or1k test was .. Re: [PATCH] or1k: New cache manager.
Hesham Moustafa heshamelmatary at gmail.com
Tue Sep 16 19:17:37 UTC 2014
On Tue, Sep 16, 2014 at 8:42 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> On 9/16/2014 1:34 PM, Hesham Moustafa wrote:
>> On Tue, Sep 16, 2014 at 8:15 PM, Joel Sherrill
>>> On 9/16/2014 12:54 PM, Hesham Moustafa wrote:
>>>> Hi
>>>> On Tue, Sep 16, 2014 at 7:47 PM, Joel Sherrill
>>>>> I don't understand this but I got it applied.
>>>>> I manually edited the saved email to delete the preinstall.am
>>>>> changes.  I committed the rest. Then I ran bootstrap -p myself
>>>>> and folded that into the rest of your patch.
>>>>> It should all be committed now.
>>>> Thanks for doing this, me too do not know what's wrong. BTW, commits
>>>> are not mirrored on github since 4 days ago.
>>>>> How about some new test results. :)
>>>> I did run one last night, no big progress since previous results :( Is
>>>> there any tool, script, utility program or whatever that I can use to
>>>> detect wrong memory access (i.e, stack overwrite, heap corruption,
>>>> access to another task context)? I tried to add -fstack-protector-all
>>>> to gcc, but QEMU did not get anything or core-dump, ticker just hangs.
>>> I haven't checked into how gcc does its stack overwrite protection.
>>> The tests by themselves don't have these problems. The first
>>> possible source is incorrect layout of sections to memory by
>>> the linker script. There is some debug code in boot
>>> There used to be debug printk's in bspgetworkarea.c so you
>>> could check if areas overlapped. That usually causes bad issues
>>> though. Let's go through some basics:
>>> + Does hello world run and exit cleanly?
>> The output of Hello World is:
>> *** BEGIN OF TEST HELLO WORLD ***
>> Hello World
>> *** END OF TEST HELLO WORLD ***
>> Fatal Error 5.0 Halted
>>  From GDB:
>> Breakpoint 1, _Terminate (
>>      the_source=RTEMS_FATAL_SOURCE_EXIT, is_internal=false, the_error=0)
>>      at ../../../../../../rtems/c/src/../../cpukit/score/src/interr.c:39
>> 39  _ISR_Disable_without_giant( level );
>> (gdb) bt
>> #0  _Terminate (
>> #1  0x0003b5f8 in rtems_shutdown_executive (result=0)
>>      at
>> ../../../../../../rtems/c/src/../../cpukit/sapi/src/exshutdown.c:21
>> #2  0x0003b350 in _exit (status=0)
>>      at
>> ../../../../../../rtems/c/src/../../cpukit/libcsupport/src/newlibc_exit.c:47
>> #3  0x0002cc30 in exit (code=0)
>>      at ../../../../../gcc-4.8.3/newlib/libc/stdlib/exit.c:70
>> #4  0x00002184 in Init (ignored=253816)
>>      at
>> ../../../../../../../rtems/c/src/../../testsuites/samples/hello/init.c:33
>> ---Type <return> to continue, or q <return> to quit---
>> #5  0x0002c5b8 in _Thread_Handler ()
>>      at
>> ../../../../../../rtems/c/src/../../cpukit/score/src/threadhandler.c:192
>> #6  0x0002c540 in _User_extensions_Thread_exitted (executing=0x40080)
>>      at
>> ../../cpukit/../../../or1ksim/lib/include/rtems/score/userextimpl.h:243
> This is normal and OK. Look at the arguments to _Terminate.
>>> + How far does ticker get?
