[PATCH] or1k: New cache manager.
Hesham Moustafa heshamelmatary at gmail.com
Tue Sep 16 17:29:30 UTC 2014
On Tue, Sep 16, 2014 at 5:59 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> I am not sure what it up. Chris committed a patch that changed
> the sort order to be more uniform. But your preinstall.am's don't
> match.
I generated an updated one in a separate commit before (after Chris
change), and it's commited.
> Maybe you should try regenerating them. Perhaps they are
> from before his change being committed.
I am sure this is after Chris change. I typed "git reset --hard
HEAD~N", then "git pull", and finally applied my patches again and
sent them out yesterday, and this is new version of the patch just
generated now. running ./boostarp -p does not affect any preinstall.am
(as it did before Chris change), so it's following latest order by
Chris. I will submit another patch with a little modification to
Makefile.am and consequently preinstall.am. It's against current RTEMS
HEAD.
> $ git am /media/sf_jrs007/patches/\[PATCH\]\ or1k\ \ New\ cache\
> manager..eml
> Applying: or1k: New cache manager.
> error: patch failed: c/src/lib/libbsp/or1k/or1ksim/preinstall.am:86
> error: c/src/lib/libbsp/or1k/or1ksim/preinstall.am: patch does not apply
> error: patch failed: c/src/lib/libcpu/or1k/preinstall.am:22
> error: c/src/lib/libcpu/or1k/preinstall.am: patch does not apply
> Patch failed at 0001 or1k: New cache manager.
> When you have resolved this problem run "git am --resolved".
> If you would prefer to skip this patch, instead run "git am --skip".
> To restore the original branch and stop patching run "git am --abort".
> On 9/16/2014 10:54 AM, Hesham ALMatary wrote:
>> Implement new cache functions for or1k and create new bspstart function
>> for or1ksim to initialize instruction and data caches. Also, sim.cfg
>> is modified to enable/confiure cache units.
>>  c/src/lib/libbsp/or1k/or1ksim/Makefile.am        |  10 +-
>>  c/src/lib/libbsp/or1k/or1ksim/preinstall.am      |   4 +
>>  c/src/lib/libbsp/or1k/or1ksim/sim.cfg            |  21 +-
>>  c/src/lib/libbsp/or1k/or1ksim/startup/bspstart.c |  25 +++
>>  c/src/lib/libbsp/or1k/shared/include/cache_.h    |  43 ++++
>>  c/src/lib/libcpu/or1k/Makefile.am                |   3 +-
>>  c/src/lib/libcpu/or1k/preinstall.am              |   4 +
>>  c/src/lib/libcpu/or1k/shared/cache/cache.c       | 241 +++++++++++++++++++++++
>>  c/src/lib/libcpu/or1k/shared/cache/cache_.h      |   2 +-
>>  9 files changed, 335 insertions(+), 18 deletions(-)
>>  create mode 100644 c/src/lib/libbsp/or1k/or1ksim/startup/bspstart.c
>>  create mode 100644 c/src/lib/libbsp/or1k/shared/include/cache_.h
>>  create mode 100644 c/src/lib/libcpu/or1k/shared/cache/cache.c
>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/Makefile.am b/c/src/lib/libbsp/or1k/or1ksim/Makefile.am
>> index 7af4fd0..9c9b27c 100644
>> --- a/c/src/lib/libbsp/or1k/or1ksim/Makefile.am
>> +++ b/c/src/lib/libbsp/or1k/or1ksim/Makefile.am
>> @@ -30,6 +30,7 @@ include_bsp_HEADERS += ../../shared/include/irq-info.h
>>  include_bsp_HEADERS += ../../shared/include/stackalloc.h
>>  include_bsp_HEADERS += ../../shared/include/uart-output-char.h
>>  include_bsp_HEADERS += ../../shared/tod.h
>> +include_bsp_HEADERS += ../shared/include/cache_.h
>>  include_bsp_HEADERS += include/irq.h
>>  include_bsp_HEADERS += include/uart.h
>>  include_bsp_HEADERS += include/or1ksim.h
>> @@ -61,8 +62,8 @@ libbsp_a_CPPFLAGS =
>>  libbsp_a_LIBADD =
>>  # Startup
>> -libbsp_a_SOURCES += ../../shared/bspstart.c
>>  libbsp_a_SOURCES += ../../shared/bspreset.c
>> +libbsp_a_SOURCES += startup/bspstart.c
>>  # Shared
>>  libbsp_a_SOURCES += ../../shared/bootcard.c
>> @@ -72,8 +73,6 @@ libbsp_a_SOURCES += ../../shared/bsplibc.c
>>  libbsp_a_SOURCES += ../../shared/bsppost.c
