c/src/lib/libcpu/powerpc/mpc8xx/timer/timer.c
@@ -1,15 +1,14 @@
-/*  timer.c
+ *  @file
+ *  @brief Timer Driver for the PowerPC MPC8xx.
  *  This file manages the interval timer on the PowerPC MPC8xx.
- *        timer
  *  Author: Jay Monkman (jmonkman at frasca.com)
  *  Copywright (C) 1998 by Frasca International, Inc.
@@ -41,6 +40,7 @@
 #include <mpc8xx.h>
@@ -69,7 +69,7 @@ void benchmark_timer_initialize(void)
   uint32_t   clicks;
   uint32_t   total;
diff --git a/c/src/lib/libcpu/powerpc/ppc403/timer/timer.c b/c/src/lib/libcpu/powerpc/ppc403/timer/timer.c
index 5ee5ff4..f883fac 100644
--- a/c/src/lib/libcpu/powerpc/ppc403/timer/timer.c
+++ b/c/src/lib/libcpu/powerpc/ppc403/timer/timer.c
@@ -1,12 +1,13 @@
-/*  timer.c
+ *  @file
+ *  @brief Timer Driver for the PowerPC 405.
  *  This file manages the interval timer on the PowerPC 405.
- *  Author:	Andrew Bray <andy at i-cubed.co.uk>
+ *  Author: Andrew Bray <andy at i-cubed.co.uk>
  *  COPYRIGHT (c) 1995 by i-cubed ltd.
@@ -37,6 +38,7 @@
@@ -51,7 +53,7 @@ void benchmark_timer_initialize(void)
   startedAt = ppc_time_base();
 	uint32_t   clicks, total;
diff --git a/c/src/lib/libcpu/sh/sh7032/timer/timer.c b/c/src/lib/libcpu/sh/sh7032/timer/timer.c
index f9750ad..94a834c 100644
--- a/c/src/lib/libcpu/sh/sh7032/timer/timer.c
+++ b/c/src/lib/libcpu/sh/sh7032/timer/timer.c
@@ -1,14 +1,9 @@
+ * @file
+ * @brief Timer for the Hitachi SH 703X
- *  timer for the Hitachi SH 703X
  *  Authors: Ralf Corsepius (corsepiu at faw.uni-ulm.de) and
  *           Bernd Becker (becker at faw.uni-ulm.de)
@@ -27,6 +22,7 @@
 #include <rtems/score/sh_io.h>
 #include <rtems/score/ispsh7032.h>
@@ -147,7 +143,7 @@ void benchmark_timer_initialize( void )
 #define LEAST_VALID       0 /* 20 */ /* Don't trust a clicks value lower than this */
   uint32_t   cclicks;
   uint32_t   total ;
diff --git a/c/src/lib/libcpu/sh/sh7045/timer/timer.c b/c/src/lib/libcpu/sh/sh7045/timer/timer.c
index 86031cd..152c99b 100644
--- a/c/src/lib/libcpu/sh/sh7045/timer/timer.c
+++ b/c/src/lib/libcpu/sh/sh7045/timer/timer.c
@@ -1,14 +1,9 @@
+ *  @file
+ *  @brief Timer for the Hitachi SH 704X
- *  timer for the Hitachi SH 704X
@@ -27,6 +22,7 @@
 #include <rtems/score/iosh7045.h>
@@ -143,7 +139,7 @@ void benchmark_timer_initialize( void )
   uint32_t   clicks;
   uint32_t   total ;
diff --git a/c/src/lib/libcpu/sh/sh7750/timer/timer.c b/c/src/lib/libcpu/sh/sh7750/timer/timer.c
index fcdf8f5..ef462c7 100644
--- a/c/src/lib/libcpu/sh/sh7750/timer/timer.c
+++ b/c/src/lib/libcpu/sh/sh7750/timer/timer.c
@@ -1,14 +1,9 @@
+ *  @file
+ *  @brief Timer driver for the Hitachi SH 7750
- *  timer driver for the Hitachi SH 7750
  *  Copyright (C) 2001 OKTET Ltd., St.-Petersburg, Russia
@@ -21,6 +16,7 @@
 #include <rtems/score/iosh7750.h>
@@ -198,7 +194,7 @@ benchmark_timer_initialize(void)
  * RETURNS:
-int
+benchmark_timer_t
     uint32_t              clicks;
diff --git a/cpukit/libcsupport/Makefile.am b/cpukit/libcsupport/Makefile.am
index 41de471..835f96e 100644
--- a/cpukit/libcsupport/Makefile.am
+++ b/cpukit/libcsupport/Makefile.am
@@ -12,7 +12,6 @@ include_rtems_HEADERS += include/iosupp.h
 include_rtems_HEADERS += include/ringbuf.h
 include_rtems_HEADERS += include/rtc.h
 include_rtems_HEADERS += include/spurious.h
-include_rtems_HEADERS += include/timerdrv.h
 include_rtems_HEADERS += include/vmeintr.h
 ## motorola
diff --git a/cpukit/libcsupport/include/timerdrv.h b/cpukit/libcsupport/include/timerdrv.h
deleted file mode 100644
index ec6028a..0000000
--- a/cpukit/libcsupport/include/timerdrv.h
+++ /dev/null
@@ -1,34 +0,0 @@
- * @file
- * @brief Timer Driver for all Boards
- * This file describes the Timer Driver for all boards.