>> Ticker goes to the end:
>> *** BEGIN OF TEST CLOCK TICK ***
>> TA1  - rtems_clock_get_tod - 09:00:00   12/31/1988
>> TA2  - rtems_clock_get_tod - 09:00:00   12/31/1988
>> TA3  - rtems_clock_get_tod - 09:00:00   12/31/1988
>> TA1  - rtems_clock_get_tod - 09:00:05   12/31/1988
>> TA2  - rtems_clock_get_tod - 09:00:10   12/31/1988
>> TA1  - rtems_clock_get_tod - 09:00:10   12/31/1988
>> TA3  - rtems_clock_get_tod - 09:00:15   12/31/1988
>> TA1  - rtems_clock_get_tod - 09:00:15   12/31/1988
>> TA2  - rtems_clock_get_tod - 09:00:20   12/31/1988
>> TA1  - rtems_clock_get_tod - 09:00:20   12/31/1988
>> TA1  - rtems_clock_get_tod - 09:00:25   12/31/1988
>> TA3  - rtems_clock_get_tod - 09:00:30   12/31/1988
>> TA2  - rtems_clock_get_tod - 09:00:30   12/31/1988
>> TA1  - rtems_clock_get_tod - 09:00:30   12/31/1988
>> *** END OF TEST CLOCK TICK ***
>> Fatal Error 9.276564 Halted
>>  From GDB:
>> (gdb) break _Terminate
>> Breakpoint 1 at 0x19a68: file
>> ../../../../../../rtems/c/src/../../cpukit/score/src/interr.c, line
>> 39.
>> (gdb) break _OR1K_Exception_default
>> Breakpoint 2 at 0x2686c: file
>> ../../../../../../../../rtems/c/src/../../cpukit/score/cpu/or1k/or1k-exception-default.c,
>> line 22.
>> (gdb) c
>> The program is not being run.
>> (gdb) target remote :50001
>> Remote debugging using :50001
>> 0x00000100 in _reset ()
>> (gdb) c
>> Continuing.
>> Breakpoint 2, _OR1K_Exception_default (vector=6, frame=0x43854) at
>> ../../../../../../../../rtems/c/src/../../cpukit/score/cpu/or1k/or1k-exception-default.c:22
>> 22  rtems_fatal( RTEMS_FATAL_SOURCE_EXCEPTION, (rtems_fatal_code) frame );
>> (gdb) bt
>> #0  _OR1K_Exception_default (vector=6, frame=0x43854) at
>> #1  0x00026980 in jump_to_c_handler ()
>> Backtrace stopped: frame did not save the PC
>> vector 6 is _unalign exception.
> Set a break point at exit() (I think) and rtems_shutdown_executive(). You
> could start in the task which calls whatever kicks off the shutdown
> sequence.
> It looks like something in the shutdown procedure trips over something.
> This might be easy to debug.
I did add just a function call to _CPU_Exception_frame_print(frame);
 from _OR1K_Exception_default(uint32_t vector, CPU_Exception_frame *frame)
And ticker exits normally without even entering
_OR1K_Exception_defaul as it did before. This is very weird. Does this
mean that some areas of the code are overlapped from the linker
script?
> If the fault address is in the exception data, you can map that back to the
> nm file and see what file that was in, then that might help.
>>> + Have you tried the trick I suggested earlier to disable the
>>> real clock tick driver, use the simulator idle tick code, and
>>> disable all the tests that are known to fail that way. This
>>> will eliminate the ISR code as an issue because you won't
>>> have any (if console output if polled).  See h8sim for
>>> an example. Should be a Makefile.am change, adding
>>> an include to the testsuite configuration file, building
>>> and running.
>>>>> --joel
>>>>> On 9/16/2014 12:30 PM, Hesham ALMatary wrote:
>>>>>> Implement new cache functions for or1k and create new bspstart
>>>>>> function
>>>>>> for or1ksim to initialize instruction and data caches. Also, sim.cfg
>>>>>> is modified to enable/confiure cache units.