>>  libbsp_a_SOURCES += ../../shared/bsppredriverhook.c
>>  libbsp_a_SOURCES += ../../shared/bsppretaskinghook.c
>> -libbsp_a_SOURCES += ../../shared/cpucounterread.c
>> -libbsp_a_SOURCES += ../../shared/cpucounterdiff.c
>>  libbsp_a_SOURCES += ../../shared/gnatinstallhandler.c
>>  libbsp_a_SOURCES += ../../shared/sbrk.c
>>  libbsp_a_SOURCES += ../../shared/src/stackalloc.c
>> @@ -100,9 +99,8 @@ libbsp_a_SOURCES += ../../shared/src/irq-info.c
>>  libbsp_a_SOURCES += irq/irq.c
>>  # Cache
>> -libbsp_a_SOURCES += ../../../libcpu/shared/src/cache_manager.c
>> -libbsp_a_SOURCES += ../../shared/include/cache_.h
>> -libbsp_a_CPPFLAGS += -I$(srcdir)/../../shared/include
>> +# Cache
>> +libbsp_a_LIBADD += ../../../libcpu/@RTEMS_CPU@/shared/cache.rel
>>  #                  Special Rules                                              #
>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/preinstall.am b/c/src/lib/libbsp/or1k/or1ksim/preinstall.am
>> index 1561b18..c0fa6b8 100644
>> --- a/c/src/lib/libbsp/or1k/or1ksim/preinstall.am
>> +++ b/c/src/lib/libbsp/or1k/or1ksim/preinstall.am
>> @@ -86,6 +86,10 @@ $(PROJECT_INCLUDE)/bsp/tod.h: ../../shared/tod.h $(PROJECT_INCLUDE)/bsp/$(dirsta
>>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/tod.h
>>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/tod.h
>> +$(PROJECT_INCLUDE)/bsp/cache_.h: ../shared/include/cache_.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/cache_.h
>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/cache_.h
>>  $(PROJECT_INCLUDE)/bsp/irq.h: include/irq.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq.h
>>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq.h
>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/sim.cfg b/c/src/lib/libbsp/or1k/or1ksim/sim.cfg
>> index 061f61a..ec73e3d 100644
>> --- a/c/src/lib/libbsp/or1k/or1ksim/sim.cfg
>> +++ b/c/src/lib/libbsp/or1k/or1ksim/sim.cfg
>> @@ -35,23 +35,23 @@ section mc
>>  end
>>  section ic
>> -  enabled   =   0
>> +  enabled   =   1
>>    nsets     = 256
>>    nways     =   1
>> -  blocksize =  16
>> +  blocksize =  32
>>    hitdelay  =  20
>> -  missdelay =  20
>> +  missdelay =  60
>>  end
>>  section dc
>> -  enabled = 0
>> -  nsets = 256
>> +  enabled = 1
>> +  nsets = 256
>>    nways = 1
>> -  blocksize = 16
>> -  load_hitdelay = 0
>> -  load_missdelay = 0
>> -  store_hitdelay = 0
>> -  store_missdelay = 0
>> +  blocksize = 32
>> +  load_hitdelay = 40
>> +  load_missdelay = 120
>> +  store_hitdelay = 40
>> +  store_missdelay = 120
>>  end
>>  section pic
>> @@ -78,6 +78,7 @@ section cpu
>>    ver = 0x12
>>    cfg = 0x00
>>    rev = 0x0001
>> +  upr = 0x0000075f
>>    superscalar = 0
>>    hazards = 0
>>    dependstats = 0
>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/startup/bspstart.c b/c/src/lib/libbsp/or1k/or1ksim/startup/bspstart.c
>> new file mode 100644
>> index 0000000..d9fb7a7
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/or1k/or1ksim/startup/bspstart.c
>> @@ -0,0 +1,25 @@
>> + * @file
>> + * @ingroup or1ksim
>> + * @brief Benchmark timer support.
>> + * Copyright (c) 2014 by Hesham ALMatary
>> + *  The license and distribution terms for this file may be
>> + *  found in the file LICENSE in this distribution or at
>> + *  http://www.rtems.org/license/LICENSE
>> +#include <bsp.h>
>> +#include <bsp/bootcard.h>
>> +#include <libcpu/cache.h>
>> +void bsp_start( void )
>> +  _CPU_cache_enable_instruction();
>> +  _CPU_cache_enable_data();
>> diff --git a/c/src/lib/libbsp/or1k/shared/include/cache_.h b/c/src/lib/libbsp/or1k/shared/include/cache_.h
>> index 0000000..ee54227
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/or1k/shared/include/cache_.h
>> @@ -0,0 +1,43 @@
>> + * COPYRIGHT (c) 2014 Hesham ALMatary <heshamelmatary at gmail.com>
>> + * http://www.rtems.org/license/LICENSE.