- *  On-Line Applications Research Corporation (OAR).
-#ifndef _RTEMS_TIMERDRV_H
-#define _RTEMS_TIMERDRV_H
-#include <rtems/btimer.h>
-#ifdef __cplusplus
-extern "C" {
-#endif
-/* Intentionally empty */
-#ifdef __cplusplus
-#endif
-#endif
diff --git a/cpukit/libcsupport/preinstall.am b/cpukit/libcsupport/preinstall.am
index eb68f50..c4286ba 100644
--- a/cpukit/libcsupport/preinstall.am
+++ b/cpukit/libcsupport/preinstall.am
@@ -46,10 +46,6 @@ $(PROJECT_INCLUDE)/rtems/spurious.h: include/spurious.h $(PROJECT_INCLUDE)/rtems
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/spurious.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/spurious.h
-$(PROJECT_INCLUDE)/rtems/timerdrv.h: include/timerdrv.h $(PROJECT_INCLUDE)/rtems/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/timerdrv.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/timerdrv.h
 $(PROJECT_INCLUDE)/rtems/vmeintr.h: include/vmeintr.h $(PROJECT_INCLUDE)/rtems/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/vmeintr.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/vmeintr.h
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index f821e04..7e7c310 100644
--- a/cpukit/sapi/include/confdefs.h
+++ b/cpukit/sapi/include/confdefs.h
@@ -1319,7 +1319,7 @@ const rtems_libio_helper rtems_fs_init_helper =
 #endif
 #ifdef CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
-  #include <rtems/timerdrv.h>
+  #include <rtems/btimer.h>
 #endif
 #ifdef CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER
diff --git a/doc/bsp_howto/timer.t b/doc/bsp_howto/timer.t
index d7cebc3..fdefd72 100644
--- a/doc/bsp_howto/timer.t
+++ b/doc/bsp_howto/timer.t
@@ -44,7 +44,7 @@ time units (typically microseconds) that have elapsed since the last
 call to @code{benchmark_timer_initialize}.