>>>>>>   c/src/lib/libbsp/or1k/or1ksim/Makefile.am        |   9 +-
>>>>>>   c/src/lib/libbsp/or1k/or1ksim/preinstall.am      |   4 +
>>>>>>   c/src/lib/libbsp/or1k/or1ksim/sim.cfg            |  21 +-
>>>>>>   c/src/lib/libbsp/or1k/or1ksim/startup/bspstart.c |  25 +++
>>>>>>   c/src/lib/libbsp/or1k/shared/include/cache_.h    |  43 ++++
>>>>>>   c/src/lib/libcpu/or1k/Makefile.am                |   3 +-
>>>>>>   c/src/lib/libcpu/or1k/preinstall.am              |   4 +
>>>>>>   c/src/lib/libcpu/or1k/shared/cache/cache.c       | 241
>>>>>>   c/src/lib/libcpu/or1k/shared/cache/cache_.h      |   2 +-
>>>>>>   9 files changed, 334 insertions(+), 18 deletions(-)
>>>>>>   create mode 100644 c/src/lib/libbsp/or1k/or1ksim/startup/bspstart.c
>>>>>>   create mode 100644 c/src/lib/libbsp/or1k/shared/include/cache_.h
>>>>>>   create mode 100644 c/src/lib/libcpu/or1k/shared/cache/cache.c
>>>>>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/Makefile.am
>>>>>> b/c/src/lib/libbsp/or1k/or1ksim/Makefile.am
>>>>>> index 7af4fd0..7e1c10b 100644
>>>>>> --- a/c/src/lib/libbsp/or1k/or1ksim/Makefile.am
>>>>>> +++ b/c/src/lib/libbsp/or1k/or1ksim/Makefile.am
>>>>>> @@ -30,6 +30,7 @@ include_bsp_HEADERS +=
>>>>>> ../../shared/include/irq-info.h
>>>>>>   include_bsp_HEADERS += ../../shared/include/stackalloc.h
>>>>>>   include_bsp_HEADERS += ../../shared/include/uart-output-char.h
>>>>>>   include_bsp_HEADERS += ../../shared/tod.h
>>>>>> +include_bsp_HEADERS += ../shared/include/cache_.h
>>>>>>   include_bsp_HEADERS += include/irq.h
>>>>>>   include_bsp_HEADERS += include/uart.h
>>>>>>   include_bsp_HEADERS += include/or1ksim.h
>>>>>> @@ -61,8 +62,8 @@ libbsp_a_CPPFLAGS =
>>>>>>   libbsp_a_LIBADD =
>>>>>>   # Startup
>>>>>> -libbsp_a_SOURCES += ../../shared/bspstart.c
>>>>>>   libbsp_a_SOURCES += ../../shared/bspreset.c
>>>>>> +libbsp_a_SOURCES += startup/bspstart.c
>>>>>>   # Shared
>>>>>>   libbsp_a_SOURCES += ../../shared/bootcard.c
>>>>>> @@ -72,8 +73,6 @@ libbsp_a_SOURCES += ../../shared/bsplibc.c
>>>>>>   libbsp_a_SOURCES += ../../shared/bsppost.c
>>>>>>   libbsp_a_SOURCES += ../../shared/bsppredriverhook.c
>>>>>>   libbsp_a_SOURCES += ../../shared/bsppretaskinghook.c
>>>>>> -libbsp_a_SOURCES += ../../shared/cpucounterread.c
>>>>>> -libbsp_a_SOURCES += ../../shared/cpucounterdiff.c
>>>>>>   libbsp_a_SOURCES += ../../shared/gnatinstallhandler.c
>>>>>>   libbsp_a_SOURCES += ../../shared/sbrk.c
>>>>>>   libbsp_a_SOURCES += ../../shared/src/stackalloc.c
>>>>>> @@ -100,9 +99,7 @@ libbsp_a_SOURCES += ../../shared/src/irq-info.c
>>>>>>   libbsp_a_SOURCES += irq/irq.c
>>>>>>   # Cache
>>>>>> -libbsp_a_SOURCES += ../../../libcpu/shared/src/cache_manager.c
>>>>>> -libbsp_a_SOURCES += ../../shared/include/cache_.h
