In nfs_dir_read() count used before and after limiting?
Sat Sep 13 15:25:21 UTC 2014
On September 13, 2014 8:32:53 AM CDT, Peter Dufault <dufault at hda.com> wrote:
>On Sep 11, 2014, at 10:03 , Sebastian Huber
><sebastian.huber at embedded-brains.de> wrote:
>>> In nfs_dir_read() I see:
>>>     /* align + round down the buffer */
>>>     count &= ~ (DIRENT_HEADER_SIZE - 1);
>>>     di->len = count;
>>> Then later:
>>>     if (count > NFS_MAXDATA)
>>>         count = NFS_MAXDATA;
>>>     di->readdirargs.count = count;
>>> Can someone who understands this comment on it?
>> Sorry, Peter.  I don't have time to look at this at the moment.  The
>NFS code
>> is hard to understand.  Since it works for me I have no urgent need
>to spend
>> time on this.
>Can you answer one question?  If nfsStBlksize is set to zero so that
>this:
>    /* Set to "preferred size" of this NFS client implementation */
>    buf->st_blksize = nfsStBlksize ? nfsStBlksize : fa->blocksize;
>returns 4096, then is it a bug if transfers larger than 4K are
>attempted?
>Limiting all transfers to values other than the default 8K can end up
>with memory corruption.  512B works, 1K works, 2K and 4K corrupt
>things.  The changes are minor (attached).
>If it's a bug for transfers to be larger than 4K when fa->blocksize=4K
>I can look at that, that's easy to trap when it happens.
Speaking purely from a defensive programming stance with no knowledge of what is possible in NFS, I would put the trap in. It is a case the codes will do bad things if it happens. So it could be a case of this should never happen or this is an odd configuration the code does not support. Either way, better to detect and report than tromp on memory.
If your work simplifies the code, that's always a good thing but certainly not a requirement to address the issues.
>Peter
>Peter Dufault
>HD Associates, Inc.      Software and System Engineering
--joel