 @example
   stop time = read the hardware timer
   if the subtract overhead feature is enabled
diff --git a/testsuites/psxtmtests/psxtmbarrier01/init.c b/testsuites/psxtmtests/psxtmbarrier01/init.c
index 059cd0c..690653f 100644
--- a/testsuites/psxtmtests/psxtmbarrier01/init.c
+++ b/testsuites/psxtmtests/psxtmbarrier01/init.c
@@ -12,7 +12,7 @@
 #endif
 #include <timesys.h>
 #include "test_support.h"
 #include <pthread.h>
diff --git a/testsuites/psxtmtests/psxtmbarrier02/init.c b/testsuites/psxtmtests/psxtmbarrier02/init.c
index 9952f63..0506db9 100644
--- a/testsuites/psxtmtests/psxtmbarrier02/init.c
+++ b/testsuites/psxtmtests/psxtmbarrier02/init.c
@@ -13,7 +13,7 @@
 #include <tmacros.h>
diff --git a/testsuites/psxtmtests/psxtmbarrier03/init.c b/testsuites/psxtmtests/psxtmbarrier03/init.c
index c8b4c1b..d81be08 100644
--- a/testsuites/psxtmtests/psxtmbarrier03/init.c
+++ b/testsuites/psxtmtests/psxtmbarrier03/init.c
@@ -17,7 +17,7 @@
 #include <sched.h>
 const char rtems_test_name[] = "PSXTMBARRIER 03";
diff --git a/testsuites/psxtmtests/psxtmbarrier04/init.c b/testsuites/psxtmtests/psxtmbarrier04/init.c
index 65fe557..2fc3b76 100644
--- a/testsuites/psxtmtests/psxtmbarrier04/init.c
+++ b/testsuites/psxtmtests/psxtmbarrier04/init.c
@@ -15,7 +15,7 @@
 #include <sched.h>
 const char rtems_test_name[] = "PSXTMBARRIER 04";
diff --git a/testsuites/psxtmtests/psxtmcond01/init.c b/testsuites/psxtmtests/psxtmcond01/init.c
index c4dd630..6dd7ab1 100644
--- a/testsuites/psxtmtests/psxtmcond01/init.c
+++ b/testsuites/psxtmtests/psxtmcond01/init.c
@@ -17,7 +17,7 @@
 #include <sched.h>
 const char rtems_test_name[] = "PSXTMCOND 01";
diff --git a/testsuites/psxtmtests/psxtmcond02/init.c b/testsuites/psxtmtests/psxtmcond02/init.c
index 668bb43..cbbb799 100644
--- a/testsuites/psxtmtests/psxtmcond02/init.c
+++ b/testsuites/psxtmtests/psxtmcond02/init.c
@@ -13,7 +13,7 @@
 const char rtems_test_name[] = "PSXTMCOND 02";
diff --git a/testsuites/psxtmtests/psxtmcond03/init.c b/testsuites/psxtmtests/psxtmcond03/init.c
index 795c8d4..fdf2dfe 100644
--- a/testsuites/psxtmtests/psxtmcond03/init.c
+++ b/testsuites/psxtmtests/psxtmcond03/init.c
@@ -17,7 +17,7 @@
 #include <sched.h>
 const char rtems_test_name[] = "PSXTMCOND 03";
diff --git a/testsuites/psxtmtests/psxtmcond04/init.c b/testsuites/psxtmtests/psxtmcond04/init.c
index 2c16dfa..889cc99 100644
--- a/testsuites/psxtmtests/psxtmcond04/init.c
+++ b/testsuites/psxtmtests/psxtmcond04/init.c
@@ -17,7 +17,7 @@
 #include <sched.h>
 const char rtems_test_name[] = "PSXTMCOND 04";
diff --git a/testsuites/psxtmtests/psxtmcond05/init.c b/testsuites/psxtmtests/psxtmcond05/init.c
index ab15fc3..81b32d8 100644
--- a/testsuites/psxtmtests/psxtmcond05/init.c
+++ b/testsuites/psxtmtests/psxtmcond05/init.c
@@ -13,7 +13,7 @@
 const char rtems_test_name[] = "PSXTMCOND 05";
diff --git a/testsuites/psxtmtests/psxtmcond06/init.c b/testsuites/psxtmtests/psxtmcond06/init.c
index 91bef6c..4f86108 100644
--- a/testsuites/psxtmtests/psxtmcond06/init.c