>>>>>> -libbsp_a_CPPFLAGS += -I$(srcdir)/../../shared/include
>>>>>> +libbsp_a_LIBADD += ../../../libcpu/@RTEMS_CPU@/shared/cache.rel
>>>>>>   #                  Special Rules
>>>>>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/preinstall.am
>>>>>> b/c/src/lib/libbsp/or1k/or1ksim/preinstall.am
>>>>>> index 1561b18..c0fa6b8 100644
>>>>>> --- a/c/src/lib/libbsp/or1k/or1ksim/preinstall.am
>>>>>> +++ b/c/src/lib/libbsp/or1k/or1ksim/preinstall.am
>>>>>> @@ -86,6 +86,10 @@ $(PROJECT_INCLUDE)/bsp/tod.h: ../../shared/tod.h
>>>>>> $(PROJECT_INCLUDE)/bsp/$(dirsta
>>>>>>          $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/tod.h
>>>>>>   PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/tod.h
>>>>>> +$(PROJECT_INCLUDE)/bsp/cache_.h: ../shared/include/cache_.h
>>>>>> $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>>>>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/cache_.h
>>>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/cache_.h
>>>>>>   $(PROJECT_INCLUDE)/bsp/irq.h: include/irq.h
>>>>>>          $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq.h
>>>>>>   PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq.h
>>>>>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/sim.cfg
>>>>>> b/c/src/lib/libbsp/or1k/or1ksim/sim.cfg
>>>>>> index 061f61a..ec73e3d 100644
>>>>>> --- a/c/src/lib/libbsp/or1k/or1ksim/sim.cfg
>>>>>> +++ b/c/src/lib/libbsp/or1k/or1ksim/sim.cfg
>>>>>> @@ -35,23 +35,23 @@ section mc
>>>>>>   end
>>>>>>   section ic
>>>>>> -  enabled   =   0
>>>>>> +  enabled   =   1
>>>>>>     nsets     = 256
>>>>>>     nways     =   1
>>>>>> -  blocksize =  16
>>>>>> +  blocksize =  32
>>>>>>     hitdelay  =  20
>>>>>> -  missdelay =  20
>>>>>> +  missdelay =  60
>>>>>>   end
>>>>>>   section dc
>>>>>> -  enabled = 0
>>>>>> -  nsets = 256
>>>>>> +  enabled = 1
>>>>>> +  nsets = 256
>>>>>>     nways = 1
>>>>>> -  blocksize = 16
>>>>>> -  load_hitdelay = 0
>>>>>> -  load_missdelay = 0
>>>>>> -  store_hitdelay = 0
>>>>>> -  store_missdelay = 0
>>>>>> +  blocksize = 32
>>>>>> +  load_hitdelay = 40
>>>>>> +  load_missdelay = 120
>>>>>> +  store_hitdelay = 40
>>>>>> +  store_missdelay = 120
>>>>>>   end
>>>>>>   section pic
>>>>>> @@ -78,6 +78,7 @@ section cpu
>>>>>>     ver = 0x12
>>>>>>     cfg = 0x00
>>>>>>     rev = 0x0001
>>>>>> +  upr = 0x0000075f
>>>>>>     superscalar = 0
>>>>>>     hazards = 0
>>>>>>     dependstats = 0
>>>>>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/startup/bspstart.c
>>>>>> b/c/src/lib/libbsp/or1k/or1ksim/startup/bspstart.c
>>>>>> new file mode 100644
>>>>>> index 0000000..d9fb7a7
>>>>>> --- /dev/null
>>>>>> +++ b/c/src/lib/libbsp/or1k/or1ksim/startup/bspstart.c
>>>>>> @@ -0,0 +1,25 @@
>>>>>> + * @file
>>>>>> + * @ingroup or1ksim
>>>>>> + * @brief Benchmark timer support.
