[PATCH-V2] smptests/smpcache01: Remove invalidation of data cache lines from test
Daniel Cederman
cederman at gaisler.com
Thu Sep 11 15:55:34 UTC 2014
Invalidation of entire data cache might cause data written to the stack
to get lost.
testsuites/smptests/smpcache01/init.c | 47 +++++++++++++++------------
testsuites/smptests/smpcache01/smpcache01.doc | 1 -
testsuites/smptests/smpcache01/smpcache01.scn | 18 ++++------
3 files changed, 33 insertions(+), 33 deletions(-)
diff --git a/testsuites/smptests/smpcache01/init.c b/testsuites/smptests/smpcache01/init.c
index dd2f9f1..39808b3 100644
--- a/testsuites/smptests/smpcache01/init.c
+++ b/testsuites/smptests/smpcache01/init.c
@@ -20,6 +20,8 @@
const char rtems_test_name[] = "SMPCACHE 1";
+CPU_STRUCTURE_ALIGNMENT static int data_to_flush[1024];
#define CPU_COUNT 32
#define WORKER_PRIORITY 100
@@ -44,6 +46,11 @@ static test_context ctx = {
.barrier = SMP_BARRIER_CONTROL_INITIALIZER,
+static void function_to_flush( void )
+ /* Does nothing. Used to give a pointer to instruction address space. */
static void test_cache_message( const void *d_addr, size_t n_bytes )
rtems_test_assert(n_bytes == 123);
@@ -52,22 +59,22 @@ static void test_cache_message( const void *d_addr, size_t n_bytes )
ctx.count[rtems_get_current_processor()]++;
-static void all_cache_manager_smp_functions( size_t set_size,
+static void cache_manager_smp_functions( size_t set_size,
cpu_set_t *cpu_set )
- rtems_cache_flush_multiple_data_lines_processor_set( 0, 10, set_size,
- cpu_set );
- rtems_cache_invalidate_multiple_data_lines_processor_set( 0, 10, set_size,
- cpu_set );
+ rtems_cache_flush_multiple_data_lines_processor_set( &data_to_flush,
+ sizeof(data_to_flush), set_size, cpu_set );
+ rtems_cache_invalidate_multiple_data_lines_processor_set( &data_to_flush,
rtems_cache_flush_entire_data_processor_set( set_size, cpu_set );
- rtems_cache_invalidate_entire_data_processor_set( set_size, cpu_set );
rtems_cache_invalidate_entire_instruction();
- rtems_cache_invalidate_multiple_instruction_lines( 0, 10 );
+ rtems_cache_invalidate_multiple_instruction_lines( &function_to_flush,
+ 4 /* arbitrary size */ );
static void standard_funcs_test( size_t set_size, cpu_set_t *cpu_set )
- all_cache_manager_smp_functions( set_size, cpu_set );
+ cache_manager_smp_functions( set_size, cpu_set );
static void standard_funcs_isrdisabled_test( size_t set_size,
@@ -79,7 +86,7 @@ static void standard_funcs_isrdisabled_test( size_t set_size,
_SMP_barrier_Wait( &ctx.barrier, bs, rtems_get_processor_count() );
_ISR_Enable_without_giant( isr_level );
@@ -92,7 +99,7 @@ static void standard_funcs_giant_taken_test( size_t set_size,
if ( rtems_get_current_processor() == 0)
_Giant_Release();
@@ -169,23 +176,23 @@ static void all_tests( void )
/* Send message to all available CPUs */
CPU_FILL_S( set_size, cpu_set );
- /* Call all SMP cache manager functions */
- cmlog( "Calling all standard SMP cache functions\n" );
+ /* Call SMP cache manager functions */
+ cmlog( "Calling standard SMP cache functions. " );
_SMP_barrier_Wait( &ctx.barrier, &bs, cpu_count );
standard_funcs_test( set_size, cpu_set );
cmlog( "Done!\n");
- /* Call all SMP cache manager functions with ISR disabled */
- cmlog( "Calling all standard SMP cache functions. With ISR disabled\n" );
+ /* Call SMP cache manager functions with ISR disabled */