+++ b/testsuites/psxtmtests/psxtmcond06/init.c
@@ -17,7 +17,7 @@
 #include <sched.h>
 #define N 5
diff --git a/testsuites/psxtmtests/psxtmcond07/init.c b/testsuites/psxtmtests/psxtmcond07/init.c
index 11d2912..275eab3 100644
--- a/testsuites/psxtmtests/psxtmcond07/init.c
+++ b/testsuites/psxtmtests/psxtmcond07/init.c
@@ -17,7 +17,7 @@
 #include <sched.h>
 #define N 1
diff --git a/testsuites/psxtmtests/psxtmcond08/init.c b/testsuites/psxtmtests/psxtmcond08/init.c
index 49ad0d7..8af9f9d 100644
--- a/testsuites/psxtmtests/psxtmcond08/init.c
+++ b/testsuites/psxtmtests/psxtmcond08/init.c
@@ -30,7 +30,7 @@
 #include <sched.h>
diff --git a/testsuites/psxtmtests/psxtmkey01/init.c b/testsuites/psxtmtests/psxtmkey01/init.c
index 4b3681e..7430b15 100644
--- a/testsuites/psxtmtests/psxtmkey01/init.c
+++ b/testsuites/psxtmtests/psxtmkey01/init.c
@@ -12,7 +12,7 @@
 #endif
diff --git a/testsuites/psxtmtests/psxtmkey02/init.c b/testsuites/psxtmtests/psxtmkey02/init.c
index 4814ef0..fafb8f6 100644
--- a/testsuites/psxtmtests/psxtmkey02/init.c
+++ b/testsuites/psxtmtests/psxtmkey02/init.c
@@ -12,7 +12,7 @@
 #endif
diff --git a/testsuites/psxtmtests/psxtmmq01/init.c b/testsuites/psxtmtests/psxtmmq01/init.c
index ca80374..aacd968 100644
--- a/testsuites/psxtmtests/psxtmmq01/init.c
+++ b/testsuites/psxtmtests/psxtmmq01/init.c
@@ -13,7 +13,7 @@
 #include <fcntl.h>
 #include <mqueue.h>
diff --git a/testsuites/psxtmtests/psxtmmutex01/init.c b/testsuites/psxtmtests/psxtmmutex01/init.c
index 8a72bf9..c8f6054 100644
--- a/testsuites/psxtmtests/psxtmmutex01/init.c
+++ b/testsuites/psxtmtests/psxtmmutex01/init.c
@@ -12,7 +12,7 @@
 #endif
diff --git a/testsuites/psxtmtests/psxtmmutex02/init.c b/testsuites/psxtmtests/psxtmmutex02/init.c
index b82d23d..3ae6276 100644
--- a/testsuites/psxtmtests/psxtmmutex02/init.c
+++ b/testsuites/psxtmtests/psxtmmutex02/init.c
@@ -17,7 +17,7 @@
 #include <sched.h>
 const char rtems_test_name[] = "PSXTMMUTEX 02";
diff --git a/testsuites/psxtmtests/psxtmmutex03/init.c b/testsuites/psxtmtests/psxtmmutex03/init.c
index 07f49a5..bad1f27 100644
--- a/testsuites/psxtmtests/psxtmmutex03/init.c
+++ b/testsuites/psxtmtests/psxtmmutex03/init.c
@@ -12,7 +12,7 @@
 #endif
diff --git a/testsuites/psxtmtests/psxtmmutex04/init.c b/testsuites/psxtmtests/psxtmmutex04/init.c
index a1a8aa2..e422763 100644
--- a/testsuites/psxtmtests/psxtmmutex04/init.c
+++ b/testsuites/psxtmtests/psxtmmutex04/init.c
@@ -13,7 +13,7 @@
diff --git a/testsuites/psxtmtests/psxtmmutex05/init.c b/testsuites/psxtmtests/psxtmmutex05/init.c
index d36e534..712b5cc 100644
--- a/testsuites/psxtmtests/psxtmmutex05/init.c
+++ b/testsuites/psxtmtests/psxtmmutex05/init.c
@@ -17,7 +17,7 @@
 #include <sched.h>
 const char rtems_test_name[] = "PSXTMMUTEX 05";
diff --git a/testsuites/psxtmtests/psxtmmutex06/init.c b/testsuites/psxtmtests/psxtmmutex06/init.c
index 047f063..2e8b82d 100644
--- a/testsuites/psxtmtests/psxtmmutex06/init.c
+++ b/testsuites/psxtmtests/psxtmmutex06/init.c