>>>>>> + * Copyright (c) 2014 by Hesham ALMatary
>>>>>> + *  The license and distribution terms for this file may be
>>>>>> + *  found in the file LICENSE in this distribution or at
>>>>>> + *  http://www.rtems.org/license/LICENSE
>>>>>> +#include <bsp.h>
>>>>>> +#include <bsp/bootcard.h>
>>>>>> +#include <libcpu/cache.h>
>>>>>> +void bsp_start( void )
>>>>>> +  _CPU_cache_enable_instruction();
>>>>>> +  _CPU_cache_enable_data();
>>>>>> diff --git a/c/src/lib/libbsp/or1k/shared/include/cache_.h
>>>>>> b/c/src/lib/libbsp/or1k/shared/include/cache_.h
>>>>>> index 0000000..ee54227
>>>>>> --- /dev/null
>>>>>> +++ b/c/src/lib/libbsp/or1k/shared/include/cache_.h
>>>>>> @@ -0,0 +1,43 @@
>>>>>> + * COPYRIGHT (c) 2014 Hesham ALMatary <heshamelmatary at gmail.com>
>>>>>> + * http://www.rtems.org/license/LICENSE.
>>>>>> +#ifndef LIBBSP_OR1K_SHARED_CACHE_H
>>>>>> +#define LIBBSP_OR1K_SHARED_CACHE_H
>>>>>> +#include <assert.h>
>>>>>> +#include <bsp.h>
>>>>>> +#include <rtems/rtems/intr.h>
>>>>>> +#ifdef __cplusplus
>>>>>> +extern "C" {
>>>>>> +#endif /* __cplusplus */
>>>>>> +/* These two defines also ensure that the rtems_cache_* functions
>>>>>> have bodies */
>>>>>> +#define CPU_DATA_CACHE_ALIGNMENT        32
>>>>>> +#define CPU_INSTRUCTION_CACHE_ALIGNMENT 32
>>>>>> +#define CPU_CACHE_SUPPORT_PROVIDES_CACHE_SIZE_FUNCTIONS 1
>>>>>> +static inline size_t
>>>>>> +_CPU_cache_get_data_cache_size( const uint32_t level )
>>>>>> +  return (level == 0 || level == 1)? 8192 : 0;
>>>>>> +_CPU_cache_get_instruction_cache_size( const uint32_t level )
>>>>>> +#ifdef __cplusplus
>>>>>> +#endif /* LIBBSP_OR1K_SHARED_CACHE_H */
>>>>>> diff --git a/c/src/lib/libcpu/or1k/Makefile.am
>>>>>> b/c/src/lib/libcpu/or1k/Makefile.am
>>>>>> index f4a6372..0148548 100644
>>>>>> --- a/c/src/lib/libcpu/or1k/Makefile.am
>>>>>> +++ b/c/src/lib/libcpu/or1k/Makefile.am
>>>>>> @@ -10,8 +10,9 @@ include_libcpudir = $(includedir)/libcpu
>>>>>>   ## shared/cache
>>>>>>   include_libcpu_HEADERS = ../shared/include/cache.h
>>>>>> +include_libcpu_HEADERS += shared/cache/cache_.h
>>>>>>   noinst_PROGRAMS += shared/cache.rel
>>>>>> -shared_cache_rel_SOURCES = ../shared/src/no_cache.c
>>>>>> +shared_cache_rel_SOURCES = shared/cache/cache.c
>>>>>> ../shared/src/cache_manager.c
>>>>>>   shared_cache_rel_CPPFLAGS = $(AM_CPPFLAGS) -I$(srcdir)/shared/cache
>>>>>>   shared_cache_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
>>>>>> diff --git a/c/src/lib/libcpu/or1k/preinstall.am
>>>>>> b/c/src/lib/libcpu/or1k/preinstall.am
>>>>>> index ee9d0da..84864cb 100644
>>>>>> --- a/c/src/lib/libcpu/or1k/preinstall.am
>>>>>> +++ b/c/src/lib/libcpu/or1k/preinstall.am
>>>>>> @@ -22,3 +22,7 @@ $(PROJECT_INCLUDE)/libcpu/cache.h:
>>>>>> ../shared/include/cache.h $(PROJECT_INCLUDE)/
>>>>>>          $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/cache.h
>>>>>>   PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/cache.h
>>>>>> +$(PROJECT_INCLUDE)/libcpu/cache_.h: shared/cache/cache_.h
>>>>>> $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
>>>>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/cache_.h
>>>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/cache_.h
>>>>>> diff --git a/c/src/lib/libcpu/or1k/shared/cache/cache.c
>>>>>> b/c/src/lib/libcpu/or1k/shared/cache/cache.c
>>>>>> index 0000000..fdc67ce
>>>>>> --- /dev/null
>>>>>> +++ b/c/src/lib/libcpu/or1k/shared/cache/cache.c
>>>>>> @@ -0,0 +1,241 @@
>>>>>> + * COPYRIGHT (c) 1989-2006
>>>>>> + * On-Line Applications Research Corporation (OAR).
