[PATCH 3/4] Revert: rtems-rfs-buffer.c: Correct printf() format specifiers to eliminate warnings
Thu Sep 11 13:28:16 UTC 2014
This may actually be a problem in inttypes.h.
 cpukit/libfs/src/rfs/rtems-rfs-buffer.c | 5 +++--
 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/cpukit/libfs/src/rfs/rtems-rfs-buffer.c b/cpukit/libfs/src/rfs/rtems-rfs-buffer.c
index 4192b21..3d89f5f 100644
--- a/cpukit/libfs/src/rfs/rtems-rfs-buffer.c
+++ b/cpukit/libfs/src/rfs/rtems-rfs-buffer.c
@@ -52,12 +52,13 @@ rtems_rfs_scan_chain (rtems_chain_control*   chain,
     buffer = (rtems_rfs_buffer*) node;
     if (rtems_rfs_trace (RTEMS_RFS_TRACE_BUFFER_CHAINS))
-      printf ("%p ", buffer->user);
+      printf ("%" PRIuPTR " ", ((intptr_t) buffer->user));
     if (((rtems_rfs_buffer_block) ((intptr_t)(buffer->user))) == block)
-        printf (": found block=%p\n", buffer->user);
+        printf (": found block=%" PRIuPTR "\n",
+                ((intptr_t)(buffer->user)));
       (*count)--;
       rtems_chain_extract_unprotected (node);
1.9.3