+ cmlog( "Calling standard SMP cache functions with ISR disabled. " );
standard_funcs_isrdisabled_test( set_size, cpu_set, &bs );
cmlog( "Done!\n" );
- /* Call all SMP cache manager functions with core 0 holding the giant lock */
- cmlog( "Calling all standard SMP cache functions. With CPU0 holding "
- "the giant lock\n" );
+ /* Call SMP cache manager functions with core 0 holding the giant lock */
+ cmlog( "Calling standard SMP cache functions with CPU0 holding "
+ "the giant lock. " );
standard_funcs_giant_taken_test( set_size, cpu_set, &bs );
@@ -194,7 +201,7 @@ static void all_tests( void )
/* Call a test function using SMP cache manager and verify that all
* cores invoke the function */
cmlog( "Calling a test function using the SMP cache manager to "
- "verify that all CPUs receive the SMP message\n" );
+ "verify that all CPUs receive the SMP message. " );
test_func_test( set_size, cpu_set, &bs );
@@ -203,7 +210,7 @@ static void all_tests( void )
* cores invoke the function. ISR disabled. */
- "verify that all CPUs receive the SMP message. With ISR disabled\n" );
+ "verify that all CPUs receive the SMP message. With ISR disabled. " );
test_func_isrdisabled_test( set_size, cpu_set, &bs );
@@ -213,7 +220,7 @@ static void all_tests( void )
* cores invoke the function. Core 0 holding giant lock. */
"verify that all CPUs receive the SMP message. With CPU0 "
- "holding the giant lock\n" );
+ "holding the giant lock. " );
test_func_giant_taken_test( set_size, cpu_set, &bs );
diff --git a/testsuites/smptests/smpcache01/smpcache01.doc b/testsuites/smptests/smpcache01/smpcache01.doc
index f6041b2..2cc66a9 100644
--- a/testsuites/smptests/smpcache01/smpcache01.doc
+++ b/testsuites/smptests/smpcache01/smpcache01.doc
@@ -7,7 +7,6 @@ directives:
- rtems_cache_flush_entire_data_processor_set
- - rtems_cache_invalidate_entire_data_processor_set
- rtems_cache_invalidate_entire_instruction
diff --git a/testsuites/smptests/smpcache01/smpcache01.scn b/testsuites/smptests/smpcache01/smpcache01.scn
index 5964d3e..c93e2c5 100644
--- a/testsuites/smptests/smpcache01/smpcache01.scn
+++ b/testsuites/smptests/smpcache01/smpcache01.scn
@@ -1,14 +1,8 @@
*** BEGIN OF TEST SMPCACHE 1 ***
-Calling all standard SMP cache functions
-Done!
-Calling all standard SMP cache functions. With ISR disabled
-Done!
-Calling all standard SMP cache functions. With CPU0 holding the giant lock
-Done!
-Calling a test function using the SMP cache manager to verify that all CPUs receive the SMP message
-Done!
-Calling a test function using the SMP cache manager to verify that all CPUs receive the SMP message. With ISR disabled
-Done!
-Calling a test function using the SMP cache manager to verify that all CPUs receive the SMP message. With CPU0 holding the giant lock
-Done!
+Calling standard SMP cache functions. Done!
+Calling standard SMP cache functions with ISR disabled. Done!
+Calling standard SMP cache functions with CPU0 holding the giant lock. Done!
+Calling a test function using the SMP cache manager to verify that all CPUs receive the SMP message. Done!
+Calling a test function using the SMP cache manager to verify that all CPUs receive the SMP message. With ISR disabled. Done!
+Calling a test function using the SMP cache manager to verify that all CPUs receive the SMP message. With CPU0 holding the giant lock. Done!
*** END OF TEST SMPCACHE 1 ***
2.1.0