>> +#ifndef LIBBSP_OR1K_SHARED_CACHE_H
>> +#define LIBBSP_OR1K_SHARED_CACHE_H
>> +#include <assert.h>
>> +#include <bsp.h>
>> +#include <rtems/rtems/intr.h>
>> +#ifdef __cplusplus
>> +extern "C" {
>> +#endif /* __cplusplus */
>> +/* These two defines also ensure that the rtems_cache_* functions have bodies */
>> +#define CPU_DATA_CACHE_ALIGNMENT        32
>> +#define CPU_INSTRUCTION_CACHE_ALIGNMENT 32
>> +#define CPU_CACHE_SUPPORT_PROVIDES_CACHE_SIZE_FUNCTIONS 1
>> +static inline size_t
>> +_CPU_cache_get_data_cache_size( const uint32_t level )
>> +  return (level == 0 || level == 1)? 8192 : 0;
>> +_CPU_cache_get_instruction_cache_size( const uint32_t level )
>> +#ifdef __cplusplus
>> +#endif /* LIBBSP_OR1K_SHARED_CACHE_H */
>> diff --git a/c/src/lib/libcpu/or1k/Makefile.am b/c/src/lib/libcpu/or1k/Makefile.am
>> index f4a6372..0148548 100644
>> --- a/c/src/lib/libcpu/or1k/Makefile.am
>> +++ b/c/src/lib/libcpu/or1k/Makefile.am
>> @@ -10,8 +10,9 @@ include_libcpudir = $(includedir)/libcpu
>>  ## shared/cache
>>  include_libcpu_HEADERS = ../shared/include/cache.h
>> +include_libcpu_HEADERS += shared/cache/cache_.h
>>  noinst_PROGRAMS += shared/cache.rel
>> -shared_cache_rel_SOURCES = ../shared/src/no_cache.c shared/cache/cache_.h
>> +shared_cache_rel_SOURCES = shared/cache/cache.c ../shared/src/cache_manager.c
>>  shared_cache_rel_CPPFLAGS = $(AM_CPPFLAGS) -I$(srcdir)/shared/cache
>>  shared_cache_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
>> diff --git a/c/src/lib/libcpu/or1k/preinstall.am b/c/src/lib/libcpu/or1k/preinstall.am
>> index ee9d0da..84864cb 100644
>> --- a/c/src/lib/libcpu/or1k/preinstall.am
>> +++ b/c/src/lib/libcpu/or1k/preinstall.am
>> @@ -22,3 +22,7 @@ $(PROJECT_INCLUDE)/libcpu/cache.h: ../shared/include/cache.h $(PROJECT_INCLUDE)/
>>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/cache.h
>>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/cache.h
>> +$(PROJECT_INCLUDE)/libcpu/cache_.h: shared/cache/cache_.h $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/cache_.h
>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/cache_.h
>> diff --git a/c/src/lib/libcpu/or1k/shared/cache/cache.c b/c/src/lib/libcpu/or1k/shared/cache/cache.c
>> index 0000000..fdc67ce
>> --- /dev/null
>> +++ b/c/src/lib/libcpu/or1k/shared/cache/cache.c
>> @@ -0,0 +1,241 @@
>> + * COPYRIGHT (c) 1989-2006
>> + * On-Line Applications Research Corporation (OAR).