@@ -17,7 +17,7 @@
 #include <sched.h>
 const char rtems_test_name[] = "PSXTMMUTEX 06";
diff --git a/testsuites/psxtmtests/psxtmmutex07/init.c b/testsuites/psxtmtests/psxtmmutex07/init.c
index adee994..299f87d 100644
--- a/testsuites/psxtmtests/psxtmmutex07/init.c
+++ b/testsuites/psxtmtests/psxtmmutex07/init.c
@@ -12,7 +12,7 @@
 #endif
diff --git a/testsuites/psxtmtests/psxtmnanosleep01/init.c b/testsuites/psxtmtests/psxtmnanosleep01/init.c
index e86a5d1..eeb67c1 100644
--- a/testsuites/psxtmtests/psxtmnanosleep01/init.c
+++ b/testsuites/psxtmtests/psxtmnanosleep01/init.c
@@ -12,7 +12,7 @@
 #endif
 const char rtems_test_name[] = "PSXTMNANOSLEEP 01";
diff --git a/testsuites/psxtmtests/psxtmnanosleep02/init.c b/testsuites/psxtmtests/psxtmnanosleep02/init.c
index f932811..12f6b75 100644
--- a/testsuites/psxtmtests/psxtmnanosleep02/init.c
+++ b/testsuites/psxtmtests/psxtmnanosleep02/init.c
@@ -12,7 +12,7 @@
 #endif
diff --git a/testsuites/psxtmtests/psxtmrwlock01/init.c b/testsuites/psxtmtests/psxtmrwlock01/init.c
index 2f99a19..0073e70 100644
--- a/testsuites/psxtmtests/psxtmrwlock01/init.c
+++ b/testsuites/psxtmtests/psxtmrwlock01/init.c
@@ -12,7 +12,7 @@
 #endif
diff --git a/testsuites/psxtmtests/psxtmrwlock02/init.c b/testsuites/psxtmtests/psxtmrwlock02/init.c
index 1017c7c..4ce7fa5 100644
--- a/testsuites/psxtmtests/psxtmrwlock02/init.c
+++ b/testsuites/psxtmtests/psxtmrwlock02/init.c
@@ -16,7 +16,7 @@
 #include <sched.h>
 const char rtems_test_name[] = "PSXTMRWLOCK 02";
diff --git a/testsuites/psxtmtests/psxtmrwlock03/init.c b/testsuites/psxtmtests/psxtmrwlock03/init.c
index 76b5db2..5fdf522 100644
--- a/testsuites/psxtmtests/psxtmrwlock03/init.c
+++ b/testsuites/psxtmtests/psxtmrwlock03/init.c
@@ -16,7 +16,7 @@
 #include <sched.h>
 const char rtems_test_name[] = "PSXTMRWLOCK 03";
diff --git a/testsuites/psxtmtests/psxtmrwlock04/init.c b/testsuites/psxtmtests/psxtmrwlock04/init.c
index 1eb2236..8b1b45d 100644
--- a/testsuites/psxtmtests/psxtmrwlock04/init.c
+++ b/testsuites/psxtmtests/psxtmrwlock04/init.c
@@ -16,7 +16,7 @@
 #include <sched.h>
 const char rtems_test_name[] = "PSXTMRWLOCK 04";
diff --git a/testsuites/psxtmtests/psxtmrwlock05/init.c b/testsuites/psxtmtests/psxtmrwlock05/init.c
index 95d0fd9..1ec86c0 100644
--- a/testsuites/psxtmtests/psxtmrwlock05/init.c
+++ b/testsuites/psxtmtests/psxtmrwlock05/init.c
@@ -16,7 +16,7 @@
 #include <sched.h>
 const char rtems_test_name[] = "PSXTMRWLOCK 05";
diff --git a/testsuites/psxtmtests/psxtmrwlock06/init.c b/testsuites/psxtmtests/psxtmrwlock06/init.c
index b83bfdd..b74ac25 100644
--- a/testsuites/psxtmtests/psxtmrwlock06/init.c
+++ b/testsuites/psxtmtests/psxtmrwlock06/init.c
@@ -17,7 +17,7 @@
 const char rtems_test_name[] = "PSXTMRWLOCK 06";
diff --git a/testsuites/psxtmtests/psxtmrwlock07/init.c b/testsuites/psxtmtests/psxtmrwlock07/init.c
index 2506755..9a77902 100644
--- a/testsuites/psxtmtests/psxtmrwlock07/init.c
+++ b/testsuites/psxtmtests/psxtmrwlock07/init.c
@@ -17,7 +17,7 @@