>>>>>> +#include <rtems/score/cpu.h>
>>>>>> +#include <rtems/score/interr.h>
>>>>>> +#include <rtems/score/or1k-utility.h>
>>>>>> +static inline void _CPU_OR1K_Cache_enable_data(void)
>>>>>> +  uint32_t sr;
>>>>>> +   ISR_Level level;
>>>>>> +  _ISR_Disable (level);
>>>>>> +  sr = _OR1K_mfspr(CPU_OR1K_SPR_SR);
>>>>>> +  _OR1K_mtspr(CPU_OR1K_SPR_SR, sr | CPU_OR1K_SPR_SR_DCE);
>>>>>> +  _ISR_Enable(level);
>>>>>> +static inline void _CPU_OR1K_Cache_disable_data(void)
>>>>>> +  uint32_t sr;
>>>>>> +   ISR_Level level;
>>>>>> +  _OR1K_mtspr(CPU_OR1K_SPR_SR, (sr & ~CPU_OR1K_SPR_SR_DCE));
>>>>>> +static inline void _CPU_OR1K_Cache_enable_instruction(void)
>>>>>> +  uint32_t sr;
>>>>>> +   ISR_Level level;
>>>>>> +  _OR1K_mtspr(CPU_OR1K_SPR_SR, sr | CPU_OR1K_SPR_SR_ICE);
>>>>>> +static inline void _CPU_OR1K_Cache_disable_instruction(void)
>>>>>> +  uint32_t sr;
>>>>>> +  ISR_Level level;
>>>>>> +  _OR1K_mtspr(CPU_OR1K_SPR_SR, (sr & ~CPU_OR1K_SPR_SR_ICE));
>>>>>> +static inline void _CPU_OR1K_Cache_data_block_prefetch(const void
>>>>>> *d_addr)
>>>>>> +  ISR_Level level;
>>>>>> +  _OR1K_mtspr(CPU_OR1K_SPR_DCBPR, d_addr);
>>>>>> +static inline void _CPU_OR1K_Cache_data_block_flush(const void
>>>>>> *d_addr)
>>>>>> +   ISR_Level level;
>>>>>> +  _OR1K_mtspr(CPU_OR1K_SPR_DCBFR, d_addr);
>>>>>> +static inline void _CPU_OR1K_Cache_data_block_invalidate(const void
>>>>>> *d_addr)
>>>>>> +   ISR_Level level;
>>>>>> +  _OR1K_mtspr(CPU_OR1K_SPR_DCBIR, d_addr);
>>>>>> +static inline void _CPU_OR1K_Cache_data_block_writeback(const void
>>>>>> *d_addr)
>>>>>> +   ISR_Level level;
>>>>>> +  _OR1K_mtspr(CPU_OR1K_SPR_DCBWR, d_addr);
>>>>>> +static inline void _CPU_OR1K_Cache_data_block_lock(const void
>>>>>> *d_addr)
>>>>>> +   ISR_Level level;
>>>>>> +  _OR1K_mtspr(CPU_OR1K_SPR_DCBLR, d_addr);
>>>>>> +static inline void _CPU_OR1K_Cache_instruction_block_prefetch
>>>>>> +(const void *d_addr)
>>>>>> +   ISR_Level level;
>>>>>> +  _OR1K_mtspr(CPU_OR1K_SPR_ICBPR, d_addr);
>>>>>> +static inline void _CPU_OR1K_Cache_instruction_block_invalidate
>>>>>> +   ISR_Level level;
>>>>>> +  _OR1K_mtspr(CPU_OR1K_SPR_ICBIR, d_addr);
>>>>>> +static inline void _CPU_OR1K_Cache_instruction_block_lock
>>>>>> +   ISR_Level level;
>>>>>> +  _OR1K_mtspr(CPU_OR1K_SPR_ICBLR, d_addr);