>> +#include <rtems/score/cpu.h>
>> +#include <rtems/score/interr.h>
>> +#include <rtems/score/or1k-utility.h>
>> +static inline void _CPU_OR1K_Cache_enable_data(void)
>> +  uint32_t sr;
>> +   ISR_Level level;
>> +  _ISR_Disable (level);
>> +  sr = _OR1K_mfspr(CPU_OR1K_SPR_SR);
>> +  _OR1K_mtspr(CPU_OR1K_SPR_SR, sr | CPU_OR1K_SPR_SR_DCE);
>> +  _ISR_Enable(level);
>> +static inline void _CPU_OR1K_Cache_disable_data(void)
>> +  uint32_t sr;
>> +   ISR_Level level;
>> +  _OR1K_mtspr(CPU_OR1K_SPR_SR, (sr & ~CPU_OR1K_SPR_SR_DCE));
>> +static inline void _CPU_OR1K_Cache_enable_instruction(void)
>> +  uint32_t sr;
>> +   ISR_Level level;
>> +  _OR1K_mtspr(CPU_OR1K_SPR_SR, sr | CPU_OR1K_SPR_SR_ICE);
>> +static inline void _CPU_OR1K_Cache_disable_instruction(void)
>> +  uint32_t sr;
>> +  ISR_Level level;
>> +  _OR1K_mtspr(CPU_OR1K_SPR_SR, (sr & ~CPU_OR1K_SPR_SR_ICE));
>> +static inline void _CPU_OR1K_Cache_data_block_prefetch(const void *d_addr)
>> +  ISR_Level level;
>> +  _OR1K_mtspr(CPU_OR1K_SPR_DCBPR, d_addr);
>> +static inline void _CPU_OR1K_Cache_data_block_flush(const void *d_addr)
>> +   ISR_Level level;
>> +  _OR1K_mtspr(CPU_OR1K_SPR_DCBFR, d_addr);
>> +static inline void _CPU_OR1K_Cache_data_block_invalidate(const void *d_addr)
>> +   ISR_Level level;
>> +  _OR1K_mtspr(CPU_OR1K_SPR_DCBIR, d_addr);
>> +static inline void _CPU_OR1K_Cache_data_block_writeback(const void *d_addr)
>> +   ISR_Level level;
>> +  _OR1K_mtspr(CPU_OR1K_SPR_DCBWR, d_addr);
>> +static inline void _CPU_OR1K_Cache_data_block_lock(const void *d_addr)
>> +   ISR_Level level;
>> +  _OR1K_mtspr(CPU_OR1K_SPR_DCBLR, d_addr);
>> +static inline void _CPU_OR1K_Cache_instruction_block_prefetch
>> +(const void *d_addr)
>> +   ISR_Level level;
>> +  _OR1K_mtspr(CPU_OR1K_SPR_ICBPR, d_addr);
>> +static inline void _CPU_OR1K_Cache_instruction_block_invalidate
>> +   ISR_Level level;
>> +  _OR1K_mtspr(CPU_OR1K_SPR_ICBIR, d_addr);
>> +static inline void _CPU_OR1K_Cache_instruction_block_lock
>> +   ISR_Level level;
>> +  _OR1K_mtspr(CPU_OR1K_SPR_ICBLR, d_addr);
>> +/* Implement RTEMS cache manager functions */
>> +void _CPU_cache_flush_1_data_line(const void *d_addr)
>> +   ISR_Level level;
>> +  _CPU_OR1K_Cache_data_block_flush(d_addr);
>> +  //asm volatile("l.csync");
>> +void _CPU_cache_invalidate_1_data_line(const void *d_addr)
>> +   ISR_Level level;
>> +  _CPU_OR1K_Cache_data_block_invalidate(d_addr);
>> +void _CPU_cache_freeze_data(void)
>> +  /* Do nothing */
>> +void _CPU_cache_unfreeze_data(void)
>> +  /* Do nothing */
>> +void _CPU_cache_invalidate_1_instruction_line(const void *d_addr)
>> +   ISR_Level level;
>> +  _CPU_OR1K_Cache_instruction_block_invalidate(d_addr);
>> +void _CPU_cache_freeze_instruction(void)
>> +  /* Do nothing */
>> +void _CPU_cache_unfreeze_instruction(void)
>> +  /* Do nothing */
>> +void _CPU_cache_flush_entire_data(void)
>> +void _CPU_cache_invalidate_entire_data(void)
>> +void _CPU_cache_invalidate_entire_instruction(void)
>> +void _CPU_cache_enable_data(void)
>> +  _CPU_OR1K_Cache_enable_data();
>> +void _CPU_cache_disable_data(void)
>> +  _CPU_OR1K_Cache_disable_data();
>> +void _CPU_cache_enable_instruction(void)
>> +  _CPU_OR1K_Cache_enable_instruction();
>> +void _CPU_cache_disable_instruction(void)
>> +  _CPU_OR1K_Cache_disable_instruction();
>> diff --git a/c/src/lib/libcpu/or1k/shared/cache/cache_.h b/c/src/lib/libcpu/or1k/shared/cache/cache_.h
>> index 08d9ecc..5f08410 100644
>> --- a/c/src/lib/libcpu/or1k/shared/cache/cache_.h
>> +++ b/c/src/lib/libcpu/or1k/shared/cache/cache_.h
>> @@ -5,7 +5,7 @@
>>  #ifndef __OR1K_CACHE_H
>>  #define __OR1K_CACHE_H
>> -#include <libcpu/cache.h>
>> +#include <bsp/cache_.h>
>>  #endif
>>  /* end of include file */
>> 1.9.3
>> devel mailing list
>> devel at rtems.org
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