 #include <sched.h>
 const char rtems_test_name[] = "PSXTMRWLOCK 07";
diff --git a/testsuites/psxtmtests/psxtmsem01/init.c b/testsuites/psxtmtests/psxtmsem01/init.c
index 10a7730..4223a02 100644
--- a/testsuites/psxtmtests/psxtmsem01/init.c
+++ b/testsuites/psxtmtests/psxtmsem01/init.c
@@ -16,7 +16,7 @@
 #include <semaphore.h>
 const char rtems_test_name[] = "PSXTMSEM 01";
diff --git a/testsuites/psxtmtests/psxtmsem02/init.c b/testsuites/psxtmtests/psxtmsem02/init.c
index 70871ec..4629ac5 100644
--- a/testsuites/psxtmtests/psxtmsem02/init.c
+++ b/testsuites/psxtmtests/psxtmsem02/init.c
@@ -16,7 +16,7 @@
 const char rtems_test_name[] = "PSXTMSEM 02";
diff --git a/testsuites/psxtmtests/psxtmsem03/init.c b/testsuites/psxtmtests/psxtmsem03/init.c
index 828a053..585b88d 100644
--- a/testsuites/psxtmtests/psxtmsem03/init.c
+++ b/testsuites/psxtmtests/psxtmsem03/init.c
@@ -16,7 +16,7 @@
 #include <sched.h>
diff --git a/testsuites/psxtmtests/psxtmsem04/init.c b/testsuites/psxtmtests/psxtmsem04/init.c
index 64cbc33..5cebc9d 100644
--- a/testsuites/psxtmtests/psxtmsem04/init.c
+++ b/testsuites/psxtmtests/psxtmsem04/init.c
@@ -20,7 +20,7 @@
 #include <sched.h>
 const char rtems_test_name[] = "PSXTMSEM 04";
diff --git a/testsuites/psxtmtests/psxtmsem05/init.c b/testsuites/psxtmtests/psxtmsem05/init.c
index fd1585d..12594c4 100644
--- a/testsuites/psxtmtests/psxtmsem05/init.c
+++ b/testsuites/psxtmtests/psxtmsem05/init.c
@@ -20,7 +20,7 @@
 #include <sched.h>
 const char rtems_test_name[] = "PSXTMSEM 05";
diff --git a/testsuites/psxtmtests/psxtmsleep01/init.c b/testsuites/psxtmtests/psxtmsleep01/init.c
index 68a2e23..f2ee0af 100644
--- a/testsuites/psxtmtests/psxtmsleep01/init.c
+++ b/testsuites/psxtmtests/psxtmsleep01/init.c
@@ -12,7 +12,7 @@
 #endif
 #include <unistd.h>
diff --git a/testsuites/psxtmtests/psxtmsleep02/init.c b/testsuites/psxtmtests/psxtmsleep02/init.c
index 9889175..95fc9d9 100644
--- a/testsuites/psxtmtests/psxtmsleep02/init.c
+++ b/testsuites/psxtmtests/psxtmsleep02/init.c
@@ -12,7 +12,7 @@
 #endif
diff --git a/testsuites/psxtmtests/psxtmthread02/init.c b/testsuites/psxtmtests/psxtmthread02/init.c
index bafa2ac..c468f03 100644
--- a/testsuites/psxtmtests/psxtmthread02/init.c
+++ b/testsuites/psxtmtests/psxtmthread02/init.c
@@ -14,7 +14,7 @@
 #include <sched.h>
 const char rtems_test_name[] = "PSXTMTHREAD 02";
diff --git a/testsuites/psxtmtests/psxtmthread03/init.c b/testsuites/psxtmtests/psxtmthread03/init.c
index 23acdd0..938a8c6 100644
--- a/testsuites/psxtmtests/psxtmthread03/init.c
+++ b/testsuites/psxtmtests/psxtmthread03/init.c
@@ -17,7 +17,7 @@
 #include <sched.h>
 const char rtems_test_name[] = "PSXTMTHREAD 03";
diff --git a/testsuites/psxtmtests/psxtmthread04/init.c b/testsuites/psxtmtests/psxtmthread04/init.c
index dc1290c..5b260dd 100644
--- a/testsuites/psxtmtests/psxtmthread04/init.c
+++ b/testsuites/psxtmtests/psxtmthread04/init.c
@@ -14,7 +14,7 @@
 #include <sched.h>
 const char rtems_test_name[] = "PSXTMTHREAD 04";