>>>>>> +/* Implement RTEMS cache manager functions */
>>>>>> +void _CPU_cache_flush_1_data_line(const void *d_addr)
>>>>>> +   ISR_Level level;
>>>>>> +  _CPU_OR1K_Cache_data_block_flush(d_addr);
>>>>>> +  //asm volatile("l.csync");
>>>>>> +void _CPU_cache_invalidate_1_data_line(const void *d_addr)
>>>>>> +   ISR_Level level;
>>>>>> +  _CPU_OR1K_Cache_data_block_invalidate(d_addr);
>>>>>> +void _CPU_cache_freeze_data(void)
>>>>>> +  /* Do nothing */
>>>>>> +void _CPU_cache_unfreeze_data(void)
>>>>>> +  /* Do nothing */
>>>>>> +void _CPU_cache_invalidate_1_instruction_line(const void *d_addr)
>>>>>> +   ISR_Level level;
>>>>>> +  _CPU_OR1K_Cache_instruction_block_invalidate(d_addr);
>>>>>> +void _CPU_cache_freeze_instruction(void)
>>>>>> +  /* Do nothing */
>>>>>> +void _CPU_cache_unfreeze_instruction(void)
>>>>>> +  /* Do nothing */
>>>>>> +void _CPU_cache_flush_entire_data(void)
>>>>>> +void _CPU_cache_invalidate_entire_data(void)
>>>>>> +void _CPU_cache_invalidate_entire_instruction(void)
>>>>>> +void _CPU_cache_enable_data(void)
>>>>>> +  _CPU_OR1K_Cache_enable_data();
>>>>>> +void _CPU_cache_disable_data(void)
>>>>>> +  _CPU_OR1K_Cache_disable_data();
>>>>>> +void _CPU_cache_enable_instruction(void)
>>>>>> +  _CPU_OR1K_Cache_enable_instruction();
>>>>>> +void _CPU_cache_disable_instruction(void)
>>>>>> +  _CPU_OR1K_Cache_disable_instruction();
>>>>>> diff --git a/c/src/lib/libcpu/or1k/shared/cache/cache_.h
>>>>>> b/c/src/lib/libcpu/or1k/shared/cache/cache_.h
>>>>>> index 08d9ecc..5f08410 100644
>>>>>> --- a/c/src/lib/libcpu/or1k/shared/cache/cache_.h
>>>>>> +++ b/c/src/lib/libcpu/or1k/shared/cache/cache_.h
>>>>>> @@ -5,7 +5,7 @@
>>>>>>   #ifndef __OR1K_CACHE_H
>>>>>>   #define __OR1K_CACHE_H
>>>>>> -#include <libcpu/cache.h>
>>>>>> +#include <bsp/cache_.h>
>>>>>>   #endif
>>>>>>   /* end of include file */
>>>>>> 1.9.3
>>>>>> _______________________________________________
>>>>>> devel mailing list
>>>>>> devel at rtems.org
>>>>>> http://lists.rtems.org/mailman/listinfo/devel
>>>>> Joel Sherrill, Ph.D.             Director of Research & Development
>>>>> joel.sherrill at OARcorp.com        On-Line Applications Research
>>>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>>>> Support Available                (256) 722-9985