diff --git a/testsuites/psxtmtests/psxtmthread05/init.c b/testsuites/psxtmtests/psxtmthread05/init.c
index f127663..53a8b11 100644
--- a/testsuites/psxtmtests/psxtmthread05/init.c
+++ b/testsuites/psxtmtests/psxtmthread05/init.c
@@ -15,7 +15,7 @@
 #include <sched.h>
 const char rtems_test_name[] = "PSXTMTHREAD 05";
diff --git a/testsuites/psxtmtests/psxtmthread06/init.c b/testsuites/psxtmtests/psxtmthread06/init.c
index 3466a8d..6031909 100644
--- a/testsuites/psxtmtests/psxtmthread06/init.c
+++ b/testsuites/psxtmtests/psxtmthread06/init.c
@@ -16,7 +16,7 @@
 #include <sched.h>
 const char rtems_test_name[] = "PSXTMTHREAD 06";
diff --git a/testsuites/rhealstone/rhdeadlockbrk/deadlockbrk.c b/testsuites/rhealstone/rhdeadlockbrk/deadlockbrk.c
index 9ab620f..a897727 100644
--- a/testsuites/rhealstone/rhdeadlockbrk/deadlockbrk.c
+++ b/testsuites/rhealstone/rhdeadlockbrk/deadlockbrk.c
@@ -4,8 +4,8 @@
  * This file's license is 2-clause BSD as in this distribution's LICENSE file.
 const char rtems_test_name[] = "RHDEADLOCKBRK";
diff --git a/testsuites/rhealstone/rhilatency/ilatency.c b/testsuites/rhealstone/rhilatency/ilatency.c
index a102b6a..0a7741b 100644
--- a/testsuites/rhealstone/rhilatency/ilatency.c
+++ b/testsuites/rhealstone/rhilatency/ilatency.c
@@ -15,8 +15,8 @@
 #define CONFIGURE_INIT
 #include <rtems/score/schedulerpriorityimpl.h>
 #include <coverhd.h>
 /* configuration information */
diff --git a/testsuites/rhealstone/rhmlatency/mlatency.c b/testsuites/rhealstone/rhmlatency/mlatency.c
index 6495da5..11a29c0 100644
--- a/testsuites/rhealstone/rhmlatency/mlatency.c
+++ b/testsuites/rhealstone/rhmlatency/mlatency.c
@@ -9,7 +9,7 @@
 #endif
 const char rtems_test_name[] = "RHMLATENCY";
diff --git a/testsuites/rhealstone/rhsemshuffle/semshuffle.c b/testsuites/rhealstone/rhsemshuffle/semshuffle.c
index 4aafc52..6800926 100644
--- a/testsuites/rhealstone/rhsemshuffle/semshuffle.c
+++ b/testsuites/rhealstone/rhsemshuffle/semshuffle.c
@@ -4,8 +4,8 @@
 const char rtems_test_name[] = "RHSEMSHUFFLE";
diff --git a/testsuites/rhealstone/rhtaskpreempt/taskpreempt.c b/testsuites/rhealstone/rhtaskpreempt/taskpreempt.c
index 137b58a..090fd78 100644
--- a/testsuites/rhealstone/rhtaskpreempt/taskpreempt.c
+++ b/testsuites/rhealstone/rhtaskpreempt/taskpreempt.c
@@ -5,7 +5,7 @@
 const char rtems_test_name[] = "RHTASKPREEMPT";
diff --git a/testsuites/rhealstone/rhtaskswitch/taskswitch.c b/testsuites/rhealstone/rhtaskswitch/taskswitch.c
index 6096f18..520de33 100644
--- a/testsuites/rhealstone/rhtaskswitch/taskswitch.c
+++ b/testsuites/rhealstone/rhtaskswitch/taskswitch.c
@@ -4,8 +4,8 @@
 #define BENCHMARKS 50000
diff --git a/testsuites/support/src/tmtests_support.c b/testsuites/support/src/tmtests_support.c
index 1d35532..a6230ab 100644
--- a/testsuites/support/src/tmtests_support.c
+++ b/testsuites/support/src/tmtests_support.c
@@ -11,10 +11,8 @@
 #include "config.h"
 #endif
 #include <bsp.h>
 #include "timesys.h"
 #include "tmtests_empty_function.h"
1.9.3
